  • 阅读:3969
5G(NR)网络中配置调度(Configured Scheduling)
Mr Kang
原始天尊
积分 104731
帖子 8513
威望 1621564 个
礼品券 11319 个
专家指数 23981
注册 2007-3-13
发表于 2020-07-31 07:55:43  只看楼主
        在5G(NR)网络中,上、下行的资源处于随时随地的变化中,而终端需要及时掌握无线网络资源情况,收取相关信息;网络中的下行资源-配置和调度消息(Configured Scheduling)网络通过RRC信令进行传递给终端;终端通过CS-RNTI进行解扰,决定对半静态调度(SPS)的解析、应用和释放;整理:kangguoying20200731
1.下行配置调度流程(Configure CS for Downlink / SPS)
  •       终端接收RRC消息中半静态调度消息(SPS)整理:kangguoying20200731
  •       监控PDCCH,根据配置调度解析DCI,使用CS-RNTI解码PDSCH上的数据整理:kangguoying20200731
2. 上行配置调度流程(Configure CS for Downlink / SPS)
            在5G(NR)网络中上行的配置调度有两类,分别为TYPE1和TYPE2;其中:整理:kangguoying20200731
2.1 TYPE1
  •       终端接收RRC消息整理:kangguoying20200731
  •       监控PDCCH,周期性的在PUSCH上传数据整理:kangguoying20200731
  •       如接收到配置调度,使用C-RNTI解码PDCCH上的消息整理:kangguoying20200731
2.2 TYPE2
  •       终端接收RRC消息;整理:kangguoying20200731
  •       监控PDCCH,根据配置调度解析DCI,使用CS-RNTI在PUSCH上传数据;整理:kangguoying20200731
  •       如接收到配置调度,使用C-RNTI解码PDCCH上的消息;整理:kangguoying20200731
3.RRC消息中的参数配置整理:kangguoying20200731
    ConfiguredGrantConfig ::= SEQUENCE {整理:kangguoying20200731
    frequencyHopping                 ENUMERATED {intraSlot, interSlot},
    cg-DMRS-Configuration            DMRS-UplinkConfig,整理:kangguoying20200731
    mcs-Table                        ENUMERATED {qam256, qam64LowSE},整理:kangguoying20200731
    mcs-TableTransformPrecoder       ENUMERATED {qam256, qam64LowSE},
    uci-OnPUSCH                      SetupRelease { CG-UCI-OnPUSCH },整理:kangguoying20200731
    resourceAllocation               ENUMERATED { resourceAllocationType0,
                                                  resourceAllocationType1,
                                                  dynamicSwitch },整理:kangguoying20200731
    rbg-Size                         ENUMERATED {config2},
    powerControlLoopToUse            ENUMERATED {n0, n1},整理:kangguoying20200731
    p0-PUSCH-Alpha                   P0-PUSCH-AlphaSetId,
    transformPrecoder                ENUMERATED {enabled, disabled},
    nrofHARQ-Processes               INTEGER(1..16),整理:kangguoying20200731
    repK                             ENUMERATED {n1, n2, n4, n8},整理:kangguoying20200731
    repK-RV                          ENUMERATED {s1-0231, s2-0303, s3-0000},
    periodicity                      ENUMERATED {整理:kangguoying20200731
                            sym2, sym7, sym1x14, sym2x14, sym4x14, sym5x14,
                            sym8x14, sym10x14, sym16x14, sym20x14,sym32x14,
                            sym40x14, sym64x14, sym80x14, sym128x14, sym160x14,
                             sym256x14, sym320x14, sym512x14,sym640x14, sym1024x14,
                            sym1280x14, sym2560x14, sym5120x14, sym6, sym1x12,
                            sym2x12, sym4x12, sym5x12, sym8x12, sym10x12, sym16x12,
                            sym20x12, sym32x12,sym40x12, sym64x12, sym80x12,
                            sym128x12, sym160x12, sym256x12, sym320x12, sym512x12,
                            sym640x12,sym1280x12, sym2560x12 },整理:kangguoying20200731
     configuredGrantTimer             INTEGER (1..64),整理:kangguoying20200731
     rrc-ConfiguredUplinkGrant        SEQUENCE {整理:kangguoying20200731
        timeDomainOffset                 INTEGER (0..5119),
        timeDomainAllocation             INTEGER (0..15),整理:kangguoying20200731
        frequencyDomainAllocation        BIT STRING (SIZE(18)),
        antennaPort                      INTEGER (0..31),整理:kangguoying20200731
        dmrs-SeqInitialization           INTEGER (0..1),整理:kangguoying20200731
        precodingAndNumberOfLayers       INTEGER (0..63),整理:kangguoying20200731
        srs-ResourceIndicator            INTEGER (0..15),整理:kangguoying20200731
        mcsAndTBS                        INTEGER (0..31),整理:kangguoying20200731
        frequencyHoppingOffset           INTEGER (1.. maxNrofPhysicalResourceBlocks-1),
        pathlossReferenceIndex           INTEGER (0..maxNrofPUSCH-PathlossReferenceRSs-1),        ...    },...}
  CG-UCI-OnPUSCH ::= CHOICE {整理:kangguoying20200731
      dynamic SEQUENCE (SIZE (1..4)) OF BetaOffsets,整理:kangguoying20200731
      semiStatic BetaOffsets}  整理:kangguoying20200731
 SPS-Config ::= SEQUENCE {整理:kangguoying20200731
     periodicity        ENUMERATED {ms10, ms20, ms32, ms40, ms64, ms80, ms128,
                  ms160, ms320, ms640,spare6, spare5, spare4,  spare3, spare2, spare1},
     nrofHARQ-Processes                INTEGER (1..8),整理:kangguoying20200731
     n1PUCCH-AN                        PUCCH-ResourceId OPTIONAL, -- Need M
     mcs-Table                         ENUMERATED {qam64LowSE} OPTIONAL, -- Need S...}
原文来自:http://www.sharetechnote.com/整理:kangguoying20200731
    当前时区 GMT+8, 现在时间是 2024-04-25 20:42:37
    Processed in 0.256888 second(s), 13 queries , Gzip enabled
