GPRSPRIO GPRS priority
This exchange property controls whether on-demand PDCHs will be treated as idle or busy for dynamic HR allocation and TCH packing functions (that is HR packing and DYMA), Cell Load Sharing, Subcell Load Distribution and GSM - UMTS Cell Reselection and Handover.
The variable consists of 16 bits, however only 4 of them have significance, the rest is always 0.
Bits B0, B1, B2, and B5, specify the priority between GPRS and the CS network for the three load regulation functions (see below).
The significant bits are defined as follows:
B0 - Dynamic HR allocation and HR packing priority
B1 - Cell Load Sharing priority
B2 - Subcell Load Distribution priority
B3 - Spare
B4 - Spare
B5 - GSM - UMTS Cell Reselection and Handover
Note: If pre-emption is restricted by exchange property PDCHPREEMPT, it is recommended to set B0, B1, B2, and B5 equal to 1 to achieve a better result from the corresponding load regulation functions.
Property type: Optional
The value is given as a decimal number, where only the significant bits (0,1,2,5) are taken in consideration. Bit value has the following meaning:
0 Allocated on-demand PDCH will be counted as idle Traffic Channel Full Rate (TCH/F) when traffic load is calculated in the cell.
1 Allocated on-demand PDCH will be counted as busy TCH/F when traffic load is calculated in the cell.
Default value: 0 for all bits
This exchange property is owned by the blocks RNLCT and RNTCH.
那么有这么一道题目:
384.有关GPRSPRIO,以下说法正确的是: AC
A: GPRSPRIO=0,计算半速率以及CELL LOAD SHARING时ON-DEMAND PDCH均作为IDLE的 TCH/F;00
B: GPRSPRIO=1,计算半速率以及CELL LOAD SHARING时ON-DEMAND PDCH均作为BUSY的 TCH/F;01
C: GPRSPRIO=2,计算半速率时ON-DEMAND PDCH作为BUSY的 TCH/F,而计算CELL LOAD SHARING时ON-DEMAND PDCH作为IDLE的TCH/F。 10
D:GPRSPRIO=3,计算半速率时ON-DEMAND PDCH作为BUSY的 TCH/F,而计算CELL LOAD SHARING时ON-DEMAND PDCH作为IDLE的TCH/F。 11
我想问的就是gprsprio答案c好像是错误的,10,1是b0位置还是b1位置
如果是b0位置就是对的。
请各位指教。
