  • 阅读:10939
  • 回复:2
5G(NR)网络中RRC的计时器、计数器和常量
Mr Kang
原始天尊
积分 104731
帖子 8513
威望 1621564 个
礼品券 11319 个
专家指数 23981
注册 2007-3-13
发表于 2020-04-01 08:56:55  只看楼主
        5G(NR)网络无线资源控制(RRC)中引入了下列计时器、计数器和常量,以便UE在RRC setuprequest, RRC reestablishment, RRC resume, RRC suspend等进程的可靠运行。
        RRC计时器,指示计时器持续时间及在事件中何时开始和停止;如果计时器超时,UE将采取的行动。这些计时器由字母“T”表示,后跟3位数字,例如 T300。每个计时器起始值为零;UE应用的计时器值倒计数为零时,则计为超时;除非明确说明另有规定。
  •         Timer: T300
    •         Start Point:起始点
      •         Upon transmission of RRCSetupRequest
    •         Stop Point:结束点
      •         Upon reception of RRCSetup or RRCReject message
      •         Upon Cell re-selection
      •         Upon abortion of connection establishment by        upper layers
    •         Action upon Timer Expiry:超时后续动作
  •         Timer: T301
    •         Start Point:(起始点)
      •         Upon transmission of RRCReestabilshmentRequest
    •         Stop Point:(结束点)
      •         Upon reception of RRCReestablishment or RRCSetupmessage
      •         when the selected cell becomes unsuitable
    •         Action upon Timer Expiry:(超时后续动作)
      •         Go to RRC-IDLE
  •         Timer: T302
    •         Start Point:起始点
      •         Upon reception of RRCReject while        performing RRC connection establishment or resume,
      •         Upon reception of RRCRelease with        waitTime
    •         Stop Point:(结束点)
      •         Upon entering RRC-CONNECTED or RRC-IDLE
      •         Upon cell re-selection
      •         Upon reception of RRCReject message
    •         Action upon Timer Expiry:超时后续动作)
      •         Inform upper layers about barring        alleviation
  •         Timer: T304
    •         Start Point:起始点
      •         Upon detecting physical layer problems for        the SpCell i.e. upon receiving N310 consecutive        out-of sync indications from lower layers
    •         Stop Point:(结束点)
      •         Upon receiving N311 consecutive in-sync indications        from lower layers for the SpCell,
      •         Upon receiving RRCReconfiguration with        reconfiguration With Sync for that cell group, and upon initiating the        connection re-establishment procedure.
      •         Upon SCG release, if the T310 is        kept in SCG
      •         If the T310 is kept in MCG: If        security is not activated: go to RRC_IDLE else:        initiate the connection re-establishment procedure
      •         If the T310 is kept in SCG,        Inform E-UTRAN/NR about the SCG radio link        failure by initiating the SCG failure information procedure as        specified in 5.7.3 of specification 38.331
  •         Timer: T311
    •         Start Point:起始点
      •         Upon initiating the RRC connection reestablishment procedure
    •         Stop Point:(结束点)
      •         Upon selection of a suitable NR cell        or a cell using another RAT
      •         Enter RRC_IDLE
  •         Timer: T319
    •         Start Point:起始点
      •         Upon transmission of RRCResumeRequest
    •         Stop Point:(结束点)
      •         Upon reception of RRCResume, RRCSetup,        RRCRelease, RRCRelease with suspendConfig or RRCReject message, cell        re-selection
      •         Perform the actions as specified in 5.3.13.5 of        3GPP specification 38.331
  •         Timer: T320
    •         Start Point:起始点
      •         Upon reception of t320
      •         upon cell (re)selection to NR from another        RAT with validity time configured for dedicated priorities (in        which case the remaining validity time is applied)
    •         Stop Point:(结束点)
      •         Upon entering RRC-CONNECTED,
      •         Upon reception of RRC Release,        when PLMN selection is performed on request by NAS
      •         Upon cell (re)selection to another RAT (in        which case the timer is carried on to the other RAT)
      • Discard the cell re-selection priority        information provided by dedicated signalling
  •         Timer: T321
    •         Start Point:起始点
      •         Upon receiving measConfig including        a reportConfig with the purpose set to report CGI
    •         Stop Point:(结束点)
      •         Upon acquiring the information needed to set        all fields of cgiinfo
      •         Upon receiving measConfig that        includes removal of the reportConfig with the purpose        set to reportCGI
      •         upon detecting that a cell is not        broadcasting SIB1
      •         Initiate the measurement reporting procedure,        stop performing the related measurements and remove the corresponding measId
  •         Timer: T325
    •         Start Point:起始点
      •         Upon reception of RRCRelease message        with deprioritisationTimer
      •         Stop deprioritisation of all    frequencies or NR signalled by RRCRelease
  •         Timer: T380
    •         Start Point:起始点
      •         Upon reception of RRCRelease including suspendConfig
    •         Stop Point:(结束点)
      •         Upon reception of RRCResume,        RRCSetup or RRCRelease
      •         Perform the actions as specified in 5.3.13 of        3GPP 38.331
  •         Timer: T390
    •         Start Point:起始点
      •         When access attempt is barred at        access barring check for an Access Category
      •         The UE shall maintain one instance of this        timer per Access Category
    •         Stop Point:(结束点)
      •         As specified in 5.3.14.3 of 3GPP 38.331
      •         Perform the actions as specified in        5.3.14.4  of 3GPP 38.331
  •         Timer: T3xx
    •         Start Point:起始点
      •         Upon transmitting UEAssistanceInformation message        with DelayBudgetReport
    •         Stop Point:(结束点)
      •         Upon initiating the connection re-establishment        procedures
      •         No action.
RRC常量和计数器计数与否或针对特定事件尝试。计数器用字母“n”表示,后面跟着3个数字。例如 n310。
  •         N310: Maximum number of consecutive “out-of-sync” indications   for the PCell received from lower layers
    •         Reset
      •         Upon  reception of “insync” indication     from lower layers
      •         Upon receiving RRCReconfiguration with reconfigurationWithSync for     that cell group
      •         Upon initiating the connection reestablishment     procedure
    •         Incremented
      •         Upon reception of “out-of-sync” from    lower layer while the timer T310 is stopped
    •         When reaching max value
      •         Start timer T310
  •         N311: Maximum number of consecutive “in-sync” indications   for the PCell received from lower layers
    •         Reset
      •         Upon reception of “outof-sync” indication     from lower layers
    •         Incremented
      •         Upon reception of the “in-sync”from   lower layer while the timer T310 is  running
      •         Stop the timer T310
原文来自:http://www.techplayon.com/5g-nr-rrc-timers-counters-and-constants/
    Mr Kang
    原始天尊
    积分 104731
    帖子 8513
    威望 1621564 个
    礼品券 11319 个
    专家指数 23981
    注册 2007-3-13
    发表于 2020-04-05 16:10:28  只看楼主
    t319是rrc的挂起,t320到异系统的重选!t321是anr中的cgi上报,t380释放挂起的rrc,t390是小区rrc禁止链接(bar)的时间 。
    牧羊小童
    积分 6337
    帖子 355
    威望 2507 个
    专家指数 23
    注册 2008-11-21
    专业方向  核心网
    发表于 2020-12-07 22:38:04
    学习了,感谢分享
    当前时区 GMT+8, 现在时间是 2024-04-25 19:27:24
    Processed in 0.276938 second(s), 19 queries , Gzip enabled
