最近在调试软件无线电平台之间的互联互通,成功调通了Amari MME + OAI eNB + srsUE。不清楚这些SDR LTE平台的可以点击我的博客了解 http://blog.csdn.net/jxwxg/article/details/53026659。
调通之后,我分别抓取了Amari MME侧信令流程Log,OAI eNB侧的信令流程Log和srsUE侧信令流程Log。主要包括eNB与MME的信令交互,UE随机接入,鉴权等信令交互。
欢迎有需要的朋友下载。下载之后建议使用notepad++打开。
SDR LTE信令流程Log.zip
Log信息示例如下所示
22:02:43.068 [MAC ] Info [00000] Resetting MAC
22:02:43.068 [PHY ] Info [00000] PHY: Configuring UL parameters
22:02:43.068 [PHY ] Info [00000] Setting new params worker_id=0, pregen_disabled=0
22:02:43.068 [MAC ] Info [00000] Waiting PHY to synchronize with cell
22:02:43.068 [PHY ] Info [00000] Setting new params worker_id=1, pregen_disabled=0
22:02:43.068 [RRC ] Info Set MAC main config: harq-MaxReTX=5, bsr-TimerReTX=2560, bsr-TimerPeriodic=-1
22:02:43.068 [RF ] Warning Late
22:02:43.265 [RF ] Warning Late
22:02:43.365 [RF ] Warning Late
22:02:43.465 [RF ] Warning Late
22:02:44.112 [RLC ] Info BCCH BCH message received.
0000: 43 d4 00
22:02:44.112 [RRC ] Info BCCH BCH message received.
0000: 43 d4 00
22:02:44.112 [RRC ] Info BCCH BCH message Stack latency: 20 us
22:02:44.112 [RRC ] Info MIB received BW=5 MHz
22:02:44.643 [RF ] Warning Late
22:02:44.899 [RF ] Warning Late
22:02:45.000 [RF ] Warning Late
22:02:45.100 [RF ] Warning Late
22:02:45.101 [PHY ] Info [00000] SYNC: Cell found. Synchronizing...
22:02:45.113 [RRC ] Info Detected 1 out-of-sync from PHY. Starting T310 timer
22:02:45.121 [PHY ] Info [00000] SYNC: Decoding MIB...
22:02:45.121 [PHY ] Info [00000] SYNC: DONE, TTI=570, sfn_offset=1
22:02:45.131 [RRC ] Info Detected 1 in-sync from PHY. Stopping T310 timer
22:02:45.169 [MAC ] Info [00619] BSR: Configured timer reTX 2560 ms
22:02:45.169 [MAC ] Info [00619] BSR: QUEUE status: 0 (0), 0 (0), 0 (0), 0 (0), 0 (0), 0 (0),
22:02:45.174 [MAC ] Info [00624] SCHED: Searching for DL grant for SI-RNTI window_st=645, window_len=1
22:02:45.196 [PHY ] Info [00645] PDCCH: DL DCI Format1A cce_index= 0, L=4, n_data_bits=25, hex=[8a c2 15 00 ]
22:02:45.196 [PHY ] Info [00645] PDSCH: l_crb= 4, harq=0, tbs=18, mcs=0, rv=1, crc=OK, snr=10.0 dB, n_iter=2, dec_time= 35 us
22:02:45.196 [RLC ] Info BCCH TXSCH message received.
0000: 40 40 04 03 00 01 00 00 e0 0c 14 60 00 82 80 04
0010: 02 4f
22:02:45.196 [RRC ] Info BCCH DLSCH message received.
0010: 02 4f
22:02:45.196 [RRC ] Info BCCH DLSCH message Stack latency: 10 us
22:02:45.196 [RRC ] Info SIB1 received, CellID=3584, si_window=20, sib2_period=8
22:02:45.196 [MAC ] Info [00646] DL 8: reTX tbs=18, rv=1, ack=OK, ndi=0 (0), tti=645 (0)
22:02:45.284 [MAC ] Info [00734] SCHED: Searching for DL grant for SI-RNTI window_st=800, window_len=20
22:02:45.366 [PHY ] Info [00815] PDCCH: DL DCI Format1A cce_index= 0, L=4, n_data_bits=25, hex=[8a c6 15 00 ]
22:02:45.366 [PHY ] Info [00815] PDSCH: l_crb= 4, harq=0, tbs=32, mcs=0, rv=1, crc=OK, snr=10.3 dB, n_iter=1, dec_time= 20 us
22:02:45.366 [RLC ] Info BCCH TXSCH message received.
0000: 00 80 0f 99 bd 64 80 00 02 08 f8 00 20 10 08 04
0010: 02 4f f9 57 96 de c0 0e 11 1f ec 07 c0 20 00 00
22:02:45.366 [RRC ] Info BCCH DLSCH message received.
22:02:45.366 [RRC ] Info BCCH DLSCH message Stack latency: 8 us
22:02:45.366 [RRC ] Info SIB2 received
22:02:45.366 [RRC ] Info Set RACH ConfigCommon: NofPreambles=64, ResponseWindow=10, ContentionResolutionTimer=48 ms
22:02:45.366 [PHY ] Info [00815] PHY: Configuring UL parameters
22:02:45.366 [PHY ] Info [00815] Setting new params worker_id=0, pregen_disabled=0
22:02:45.366 [PHY ] Info [00815] Setting new params worker_id=1, pregen_disabled=0
22:02:45.366 [RRC ] Info Set PUSCH ConfigCommon: HopOffset=0, RSGroup=0, RSNcs=1, N_sb=1
22:02:45.366 [RRC ] Info Set PUCCH ConfigCommon: DeltaShift=1, CyclicShift=0, N1=32, NRB=1
22:02:45.366 [RRC ] Info Set PRACH ConfigCommon: SeqIdx=0, HS=no, FreqOffset=2, ZC=1, ConfigIndex=0
22:02:45.366 [RRC ] Info Set SRS ConfigCommon: BW-Configuration=0, SF-Configuration=0, ACKNACK=no
22:02:45.366 [RRC ] Info Set Constants and Timers: N310=20, N311=1, t301=1000, t310=1000, t311=10000
22:02:45.366 [RRC ] Info Sending RRC Connection Request on SRB0
22:02:45.366 [PDCP] Info TX SRB0 SDU, do_security = false
0000: 50 00 00 00 3e 86
22:02:45.366 [RLC ] Info SRB0 Tx SDU
22:02:45.366 [MAC ] Info [00816] DL 8: reTX tbs=32, rv=1, ack=OK, ndi=0 (0), tti=815 (0)
22:02:45.367 [MAC ] Info [00817] BSR: Triggered REGULAR BSR for single LCID=0
22:02:45.367 [MAC ] Info [00817] BSR: Need to send sr: sr_is_sent=true, reset_sr=false, tti=817, next_tx_tti=0
22:02:45.367 [MAC ] Info [00817] SR: PUCCH not configured. Starting RA procedure
22:02:45.367 [MAC ] Info [00817] RA: INIT: Starting PRACH by MAC order
22:02:45.749 [MAC ] Info [01199] BSR: QUEUE status: 6 (6), 0 (0), 0 (0), 0 (0), 0 (0), 0 (0),
22:02:45.768 [PHY ] Info [01217] PRACH: Transmitted preamble=1, CFO=-0.28 KHz, tx_time=0.434233
22:02:45.769 [MAC ] Info [01218] RA: PDCCH: seq=1, ra-rnti=2, ra-tti=1221
22:02:45.776 [PHY ] Info [01225] PDCCH: DL DCI Format1A cce_index= 4, L=4, n_data_bits=25, hex=[89 60 11 00 ]
22:02:45.776 [PHY ] Info [01225] PDSCH: l_crb= 4, harq=0, tbs=7, mcs=0, rv=0, crc=OK, snr=9.9 dB, n_iter=1, dec_time= 17 us
22:02:45.776 [PHY ] Info [01225] PHY: Set TA RAR: ta_cmd: 1, n_ta: 16, ta_usec: 0.5
22:02:45.776 [MAC ] Info [01225] RA: Rx: RAPID=1, TA=1
22:02:45.778 [RLC ] Info SRB0 Complete SDU scheduled for tx. Stack latency: 411636 us
22:02:45.778 [RLC ] Info TX SRB0, Transparent Mode PDU
22:02:45.778 [MAC ] Info [01227] SDU: rlc_buffer=6, allocated=6/17, max_sdu_sz=-1, remaining=11
