  • 阅读:4306
  • 回复:4
常用表格宏代码总结
随风而飘
积分 291
帖子 58
威望 31238 个
注册 2011-5-20
专业方向  网络维护
发表于 2019-02-20 22:57:46  只看楼主
1、按照单元格内容生成文件夹
Sub test()
d = ActiveSheet.Range("b2:b977")
For Each c In d
MkDir "e:MR报告输出文件夹" & c
Next
End Sub
2、从多个表中汇总数据
Sub smergeworkbook()
Dim sPath As String
Dim sName As String
Dim sMsg As String
Dim sMode As String
Dim sFirstFile As String
Dim lFileCount As Long
Dim lRow As Long
Dim iCol As Integer
Dim objWorkbook As Workbook
Dim objSumWk As Workbook
Dim objSumSht As Worksheet
Dim objRng As Range    '2- 13行 申明变量
With Application.FileDialog(msoFileDialogFolderPicker)
     .Show
     If .SelectedItems.Count = 0 Then
         MsgBox "请选择文件目录!", vbInformation, "Excel Home"
          Exit Sub
     End If
     sPath = .SelectedItems(1) & ""
End With     '14-21行浏览文件目录
Application.DisplayAlerts = False
If Len(Dir(sPath & "Summary.xlsx")) > 0 Then   '判断是否存在
    Kill sPath & "Summary.xlsx"
End If
Application.DisplayAlerts = True
sName = Dir(sPath & "*.xlsx")       '查找指定目录中的xlsx文件
If Len(sName) > 0 Then
       sMsg = "请选择合并方式:" & vbNewLine & vbNewLine & "1 - 合并至工作簿" & vbTab & "2 - 合并至工作表" & vbNewLine & vbNewLine
       sMode = Application.InputBox(sMsg, "Excel Home", "1")
       If Not (sMode = "1" Or sMode = "2") Then
          MsgBox "合并方式错误!", vbInformation, "Excel Home"
          Exit Sub
       End If
       Application.ScreenUpdating = False
       sFirstFile = sName
       Do
          lFileCount = lFileCount + 1   '记录被合并的工作簿个数
          Set objWorkbook = Workbooks.Open(sPath & sName)  '打开被合并的文件
          If objSumWk Is Nothing Then   '判断汇总工作簿是否存在
                 objWorkbook.Worksheets("清单").Activate
                 objWorkbook.ActiveSheet.Copy
                  Set objSumWk = ActiveWorkbook
                 If sMode = "2" Then
                   Set objSumSht = objSumWk.ActiveSheet
                    objSumSht.Name = "汇总数据"
                 End If
           Else
         If sMode = "1" Then
    objWorkbook.ActiveSheet.Copy before:=objSumWk.Sheets(1)
         Else
             With objWorkbook.ActiveSheet
             lRow = .Cells(1048576, 1).End(xlUp).Row
             iCol = .Cells(4, 16384).End(xlToLeft).Column
             If lRow > 3 Then
             .Cells(4, 1).Resize(1, iCol).Copy objSumSht.Cells(1048576, 1).End(xlUp).Offset(1, 0)
                  Application.CutCopyMode = False
             End If
           End With
           End If
           End If
           objWorkbook.Close False
           sName = Dir
    Loop While Len(sName) > 0 And sName <> sFirstFile
    If Not objSumWk Is Nothing Then
       With objSumWk
           If sMode = "2" Then
              With objSumSht
                Set objRng = .Cells(2, 1).Resize(lRow - 1, 1)
               End With
               'objRng.Formula = "=ROW()-1"
               'objRng.Formula = objRng.Value
            End If
            .SaveAs sPath & "summary.xlsx"
            .Close
        End With
    End If
    Application.ScreenUpdating = True
    If lFileCount > 0 Then
    MsgBox "成功合并" & lFileCount & "个数据文件!", vbInformation, "Excel Home"
    End If
    Else
       MsgBox "没有Excel文件!", vbInformation, "Excel Home"
    End If
    Set objRng = Nothing
    Set objSumSht = Nothing
    Set objWorkbook = Nothing
    Set objSumWk = Nothing
End Sub
3、隔行插入
Sub 隔行插入()
Dim r%
    Do
        r = r + 2
        Rows(r).Insert
    Loop Until Cells(r + 1, 1) = ""
End Sub
4、隔行删除
Sub 隔行删除()
Dim r, s
m = Application.CountA(Columns(1))
    For r = 1 To m / 2
        Rows(r).Delete
    Next
End Sub
5、根据查找功能拾取的颜色求平均
Sub 根据查找功能拾取的颜色求平均()
    On Error GoTo 100
  Dim erng As Range, rng As Range, i As Long
  i = Application.FindFormat.Interior.Color
  Set erng = Cells(Rows.Count, "e").End(xlUp)
  For Each rng In Range([b2], erng)
    If rng.Interior.Color = i Then k = k + rng.Value: n = n + 1
  Next
  MsgBox "最后平均分为:" & k / n & "分"
  End
100:
  MsgBox "查找功能没有拾取到颜色!"
End Sub
6、合并单元格时连接每个单元格内容
Sub mergecells()
   Dim mergestr As String
   Dim mergerng As Range
   Dim rng As Range
   Set mergerng = Range("A1:B2")
   For Each rng In mergerng
        mergestr = mergestr & rng & ""
   Next
   mergerng.Merge
   mergerng.Value = mergestr
   Set mergerng = Nothing
   Set rng = Nothing
End Sub
7、合并内容相同的单元格
Sub 合并内容相同的单元格()
   Dim r As Integer
   Dim i As Integer
   With Sheet1
      r = .Cells(Row.Count, 1).End(xlUp).Row
      For i = r To 2 Step -1
          If .Cells(i, 2).Value = .Cells(i - 1, 2).Value Then
          .Range(.Cells(i - 1, 2), .Cells(i, 2)).Merge
          End If
      Next
    End With
End Sub
8、是否包含合并单元格
Sub ismergecells()
  If IsNull(Range("A1:D10").MergeCells) Then
      MsgBox "包含合并单元格", vbInformation
  Else
      MsgBox "没有包含合并单元格", vbInformation
  End If
End Sub
9、删除空行
Sub test1()
Dim rng As Range, ads As String
For Each rng In [a1:a10]
    If rng = "" Then ad = ad & rng.Address & ","
Next
ads = Left(ad, Len(ad) - 1)
Range(ads).EntireRow.Delete
End Sub
10、提取文件夹下文件名及路径
Dim arr(), i
Sub 创建文件目录()
Dim PathStr As String
With Application.FileDialog(msoFileDialogFolderPicker)  '创建一个选择文件夹的对话框
   If .Show = True Then PathStr = .SelectedItems(1) Else Exit Sub
End With
If Right(PathStr, 1) <> "" Then PathStr = PathStr & ""   '如果路径没有"",则追加一个""
Cells.Clear
Call 查找(PathStr)
If i > 0 Then  '如果文件大于0,从A2开始,在i行3列的区域存放查找结果
Range("a2").Resize(i, 3) = WorksheetFunction.Transpose(arr)
Range("a1:c1") = Array("路径", "文件名", "大小(MB)")
Range("a:c").EntireColumn.AutoFit   '自动调整宽度
Range("c:c").NumberFormat = "0.00"
End If
End Sub
Private Sub 查找(路径 As String)
   Dim dirs() As String, dir_count As Long, dir_name As String, dir_name_2 As String, j
   If Right(路径, 1) <> "" Then 路径 = 路径 & ""
   dir_name = Dir(路径 & "*.*", vbDirectory) '获取文件的名称(可能文件可能文件夹)
Do While Len(dir_name) <> 0
   If Left$(dir_name, 1) <> "." Then '如果左边第一个字符不是"."(排除父级目录)
       dir_name_2 = 路径 & dir_name
   If (GetAttr(dir_name_2) And vbDirectory) = vbDirectory Then
       dir_count = dir_count + 1
       ReDim Preserve dirs(1 To dir_count) As String
       dirs(dir_count) = dir_name_2
   Else
       i = i + 1
       ReDim Preserve arr(1 To 3, 1 To i)
       arr(1, i) = 路径
       arr(2, i) = dir_name
       arr(3, i) = FileLen(路径 & dir_name) / 1024 / 1024
    通信悠悠
    积分 3447
    帖子 696
    威望 138163 个
    专家指数 -33
    注册 2013-8-19
    专业方向  通信工程,网络优化
    发表于 2019-02-21 08:20:31
    原帖由 随风而飘 于 2019-2-20 22:57:46 发表
    1、按照单元格内容生成文件夹Sub test()d = ActiveSheet.Range("b2:b977")For Each c In dMkDir "e:MR报告输出文件夹" & cNextEnd Sub2、从多个表中汇总数据Sub smergeworkbook()Dim sPath As StringDim sName...
    史蒂芬孙
    C友·贡献勋章
    积分 680
    帖子 143
    威望 7202 个
    专家指数 -35
    注册 2011-11-28
    专业方向  通信技术
    发表于 2019-02-21 09:13:16
    直接SQL不就完了。
    bikerboy
    积分 20363
    帖子 548
    威望 201761 个
    礼品券 115 个
    专家指数 -1338
    注册 2008-11-11
    专业方向  无线
    发表于 2019-02-25 12:56:34
     谢谢分享学习!
    qiu8668
    威望 38 个
    注册 2016-12-20
    发表于 2019-02-26 16:04:20
    原帖由 随风而飘 于 2019-2-20 14:57:46 发表
    谢谢分享学习!
    当前时区 GMT+8, 现在时间是 2024-04-25 23:02:36
    Processed in 0.368103 second(s), 23 queries , Gzip enabled
