重复资料回收站
» 诺基亚基站告警解释
诺基亚基站告警解释
apple1765
威望 51 个
注册 2013-12-11
专业方向 通信
发表于 2014-04-16 16:37:36
【资料名称】:基站告警
【资料作者】:诺西
【资料日期】:20090203
【资料格式】:PDF
2.2437600 BCF FAULTY196
2.2447601 BCF OPERATION DEGRADED197
2.2457602 BCF NOTIFICATION198
2.2467604 BTS OPERATION DEGRADED199
2.2477606 RX FAULTY199
2.2487607 TRX OPERATION DEGRADED200
2.2497608 TRX NOTIFICATION200
2.2507609 TRE FAULTY201
2.2517616 OSCILLATOR ADJUSTING TEMPORARILY INTERRUPTED202
2.2527622 CABINET OPEN202
2.2537700 BTS OMU INITIALIZATION203
2.2547701 BCF INITIALIZATION203
2.2557704 PCM FAILURE204
2.2567705 LAPD FAILURE204
2.2577706 BTS O&M LINK FAILURE205
2.2587711 WORKING FULL RATE TCH RATIO BELOW THRESHOLD205
2.2597715 CONTINUOUS RESTARTS OF BCF/TRX206
2.2607716 ACTIVE BCF HW DATABASE DIFFERENCE206
2.2617717 WORKING HALF RATE TCH RATIO BELOW THRESHOLD207
2.2627723 FAILURE IN SENDING SYSTEM INFORMATION TO BTS SIT207
2.2637724 CONFLICT BETWEEN BSS RADIO NETWORK DATABASE A208
2.2647725 TRAFFIC CHANNEL ACTIVATION FAILURE210
2.2657730 CONFIGURATION OF BCF FAILED210
2.2667735 TRX TEST FAILED212
2.2677736 ABIS LOOP TEST FAILED213
2.2687738 BTS WITH NO TRANSACTIONS214
2.2697740 BEATING BTS ALARM214
2.2707741 MEAN HOLDING TIME ABOVE DEFINED THRESHOLD215
2.2717743 MEAN HOLDING TIME BELOW DEFINED THRESHOLD216
2.2727744 EXCESSIVE TCH INTERFERENCE217
2.2737745 CHANNEL FAILURE RATE ABOVE DEFINED THRESHOLD218
2.2747746 CH CONGESTION IN CELL ABOVE DEFINED THRESHOLD219
2.2757753 TRX LOOP TEST FAILED220
2.2767767 BCCH MISSING221
2.2777801 MMI CONNECTED TO BASE STATION222
2.2787805 UNIT TEMPERATURE HIGH222
2.2797808 FAULT IN Q1-INTERFACE OF BCF223
2.2807840 SW DOWNLOAD TO UNIT FAILED223
2.2817861 SERVICE TERMINAL CONNECTED TO ABIS TRANSMISSIO224
2.2827870 CABINET DOOR OPEN225
2.2837890 FAULT IN COOLING FAN225
2.2847900 NO CONNECTION TO TRX226
2.2857939 FORWARD POWER TOO LOW AT TX ANTENNA226
2.2867941 TX ANTENNA PERFORMANCE DEGRADED227
2.2877944 MAIN BRANCH LNA OUT OF ORDER IN ANTENNA FILTER UNI228
2.2887949 DIFFERENCE IN RX LEVELS OF MAIN AND DIVERSITY ANTE228
2.2897990 MAINS BREAKDOWN WITHOUT BATTERY BACK-UP229
2.2907991 POWER SUPPLY FAULT230
2014-4-16 16:37:36 下载次数: 4
基站告警.pdf
(2.83 MB)
TD-SCDMA 基础知识篇
2014-04-16
基站告警.pdf
当前时区 GMT+8, 现在时间是 2024-04-26 16:33:22
Processed in 0.352591 second(s), 15 queries , Gzip enabled
