1.5G(NR)网络中信道带宽整理:kangguoying20200619
3GPP在协议38.101-1,图5.3.3-1对5G(NR)网络中信道带宽和传输带宽进行了定义;整理:kangguoying20200619
信道带宽(Channel BW=最大传输带宽+保护带宽(两侧);其中:最大传输带宽是RB;而保护带宽单位为khz;
2.5G(NR)网络信道带宽计算公式整理:kangguoying20200619
信道带宽(CBW)=N_RB*子载波数*子载波间隔+保护带宽*2;其中:整理:kangguoying20200619
N_RB最大传输带宽 查:38.101-1表5.3.2-1;38.101-2表5.3.2-1整理:kangguoying20200619
子载波数=12(常数)整理:kangguoying20200619
子载波间隔 查:38.101-1表5.3.2-1;38.101-2表5.3.2-1整理:kangguoying20200619
保护带宽 查:38.101-1表5.3.3-1,38.101-2表5.3.3-1整理:kangguoying20200619
举例:
CBW=5Mhz,SCS=30Khz整理:kangguoying20200619
N_RB* NumOfSubcarrier* SCS =11*12*30=3960(kHz) (a)整理:kangguoying20200619
GuardBand x 2= 505 x 2 = 1010 (b)整理:kangguoying20200619
(a)+(b)=3960+1010=4970kHz = 4.970 Mhz接近5 Mhz CBW整理:kangguoying20200619
3.3GPP协议相关表整理:kangguoying20200619
3.1 38.101-1 Table 5.3.2-1: Maximum transmission bandwidth configuration NRB : FR1整理:kangguoying20200619
3.2 38.101-2 Table 5.3.2-1: Maximum transmission bandwidth configuration NRB : FR2整理:kangguoying20200619
3.3 38.101-1 Table 5.3.3-1: Minimum Guardband for each UE channel bandwidth and SCS (kHz) : FR1
3.4 38.101-2 Table 5.3.3-1: Minimum guardband for each UE channel bandwidth and SCS (kHz) : FR2
原文来自:http://www.sharetechnote.com/整理:kangguoying20200619
