在5G(NR)网络提出后,3GPP针对终端在空闲态下4G->5G的重选制定了特定的系统消息SIB24;其在4G(LTE)网络中进行广播,以供终端从4G重选到5G,而SIB24消息中的主要内容如下:
SIB 24( InterRAT/NR Neighbouring cells for cell reselection).
SystemInformationBlockType24-r15 ::= SEQUENCE {
carrierFreqListNR-r15 CarrierFreqListNR-r15 OPTIONAL, -- Need----NR载频列表
t-ReselectionNR-r15 T-Reselection, ----NR重选指示
t-ReselectionNR-SF-r15 SpeedStateScaleFactors OPTIONAL, -- Need OR ----NR重选速度因子
lateNonCriticalExtension OCTET STRING OPTIONAL,...}
CarrierFreqListNR-r15 ::= SEQUENCE (SIZE (1..maxFreq)) OF CarrierFreqNR-r15
CarrierFreqNR-r15 ::= SEQUENCE {
carrierFreq-r15 ARFCN-ValueNR-r15, ----NR载频点列表
multiBandInfoList-r15 MultiFrequencyBandListNR-r15 OPTIONAL, -- Need OR
multiBandInfoListSUL-r15 MultiFrequencyBandListNR-r15 OPTIONAL, -- Need OR
measTimingConfig-r15 MTC-SSB-NR-r15 OPTIONAL, -- Need OR ----NR小区(SSB MTC) subcarrierSpacingSSB-r15 ENUMERATED {kHz15, kHz30, kHz120, kHz240},----NR子载波间隔
ss-RSSI-Measurement-r15 SS-RSSI-Measurement-r15 OPTIONAL, -- Cond RSRQ2---NR RSSI测量
cellReselectionPriority-r15 CellReselectionPriority OPTIONAL, -- Need OP
cellReselectionSubPriority-r15 CellReselectionSubPriority-r13 OPTIONAL, -- Need OR
threshX-High-r15 ReselectionThreshold, ---NR 重选的X-High
threshX-Low-r15 ReselectionThreshold, ---NR 重选的X-LOW
threshX-Q-r15 SEQUENCE {
threshX-HighQ-r15 ReselectionThresholdQ-r9,
threshX-LowQ-r15 ReselectionThresholdQ-r9
} OPTIONAL, -- Cond RSRQ
q-RxLevMin-r15 INTEGER (-70..-22), ---NR 重选主小区最小接入电平
q-RxLevMinSUL-r15 INTEGER (-70..-22) OPTIONAL, -- Need OR ---NR 重选SUL小区最小接入电平
p-MaxNR-r15 P-MaxNR-r15, ---NR小最大发射功率
ns-PmaxListNR-r15 NS-PmaxListNR-r15 OPTIONAL, -- Need OR
q-QualMin-r15 INTEGER (-43..-12) OPTIONAL, -- Need OP
deriveSSB-IndexFromCell-r15 BOOLEAN,
maxRS-IndexCellQual-r15 MaxRS-IndexCellQualNR-r15 OPTIONAL, -- Need OR
threshRS-Index-r15 ThresholdListNR-r15 OPTIONAL, -- Need OR
[[ multiBandNsPmaxListNR-v1550 MultiBandNsPmaxListNR-1-v1550 OPTIONAL, -- Need OR
multiBandNsPmaxListNR-SUL-v1550 MultiBandNsPmaxListNR-v1550 OPTIONAL, -- Need OR
ssb-ToMeasure-r15 SSB-ToMeasure-r15 OPTIONAL -- Need OR
MultiBandNsPmaxListNR-1-v1550 ::= SEQUENCE (SIZE (1.. maxMultiBandsNR-1-r15)) OF NS-PmaxListNR-r15
MultiBandNsPmaxListNR-v1550 ::= SEQUENCE (SIZE (1.. maxMultiBandsNR-r15)) OF NS-PmaxListNR-r15
原文来自:www.sharetechnote.com
整理:kangguoying20201206
"4G(LTE)小区能支持多少VOLTE用户?"将在微信公众号"跟着老康学5G"中推出,敬请关注。
