  • 阅读:3715
5G(NR)中的波束管理--2
Mr Kang
原始天尊
积分 104736
帖子 8514
威望 1622591 个
礼品券 11319 个
专家指数 23981
注册 2007-3-13
发表于 2020-07-04 09:22:15  只看楼主
       5G(NR)网络支持FR1和FR2频段,FR1频率范围:450—6000MHZ;FR2是毫米波,频率范围:24.25GHz-- 52.6GHz)。而毫米波波段使用高频,其将导致传播损失和损耗;为了弥补其损失,天线阵列、大量天线振子成为可能。而波束管理则可以“优中选优”,使网络和终端分别获得最佳的信号。整理:kangguoying20200704
5.5G(NR)网络中下行信号和波束测量整理:kangguoying20200704
5.1 SSB块整理:kangguoying20200704
        在5G(NR)网络的下行链路帧中,SSB块根据 (5 / 10 / 20 / 40 / 80 / 160ms) 的周期性设置,以规则的间隔传送给UE。1 个SSB块在时间轴上占用4个OFDM符号,在频域轴上占用240个子载波;SSB块携带PSS (主同步信号)、SSS (次同步信号)和携带DMRS的PBCH。SSB块分为第一个5 ms的SS burst。 单个burst中SS块的最大数目(L)依赖其频段。在频率>6 GHz (即毫米波频率)时,每个burst约有64个block。整理:kangguoying20200704
5.2 DMRS(解调参考信号)
        PBCH上DMRS(解调参考信号)的RSRP被UE用来计算SS块的信号强度;整理:kangguoying20200704
        上图显示的是gNB以20ms为间隔发送给UE的SS块;整理:kangguoying20200704
5.3 CSI-RS整理:kangguoying20200704
       在LTE网络中,连接态的UE评估服务基站的信道质量,上报CQI(信道质量);与LTE相同在5G(NR)网络中这些信号用于连接态下的RRM测量,用于移动性的管理;CSI-RS占用N = 1/2/4 个OFDM符号,其有周期和半静态/非周期传输两种形式;整理:kangguoying20200704
6.上行信号的波束测量
       探测参考信号(如SRSs)由UE发送,由gNB接收。这些信号是用来监控上行信道的质量。 为了波束管理,上行配置了多个SRSs。 它们可占用1到4个OFDM符号,并使用分配给UE的部分带宽。整理:kangguoying20200704
7.5G(NR)网络SA NSA波束管理整理:kangguoying20200704
Beam Management Phase
SA-downlink
NSA-downlink
NSA-uplink
Beam sweeping
Exhaustive search based on SS blocks   received by UE.
Based on SRS (Sounding Reference Signal)   transmitted by UE and received by gNB
Beam measurement
Performed at UE-side
Performed at gNB-side
Beam Determination or Selection
UE selects best communication direction as   per beam measurement operation.
The gNB along with central controller   selects the best beam pair for communication between itself and UE.
Beam reporting
Exhaustive serch at gNB side.
UE signals the best beam pair using LTE   backbone, a RACH opportunity is scheduled in the selected direction.
gNB signals the best beam pair using LTE   backbone, a RACH opportunity is scheduled in the selected direction.
原文来自:https://www.rfwireless-world.com/5G/5G-NR-Beam-Management.html整理:kangguoying20200704
    当前时区 GMT+8, 现在时间是 2024-04-29 07:52:11
    Processed in 0.270938 second(s), 13 queries , Gzip enabled
