关于IMS/SIP中的无应答前转(Communication Forwarding on no Reply-CFNR)是当被叫未做出应答时处理方式之一,其具体在3GPP TS24.604有具体定义;
1.终端注册,参与无应答前转的终端(UA)需要:
A.在CSCF进行注册并预设前转条件;
B.当某一终端(UA)发起的呼叫响应(180 Ringing)超时后,根据预设进行呼叫前转;
2.无应答前转信令流程:
3.无应答前转主要消息内容
(A) INVITE sip:UA1@ims.mnc246.mcc081.3gppnetwork.org SIP/2.0
Via: SIP/2.0/TCP [2001:0:0:1::2]:59417;branch=z9hG4bK62bc484e8cdd4ddc8e563c19815bf51aac5bd1e1;transport=tcp
Max-Forwards: 70
Call-ID: cf01b053c04a414ab24990140d4d2297
CSeq: 38001 INVITE
To: sip:UA1@ims.mnc246.mcc081.3gppnetwork.org
From: sip:UA2@ims.mnc246.mcc081.3gppnetwork.org;tag=1111111111
Feature-Caps: *;+g.3gpp.srvcc-alerting;+g.3gpp.mid-call
Allow: ACK, BYE, CANCEL, INVITE, PRACK, UPDATE
Accept-Contact: *;+g.3gpp.icsi-ref="urn%3Aurn-7%3A3gpp-service.ims.icsi.mmtel";require;explicit
Privacy: none
User-Agent: Sharetechnote-VirtualUA/7e501f1
Content-Type: application/sdp
Content-Length: 728
Route: <sip:[2001:0:0:1::2]:28101;lr>
Contact: <sip:UA2@[2001:0:0:1::2]:59417;transport=tcp>;+g.3gpp.icsi-ref="urn%3Aurn-7%3A3gpp-service.ims.icsi.mmtel";video;+g.3gpp.srvcc-alerting;+g.3gpp.mid-call
v=0
o=Sharetechnote 583 102583 IN IP6 2001:0:0:1::2
s=-
i=A VOIP Session
c=IN IP6 2001:0:0:1::2
t=0 0
m=audio 60000 RTP/AVP 96 97 98 99 100 8 0 101 102
b=AS:153
b=RS:800
b=RR:2400
a=ptime:20
a=maxptime:240
a=rtpmap:96 EVS/16000/1
a=fmtp:96 max-red=220
a=rtpmap:97 AMR-WB/16000/1
a=fmtp:97 mode-change-capability=2
a=rtpmap:98 AMR-WB/16000/1
a=fmtp:98 octet-align=1; mode-change-capability=2
a=rtpmap:99 AMR/8000/1
a=fmtp:99 mode-change-capability=2
a=rtpmap:100 AMR/8000/1
a=fmtp:100 octet-align=1; mode-change-capability=2
a=rtpmap:8 PCMA/8000/1
a=rtpmap:0 PCMU/8000/1
a=rtpmap:101 telephone-event/16000
a=fmtp:101 0-15
a=rtpmap:102 telephone-event/8000
a=fmtp:102 0-15
a=mid:0
a=rtcp:60001
a=sendrecv
(C) 180 Ringing(UA1送回铃音给CSCF)
Via: SIP/2.0/UDP [2001:0:0:1::2]:5060;branch=z9hG4bKc7d5dede360c4bb5a88be02f843e7c4598;rport;transport=udp
Max-Forwards: 70
Record-Route: <sip:[2001:0:0:1::2]:5060;lr>
Contact: <sip:UA1@[2001:0:0:1::11]:5060>;+sip.instance="<urn:gsma:imei:35975507-290776-0>";+g.3gpp.icsi-ref="urn%3Aurn-7%3A3gpp-service.ims.icsi.mmtel";+g.3gpp.mid-call;+g.3gpp.srvcc-alerting;+g.3gpp.ps2cs-srvcc-orig-pre-alerting;video
To: <sip:UA1@ims.mnc246.mcc081.3gppnetwork.org>;tag=c0eff945
From: <sip:UA2@ims.mnc246.mcc081.3gppnetwork.org>;tag=1111111111
CSeq: 38001 INVITE
Supported: timer, 100rel
User-Agent: T-Mobile VoLTE-ePDG-IR94 SEC/G930TUVU4Z 7.0
P-Access-Network-Info: 3GPP-E-UTRAN-FDD;utran-cell-id-3gpp=0010100010000000
Content-Length: 0
(D) 180 Ringing(CSCF送回铃音给UA2)
Max-Forwards: 70
Record-Route: <sip:[2001:0:0:1::2]:28101;lr>
CSeq: 38001 INVITE
Content-Length: 0
(E) CANCEL sip:UA1@[2001:0:0:1::11]:5060 SIP/2.0(呼叫超时,CSCF撤消UA1发起的呼叫)
Max-Forwards: 70
CSeq: 38001 CANCEL
Content-Length: 0
(F) 181 Call Is Being Forwarded(呼叫前转)
Max-Forwards: 70
To: sip:UA1@ims.mnc246.mcc081.3gppnetwork.org;tag=c0eff945
CSeq: 38001 INVITE
History-Info: <sip:UA1@ims.mnc246.mcc081.3gppnetwork.org>; index=1
History-Info: <sip:UA1@ims.mnc246.mcc081.3gppnetwork.org>; index=1.1; NP=1
Content-Length: 0
(G) INVITE sip:UA3@[2001:0:0:1::2]:54990;transport=udp;cause=408 SIP/2.0(呼叫INVITE预设对象UA3)
Via: SIP/2.0/UDP [2001:0:0:1::2]:5060;branch=z9hG4bKc7d5dede360c4bb5a88be02f843e7c459d;rport;transport=udp
Max-Forwards: 69
CSeq: 38001 INVITE
To: sip:UA3@test.3gpp.com
Content-Length: 728
Privacy: none
P-Asserted-Identity: <sip:UA2@ims.mnc246.mcc081.3gppnetwork.org>
原文来自:http://www.sharetechnote.com
整理:kangguoying20201016
“5G网络中层二的RLC介绍 ”已在微信公众号"跟着老康学5G"中推出,敬请关注!
