由于用户的流动性,经常会出现移出网络服务范围;此时做为被叫就会出现“您所拨叫的用户不在服务区”的情况,针对此情况IMS/SIP在3GPP TS.24.604中定义了用户可达的前转( Communication Forwarding on Subscriber Not Reachable --CFNRc) ;
* 这种情况一般是由于终端周期性更新超时或移出服务区,核心网侧隐含关机时发生;
1.终端注册,参与用户不可达前转(UA)需要:
A.参与终端(UA1,UA2,UA3)在CSCF进行注册;
B.并不可达前转条件;
2.不可达前转信令流程
3.不可达前转信令主要消息内容
3.1(A) INVITE sip:UA2@ims.mnc246.mcc081.3gppnetwork.org SIP/2.0
Via: SIP/2.0/UDP [2001:0:0:1::2]:56439;branch=z9hG4bK1161335930;rport
To: <sip:UA2@ims.mnc246.mcc081.3gppnetwork.org>
Contact: <sip:UA1@[2001:0:0:1::2]:56439;transport=udp>;+g.oma.sip-im;language="en,fr";+g.3gpp.icsi-ref="urn%3Aurn-7%3A3gpp-service.ims.icsi.mmtel"
Call-ID: bdc0cdba-3278-1303-7151-eada26d4de3a
CSeq: 21140 INVITE
Content-Type: application/sdp
Content-Length: 739
Max-Forwards: 70
Route: <sip:[2001:0:0:1::2]:5060;lr;transport=udp>
Accept-Contact: *;+g.3gpp.icsi-ref="urn%3Aurn-7%3A3gpp-service.ims.icsi.mmtel"
P-Preferred-Service: urn:urn-7:3gpp-service.ims.icsi.mmtel
Allow: INVITE, ACK, CANCEL, BYE, MESSAGE, OPTIONS, NOTIFY, PRACK, UPDATE, REFER
Privacy: none
P-Access-Network-Info: ADSL;utran-cell-id-3gpp=00000000
User-Agent: IM-client/OMA1.0 Boghe/v2.0.112.744
P-Preferred-Identity: <sip:123456789@test.3gpp.com>
Supported: 100rel
v=0
o=doubango 1983 678901 IN IP6 2001:0:0:1::2
s=-
c=IN IP6 2001:0:0:1::2
t=0 0
m=audio 8048 RTP/AVP 112 111 3 8 0 9 97 98 99 101
a=ptime:20
a=rtpmap:112 AMR/8000/1
a=imageattr:112 octet-align=1
a=fmtp:112 octet-align=1
a=rtpmap:111 AMR/8000/1
a=imageattr:111 octet-align=0
a=fmtp:111 octet-align=0
a=rtpmap:3 GSM/8000/1
a=rtpmap:8 PCMA/8000/1
a=rtpmap:0 PCMU/8000/1
a=rtpmap:9 G722/8000/1
a=rtpmap:97 SPEEX/8000/1
a=rtpmap:98 SPEEX/16000/1
a=rtpmap:99 SPEEX/32000/1
a=rtpmap:101 telephone-event/8000/1
a=fmtp:101 0-15
a=tcap:1 RTP/AVPF
a=pcfg:1 t=1
a=sendrecv
a=rtcp-mux
a=ssrc:1311262921 cname:ldjWoB60jbyQlR6e
a=ssrc:1311262921 mslabel:6994f7d1-6ce9-4fbd-acfd-84e5131ca2e2
a=ssrc:1311262921 label:Doubango
3.2 (B) 181 Call Is Being Forwarded
Max-Forwards: 70
Via: SIP/2.0/UDP [2001:0:0:1::2]:56439;branch=z9hG4bK1161335930;rport=56439
To: <sip:UA2@ims.mnc246.mcc081.3gppnetwork.org>;tag=987654321
CSeq: 21140 INVITE
History-Info: <sip:001010123456789@ims.mnc246.mcc081.3gppnetwork.org>; index=1
Content-Length: 0
3.3(C) INVITE sip:UA3@[2001:0:0:1::2]:49329;transport=udp;cause=503 SIP/2.0
Via: SIP/2.0/UDP [2001:0:0:1::2]:28101;branch=z9hG4bKbf2ece8e7f3e42539582fdba3875fe9d198;rport;transport=udp
To: <sip:UA3@ims.mnc246.mcc081.3gppnetwork.org>
CSeq: 21140 INVITE
Content-Length: 739
Max-Forwards: 69
Privacy: none
Supported: 100rel
P-Asserted-Identity: <sip:123456789@test.3gpp.com>
History-Info: <sip:UA2@ims.mnc246.mcc081.3gppnetwork.org>; index=1
History-Info: <sip:UA3@ims.mnc246.mcc081.3gppnetwork.org?cause=503>; index=1.1; MP=1
Record-Route: <sip:[2001:0:0:1::2]:28101;lr>
v=0
s=-
t=0 0
a=ptime:20
a=fmtp:101 0-15
a=tcap:1 RTP/AVPF
a=pcfg:1 t=1
a=sendrecv
a=rtcp-mux
原文来自:http://www.sharetechnote.com
整理:kangguoying20201017
“5G网络中层二的RLC介绍 ”已在微信公众号"跟着老康学5G"中推出,敬请关注!
