LTE Identifiers,Following table is based on the document from MNC Group (LTE-Identifier)
ID | Meaning | Description | Structure |
IMSI | International MobileSubscriber Identity | Unique identification ofmobile (LTE) subscriber Network (MME) gets the PLMN of the subscriber | IMSI (not more than 15digits) = PLMN ID + MSIN = MCC + MNC + MSIN |
PLMN ID | Public Land Mobile NetworkIdentifier | Unique identification ofPLMN | PLMN ID (not more than 6digits) = MCC + MNC |
MCC | Mobile Country Code | assigned by ITU | 3 digits |
MNC | Mobile Network Code | assigned by NationalAuthority | 2 or 3 digits |
MSIN | Mobile SubscriberIdentification Number | assigned by operator | 9 or 10 digits |
GUTI | Globally Unique Temporary UEIdentity | To identify a UE between theUE and the MME on behalf of IMSI for security reason | GUTI (not more than 80 bits)= GUMMEI + M-TMSI |
TIN | Temporary Identity used inNext Update | GUTI is stored in TINparameter of UE抯 MM context. TIN indicates which temporary ID willbe used in the next update. | TIN = GUTI |
S-TMSI | SAE Temporary MobileSubscriber Identity | To locally identify a UE inshort within a MME group (Unique within a MME Pool) | S-TMSI (40 bits) = MMEC +M-TMSI |
M-TMSI | MME Mobile SubscriberIdentity | Unique within a MME | 32 bits |
GUMMEI | Globally Unique MME Identity | To identify a MME uniquely in global GUTI contains GUMMEI | GUMMEI (not more than 48bits)= PLMN ID + MMEI |
MMEI | MME Identifier | To identify a MME uniquely within a PLMN Operator commissions at eNBMMEI | MMEI (24 bits) = MMEGI +MMEC |
MMEGI | MME Group Identifier | Unique within a PLMN | 16 bits |
MMEC | MMECode | To identify a MME uniquelywithin a MME Group. S-TMSI contains MMEC8 | 8 bits |
C-RNTI | Cell- Radio NetworkTemporary Identifier | To identify an UE uniquelyin a cell | 0x0001 ~ 0xFFF3 (16 bits) |
IMEI | International MobileEquipment Identity | To identify a ME (MobileEquipment) uniquely | IMEI (15 digits) = TAC + SNR+ CD |
IMEI/SV | IMEI/Software Version | To identify a ME (MobileEquipment) uniquely | IMEI/SV (16 digits) = TAC +SNR + SVN |
ECGI | E-UTRAN Cell GlobalIdentifier | To identify a Cell in global (Globally Unique) EPC can know UE location based of ECGI | ECGI (not more than 52 bits)= PLMN I D+ ECI |
ECI | E-UTRAN Cell Identifier | To identify a Cell within aPLMN | ECI (28 Bits) = eNB ID +Cell ID |
PGWID | PDN GW Identity | To identify a specific PDN GW (P-GW) HSS assigns P-GW for PDN (IP network) connection ofeach UE | IP address (4 bytes) or FQDN(variable length) |
TAI | Tracking Area Identity | To identify Tracking Area Globally uniqueTAI | TAI (not more than 32 bits)= PLMN ID + TAC P-GW |
TAC | Tracking Area Code | To indicate eNB to which Tracking Area the eNBbelongs (per Cell) Unique within a PLMN16 | 16 bits |
TAIList | Tracking Area Identity List | UE can move into the cells included in TAL listwithout location update (TA update) Globally unique | Variablelength |
PDNID | Packet Data Network Identity | To identify an PDN (IP network), that mobile datauser wants to communicate with PDN Identity (APN) is used to determine the P-GW andpoint of interconnection with a PDN With APN as query parameter to the DNS procedures,the MME will receive a list of candidate P-GWs, and then a P-GW is selectedby MME with policy | PDN Identify = APN = APN.NI+ APN.OI (variable length) |
EPSBearer ID | Evolved Packet System BearerIdentifier | To identify an EPS bearer(Default or Dedicated) per an UE4 | 4 bits |
E-RAB ID | E-UTRAN Radio Access BearerIdentifier� | To identify an E-RAB per anUE | 4 bits |
DRBID | Data Radio Bearer Identifier | To identify a DRB per an UE4 | 4 bits |
LBI | Linked EPS Bearer ID | To identify the defaultbearer associated with a dedicated EPS bearer4 | 4 bits |
TEID | Tunnel End Point identifier | To identify the end point ofa GTP tunnel when the tunnel is established | 32 bits |
