与4G(LTE)网络相同,在5G(NR)网络中下行采用功率分配,上行采用功率控制的方式,以达到满足网络的信噪比和误码率,降低同频信道干扰的目的;整理:kangguoying20200623
1.5G(NR)网络功率控制
上行链路的功率控制过程决定了不同上行链路物理信道(PUCCH、PUSCG)或信号(SRS、PRACH)的传输功率。
在无线系统中通常要求增加或减少UE或移动设备的发射功率,这就是所谓的上行能量控制。 增加发射功率以满足gNB (或基站或eNB)所需的信噪比或误码率 ;减少发射功率以尽量减少5G系统的同频信道干扰。功率控制有两种类型:开环功率控制和闭环功率控制。整理:kangguoying20200623
功率控制模式配置在调度(Configured Grant)信息单元中;整理:kangguoying20200623
调度信元的“Alpha”值为上行功率控制调整值;整理:kangguoying20200623
在5G(NR)网络中功率控制与参数集、子载波间隔或其他参数一同更新;整理:kangguoying20200623
在2μ 为5G网络的参数集,其中μ取值为0到5;整理:kangguoying20200623
在"TPC command"字段指示了功率调整增加或减少值;整理:kangguoying20200623整理:kangguoying20200623
2.PUSCH共享信道功率控制
PUSCH共享信道功率控制参数计算公式如下:
通过RRC下发的功率控制相关信息单元(取值范围):整理:kangguoying20200623
PUSCH-PowerControl ::= SEQUENCE {整理:kangguoying20200623
tpc-Accumulation ENUMERATED { disabled }整理:kangguoying20200623
msg3-Alpha Alpha整理:kangguoying20200623
p0-NominalWithoutGrant INTEGER (-202..24)整理:kangguoying20200623
p0-AlphaSets SEQUENCE (SIZE(1..maxNrofP0-PUSCH-AlphaSets)) OF P0-PUSCH-AlphaSet整理:kangguoying20200623
pathlossReferenceRSToAddModList SEQUENCE (SIZE (1..maxNrofPUSCH-PathlossReferenceRSs)) OF PUSCH-PathlossReferenceRS
pathlossReferenceRSToReleaseList SEQUENCE (SIZE (1..maxNrofPUSCH-PathlossReferenceRSs)) OF PUSCH-PathlossReferenceRS-Id
twoPUSCH-PC-AdjustmentStates ENUMERATED {twoStates}整理:kangguoying20200623
deltaMCS ENUMERATED {enabled}整理:kangguoying20200623
sri-PUSCH-MappingToAddModList SEQUENCE (SIZE (1..maxNrofSRI-PUSCH-Mappings)) OF SRI-PUSCH-PowerControl
sri-PUSCH-MappingToReleaseList SEQUENCE (SIZE (1..maxNrofSRI-PUSCH-Mappings)) OF SRI-PUSCH-PowerControlId}
P0-PUSCH-AlphaSet ::= SEQUENCE {整理:kangguoying20200623
p0-PUSCH-AlphaSetId P0-PUSCH-AlphaSetId,整理:kangguoying20200623
p0 INTEGER (-16..15)整理:kangguoying20200623
alpha Alpha}整理:kangguoying20200623
P0-PUSCH-AlphaSetId ::= INTEGER (0..maxNrofP0-PUSCH-AlphaSets-1)整理:kangguoying20200623
PUSCH-PathlossReferenceRS ::= SEQUENCE {整理:kangguoying20200623
pusch-PathlossReferenceRS-Id PUSCH-PathlossReferenceRS-Id,整理:kangguoying20200623
referenceSignal CHOICE {整理:kangguoying20200623
ssb-Index SSB-Index,整理:kangguoying20200623
csi-RS-Index NZP-CSI-RS-ResourceId}}整理:kangguoying20200623
PUSCH-PathlossReferenceRS-Id ::= INTEGER (0..maxNrofPUSCH-PathlossReferenceRSs-1)
SRI-PUSCH-PowerControl ::= SEQUENCE {整理:kangguoying20200623
sri-PUSCH-PowerControlId SRI-PUSCH-PowerControlId,整理:kangguoying20200623
sri-PUSCH-PathlossReferenceRS-Id PUSCH-PathlossReferenceRS-Id,
sri-P0-PUSCH-AlphaSetId P0-PUSCH-AlphaSetId,整理:kangguoying20200623
sri-PUSCH-ClosedLoopIndex ENUMERATED { i0, i1 }}整理:kangguoying20200623
SRI-PUSCH-PowerControlId ::= INTEGER (0..maxNrofSRI-PUSCH-Mappings-1)
BetaOffsets ::= SEQUENCE {整理:kangguoying20200623
betaOffsetACK-Index1 INTEGER(0..31)整理:kangguoying20200623
betaOffsetACK-Index2 INTEGER(0..31)
betaOffsetACK-Index3 INTEGER(0..31)整理:kangguoying20200623
betaOffsetCSI-Part1-Index1 INTEGER(0..31)
betaOffsetCSI-Part1-Index2 INTEGER(0..31)整理:kangguoying20200623
betaOffsetCSI-Part2-Index1 INTEGER(0..31)
betaOffsetCSI-Part2-Index2 INTEGER(0..31)整理:kangguoying20200623
3.PUCCH控制信道功率控制
PUCCH共享信道功率控制参数计算公式如下:整理:kangguoying20200623
PUCCH-PowerControl ::= SEQUENCE {
deltaF-PUCCH-f0 INTEGER (-16..15)整理:kangguoying20200623
deltaF-PUCCH-f1 INTEGER (-16..15)
deltaF-PUCCH-f2 INTEGER (-16..15)整理:kangguoying20200623
deltaF-PUCCH-f3 INTEGER (-16..15)
deltaF-PUCCH-f4 INTEGER (-16..15)
p0-Set SEQUENCE (SIZE (1..maxNrofPUCCH-P0-PerSet)) OF P0-PUCCH整理:kangguoying20200623
pathlossReferenceRSs SEQUENCE (SIZE (1..maxNrofPUCCH-PathlossReferenceRSs)) OF PUCCH-PathlossReferenceRS
twoPUCCH-PC-AdjustmentStates ENUMERATED {twoStates}...}整理:kangguoying20200623
P0-PUCCH ::= SEQUENCE {整理:kangguoying20200623
p0-PUCCH-Id P0-PUCCH-Id,
p0-PUCCH-Value INTEGER (-16..15)}
P0-PUCCH-Id ::= INTEGER (1..8)整理:kangguoying20200623
PUCCH-PathlossReferenceRS ::= SEQUENCE {
pucch-PathlossReferenceRS-Id PUCCH-PathlossReferenceRS-Id,
4.SRS参考信号
SRS参考信号功率控制计算公式如下:整理:kangguoying20200623
SRS配置信息中的“srs-PowerControlAdjustmentStates"即为功率控制信元整理:kangguoying20200623
5.PRACH信道整理:kangguoying20200623
5.1 PRACH功率控制公式整理:kangguoying20200623
PRACH信道功率控制公式如下;功率攀升步长包括在“随机接入码传输”(Random Access Preamble transmission)中。整理:kangguoying20200623
5.2 随机接入响应调度字段整理:kangguoying20200623
5.3.功率调整命令(单位Db)整理:kangguoying20200623
TPC command | value (in dB) |
0 | -6 |
1 | -4 |
2 | -2 |
3 | 0 |
4 | 2 |
5 | 4 |
6 | 6 |
7 | 8 |
原文来自:https://www.rfwireless-world.com/5G 整理:kangguoying20200623
