通信设备厂商技术区
华为技术资料区
» eNodeB Commissioning Guide(V100R005C00_04)(PDF)-EN
komann
积分 103
帖子 18
威望 2973 个
注册 2012-5-5
专业方向 LTE eNB 研发
发表于 2015-01-16 18:04:03
【资料名称】:eNodeB Commissioning Guide(V100R005C00_04)(PDF)-EN
【资料作者】:huawei
【资料日期】:2012-06-29
【资料语言】:英文
【资料格式】:PDF
About This Document.....................................................................................................................ii
1 Changes in eNodeB Commissioning Guide............................................................................1
2 Commissioning Mode..................................................................................................................6
3 eNodeB Commissioning Procedures (Without the SeGW)...................................................9
3.1 Overview of eNodeB Automatic Discovery (Without the SeGW)..................................................................10
3.2 PnP Remote Commissioning (Without the SeGW)..........................................................................................12
3.2.1 Commissioning Procedure......................................................................................................................12
3.2.2 Preparations............................................................................................................................................15
3.2.3 Creating an eNodeB Commissioning Task.............................................................................................29
3.2.4 Starting an eNodeB Commissioning Task...............................................................................................31
3.2.5 Monitoring eNodeB Commissioning.......................................................................................................34
3.2.6 Confirming eNodeB Commissioning Completion..................................................................................38
3.2.7 Checking the Running Status of the eNodeB on the M2000...................................................................39
3.2.8 Commissioning the Antenna System on the M2000...............................................................................42
3.2.9 Commissioning the Environment Monitoring Equipment on the M2000...............................................47
3.2.10 Setting the Maximum Output Power for RRUs or RFUs......................................................................50
3.2.11 Testing the Basic Services of the eNodeB.............................................................................................51
3.2.12 Setting an NE to the NORMAL Mode..................................................................................................52
3.2.13 References to eNodeB Commissioning.................................................................................................53
3.3 Local Commissioning Using a USB Flash Drive (Without the SeGW)...........................................................62
3.3.1 Commissioning Procedure......................................................................................................................62
3.3.2 Preparations............................................................................................................................................65
3.3.3 Downloading and Activating the Software, Data Configuration File, and License File Using a USB Flash
Drive................................................................................................................................................................68
3.3.4 Uploading Data Files..............................................................................................................................72
3.3.5 Creating an eNodeB Commissioning Task.............................................................................................82
3.3.6 Starting an eNodeB Commissioning Task...............................................................................................84
3.3.7 Monitoring eNodeB Commissioning.......................................................................................................87
3.3.8 Confirming eNodeB Commissioning Completion..................................................................................91
3.3.9 Checking the Running Status of the eNodeB on the M2000...................................................................92
3.3.10 Commissioning the Antenna System on the M2000.............................................................................95
3.3.11 Commissioning the Environment Monitoring Equipment on the M2000...........................................100
vi
3.3.12 Setting the Maximum Output Power for RRUs or RFUs....................................................................103
3.3.13 Testing the Basic Services of the eNodeB...........................................................................................104
3.3.14 Setting an NE to the NORMAL Mode................................................................................................105
3.3.15 References to eNodeB Commissioning...............................................................................................106
3.4 Local Commissioning on the LMT(Without the SeGW)...............................................................................115
3.4.1 Commissioning Procedure.....................................................................................................................115
3.4.2 Preparations..........................................................................................................................................118
3.4.3 Downloading and Activating the eNodeB Software and Data Configuration File on the LMT...........121
3.4.4 Downloading the License for eNodeB Commissioning on the LMT....................................................124
3.4.5 Commissioning the Antenna System on the LMT................................................................................124
3.4.6 Commissioning the Environment Monitoring Equipment on the LMT................................................130
3.4.7 Setting the Maximum Output Power for RRUs or RFUs......................................................................132
3.4.8 Handling the eNodeB Alarms on the LMT...........................................................................................133
3.4.9 Checking the Operating Status of the eNodeB on the LMT..................................................................133
3.4.10 Testing the Basic Services of the eNodeB...........................................................................................134
3.4.11 Establishing an OML Between the M2000 and the eNodeB...............................................................135
3.4.12 Setting an NE to the NORMAL Mode................................................................................................138
4 eNodeB Commissioning Procedures (with the SeGW).....................................................139
4.1 Overview of eNodeB Automatic Discovery (with the SeGW)......................................................................142
4.2 PnP Remote Commissioning in Unified Encryption Mode (with the SeGW)...............................................150
4.2.1 Commissioning Procedure.....................................................................................................................150
4.2.2 Preparations..........................................................................................................................................153
4.2.3 Creating an eNodeB Commissioning Task...........................................................................................175
4.2.4 Starting an eNodeB Commissioning Task.............................................................................................177
4.2.5 Monitoring eNodeB Commissioning.....................................................................................................180
4.2.6 Confirming eNodeB Commissioning Completion................................................................................184
4.2.7 Checking the Running Status of the eNodeB on the M2000.................................................................185
4.2.8 Commissioning the Antenna System on the M2000.............................................................................189
4.2.9 Commissioning the Environment Monitoring Equipment on the M2000.............................................193
4.2.10 Setting the Maximum Output Power for RRUs or RFUs....................................................................196
4.2.11 Testing the Basic Services of the eNodeB...........................................................................................197
4.2.12 Setting an NE to the NORMAL Mode................................................................................................198
4.2.13 References to eNodeB Commissioning...............................................................................................199
4.3 PnP Remote Commissioning in Differentiated Encryption Mode (with the SeGW).....................................208
4.3.1 Commissioning Procedure.....................................................................................................................208
4.3.2 Preparations..........................................................................................................................................211
4.3.3 Creating an eNodeB Commissioning Task...........................................................................................229
4.3.4 Starting an eNodeB Commissioning Task.............................................................................................232
4.3.5 Monitoring eNodeB Commissioning.....................................................................................................235
4.3.6 Obtaining an Operator's Device Certificate Manually (with PKI)........................................................239
4.3.7 Confirming eNodeB Commissioning Completion................................................................................243
4.3.8 Checking the Running Status of the eNodeB on the M2000.................................................................244
eNodeB
Commissioning Guide Contents
Issue 04 (2012-06-29) Huawei Proprietary and Confidential
Copyright ? Huawei Technologies Co., Ltd.
vii
4.3.9 Commissioning the Antenna System on the M2000.............................................................................248
4.3.10 Commissioning the Environment Monitoring Equipment on the M2000...........................................252
4.3.11 Setting the Maximum Output Power for RRUs or RFUs....................................................................255
4.3.12 Testing the Basic Services of the eNodeB...........................................................................................256
4.3.13 Setting an NE to the NORMAL Mode................................................................................................257
4.3.14 References to eNodeB Commissioning...............................................................................................258
4.4 Local Commissioning Using a USB Flash Drive in Unified Encryption Mode (with the SeGW)................267
4.4.1 Commissioning Procedure.....................................................................................................................267
4.4.2 Preparations..........................................................................................................................................270
4.4.3 Downloading and Activating the Software, Data Configuration File, and License File Using a USB Flash
Drive..............................................................................................................................................................281
4.4.4 Uploading Data Files............................................................................................................................285
4.4.5 Creating an eNodeB Commissioning Task...........................................................................................295
4.4.6 Starting an eNodeB Commissioning Task.............................................................................................297
4.4.7 Monitoring eNodeB Commissioning.....................................................................................................300
4.4.8 Confirming eNodeB Commissioning Completion................................................................................304
4.4.9 Checking the Running Status of the eNodeB on the M2000.................................................................305
4.4.10 Commissioning the Antenna System on the M2000...........................................................................308
4.4.11 Commissioning the Environment Monitoring Equipment on the M2000...........................................313
4.4.12 Setting the Maximum Output Power for RRUs or RFUs....................................................................316
4.4.13 Testing the Basic Services of the eNodeB...........................................................................................317
4.4.14 Setting an NE to the NORMAL Mode................................................................................................318
4.4.15 References to eNodeB Commissioning...............................................................................................319
4.5 Local Commissioning Using a USB Flash Drive in Differentiated Encryption Mode (with the SeGW)
.............................................................................................................................................................................328
4.5.1 Commissioning Procedure.....................................................................................................................328
4.5.2 Preparations..........................................................................................................................................331
4.5.3 Downloading and Activating the Software, Data Configuration File, and License File Using a USB Flash
Drive..............................................................................................................................................................337
4.5.4 Uploading Data Files............................................................................................................................341
4.5.5 Creating an eNodeB Commissioning Task...........................................................................................351
4.5.6 Starting an eNodeB Commissioning Task.............................................................................................353
4.5.7 Monitoring eNodeB Commissioning.....................................................................................................356
4.5.8 Obtaining an Operator's Device Certificate Manually (with PKI)........................................................360
4.5.9 Confirming eNodeB Commissioning Completion................................................................................365
4.5.10 Checking the Running Status of the eNodeB on the M2000...............................................................365
4.5.11 Commissioning the Antenna System on the M2000...........................................................................369
4.5.12 Commissioning the Environment Monitoring Equipment on the M2000...........................................373
4.5.13 Setting the Maximum Output Power for RRUs or RFUs....................................................................377
4.5.14 Testing the Basic Services of the eNodeB...........................................................................................378
4.5.15 Setting an NE to the NORMAL Mode................................................................................................379
4.5.16 References to eNodeB Commissioning...............................................................................................379
4.6 Local Commissioning on the LMT(with the SeGW).....................................................................................388
viii
4.6.1 Commissioning Procedure.....................................................................................................................388
4.6.2 Preparations..........................................................................................................................................391
4.6.3 Downloading and Activating the eNodeB Software and Data Configuration File on the LMT...........398
4.6.4 Downloading the License for eNodeB Commissioning on the LMT....................................................401
4.6.5 Commissioning the Antenna System on the LMT................................................................................402
4.6.6 Commissioning the Environment Monitoring Equipment on the LMT................................................408
4.6.7 Setting the Maximum Output Power for RRUs or RFUs......................................................................410
4.6.8 Handling the eNodeB Alarms on the LMT...........................................................................................411
4.6.9 Checking the Operating Status of the eNodeB on the LMT..................................................................411
4.6.10 Testing the Basic Services of the eNodeB...........................................................................................412
4.6.11 Establishing an OML Between the M2000 and the eNodeB...............................................................413
4.6.12 Setting an NE to the NORMAL Mode................................................................................................415
5 Appendix....................................................................................................................................417
5.1 eNodeB Binding Using a Bar Code Scanner..................................................................................................418
5.1.1 Printing a Bar Code on the M2000........................................................................................................418
5.1.2 Setting a Bar Code Scanner...................................................................................................................421
5.1.3 Binding the eNodeB by Scanning a Bar Code......................................................................................423
5.2 Triggering Monitoring Device Alarms...........................................................................................................424
5.2.1 Triggering PMU Alarms........................................................................................................................424
5.2.2 Triggering FMU Alarms........................................................................................................................430
5.2.3 Triggering TCU Alarms........................................................................................................................432
5.2.4 Triggering EMU Alarms.......................................................................................................................434
5.3 Checking the Status of Indicators...................................................................................................................436
5.4 Configuring the Default Configuration File...................................................................................................442
5.5 Encrypting Files in the USB Flash Drive.......................................................................................................442
5.6 Data Sheet for eNodeB Commissioning.........................................................................................................445
6 FAQ............................................................................................................................................. 450
6.1 Failing to Identify the USB Flash Drive.........................................................................................................451
6.2 Failing to Read Files in the USB Flash Drive................................................................................................452
6.3 Failing to Activate the Software.....................................................................................................................453
6.4 Failing to Download the Software Based on the Default Configuration File.................................................453
2015-1-16 18:04:03 下载次数: 31
eNodeB Commissioning Guide(V100R005C00_04)(PDF)-EN.pdf
(3.18 MB)
HW LTE TDD System Multiple Antenna Tech
2013-04-02
【没有密码,请勿下载】eRAN3.0 LTE TDD PRACH Planning and Configuration Guide
2012-11-29
LTE Air Interface ISSUE 1.04
2012-05-06
NSN卡塔尔电信实验网报告
2012-05-06
爱立信EPC资料集
2012-05-06
阿朗LTE KPI参数优化测试计划
2012-05-06
[下载] eNodeB Commissioning Guide(V100R005C00_04)(PDF)-EN" tabindex="1">
当前时区 GMT+8, 现在时间是 2024-04-24 00:27:50
Processed in 0.278168 second(s), 15 queries , Gzip enabled
