5G NR 网络架构和网元功能
不废话,先放名词解释:
gNB: node providing NR user plane and control plane protocol terminations towards the UE, and connected via the NG interface to the 5GC.
ng-eNB: node providing E-UTRA user plane and control plane protocol terminations towards the UE, and connected via the NG interface to the 5GC.
NG-C: control plane interface between NG-RAN and 5GC.
NG-U: user plane interface between NG-RAN and 5GC.
NG-RAN node: either a gNB or an ng-eNB.
Xn: network interface between NG-RAN nodes.
然后请欣赏5G网元功能划分和网络架构:
各个模块功能描述如下:
(关注几点:1. gNB和ng-eNB的区别在于一个支持5G新空口一个支持LTE空口,都可以连入到5G核心网 2. AMF的功能更加类似于MME在LTE中地位 3. UPF的功能接近LTE中SGW+PGW的功能,只是UE IP地址的分配,交给了SMF去干)
The gNB and ng-eNB host the following functions:
- Functions for Radio Resource Management: Radio Bearer Control, Radio Admission Control, Connection Mobility Control, Dynamic allocation of resources to UEs in both uplink and downlink (scheduling);
- IP header compression, encryption and integrity protection of data;
- Selection of an AMF at UE attachment when no routing to an AMF can be determined from the information provided by the UE;
- Routing of User Plane data towards UPF(s);
- Routing of Control Plane information towards AMF;
- Connection setup and release;
- Scheduling and transmission of paging messages;
- Scheduling and transmission of system broadcast information (originated from the AMF or O&M);
- Measurement and measurement reporting configuration for mobility and scheduling;
- Transport level packet marking in the uplink;
- Session Management;
- Support of Network Slicing;
- QoS Flow management and mapping to data radio bearers;
- Support of UEs in RRC_INACTIVE state;
- Distribution function for NAS messages;
- Radio access network sharing;
- Dual Connectivity;
- Tight interworking between NR and E-UTRA.
The AMF hosts the following main functions (see 3GPP TS 23.501 [3]):
- NAS signalling termination;
- NAS signalling security;
- AS Security control;
- Inter CN node signalling for mobility between 3GPP access networks;
- Idle mode UE Reachability (including control and execution of paging retransmission);
- Registration Area management;
- Support of intra-system and inter-system mobility;
- Access Authentication;
- Access Authorization including check of roaming rights;
- Mobility management control (subscription and policies);
- SMF selection.
The UPF hosts the following main functions (see 3GPP TS 23.501 [3]):
- Anchor point for Intra-/Inter-RAT mobility (when applicable);
- External PDU session point of interconnect to Data Network;
- Packet routing & forwarding;
- Packet inspection and User plane part of Policy rule enforcement;
- Traffic usage reporting;
- Uplink classifier to support routing traffic flows to a data network;
- Branching point to support multi-homed PDU session;
- QoS handling for user plane, e.g. packet filtering, gating, UL/DL rate enforcement;
- Uplink Traffic verification (SDF to QoS flow mapping);
- Downlink packet buffering and downlink data notification triggering.
The Session Management function (SMF) hosts the following main functions (see 3GPP TS 23.501 [3]):
- UE IP address allocation and management;
- Selection and control of UP function;
- Configures traffic steering at UPF to route traffic to proper destination;
- Control part of policy enforcement and QoS;
- Downlink Data Notification.
别急,还没完,下边请欣赏基站的模块划分,你会发现仿佛回到了RNC-nodeB时代,只不过在某种程度上做了CU的控制面与用户面的分离:
gNB Central Unit (gNB-CU): a logical node hosting RRC, SDAP and PDCP protocols of the gNB or RRC and PDCP protocols of the en-gNB that controls the operation of one or more gNB-DUs. The gNB-CU terminates the F1 interface connected with the gNB-DU.
gNB Distributed Unit (gNB-DU): a logical node hosting RLC, MAC and PHY layers of the gNB or en-gNB, and its operation is partly controlled by gNB-CU. One gNB-DU supports one or multiple cells. One cell is supported by only one gNB-DU. The gNB-DU terminates the F1 interface connected with the gNB-CU.
editor: ZYB
2018/05
BeiJing
