呼叫等待(Communication Waiting)服务允许主叫终端告知被叫终端有没有可用于接入的通信资源。主叫(UA)可以选择接受、拒绝或忽略传入的通信。
1. IMS/SIP中呼叫等待信令流程
2.呼叫等待信令消息主要内容
2.1(A) INVITE sip:001010123456789@[2001::1:d279:3516:72e6:fa46]:39047 SIP/2.0
Via: SIP/2.0/UDP [2001:0:0:1::2]:65211;branch=z9hG4bK7274b6a822524ffa...;transport=udp
Via: SIP/2.0/TCP [2001:0:0:1::2]:50626;branch=z9hG4bKe16b0a51e196416...;transport=tcp
Max-Forwards: 69
Call-ID: 1e73797a14b14c7eb85e33e3e4b628ea
CSeq: 30001 INVITE
To: sip:001010123456789@ims.mnc01.mcc001.3gppnetwork.org
From: sip:0123456789@ims.mnc01.mcc001.3gppnetwork.org;tag=1111111111
Feature-Caps: *;+g.3gpp.srvcc-alerting;+g.3gpp.mid-call
Allow: ACK, BYE, CANCEL, INVITE, PRACK, UPDATE
Accept-Contact: *;+g.3gpp.icsi-ref="urn%3Aurn-7%3A3gpp-service.ims.icsi.mmtel";require;explicit
User-Agent: UA2/9dc040f
Content-Type: application/sdp
Content-Length: 727
Contact: <sip:0123456789@[2001:0:0:1::2]:50626;transport=tcp>;+g.3gpp.icsi-ref="urn%3Aurn-7%3A3gpp-service.ims.icsi.mmtel";video;+g.3gpp.srvcc-alerting;+g.3gpp.mid-call
Privacy: none
P-Asserted-Identity: <sip:0123456789@ims.mnc01.mcc001.3gppnetwork.org>
Record-Route: <sip:[2001:0:0:1::2]:65211;lr>
v=0
o=Sharetechnote 164 63164 IN IP6 2001:0:0:1::2
s=-
i=A VOIP Session
c=IN IP6 2001:0:0:1::2
t=0 0
m=audio 60000 RTP/AVP 96 97 98 99 100 8 0 101 102
b=AS:153
b=RS:800
b=RR:2400
a=ptime:20
a=maxptime:240
a=rtpmap:96 EVS/16000/1
a=fmtp:96 max-red=220
a=rtpmap:97 AMR-WB/16000/1
a=fmtp:97 mode-change-capability=2
a=rtpmap:98 AMR-WB/16000/1
a=fmtp:98 octet-align=1; mode-change-capability=2
a=rtpmap:99 AMR/8000/1
a=fmtp:99 mode-change-capability=2
a=rtpmap:100 AMR/8000/1
a=fmtp:100 octet-align=1; mode-change-capability=2
a=rtpmap:8 PCMA/8000/1
a=rtpmap:0 PCMU/8000/1
a=rtpmap:101 telephone-event/16000
a=fmtp:101 0-15
a=rtpmap:102 telephone-event/8000
a=fmtp:102 0-15
a=mid:0
a=rtcp:60001
a=sendrecv
2.2(B) INVITE sip:001010123456789@[2001::1:d279:3516:72e6:fa46]:39047 SIP/2.0
Via: SIP/2.0/UDP [2001:0:0:1::2]:65211;branch=z9hG4bK7274b6a822524ffa838...;transport=udp
Via: SIP/2.0/TCP [2001:0:0:1::2]:50628;branch=z9hG4bK3234f01ce09b445aa5...;transport=tcp
Max-Forwards: 69
Call-ID: bf653744ce1d4b83ae0ccebdfad4e14d
CSeq: 52001 INVITE
From: sip:VirtualUA_2nd@test.3gpp.com;tag=2222222222
Privacy: none
User-Agent: UA3/9dc040f
Content-Length: 728
Contact: <sip:VirtualUA_2nd@[2001:0:0:1::2]:50628;transport=tcp>;+g.3gpp.icsi-ref="urn%3Aurn-7%3A3gpp-service.ims.icsi.mmtel";video;+g.3gpp.srvcc-alerting;+g.3gpp.mid-call
P-Asserted-Identity: <sip:UA3@test.3gpp.com>
v=0
o=Sharetechnote 960 775960 IN IP6 2001:0:0:1::2
s=-
i=A VOIP Session
t=0 0
m=audio 60002 RTP/AVP 96 97 98 99 100 8 0 101 102
b=AS:153
b=RS:800
b=RR:2400
a=ptime:20
a=maxptime:240
a=fmtp:101 0-15
a=fmtp:102 0-15
a=mid:0
a=rtcp:60003
a=sendrecv
2.3(C) INVITE sip:0123456789@[2001:0:0:1::2]:50626;transport=tcp SIP/2.0
Max-Forwards: 70
Via: SIP/2.0/TCP [2001::1:d279:3516:72e6:fa46]:39047;branch=z9hG4bK150087668-37dae110
CSeq: 1 INVITE
From: <sip:001010123456789@ims.mnc01.mcc001.3gppnetwork.org>;tag=5446714287d456-5e34ced8
To: <sip:0123456789@ims.mnc01.mcc001.3gppnetwork.org>;tag=1111111111
Contact: <sip:001010123456789@[2001::1:d279:3516:72e6:fa46]:39047>;+g.3gpp.icsi-ref="urn%3Aurn-7%3A3gpp-service.ims.icsi.mmtel";video;+g.3gpp.srvcc-alerting;+sip.instance="<urn:gsma:imei:35910506-000422-0>"
Accept-Contact: *;+g.3gpp.icsi-ref="urn%3Aurn-7%3A3gpp-service.ims.icsi.mmtel";video
Allow: INVITE,BYE,CANCEL,ACK,PRACK,UPDATE,INFO,REFER,NOTIFY,MESSAGE
P-Preferred-Identity: <sip:001010123456789@ims.mnc01.mcc001.3gppnetwork.org>
P-Access-Network-Info: 3GPP-E-UTRAN-FDD;utran-cell-id-3gpp=0010100010000000
Security-Verify: ipsec-3gpp;q=0.1;alg=hmac-md5-96;prot=esp;mod=trans;ealg=null;spi-c=3854453982;spi-s=1494228412;port-c=65210;port-s=65211
Require: sec-agree
Supported: 100rel,timer
User-Agent: UA1
Proxy-Require: sec-agree
Content-Length: 648
v=0
o=sip:001010123456789@ims.mnc01.mcc001.3gppnetwork.org 3690753268 3690753269 IN IP6 2001:0:0:1::11
s=-
c=IN IP6 2001:0:0:1::11
t=0 0
m=audio 50010 RTP/AVP 97 98 99 100 101 102
b=AS:49
b=RS:0
b=RR:1200
a=rtpmap:99 telephone-event/16000
a=fmtp:99 0-15
a=fmtp:100 mode-change-capability=2
a=rtpmap:101 AMR/8000/1
a=fmtp:101 octet-align=1; mode-change-capability=2
a=fmtp:102 0-15
a=mid:0
a=sendonly
a=ptime:20
a=maxptime:240
2.4(D) SIP/2.0 200 OK
SIP/2.0 200 OK
Max-Forwards: 70
CSeq: 1 INVITE
Content-Length: 336
Privacy: none
v=0
o=Sharetechnote 164 63166 IN IP6 2001:0:0:1::2
s=-
i=A VOIP Session
t=0 0
m=audio 60000 RTP/AVP 97 99
b=AS:49
b=RS:0
b=RR:1200
a=fmtp:99 0-15
a=mid:0
a=ptime:20
a=maxptime:240
a=recvonly
a=rtcp:60001
2.5(E) ACK sip:0123456789@[2001:0:0:1::2]:50626;transport=tcp SIP/2.0
Max-Forwards: 70
Via: SIP/2.0/UDP [2001::1:d279:3516:72e6:fa46]:39047;branch=z9hG4bK15009b44d-410bdd5b
CSeq: 1 ACK
Require: sec-agree
User-Agent: UA1
Content-Length: 0
原文来自:http://www.sharetechnote.com
整理:kangguoying20201020
“5G网络中层二的RLC介绍 ”已在微信公众号"跟着老康学5G"中推出,敬请关注!
