  • 阅读:1664
IMS/SIP中的订阅(SUSCRIBE)和通知(NOTIFY)
Mr Kang
原始天尊
积分 104731
帖子 8513
威望 1621464 个
礼品券 11319 个
专家指数 23981
注册 2007-3-13
发表于 2020-10-23 07:54:32  只看楼主
        IMS/SIP中流程中我们经常看到订阅(SUSCRIBE)通知(NOTIFY)消息,它们的定义、用途及示例分别如下:
1.消息定义
       订阅(SUSCRIBE)在无线协议中类似“测量控制”或“信息请求”,要求对方对特定事件或状态进行报告;
       通知(NOTIFY)在无线协议中类似“测量报告”或“信息反馈”,其是对订阅(SUSCRIBE)事件的信息反馈(具体见RFC3265中SIP事件定义节);
2.订阅(SUSCRIBE)支持的事件
        订阅是经常见的事件就是注册“reg”(注册状态检查),另有很多其他的事件;详见下表:
Event
Description
Reference
     reg
          Request   for IMS/SIP Registration Status
  RFC   3680
  presence
Request   for presence information (commonly used in RCS)
   RFC   3856
     winfo
Request   for Watcher information (commonly used in RCS)
   RFC   3857
  xcap-diff
Request   for Xcap-Diff information (commonly used in RCS)
   RFC   3875
3.通知(NOTIFY)支持的事件
       通知(通常是CSCF)有错误出现(如481,400,500);除在消息正文之外提供的详细(除已订阅)信息,还会发送带有特定订阅状态信息的通知消息(具体参阅RFC3265 3.2.4);
Subscription-State
Description
active(激活)
It   means the subscription is accepted (in most case, authorized as well)
   pending      (暂缓)
It means the subscription   has been received by the notifier, but there is insufficient policy   information to grant or deny the subscription yet
terminated (结束)
It   means the subscription is terminated and this can specify as a reason code as   follows
deactivated (去激活)
This mean that the   subscription ended (terminated) but the subscriber (UE) SHOULD retry   with a new subscription immediately.
probation (稍后再试)
This   mean that the subscription ended (terminated) but the client   SHOULD retry at some time later.
rejected   (拒绝)
This   mean that the subscription ended (terminated) due to change in authorization   policy. The client SHOULD NOT retry.
timeout   (超时)
This   mean that the subscription ended (terminated) because it is not refreshed   before it expired. The client MAY retry immediately.
giveup
(放弃)
This mean that the   subscription ended (terminated) because the notifier could not obtain   authorization in time
noresource  (无资源)
This mean that the   subscription ended (terminated) because the resource being monitored is no   longer available.
4.订阅和通知流程
          订阅(SUSCRIBE)一般由终端(UA)发起,服务器应答 通知(NOTIFY),其流程简化如下:
5.订阅和通知消息内容
       以注册“reg”(注册状态检查)为例的“订阅” SUBSCRIBE“通知”NOTIFY )消息内容如下:
Step 1 : SUBSCRIBE -----------------------------------
SUBSCRIBE sip:+11234567890@test.3gpp.com SIP/2.0
Via: SIP/2.0/UDP 10.133.202.46:50997;branch=z9hG4bK2968d27245f17c7bcae38c31991bfdaa
Max-Forwards: 70
Contact: <sip:+11234567890@10.133.202.46:50997>;+sip.instance="<urn:gsma:imei:00440113-904785-0>"
To: <sip:+11234567890@test.3gpp.com>
Call-ID: d57a0b04-785ba328-13a4d876@10.133.202.46
CSeq: 14534 SUBSCRIBE
Expires: 600000
User-Agent: IM-client/OMA1.0 DUT-IMS
Event: reg
Accept: application/reginfo+xml
P-Access-Network-Info: 3GPP-E-UTRAN-FDD;utran-cell-id-3gpp="0010100010000000"
P-Preferred-Identity: <sip:+11234567890@test.3gpp.com>
Content-Length: 0
Step 2 : 200 OK -----------------------------------
SIP/2.0 200 OK
To: <sip:+11234567890@test.3gpp.com>;tag=987654321
Expires: 600000
Contact: <sip:10.133.202.47:5060>
Record-Route: <sip:10.133.202.47;lr>
Content-Length: 0
Step 3 : NOTIFY -----------------------------------
NOTIFY sip:+11234567890@test.3gpp.com SIP/2.0
Via: SIP/2.0/UDP 10.133.202.47:5060;branch=z9hG4bK-d1e4c4961ca9d523ae76b67e088589cd
From: <sip:+11234567890@test.3gpp.com>;tag=987654321
To: <sip:+11234567890@test.3gpp.com>;tag=210a54
Subscription-State: active;expires=600000
Event: reg
CSeq: 14534 NOTIFY
Max-Forwards: 70
Content-Type: application/reginfo+xml
Content-Length: 340
<?xml version="1.0" encoding="UTF-8"?>
<reginfo xmlns="urn:ietf:params:xml:ns:reginfo" version="0" state="full">
<registration aor="sip:+11234567890@test.3gpp.com" id="12345" state="active">
<contact id="100" state="active" event="registered" expires="600000">
<uri>sip:+11234567890@10.133.202.46:50997</uri>
</contact>
</registration>
</reginfo>
Step 4 : 200 OK -----------------------------------
SIP/2.0 200 OK
Max-Forwards: 70
CSeq: 14534 NOTIFY
Allow: NOTIFY,SUBSCRIBE
Content-Length: 0
原文来自:http://www.sharetechnote.com
整理:kangguoying20201023
5G终端接入网络第一把密钥---RA-RNTI计算 ”已在微信公众号"跟着老康学5G"中推出,敬请关注!
    当前时区 GMT+8, 现在时间是 2024-04-25 13:26:02
    Processed in 0.242207 second(s), 13 queries , Gzip enabled
