3GPP有关5G(NR)的KPI指标仍在完善中;根据ITM-2020提议相关KPI见下表,这些KPI指标主要分为三大类:
增强型移动宽带(eMBB)
任务关键控制(MCC)
大规模的物联网(Massive IoT)
Parameter(参数)
KeyPerformanceIndicator(KPI)主要指标
Category分类
PeakDataRate/峰值速率
DL-20Gbps/UL-10Gbps;下行20Gbps/上行10Gbps
eMBB
SpectralEfficiency/频谱频率
DL-30bits/Hz/UL-15bits/Hz;下行30bits/HZ,上行15bits/Hz
Latency/时延
C-Plane-10ms,U-Plane-0.5ms;控制面<10ms,用户面<0.5ms
MCC
UserExpe.DataRate/用户体验速率
DL-100Mbps,UL-50Mbps;下行 100Mbps,上行50Mbps
energyEfficiency/能源效率
10Mbits/s/m2
MassiveIoT
ConnectionDensity/连接密度
1millionDevices/Km2;100万/平方公里
EnergyEfficiency/能效转换率
90%ReductioninEnergyusage; 90%利用率
Reliability/可靠性
1packetlossoutof100millionpackets;1/100万的丢包率
Mobility/支持最大移动速度
500Km/h;最高500公里/小时
MobilityInterruptionTime/切换中断时间
0ms
SystemBandwidthsupport/系统支持带宽
up to 1GHz;最大1GHz
Coverage/覆盖率
mMTC -164dB;-164dB
UEBatteryLife/终端电池寿命
mMTC –15years;最长15年
Related Post
5G Key Performance Indicator Definitions Template by 3GPP
NFV Management and Orchestration [MANO] Key Performance Indicators [KPIs]
5G End to End KPI – Accessibility, Integrity and Utilization
