==============================代码开始=============================
<!DOCTYPE html>
<html>
<head>
<title>ArcGIS Server Map Cache Example (Direct Access)</title>
<meta http-equiv="Content-Type" c>
<link rel="stylesheet" href="OpenLayers-2.13.1/theme/default/style.css" type="text/css">
<link rel="stylesheet" href="style.css" type="text/css">
<script src="../lib/OpenLayers.js"></script>
<script src="../lib/OpenLayers/Layer/ArcGISCache.js" type="text/javascript"></script>
<script type="text/javascript">
/* First 4 variables extracted from conf.xml file */
/* Tile layers & map MUST have same projection */
var proj = 'EPSG:4326';
/* Layer can also accept serverResolutions array
* to deal with situation in which layer resolution array & map resolution
* array are out of sync*/
var mapResolutions = [
1.40625,
0.703125,
0.3515625,
0.17578125,
0.087890625,
0.0439453125,
0.02197265625,
0.010986328125,
0.0054931640625,
0.00274658203125,
0.001373291015625,
0.0006866455078125,
0.00034332275390625,
0.000171661376953125,
0.0000858306884765625,
0.00004291534423828125,
0.000021457672119140625,
0.0000107288360595703125,
0.00000536441802978515625,
0.000002682209014892578125,
0.0000013411045074462890625,
0.00000067055225372314453125
/* For this example this next line is not really needed, 256x256 is default.
* However, you would need to change this if your layer had different tile sizes */
var tileSize = new OpenLayers.Size(256, 256);
/* Tile Origin is required unless it is the same as the implicit map origin
* which can be affected by several variables including maxExtent for map or base layer
var agsTileOrigin = new OpenLayers.LonLat(-180, 90);
/* This can really be any valid bounds that the map would reasonably be within */
/*var mapExtent = new OpenLayers.Bounds
(293449.454286,4307691.661132,314827.830376,4323381.484178); */
var mapExtent = new OpenLayers.Bounds(-180, -90, 180, 90);
var aerialsUrl = 'http://localhost:8080/data/_alllayers';
var map;
function init() {
map = new OpenLayers.Map('map', {
maxExtent: mapExtent,
controls: [
new OpenLayers.Control.Navigation(),
new OpenLayers.Control.LayerSwitcher(),
new OpenLayers.Control.PanZoomBar(),
var baseLayer = new OpenLayers.Layer.ArcGISCache('Aerials', aerialsUrl, {
tileOrigin: agsTileOrigin,
resolutions: mapResolutions,
sphericalMercator: false,
useArcGISServer: false,
isBaseLayer: true,
type: 'jpg',
projection: proj
map.addLayers([baseLayer]);
//map.zoomToExtent(new OpenLayers.Bounds(295892.34, 4308521.69, 312825.71, 4316988.37));
map.setCenter(new OpenLayers.LonLat(103,31).transform
(map.displayProjection, map.getProjectionObject()), 3);
</script>
</head>
<body >
<h1 id="title">
ArcGIS Server Map Cache Example (Direct Access)</h1>
<div id="tags">
</div>
<p id="shortdesc">
Demonstrates the basic initialization of the ArcGIS Cache layer using a prebuilt
configuration, and direct tile access from a file store.
</p>
<div id="map" class="smallmap">
</div>
<div id="docs">
<p>
This example demonstrates using the ArcGISCache layer for accessing ESRI's ArcGIS
Server (AGS) Map Cache tiles directly via the folder structure and HTTP. Toggle
the visibility of the AGS layer to demonstrate how the two maps are lined up
correctly.</p>
<h2>
Notes on this Layer</h2>
<p>
It's important that you set the correct values in your layer, and these values will
differ between tile sets. You can find these values for your layer in conf.xml at
the root of your cache. (ie. <a
href="http://serverx.esri.com/arcgiscache/dgaerials/Layers/conf.xml">
http://serverx.esri.com/arcgisca ... /conf.xml</a>)</p>
<p>
For fused map caches this is often
http:<i>ServerName</i>/arcgiscache/<i>MapServiceName</i>/Layers
<br>
For individual layer caches this is often
http:<i>ServerName</i>/arcgiscache/<i>LayerName</i>/Layers
</p>
<h2>
Other Examples
</h2>
<p>
This is one of three examples for this layer. You can also configure this layer
to use <a href="arcgiscache_ags.html">prebuilt tiles from a live server.</a> It
is also possible to let this <a href="arcgiscache_jsonp.html">layer 'auto-configure'
itself using the capabilities json object from the server itself when using a live
ArcGIS server.</a>
</p>
</div>
</body>
</html>
==============================代码结束=============================
第四步:双击打开刚才保存的文件,如果部署正确,则将会显示离线WGS84卫星地图的浏览结果,如下图所示。
当然,你也可以通过以下网址进行访问,效果也是一样的。
http://localhost:8080/OpenLayers-2.13.1/examples/Example_ArcGIS%20Server.html
以上即是如何将天地图基于OpenLayers在服务器端进行部署的全部过程及示例源码,你可以基于此平台并根据自己的实际需求作进一步开发了。
