Mr Kang
在4G(LTE)网络中由于带宽很大(20MHZ,100PRB),资源(频域、时域和调制方式)分配形式特别复杂;做为接收端必须了解发送端对这些的分配,以便准时接收和解析;而进行这些关键信息控制的就是DCI(Downlink Control Indicator)。 DCI中承载了“那个资源块中有什么信息”,“解码数据需用那种调制方式”和其他内容;因此,接收端需首先解码DCI,再根据DCI解析其他内容;所以说没有DCI,你就不能解析任何消息; DCI不只是出现在4G(LTE)网络中,之前在WCDMA R99网络中Slot format和TFCI载波,HSDPA HS-SCCH 承载和 HSUPA E-TFCI都包括在下行控制指示(DCI)内容之中。
1.DCI 分类 LTE网络中根据其承载,DCI分为两大类:
上行资源分配(静态,半静态); 下行数据传送形式;
2.DCI格式及内容
LTE网络中层一(L1)在PDCCH可配置为8种格式(formats),其中6种格式(formats)中:1用种做上行调度, 2用种做Non-MIMO下行调度, 1用种做 MIMO DL调度,2 用种做上行功率控制;其格式、用途及内容见下表:
DCI Format(格式) | Usage(用途) | Major Contents(内容) | Format 0 | UL Grant. Resource Allocation for UL Data | RB Assignment,TPC,PUSCH Hopping Flag | Format 1 | DL Assignment for SISO | RB Assignment,TPC, HARQ | Format 1A | DL Assignment for SISO (compact) | RB Assignment,TPC, HARQ | Format 1B | DL Assignment for MIMO with Rank 1 | RB Assignment,TPC, HARQ,TPMI, PMI | Format 1C | DL Assignment for SISO (minimum size) | RB Assignment | Format 1D | DL Assignment for Multi User MIMO | RB Assignment,TPC, HARQ,TPMI,DL Power Offset | Format 2 | DL Assignment for Closed Loop MIMO | RB Assignment,TPC, HARQ, Precoding Information | Format 2A | DL Assignment for Open Loop MIMO | RB Assignment,TPC, HARQ, Precoding Information | Format 2B | DL Assignment for TM8 (Dual Layer Beamforming) | RB Assignment,TPC, HARQ, Precoding Information | Format 2C | DL Assignment for TM9 | RB Assignment,TPC, HARQ, Precoding Information | Format 3 | TPC Commands for PUCCH and PUSCH with 2 bit power adjustment | Power Control Only | Format 3A | TPC Commands for PUCCH and PUSCH with 1 bit power adjustment | Power Control Only | Format 4 | UL Assignment for UL MIMO (up to 4 layers) | RB Assignment,TPC, HARQ, Precoding Information |
原文来自:[url]www.sharetechnote.com[/url] 整理:kangguoying20201213 "最大耦合损耗(MCL)与最大路径损耗(MPL)之差异"已在微信公众号"跟着老康学5G"中推出,敬请关注。
