【语言】:英文
【何人(公司)所著】:爱立信
【文件格式】:txt
【摘要或目录】:
----------------------------------- BASIC MO COMMANDS----------------------------------
mom[tcd]Print description of MO classes, CM/FM attributes, actions, enums and structs.
lt/ltc[1-9]Load MO tree (full or partial) and build proxy table.
lc[1-9]/lccLoad MO tree (full or partial) and build proxy table.
lu/llu Unload MOs from MO tree.
pr/lpr Print MO LDNs and proxy ids for all or part of the MO tree currently loaded in moshell.
ma/lma Add MO(s) to an MO group.
mr/lmr Remove an MO group or remove MOs from an MO group (MOs will NOT be deleted, only the group).
mpPrint all defined MO groups.
get/lgetRead CM/FM attribute(s) from MO(s).
hget[c]/lhget[c]Read CM/FM attribute(s) from MO(s), print horizontally one line per MO (instead of one line per attribute).
kget/lkgetDisplay CM/FM attributes in exportable printout format.
fro/lfro[m]Read MAO data of an MO and/or froid of the MO. Data read from SQL tables motype_r1 and modata_r2.
st/lst Print state of MOs (operationalState and administrativeState when applicable).
prodPrint productData of MO(s).
lk/llk View all MO's linked to an MO, and their states (admState and opState).
lko/llkoThe old lk. Messier than lk but supports a wider range of MO classes.
set[m]/lset[m]Set an attribute value on one or several MO's.
rset/lrsetSet attribute value on a restricted attribute or change the MOid of an MO.
bl[s]/lbl[s] Lock or soft-lock MO(s).
deb/ldebUnlock MO(s).
acl/laclLists available MO actions.
acc/laccExecute an MO action.
crCreate an MO.
del/ldelDelete MO(s).
rdel/lrdelDelete MO(s) together with children and reserving MOs.
u+[s]/u-/u?/u!Handling of undo mode (for undo of del/rdel/set commands). Can be used for generation of MO scripts as well.
run Run a command file in moshell format.
trunRun a command file in EMAS/MoTester format.
ctrl-z Abort an MO command or a "for" loop. Type "touch /tmp/<stopfile>;fg" to resume the moshell session.
pol[s][h][c] Poll the node until the MO service is up or until an operation has completed.
reDisconnect and reconnect to the CM service (mobrowser) and/or the PM service (pmtester).
getmom Check the MOM version currently stored on the node.
parsemomParse an xml MOM file.
flt/fltcLoad proxys for an MO type that is not defined in the MOM. ("Force" lt/ltc).
ldLoad one MO from the tree and add to the proxy table.
fget/lfgetRead attributes that are not described in the MOM ("Force" get).
sget/lsgetRead CM/FM attributes from MO(s), one by one ("Slow" get).
fset/lfsetSet an attribute that is not described in the MOM ("Force" set).
facc/lfaccPerform actions that are not defined in the MOM ("Force" action).
----------------------------------- OTHER MO COMMANDS ----------------------------------
cvls/cvmk/cvms/cvset/cvrm/cvcu/cvget/cvls1CV backup handling: list, make local, make remote, remove, setstartable.
inv[hr]Complete HW/SW inventory. Includes information about RPUs, licensing, JVM, devices, XPs, ISL, etc.
cab[slxradgtm]Display of miscellaneous COLI printouts relating to hw, sw, restarts, leds, cpu load, errors, disk/ram usage
stc[p][r] Display state and configuration of AtmCrossConnections.
std Display state and configuration of devices (RNC and MGW only).
stv[r] Display state, user, and bandwidth usage for ATM ports and channels.
stt[r] Display state and user of Physical Ports and Ds0Bundles.
hcRun a general healthcheck on the node.
dcg[msie] Fetch data for CSRs, according to the Data Collection Guidelines.
diff/ldiffParameter auditing or MO dump comparisons.
str[12ft] Print status of the IubLinks/AbisLinks and their associated Cells and Channels (RNC/BSC only).
lki Resource usage and configuration of IubLinks (RNC only).
remod[2]Remodule an IubLink (RNC only).
tg[r][c][d]Print Resource Object information for all MOs in LmCell (RNC only).
uer[d][t] Print UE context data (serving or drifting) for all active calls (RNC only).
ced[h][r] Print dynamic cell data or capacity usage (RNC only).
al[atkc]Print the list of active alarms. Acknowledge/Unacknowledge an alarm.
lg[aevsyuoldhmircf]Fetching and/or processing of node logs (alarm, event, availability, system, etc)
----------------------------------- OTHER COMMANDS----------------------------------
uvPrint or change moshell configuration settings (also called "user variables").
pvPrint scripting variables.
!/l Execute a unix command on the PC/workstation.
l+[m][m][s][o]/l-/l?Open/close moshell logfiles.
ose/coli commandSend a COLI command to the node's OSE shell. Type "h ose" for syntax help and "?" to view available commands.
bo[r]/ba[swdp]/br[wd]/be[0-50]/bpManage board groups that can be used for running COLI commands on multiple boards.
lhRun COLI commands on all boards of a board group.
mon/mon+/mon-/mon? Start/stop/check the target monitor server on the node and/or start the monitor client for one or more board Group(s).
sql+/sql-/sql?Start/stop/check the SQL client on the node (CXC1325608).
pgu[c][f][r] Program Upgrade. For STP use only, eg, to load black LMs.
ftree[f]Recursive listing of a directory on the file system of the node or the workstation.
ftget[c]/ftput[c]Transfer files or directories to/from the node, using ftp or sftp.
htgetTransfer files from the node using http.
editEdit a file on the node.
fclean[f|ff|d|e]Removal of obsolete loadmodules OR recursive removal of a directory on the node.
hiPrint history of moshell commands entered during the current session.
lmid[c]Print translation of loadmodule product number or T&E error codes.
p/w/pw/bChange moshell prompt and/or window title.
proxToggle display of proxy identities in printout of get <mo> <attribute> command.
col Toggle display of colors.
ulToggle display of userlabel in st/lst and pget/lpget printout.
conf[bld] Toggle confirmation on various MO commands.
gs/gsg Toggle display of old/new attribute value in set/bl/deb commands.
ip2d/d2ip Convert an IP address into the format used in the fRO (sql database) or vice-versa.
h2d/d2hConvert an integer to hexadecimal or viceversa.
h2b/b2hConvert a binary to hexadecimal or viceversa.
waitSpecify a delay in hrs, mins, secs, or rops. Similar to the unix "sleep" command (scripting).
return Exit from a command file without exiting from moshell (scripting).
printPrint a line or variable (scripting).
alias/unaliasPrint or define command aliases.
q/by/exit/quitExit moshell.
----------------------------------- PM COMMANDS----------------------------------
pmom[acd]/lmom[c]Print description of PM counters (pmom) or log attributes (lmom, CDMA only).
pget/lpgetRead PM attribute(s) from MO(s).
spget/lspget Read PM attribute(s) one by one ("slow pget").
hpget[c]/lhpget[c] Read PM attribute(s) from MO(s), print horizontally one line per MO (instead of one line per attribute).
pdiff/lpdiff Print incrementation of PM attributes.
pmx[hfdn] Display counter values, extracted from the statistics ROP files.
pmr[ag]Produce PM KPI reports, based on counter values in statistics ROP files and formulas in CPI documentation.
pme[fd][cgu] Fetch/decode event ROP files (RNC/RBS only).
pst List all PM scanners and their state.
pgets[n]Print scanner contents.
pcr[cfd]/lpcr[cfd] Create a statistics scanner.
pbl Suspend a scanner.
pdebResume a scanner.
pdelDelete a scanner.
emomDisplay list of events available for each kind of event-based scanner.
pset[d]Set the contents of an event-based scanner (RNC/RBS only).
----------------------------------- HELP CHAPTERS----------------------------------
0Installation, security, and user settings
1Revision History
2Tutorial
3Command syntax, regular expressions
4Command descriptions
5Lazy
6Scripting
7Utilities
8Server Maintenance
9Offline Mode
