自3GPP R12版本开始,4G(LTE)网络就开启了Sidelink([url]https://club.mscbsc.com/t707661p1.html[/url])功能;为支持该功能4G网络通过系统消息Sib18和Sib19进行传递,其具体内容如下:
1.Sib18(Sidelink Information)--网络侧
SystemInformationBlockType18-r12 ::= SEQUENCE {
commConfig-r12 SEQUENCE {
commRxPool-r12 SL-CommRxPoolList-r12,
commTxPoolNormalCommon-r12 SL-CommTxPoolList-r12 OPTIONAL, -- Need OR
commTxPoolExceptional-r12 SL-CommTxPoolList-r12 OPTIONAL, -- Need OR
commSyncConfig-r12 SL-SyncConfigList-r12 OPTIONAL -- Need OR
} OPTIONAL, -- Need OR
lateNonCriticalExtension OCTET STRING OPTIONAL, ...,
[[ commTxPoolNormalCommonExt-r13 SL-CommTxPoolListExt-r13 OPTIONAL, -- Need OR
commTxResourceUC-ReqAllowed-r13 ENUMERATED {true} OPTIONAL, -- Need OR
commTxAllowRelayCommon-r13 ENUMERATED {true} OPTIONAL -- Need OR
2.SIB 19(sidelink UE information procedure and may contain sidelink discovery related resource configuration information)--终端侧
SystemInformationBlockType19-r12 ::= SEQUENCE {
discConfig-r12 SEQUENCE {
discRxPool-r12 SL-DiscRxPoolList-r12,
discTxPoolCommon-r12 SL-DiscTxPoolList-r12 OPTIONAL, -- Need OR
discTxPowerInfo-r12 SL-DiscTxPowerInfoList-r12 OPTIONAL, -- Cond Tx
discSyncConfig-r12 SL-SyncConfigList-r12 OPTIONAL -- Need OR
discInterFreqList-r12 SL-CarrierFreqInfoList-r12 OPTIONAL, -- Need OR
lateNonCriticalExtension OCTET STRING OPTIONAL,...,
[[ discConfig-v1310 SEQUENCE {
discInterFreqList-v1310 SL-CarrierFreqInfoList-v1310 OPTIONAL, -- Need OR
gapRequestsAllowedCommon ENUMERATED {true} OPTIONAL -- Need OR
discConfigRelay-r13 SEQUENCE {
relayUE-Config-r13 SL-DiscConfigRelayUE-r13,
remoteUE-Config-r13 SL-DiscConfigRemoteUE-r13
discConfigPS-13 SEQUENCE {
discRxPoolPS-r13 SL-DiscRxPoolList-r12,
discTxPoolPS-Common-r13 SL-DiscTxPoolList-r12 OPTIONAL -- Need OR } OPTIONAL -- Need OR]] }
SL-CarrierFreqInfoList-r12 ::= SEQUENCE (SIZE (1..maxFreq)) OF SL-CarrierFreqInfo-r12
SL-CarrierFreqInfoList-v1310 ::= SEQUENCE (SIZE (1..maxFreq)) OF SL-CarrierFreqInfo-v1310
SL-CarrierFreqInfo-r12::= SEQUENCE {
carrierFreq-r12 ARFCN-ValueEUTRA-r9,
plmn-IdentityList-r12 PLMN-IdentityList4-r12 OPTIONAL -- Need OP}
SL-DiscConfigRelayUE-r13 ::= SEQUENCE {
threshHigh-r13 RSRP-RangeSL4-r13 OPTIONAL, -- Need OR
threshLow-r13 RSRP-RangeSL4-r13 OPTIONAL, -- Need OR
hystMax-r13 ENUMERATED {dB0, dB3, dB6, dB9, dB12, dBinf}
hystMin-r13 ENUMERATED {dB0, dB3, dB6, dB9, dB12}}
SL-DiscConfigRemoteUE-r13 ::= SEQUENCE {
hystMax-r13 ENUMERATED {dB0, dB3, dB6, dB9, dB12} OPTIONAL,
reselectionInfoIC-r13 ReselectionInfoRelay-r13}
ReselectionInfoRelay-r13 ::= SEQUENCE {
q-RxLevMin-r13 Q-RxLevMin,
filterCoefficient-r13 FilterCoefficient,
minHyst-r13 ENUMERATED {dB0, dB3, dB6, dB9, dB12, dBinf}}
SL-CarrierFreqInfo-v1310::= SEQUENCE {
discResourcesNonPS-r13 SL-ResourcesInterFreq-r13 OPTIONAL,
discResourcesPS-r13 SL-ResourcesInterFreq-r13 OPTIONAL,
discConfigOther-r13 SL-DiscConfigOtherInterFreq-r13 OPTIONAL,...}
PLMN-IdentityList4-r12 ::= SEQUENCE (SIZE (1..maxPLMN-r11)) OF PLMN-IdentityInfo2-r12
PLMN-IdentityInfo2-r12 ::= CHOICE {
plmn-Index-r12 INTEGER (1..maxPLMN-r11),
plmnIdentity-r12 PLMN-Identity}
SL-DiscTxResourcesInterFreq-r13 ::= CHOICE {
acquireSI-FromCarrier-r13 NULL,
discTxPoolCommon-r13 SL-DiscTxPoolList-r12,
requestDedicated-r13 NULL,
noTxOnCarrier-r13 NULL }
SL-DiscConfigOtherInterFreq-r13::= SEQUENCE {
txPowerInfo-r13 SL-DiscTxPowerInfoList-r12 OPTIONAL, -- Cond Tx
refCarrierCommon-r13 ENUMERATED {pCell} OPTIONAL, -- Need OR
discSyncConfig-r13 SL-SyncConfigListNFreq-r13 OPTIONAL, -- Need OR
discCellSelectionInfo-r13 CellSelectionInfoNFreq-r13 OPTIONAL -- Need OR}
SL-ResourcesInterFreq-r13 ::= SEQUENCE {
discRxResourcesInterFreq-r13 SL-DiscRxPoolList-r12 OPTIONAL, -- Need OR
discTxResourcesInterFreq-r13 SL-DiscTxResourcesInterFreq-r13 OPTIONAL -- Need OR}
原文来自:[url]www.sharetechnote.com[/url]
整理:kangguoying20201205
"自动驾驶为什么更可靠--5G网络时延缩短的秘密!"已在微信公众号"跟着老康学5G"中推出,敬请关注!
