  • 阅读:1490
VoLTE语音MOS背后的秘密
Mr Kang
原始天尊
积分 104741
帖子 8515
威望 1626420 个
礼品券 11319 个
专家指数 23981
注册 2007-3-13
发表于 2020-09-28 10:08:50  只看楼主
 "无会话,非5G”链接如下:https://mp.weixin.qq.com/s/AX3MCn1woaSRrDVd2nkrtA
 VoLTE测试中绕不开的一项就是MOS;它是对VOLTE语音质量的评估,根据中移评估标准其最高值为5.0;而决定MOS值的是通话中编码(Codec)选择和更新;
1.编码(Codec)选择和更新
       在VoLTE和Video通话中,编码(Codec)的选择和配置是在会话建立或通话中根据主、被叫协商情况结果,通过SDP(Session Description Protocol)执行的;如下表所示:
  •        STEP  1,3为初始编码(Codec)选择;
  •        STEP  3,5,6,7为资源预留的QoS建立;
  •        STEP 13,14为编码(Codec)更新;
2.SDP相关内容(以下示例红色字体部分
2.1  INVITE
       INVITE sip:0123456789;phone-context=test.net@test.net;user=phone SIP/2.0
           Allow: INVITE,ACK,OPTIONS,CANCEL,BYE,UPDATE,INFO,REFER,NOTIFY,MESSAGE,PRACK
           P-Preferred-Identity: <sip:310410123456789@test.net>
           User-Agent: TEST IMS CLIENT 4.0
           P-Preferred-Service: urn:urn-7:3gpp-service.ims.icsi.mmtel
           CSeq: 1 INVITE
           Max-Forwards: 70
           P-Access-Network-Info: 3GPP-E-UTRAN-FDD;utran-cell-id-3gpp=31041000010000000
           Route: <sip:[2001:0:0:2::2]:5060;lr>
           a: *;+g.3gpp.icsi-ref="urn%3Aurn-7%3A3gpp-service.ims.icsi.mmtel"
           c: application/sdp
           f: <sip:310410123456789@test.net>;tag=2763466811
           i: 2270680280
           k: 100rel,timer,precondition
           l: 733
           m: <sip:310410123456789@[2001:0:0:2::1]:5060;transport=UDP>;+g.3gpp.icsi-ref="urn%3Aurn-7%3A3gpp-service.ims.icsi.mmtel"
           t: <sip:0123456789;phone-context=test.net@test.net;user=phone>
           v: SIP/2.0/TCP [2001:0:0:2::1]:5060;branch=z9hG4bK932432170smg;transport=TCP
           v=0
           o=TEST-IMS-UE 1234562 0 IN IP6 2001:0:0:2::1
           s=SS VOIP
           c=IN IP6 2001:0:0:2::1
           t=0 0
           m=audio 50000 RTP/AVP 116 107 97 115 111 110
           b=AS:49
           a=rtpmap:116 AMR-WB/16000
           a=fmtp:116 mode-change-capability=2; max-red=0
           a=rtpmap:107 AMR-WB/16000
           a=fmtp:107 octet-align=1;mode-change-capability=2; max-red=0
           a=rtpmap:97 AMR/8000
           a=fmtp:97 mode-change-capability=2; max-red=0
           a=rtpmap:115 AMR/8000
           a=fmtp
2.2  100 Trying
       SIP/2.0 100 Trying
           Via: SIP/2.0/TCP [2001:0:0:2::1]:5060;branch=z9hG4bK932432170smg;transport=TCP
           Max-Forwards: 70
           From: <sip:310410123456789@test.net>;tag=2763466811
           To: <sip:0123456789;phone-context=test.net@test.net;user=phone>
           Call-ID: 2270680280
           CSeq: 1 INVITE
           Content-Length: 0
2.3 183 Session Progress
       SIP/2.0 183 Session Progress
           Max-Forwards: 70
           To: <sip:0123456789;phone-context=test.net@test.net;user=phone>;tag=1111111111
           Call-ID: 2270680280
           CSeq: 1 INVITE
           Contact: <sip:0123456789@[2001:0:0:2::2]:65094;transport=tcp>
           Record-Route: <sip:[2001:0:0:2::2];lr>
           Content-Type: application/sdp
           Require: precondition
           Require: 100rel
           RSeq: 1
           Content-Length: 763
           Privacy: none
           P-Asserted-Identity: <sip:0123456789>;phone-context=test.net@test.net;user=phone
           v=0
           o=anritsu 1 1 IN IP6 2001:0:0:2::2
           s=SS VOIP
           c=IN IP6 2001:0:0:2::2
           t=0 0
           m=audio 60000 RTP/AVP 116 107 97 115 111 110
           b=AS:49
           a=fmtp:115 octet-align=1;mode-change-capability=2; max-red=0
           a=rtpmap:111 telephone-event/16000
           a=fmtp:111 0-15
           a=rtpmap:110 telephone-event/8000
            a=fmtp:110 0-15
           a=curr:qos local none
           a=curr:qos remote none
           a=des:qos mandatory local sendrecv
            a=des:qos mandatory remote sendrecv
            a=sendrecv
            a=ptime:20
            a=maxptime:240
            a=conf:qos remote sendrecv
            a=rtcp:60001
2.5 200 OK
      SIP/2.0 200 OK
          Max-Forwards: 70
          Via: SIP/2.0/TCP [2001:0:0:2::1]:5060;branch=z9hG4bK1835967788smg;transport=TCP
          Call-ID: 2270680280
          CSeq: 3 UPDATE
          Allow: INVITE, ACK, CANCEL, BYE, PRACK, MESSAGE
          Content-Length: 743
          Privacy: none
          v=0
          o=anritsu 1 2 IN IP6 2001:0:0:2::2
          s=SS VOIP
          t=0 0
          b=AS:49
          a=fmtp:111 0-15
          a=fmtp:110 0-15
          a=curr:qos local sendrecv
          a=curr:qos remote sendrecv
          a=sendrecv
          a=ptime:20
          a=maxptime:240
          a=rtcp:60001
2.6 UPDATE
      SIUPDATE sip:0123456789@[2001:0:0:2::2]:65094;transport=TCP SIP/2.0
          Proxy-Require: sec-agree
          Security-Verify:
          CSeq: 3 UPDATE
          Max-Forwards: 70
          c: application/sdp
          i: 2270680280
          l: 738
          t: <sip:0123456789;phone-context=test.net@test.net;user=phone>;tag=1111111111
          v: SIP/2.0/TCP [2001:0:0:2::1]:5060;branch=z9hG4bK1835967788smg;transport=TCP
          v=0
          o=TEST-IMS-UE 1234562 1 IN IP6 2001:0:0:2::1
          s=SS VOIP
          t=0 0
          b=AS:49
          a=fmtp:111 0-15
          a=fmtp:110 0-15
          a=sendrecv
          a=ptime:20
          a=maxptime:240
2.7 200 OK
       SIP/2.0 200 OK
          Max-Forwards: 70
          Call-ID: 2270680280
          CSeq: 3 UPDATE
          Content-Length: 743
          Privacy: none
          v=0
          s=SS VOIP
          t=0 0
          b=AS:49
          a=fmtp:111 0-15
          a=fmtp:110 0-15
          a=sendrecv
          a=ptime:20
          a=maxptime:240
          a=rtcp:60001
原文来自:http://www.sharetechnote.com/
整理:kangguoying20200928
"NSA网络中终端无法接入5G (NR)排查要点”将在微信公众号"跟着老康学5G"中推出,敬请关注!
    当前时区 GMT+8, 现在时间是 2024-05-13 08:31:38
    Processed in 0.298642 second(s), 13 queries , Gzip enabled
