本次TD-LTE无锡华庄簇异频组网涉及的主要无线参数如下:
Parameter Name
Parameter Description
ueMeasurementsActive
Activates or deactivates A5/B2 measurements on EUTRAN inter-frequencies, GERAN, UTRA and CDMA2000 frequencies for mobility purposes.
a1ThresholdRsrpPrim
The Reference Signal Received Power (RSRP) threshold value for the primary eventA1.
a2ThresholdRsrpPrim
The primary Reference Signal Received Power (RSRP) threshold value for eventA2. Used only when triggerQuantityA2Prim is set to RSRP.Primary and secondary measurement attributes refer to the option to use different settings for two simultaneous measurements for eventA2.
a5Threshold1Rsrp
The Reference Signal Received Power (RSRP) threshold1 value for eventA5.
a5Threshold2Rsrp
The Reference Signal Received Power (RSRP) threshold2 value for eventA5.
hysteresisA1Prim
The hysteresis value for the primary eventA1 measurement.
hysteresisA2Prim
The hysteresis value for the primary eventA2 measurement. Primary and secondary measurement parameters refer to the option to use different settings for two simultaneous measurements for eventA2.
hysteresisA5
The hysteresis value for the eventA5 measurement.
timeToTriggerA1Prim
The time-to-trigger value for the primary eventA1 measurement.
timeToTriggerA2Prim
The time-to-trigger value for the primary eventA2 measurement. Primary and secondary measurement parameters refer to the option to use different settings for two simultaneous measurements for eventA2.
timeToTriggerA5
The time-to-trigger value for eventA5. This attribute is modified by SON function HoOscCtrlRel.
...........篇幅有限,更多精彩请关注下方
TD-LTE异频组网.pdf
