5G(NR)网络中服务小区可以针对UE通过发送特定的PDCCH MAC CE,来指示用于在PDCCH接收的用于服务单元CORESET的TCI(Transmission Configuration Index)状态;翻译整理:kangguoying20200812
1.传输配置指标TCI(Transmission Configuration Index)
TCI传输配置指示是服务小区通过下行共享信道(DL-SCH)特定的PDCCH MAC CE发给UE,其MAC子标头标识的LCID固定为16位bits;功能分别如表6.2.1-1所示翻译整理:kangguoying20200812
Index | LCID values |
0 | CCCH |
1–32 | Identity of the logical channel |
33-46 | Reserved |
47 | Recommended bit rate |
48 | SP ZP CSI-RS Resource Set Activation/Deactivation |
49 | PUCCH spatial relation Activation/Deactivation |
50 | SP SRS Activation/Deactivation |
51 | SP CSI reporting on PUCCH Activation/Deactivation |
52 | TCI State Indication for UE-specific PDCCH |
53 | TCI States Activation/Deactivation for UE-specific PDSCH |
54 | Aperiodic CSI Trigger State Subselection |
55 | SP CSI-RS/CSI-IM Resource Set Activation/Deactivation |
56 | Duplication Activation/Deactivation |
57 | SCell Activation/Deactivation (four octets) |
58 | SCell Activation/Deactivation (one octet) |
59 | Long DRX Command |
60 | DRX Command |
61 | Timing Advance Command |
62 | UE Contention Resolution Identity |
63 | Padding |
Table 6.2.1-1 Values of LCID for DL-SCH
2.字段定义
服务单元ID: 该字段表示MAC CE应用的服务小区身份。字段长度5bits;翻译整理:kangguoying20200812
CORESET ID:该字段表示一个控制资源集,该控制资源集与TS 38.331[5]中指定的资源控制器一起标识,该资源集的TCI状态被指示。 如果字段值为0,则该字段引用TS 38.331[5]中指定由controlResourceSetZero配置的控制资源集。字段长度为4bits;翻译整理:kangguoying20200812
TCI状态ID: 该字段表示TCI状态ID:标识的TCI状态,如TS38.331[5]中所指定,适用于由CORESET ID字段标识的控制资源集。 如果CORESET ID字段设置为0,则该字段表示ACTIVE BWP中PDSCH-config 中 tci-states-toaddmodlist 和 tci-states-toreleaselist 配置的前64个 tci 状态的 tci-stateid。 如果 coreset id 字段设置为小于0的其他值,则该字段表示由tci-StatesPDCCH-ToAddList和tci-StatesPDCCH-ToReleaseList配置的TCI-StateId,该tci-StatesPDCCH-ToReleaseList位于由指示的CORESET标识的控制集中。字段的长度是7bits;理:kangguoying20200812
| Oct1 Oct2 |
Serving Cell ID | CORESET ID |
CORE SET ID | TCI State ID |
Figure 6.1.3.15-1: TCI State Indication for UE-specific PDCCH MAC CE
3.UE的TCI激活和去激活
针对特定用户TCI状态PDSCH MAC CE 的激活/去激活由表6.2.1-1中指定的带有LCID的MAC 子标头标识。它的大小可变,包括以下字段:翻译整理:kangguoying20200812
服务小区ID: 这个字段表示 MAC CE 应用的服务小区的身份 字段长度为5bits;;
BWP ID: 该字段表示 DL BWP,MAC CE应用于该字段,作为 TS38.212[9]中指定的 DCI带宽部分指示器字段的码点。 BWP ID字段的长度为2bits;翻译整理:kangguoying20200812
TI : 如果有一个TCI状态,如TS 38.331[5]所指定的 TCI状态 id i,这个字段表示 TCI状态的激活 / 去激活状态,否则 MAC 实体将忽略 Ti字段。 翻译整理:kangguoying20200812
Ti 字段设置为1,以表明激 状态 i 将被激活并映射到 DCI传输配置指示字段的码点,如 ts 38.214[7]所指定。 Ti 字段设置为0,以表明TCI状态 i 将被停用,并且没有映射到 DCI传输配置指示字段的码点。 将TCI状态映射到的码点由其在 Ti 字段设置为1的所有TCI状态中的序位确定,即将 Ti 字段设置为1的第一TCI状态映射到码点值0,将Ti 字段设置为1的第二TCI状态映射到码点值1,以此类推。 最大激活 TCI状态数为8个;翻译整理:kangguoying20200812
R.保留比特,置为0;
Figure 6.1.3.14-1: TCI States Activation/Deactivation for UE-specific PDSCH MAC CE
原文来自:3GPP 38.214 5.18.5 翻译整理:kangguoying20200812
