!****** BSC R9.1(UM4&EC4) AXE810 Gb interface DT *******!
!1.open GPRS function!
SYPAC:ACCESS=ENABLED,PSW=PSW2PAR;
DBTRI;
DBTSC:TAB=AXEPARS, SETNAME=CME20BSCF , NAME= GPRS, VALUE= 1;
DBTSC:TAB=AXEPARS, SETNAME=CME20BSCF , NAME= MEASRESREC, VALUE= 1; !needed!
DBTSC:TAB=AXEPARS, SETNAME=CME20BSCF , NAME= XRANGESUBCELL, VALUE= 1; !needed!
DBTSC:TAB=AXEPARS, SETNAME=CME20BSCF , NAME= XRANGECELL, VALUE= 1; !needed!
DBTSC:TAB=AXEPARS, SETNAME=CME20BSCF , NAME= GBCAPACITY, VALUE= 128;
DBTRE:COM;
SYPAC:ACCESS=DISABLED;
!exchange properties change!
!you should confirm BSSRELEASE-90 and compatible with cell MO!
RAEPP:ID=ALL;
RAEPC:PROP=ALPHA-0;
RAEPC:PROP=CHCODING-2;
RAEPC:PROP=GPRSCHALLOC-0;
RAEPC:PROP=GSINTEREXIST-NO;
RAEPC:PROP=ONDEMANDGPHDEV-20;
RAEPC:PROP=GPRSNWMODE-2;
RAEPC:PROP=GPRSPRIO-0;
!2.Gb HW data!
!2.1 size alteration for RP used PCU and DIP!
SAAEP:SAE=807,BLOCK=RPDI;!NI=SAE(304*4)+100!
SAAEP:SAE=304;
SAAEP:SAE=1822;!NI=(SAE304)!
SAAEP:SAE=1823;
SAAEP:SAE=0;
SAAEP:SAE=51;
SAAII:SAE=515,BLOCK=DIPRTG, NI=4;
SAAII:SAE=529,BLOCK=ETRTG, NI=4;
SAAII:SAE=500,BLOCK=RTGLT, NI=128;
SAAII:SAE=500,BLOCK=HIDRTG, NI=4;
!2.2 RP & EM & SNT!
!RP4!
DBTRI;
DBTSI:TAB=RPSRPBSPOS,RPADDR=206,BRNO=3,MAGNO=0,SLOTNO=0,BUSCONN=YES;
DBTSI:TAB=RPSRPBSPOS,RPADDR=207,BRNO=3,MAGNO=0,SLOTNO=19,BUSCONN=YES;
DBTRE:COM;
!RPP!
DBTRI;
DBTSI:TAB=RPSRPBSPOS,RPADDR=34,BRNO=3,MAGNO=0,SLOTNO=3,BUSCONN=NO !RPP!
DBTSI:TAB=RPSRPBSPOS,RPADDR=35,BRNO=3,MAGNO=0,SLOTNO=15,BUSCONN=NO !RPP!
DBTSI:TAB=RPSRPBSPOS,RPADDR=226,BRNO=7,MAGNO=0,SLOTNO=3,BUSCONN=NO !RPP!
DBTSI:TAB=RPSRPBSPOS,RPADDR=227,BRNO=7,MAGNO=0,SLOTNO=15,BUSCONN=NO !RPP!
DBTRE:COM;
!here RP 34,35,226,227 are in same magazine, RP 206,207 in other magazine for controlled ETC5 EM!
!here ignore RPPS1's controlled RP4 definition!
EXRPI:RP=206,RPT=207,TYPE=RP4S1A;!ETC/TRA!
EXRPI:RP=34, TYPE=RPPS1; !PCU!
EXRPI:RP=35, TYPE=RPPS1; !PCU!
EXRPI:RP=226,TYPE=RPPS1; !PCU!
EXRPI:RP=227,TYPE=RPPS1; !PCU!
!RP OS SWdefinition!
EXRUI:RP=206,RPT=207,SUID=" 1/CAA 135 004/RPFDR3A01";
EXRUI:RP=206,RPT=207,SUID=" 1/CAA 135 005 R1A02";
EXRUI:RP=206,RPT=207,SUID=" 1/CAA 135 2517/RPMM R1A01";
EXRUI:RP=206,RPT=207,SUID=" 1/CAA 135 2518/RPMBHR1C02";
EXRUI:RP=206,RPT=207,SUID=" 1/CAA 135 2509/REXR3B01";
!RP application SW definition!
EXRUI:RP=206,RPT=207,SUID=" 1/CAA 135 3024/ETRTGR3A02";
EXRUI:RP=206,RPT=207,SUID=" 1/CAA 135 3024/ETRBLTR3A02";
!for RPPS1 RP34,35,226,227 SW!
EXRUI:RP=,SUID="9000/CXC 146 03R1A08 ";
EXRUI:RP=,SUID="9000/CXC 146 05R1A03 ";
EXRUI:RP=,SUID="9000/CXC 146 07R1A03 ";
EXRUI:RP=,SUID="9000/CXC 146 19R2C01 ";
EXRUI:RP=,SUID="CXC 146 1058R1A02 ";
EXRUI:RP=,SUID="CXC 146 1002R3A01 ";
EXRUI:RP=,SUID="CXC 146 1057R1A01 ";
EXRUI:RP=,SUID="CXC 146 1000R9B01 ";
!EM!
EXEMI:EQM=RGSERV-0, rp=34,EM=0;
EXEMI:EQM=RTGB-0,rp=34,EM=1;
EXEMI:EQM=RTGPHDV-0&&-63, rp=34,EM=2;
EXEMI:EQM=RGRLC-0,rp=34,EM=3;
EXEMI:EQM=RGSERV-1, rp=35,EM=0;
EXEMI:EQM=RTGB-1,rp=35,EM=1;
EXEMI:EQM=RTGPHDV-64&&-127,rp=35,EM=2;
EXEMI:EQM=RGRLC-1,rp=35,EM=3;
!MUX34!
GDCOI:UNIT=MUX34-A-8,AP=XM-0-1-1,VAR=0;
GDCOI:UNIT=MUX34-B-8,AP=XM-0-1-12,VAR=0;
!MUX3!
GDCOI:UNIT=MUX3-A-4, AP=MUX34-8-0,VAR=0;
GDCOI:UNIT=MUX3-B-4, AP=MUX34-8-0,VAR=0;
!SNT!
NTCOI:SNT=RTGPHDV-0, SNTP=MUX3-4-1,SNTV=1;
NTCOI:SNT=RTGPHDV-1, SNTP=MUX3-4-2,SNTV=1;
NTCOI:SNT=RTGPHDV-2, SNTP=MUX3-4-13,SNTV=1;
NTCOI:SNT=RTGPHDV-3, SNTP=MUX3-4-14,SNTV=1;
!devices!
EXDUI:DEV=RTGPHDV-0&&-31;
EXDUI:DEV=RTGPHDV-32&&-63;
EXDUI:DEV=RTGPHDV-64&&-95;
EXDUI:DEV=RTGPHDV-96&&-127;
EXDAI:DEV=RTGPHDV-0&&-31;
EXDAI:DEV=RTGPHDV-32&&-63;
EXDAI:DEV=RTGPHDV-64&&-95;
EXDAI:DEV=RTGPHDV-96&&-127;
!below is DIP related EM,SNT&devices!
!only RPB handler RP4(only OS SW loaded) no EM,but here has ETRTG application,so ETRTG EM need to be defined!
EXEMI:RP=206,RPT=207,EM=14,EQM=ETRTG-0&&-31;
GDCOI:UNIT=MUX3-A-7, AP=MUX34-2-3,VAR=0;
GDCOI:UNIT=MUX3-B-7, AP=MUX34-2-3,VAR=0;
NTCOI:SNT=ETRTG-0,SNTP=MUX3-7-14,SNTV=1;
EXDUI:DEV=RTGLT-1&&-31;
EXDAI:DEV=RTGLT-0&&-31;
DTDII:DIP=0RTG, SNT=ETRTG-0;
DTIDC:DIP=0RTG,INACT=0,MODE=0,MULTFS=00,CRC=0;
DTFSC:DIP=0RTG,FAULT=1&&4,ACL=A3;
DTFSI:DIP=0RTG,FAULT=1&&4;
DTQSC:DIP=0RTG,SF,SFL=5,ACL=A2,TI=24;
DTQSC:DIP=0RTG,ES,ESL=120,RESL=0,ACL1=A2,SDEGR=0000;
DTQSC:DIP=0RTG,SES,SESL=15,ACL1=A2,SDEGR=0000,RSESL=0;
DTQSI:DIP=0RTG,SF;
DTQSI:DIP=0RTG,ES;
DTQSI:DIP=0RTG,SES;
!3.PCU load sharing for Gb working stable!
!*** Define a RPIG ***!
DBTSP:TAB=RPSRPIGROUPS;
DBTRI;
DBTSI:TAB=RPSRPIGROUPS,GROUP=GPRSPCU ,GROUPNO=1;
DBTRE:COM;
!*** Connect all RPs to be used with ethernet to the group ***!
DBTSP:TAB=RPSRPIRPS;
DBTRI;
DBTSI:TAB=RPSRPIRPS,RPADDR=85,GROUP=GPRSPCU;
DBTSI:TAB=RPSRPIRPS,RPADDR=35,GROUP=GPRSPCU;
DBTSI:TAB=RPSRPIRPS,RPADDR=226,GROUP=GPRSPCU;
DBTSI:TAB=RPSRPIRPS,RPADDR=227,GROUP=GPRSPCU;
DBTRE:COM;
!*** Deblock RP NET A and NET B in RPIG ***!
BLRCi:GROUP=GPRSPCU, NET=A;
BLRCi:GROUP=GPRSPCU, NET=B;
BLRCE:GROUP=GPRSPCU, NET=A;
BLRCE:GROUP=GPRSPCU, NET=B;
!NOTE: THE RP SHOULD BLOCK AND DEBLOCK!
!THE GB SHOULD BE BLOCK AND EARSED!
!*** CHECK IF ETHERNET IS WORKING ***!
! ** CHECK WHICH RPs ARE UP OR DOWN **!
DBTSP:TAB=RPSRPISUPERVS,GROUP=GPRSPCU,RPADDR1=34,RPADDR2=35,NET=A;
DBTSP:TAB=RPSRPISUPERVS,GROUP=GPRSPCU,RPADDR1=34,RPADDR2=35,NET=B;
DBTSP:TAB=RPSRPISUPERVS,GROUP=GPRSPCU,RPADDR1=226,RPADDR2=227,NET=A;
DBTSP:TAB=RPSRPISUPERVS,GROUP=GPRSPCU,RPADDR1=226,RPADDR2=227,NET=B;
! ** CHECK WHICH RPs HAVE STATE U **!
DBTSP:TAB=RPSRPISUPERVS,GROUP=GPRSPCU,STATE=UP;
! ** CHECK WHICH RPs HAVE STATE DOWN **!
DBTSP:TAB=RPSRPISUPERVS,GROUP=GPRSPCU,STATE=DOWN;
rrpcp;
Test system;
Print var rtgphdv 0-:21;! The vale must = 2!
end test;
!4.Gb interface data!
!NSE & NSVC data!
blodI:dev=rtgphdv-0&&-28;
blodI:dev=rtgphdv-64&&-92;
rrgbp;
RRNEI:NSEI=32; ! NETWORK SERVICE ENTITY !
RRNSI:NSVCI=3201, DLCI=163, DEV=RTGLT-1, NUMDEV=29;! NSVCI CONNECTION !
RRNSI:NSVCI=3202, DLCI=164, DEV=RTGLT-33, NUMDEV=29;! NSVCI CONNECTION !
RRVBE:NSVCI=3201;
RRVBE:NSVCI=3202;
RRGBP;!!
!cell data!
RLGSC:CELL=C1AG10, FPDCH=4;
RLGSI:CELL=C1AG10;
RLGRP:CELL=C1AG10;!conform cell GPRS function normal!
