网站又没法搜帖子了,怎么回事?404,出现好几天了 在线,9天前提问
怎么下载文件一直失败? 在线,23天前提问
为什么登不进去 在线,49天前提问
服务器又出问题了 在线,90天前提问
签到出现问题几天了 在线,95天前提问
签到出现问题几天了 在线,95天前提问
签到出现问题几天了 在线,95天前提问
为什么不能签到? 在线,97天前提问
签到又有问题了吗 在线,97天前提问
从哪里下载这个监控软件? 在线,107天前提问
能同时发本5g的书么? 在线,108天前提问
Keysight World: Innovate全球创新云峰会直播链接是. 在线,129天前提问
请问直播链接是? 在线,129天前提问
请问24号的keysight的会议地址在哪里呀 在线,149天前提问
ims失败原因值 在线,172天前提问
UE RRC Inactive处于以下哪些管理状态 在线,184天前提问
作用:The purpose of the GUTI is to provide an unambiguous identification of the UE that does not reveal the UE or the user's permanent identity in the Evolved Packet System (EPS).
分配:It also allows the identification of the MME and network. It can be used by the network and the UE to establish the UE's identity during signalling between them in the EPS. See 3GPP TS 23.401 [72].
The GUTI has two main components:
-one that uniquely identifies the MME which allocated the GUTI; and
-one that uniquely identifies the UE within the MME that allocated the GUTI.
Within the MME, the mobile shall be identified by the M-TMSI.
The Globally Unique MME Identifier (GUMMEI) shall be constructed from the MCC, MNC and MME Identifier (MMEI).
The MMEI shall be constructed from an MME Group ID (MMEGI) and an MME Code (MMEC).
The GUTI shall be constructed from the GUMMEI and the M-TMSI.
For paging purposes, the mobile is paged with the S-TMSI. The S-TMSI shall be constructed from the MMEC and the M-TMSI.
The operator shall need to ensure that the MMEC is unique within the MME pool area and, if overlapping pool areas are in use, unique within the area of overlapping MME pools.
The GUTI shall be used to support subscriber identity confidentiality, and, in the shortened S-TMSI form, to enable more efficient radio signalling procedures (e.g. paging and Service Request).
定义:The format and size of the GUTI is therefore the following:
<GUTI> = <GUMMEI><M-TMSI>,
where <GUMMEI> = <MCC><MNC><MME Identifier>
and <MME Identifier> = <MME Group ID><MME Code>
MCC and MNC shall have the same field size as in earlier 3GPP systems.
M-TMSI shall be of 32 bits length.
MME Group ID shall be of 16 bits length.
MME Code shall be of 8 bits length.
好好读读这段,你要的信息都有。
attach accept中网络侧会维护GUTI值,GUTI可能会变化。
