  • 阅读:5097
IMS和SIP中的消息会话中继协议SRPF协议之二
Mr Kang
原始天尊
积分 104736
帖子 8514
威望 1622771 个
礼品券 11319 个
专家指数 23981
注册 2007-3-13
发表于 2020-10-04 09:21:06  只看楼主
        IMS和SIP消息(Message)通过“消息会话中继协议”SRPM( Message Session Relay Protocol)定义;其设置是为在IP网络传送短消息和视频,此类业务也称中“即时信息”IM((Instant Messaging);类似于短信(SMS)和彩信(MMS);   "消息会话中继协议”MSRP主要应用于"富媒体系统"(RCS);“消息会话中继协议”MSRP共有两类:Pager Mode和Session Mode,其中:Session Mode主要用于多媒体消息(类似MMS)业务交互;
1.Session Mode特点
        在Session Mode中的处理方式与RTP方式基本相同;消息通过建立、发送会话和结束(BYE)完成;
2.Session Mode
2.1  Session Mode中的SDP
        v=0
        o=TEST-IMS-UE 1234562 0 IN IP6 2001::1:4c16:9c0f:4986:9e6d
        s=SS VOIP
        c=IN IP6 2001::1:4c16:9c0f:4986:9e6d
        t=0 0
       m=message 8880 TCP/MSRP *   // Indicate this is for MSRP
       a=accept-types:message/cpim application/im-iscomposing+xml // allowed content type
       a=accept-wrapped-types:text/plain message/imdn+xml  // allowed content type
        a=setup:active
        a=path:msrp://[2001::1:4c16:9c0f:4986:9e6d]:8880/FmnP;tcp //MSRP URI. It indicates where message should be sent
        a=msrp-cema
        a=sendrecv
2.1  Session Mode中的发送方式(SEND method)
         MSRP RgGcYXJW2nHr SEND
        // To-Path indicates series of hopts to recipient
        To-Path: msrp://[2001:0000:0000:0001:0000:0000:0000:0002]:16000/558f02b9d0;tcp
        // From-Path indicates path from the sender
        From-Path: msrp://[2001::1:4c16:9c0f:4986:9e6d]:8880/FmnP;tcp
        // Message ID is unique per message
        Message-ID: ZNsPlykpMApIABRrejarbO37ADMMae
        Success-Report: no
        Failure-Report: yes
        // This for chucking the big data into multiple blocks
        Byte-Range: 1-430/430
        // contents type. It can be text/plain or cpim or any other.
        Content-Type: message/cpim
3.Session Mode示例
Step
Direction
Protocol
Message
Comments
(1)
UA1 --> Proxy/UA2
SIP/SDP
INVITE
(2)
UA1 <-- Proxy/UA2
SIP
100 Trying
(3)
UA1 <-- Proxy/UA2
SIP
183 Session Progress
(4)
UA1 <-- Proxy/UA2
SIP/SDP
200 OK
(5)
UA1 --> Proxy/UA2
SIP
ACK
(6)
UA1 --> Proxy/UA2
MSRP
SEND
(7)
UA1 <-- Proxy/UA2
MSRP
200 OK
(8)
UA1 --> Proxy/UA2
MSRP
SENDSend Text 'Hello'
(9)
UA1 <-- Proxy/UA2
MSRP
200 OK
(10)
UA1 <-- Proxy/UA2
MSRP
SENDDelivery Notification
(11)
UA1 --> Proxy/UA2
MSRP
200 OK
4.Session Mode消息
4.1 INVITE
        INVITE sip:+[email]14448880000@sharetechnote.com[/email];user=phone SIP/2.0
        Conversation-ID: 6b79b8bc937e4985b1dffd062b687bd7
        Contribution-ID: d5e4121aeec2cc59546ebaef8966ef185a2f37f0
        P-Preferred-Service: urn:urn-7:3gpp-service.ims.icsi.oma.cpm.session
        P-Preferred-Identity: <sip:310410123456789@sharetechnote.com>
        P-Early-Media: supported
        Allow: INVITE,ACK,OPTIONS,CANCEL,BYE,UPDATE,INFO,REFER,NOTIFY,MESSAGE,PRACK
        User-Agent: Samsung IMS 5.0
        CSeq: 1 INVITE
        Max-Forwards: 70
        P-Access-Network-Info: 3GPP-E-UTRAN-FDD;utran-cell-id-3gpp=31041000010000000
        Route: <sip:[2001:0:0:1::2]:5060;lr>
        a: *;+g.3gpp.icsi-ref="urn%3Aurn-7%3A3gpp-service.ims.icsi.oma.cpm.session"
        c: application/sdp
        f: <sip:310410123456789@sharetechnote.com>;tag=284849603
        i: 508868544@2001::1:4c16:9c0f:4986:9e6d
        k: timer
        l: 363
        m: <sip:310410123456789@[2001::1:4c16:9c0f:4986:9e6d]:5060;transport=UDP>;+g.3gpp.icsi-ref="urn%3Aurn-7%3A3gpp-        service.ims.icsi.oma.cpm.session"
        t: <sip:+[email]14448880000@sharetechnote.com[/email];user=phone>
        v: SIP/2.0/TCP [2001::1:4c16:9c0f:4986:9e6d]:5060;branch=z9hG4bK2563646430smg;transport=TCP
        v=0
        s=SS VOIP
        t=0 0
        a=setup:active
        a=msrp-cema
        a=sendrecv
4.2 100 Trying
        SIP/2.0 100 Trying
        Via: SIP/2.0/TCP [2001::1:4c16:9c0f:4986:9e6d]:5060;branch=z9hG4bK2563646430smg;transport=TCP
        Max-Forwards: 70
        From: <sip:310410123456789@sharetechnote.com>;tag=284849603
        To: <sip:+[email]14448880000@sharetechnote.com[/email];user=phone>
        Call-ID: 508868544@2001::1:4c16:9c0f:4986:9e6d
        CSeq: 1 INVITE
        Content-Length: 0
4.3 183 Session Progress
        SIP/2.0 183 Session Progress
        Max-Forwards: 70
        To: <sip:+[email]14448880000@sharetechnote.com[/email];user=phone>;tag=b2fbe90a8c2e488ba04ad6d0c0956a6c
        CSeq: 1 INVITE
        Contact: <sip:+[email]14448880000@sharetechnote.com[/email]>
        Record-Route: <sip:[2001:0:0:1::2]:5060;lr>
        Content-Length: 0
4.4 200 OK
        CSeq: 1 INVITE
        Allow: INVITE, ACK, CANCEL, BYE, MESSAGE
        Contact: <sip:[2001:0:0:1::2]:49466;transport=tcp>
        Content-Type: application/sdp
        Content-Length: 292
        v=0
        o=- 1192 5963 IN IP6 2001:0:0:1::2
        s=-
        c=IN IP6 2001:0:0:1::2
        m=message 16000 TCP/MSRP *
        a=accept-wrapped-types:*
        a=path:msrp://[2001:0000:0000:0001:0000:0000:0000:0002]:16000/558f02b9d0;tcp
        a=msrp-cema
        a=setup:passive
原文来自:http://www.sharetechnote.com/
整理:kangguoying20201004
"5G(NR)NSA网络接入问题排查点”已在微信公众号"跟着老康学5G"中推出,敬请关注!
    当前时区 GMT+8, 现在时间是 2024-04-30 05:49:16
    Processed in 0.259163 second(s), 13 queries , Gzip enabled
