在5G(NR)网络中基站和终端均需进行测量,其中包括双方共同的测试项目,也有各自不同的测试项目,它们分别如下;整理:kangguoying20200531
1.基站和终端共同测试项目
发射机一致性测量整理:kangguoying20200531
接收机一致性测量整理:kangguoying20200531
互操作性试验期间的测量
网络稳定性测量整理:kangguoying20200531
系统间测量整理:kangguoying20200531
路测整理:kangguoying20200531
近场和远场测量
2.1 5G终端测量(发射项目)整理:kangguoying20200531
Test Case | Description |
Transmit power | 发射功率 |
Output Power Dynamics | 输出功率(动态) |
Transmit Signal Quality | 发射信号质量 |
Output RF Spectrum Emissions | 输出射频信号频谱 |
Spurious Emissions | 衍射频率 |
2.2 5G终端测量(接收项目)整理:kangguoying20200531
Diversity characteristics | 分集特性 |
Reference sensitivity power level | 参考灵敏度功率电平 |
Maximum input level | 最大输入电平 |
Adjacent channel selectivity | 相邻信道选择性 |
Blocking characteristics | 阻塞特性 |
Spurious response | 虚假响应 |
Intermodulation characteristics | 互调特性 |
Spurious emissions | 虚假发射 |
3.1 5G基站测试(发射项目)整理:kangguoying20200531
Radiated Transmit Power | 无线发射功率 |
Output Power | 输出功率 |
Output Power Dynamics | (动态)输出功率 |
Transmit ON/OFF Power | 射频(开/关)功率 |
Minimum Output Power | 最小输出功率 |
Transmitted Signal Quality | 发射信号质量 |
Occupied Bandwidth | 占用带宽 |
ACLR (Adjacent Channel Leakage Ratio) | 相邻信道泄漏比 |
Operating band unwanted emissions | 工作频带不需要的辐射 |
Transmitter spurious emissions | 发射机的虚假发射 |
Transmitter intermodulation | 发射机互调 |
3.2 5G基站测试(接收项目)整理:kangguoying20200531
Sensitivity | 灵敏度 |
Reference sensitivity level | 参考灵敏度水平 |
Dynamic range | 动态范围 |
In-band selectivity and blocking | 带内选择性和阻塞性 |
Out-of-band blocking | 带外阻塞 |
Receiver spurious emissions | 接收器虚假发射 |
Receiver intermodulation | 接收机互调 |
In-channel selectivity | 信道内选择性 |
References:整理:kangguoying20200531
• TS 38.101 UE radio transmission and reception
• TS 38.104 Base Station (BS) radio transmission and reception
• TS 38.141 BS conformance testing
