NB-IOT protocol collection
1. NB-IOT基本概念
Ø Improved indoor coverage, support for massive number of low throughput devices, low delay sensitivity, ultra low device cast, low device power consumption
Ø NB-IOT should support 3 different modes of operation:
ü ‘Stand-alone operation’ utilizing for example the spectrum currently being used by GERAN systems as a replacement of one or more GSM carriers, as well as scattered spectrum for potential IoT deployment.
ü ‘Guard band operation’ utilizing the unused resource blocks within a LTE carrier’s guard-band
ü ‘In-band operation’ utilizing resource blocks within a normal LTE carrier
Ø 180kHz UE RF bandwidth for both downlink and uplink
Ø 上行支持15kHz和3.75kHz两种subcarrier spacing;下行仅支持15kHz 的sub-carrier spacing
ü 3.75kHz 只支持single-Tone; 可以提供更大的覆盖,CP较长,对timing要求放松了;
ü 更小的功耗
Ø 仅支持type-B half-duplex FDD operation(type-B定义参考3GPP 36.211 R13 chapter 6.2.5)
Ø NB-IOT vs eMTC vs legacy LTE
| LTE R9 | NB-IoT |
系统带宽 | 1.4M/3M/5M/10M/15M/20M | 200kHz |
工作模式 | full duplex FDD/TDD | half-duplex FDD |
最大传输速率 | DL: 150Mbps; UL 50Mbps | DL/UL: < 200kbps |
频带部署方式 | LTE授权频段 | 带内,带外,保护带 三种部署方式 |
覆盖范围(MCL) | ~145dB | 164dB |
子载波间隔 | DL/UL: 15kHz | DL: 15kHz, UL: 15kHz or 3.75kHz |
传输模式 | TM1-TM9 | TM1/TM2 (单天线或双天线发送分集) |
同步信号 | PSS/SSS | NPSS/NSSS,构造以及相对间隔都与R9 PSS/SSS不同 |
随机接入 | Preamble/RAR/MSG3/MSG4 | NPRACH/NPDSCH |
解调信号 | DL: CRS UL: DMRS | DL: NRS UL: NDMRS |
上下行信道探测 | 下行CSI, 上行SRS | 没有CSI, 没有SRS |
下行数据信道 | PDSCH | NPDSCH |
QPSK, 16QAM, 64QAMP | QPSK |
1/3 turbo coding | 1/3 Tail biting convolutional coding |
单子帧传输一个传输块 | 单个或多个子帧传输一个传输块 |
下行控制信道 | PDCCH | NPDCCH |
和PDSCH在同一个子帧,占用前几个OS | 占用单独的下行子帧,类似于EPDCCH |
DCI Format 0/1/1A/2/2A/3/3A… | DCI Format N0/N1/N2 |
上行数据信道 | PUSCH | NPUSCH |
15kHz sub-carrier spacing | 15kHz or 3.75kHz sub-carrier spacing |
1/3 turbo coding | 1/3 turbo coding |
单子帧传输一个传输块 | 以Resource Unit(可以跨多个子帧)作 为传输块的传输单位 |
UL-SCH和UCI在同一个子帧发送 | UL-SCH 和 UCI 在不同子帧发送 |
省电技术 | DRX | PSM, eDRX |
...........篇幅有限,更多精彩请关注下方
LTE-NB-IOT-协议介绍.pdf
