» 3gpp R9 V9.0.3
3gpp R9 V9.0.3
yangzhaofeng
积分 2715
帖子 387
威望 -644 个
专家指数 -26
注册 2009-4-25
专业方向 网优
发表于 2013-12-17 14:47:56
如题,3gpp R9 V9.0.3
Contents
Intellectual Property Rights ................................................................................................................................ 2
Foreword ............................................................................................................................................................. 2
Foreword ............................................................................................................................................................. 5
1 Scope ........................................................................................................................................................ 6
2 References ................................................................................................................................................ 6
3 Definitions, symbols, and abbreviations .................................................................................................. 7
3.1 Symbols .............................................................................................................................................................. 7
3.2 Abbreviations ..................................................................................................................................................... 7
4 Synchronisation procedures ..................................................................................................................... 8
4.1 Cell search .......................................................................................................................................................... 8
4.2 Timing synchronisation ...................................................................................................................................... 8
4.2.1 Radio link monitoring ................................................................................................................................... 8
4.2.2 Inter-cell synchronisation ............................................................................................................................. 8
4.2.3 Transmission timing adjustments ................................................................................................................. 8
5 Power control ........................................................................................................................................... 9
5.1 Uplink power control.......................................................................................................................................... 9
5.1.1 Physical uplink shared channel ..................................................................................................................... 9
5.1.1.1 UE behaviour .......................................................................................................................................... 9
5.1.1.2 Power headroom ................................................................................................................................... 12
5.1.2 Physical uplink control channel .................................................................................................................. 12
5.1.2.1 UE behaviour ........................................................................................................................................ 12
5.1.3 Sounding Reference Symbol....................................................................................................................... 14
5.1.3.1 UE behaviour ........................................................................................................................................ 14
5.2 Downlink power allocation .............................................................................................................................. 15
5.2.1 eNodeB Relative Narrowband TX Power restrictions ................................................................................ 16
6 Random access procedure ...................................................................................................................... 16
6.1 Physical non-synchronized random access procedure ...................................................................................... 17
6.1.1 Timing ........................................................................................................................................................ 17
6.2 Random Access Response Grant ...................................................................................................................... 18
7 Physical downlink shared channel related procedures ........................................................................... 19
7.1 UE procedure for receiving the physical downlink shared channel ................................................................. 19
7.1.1 Single-antenna port scheme ........................................................................................................................ 22
7.1.2 Transmit diversity scheme .......................................................................................................................... 23
7.1.3 Large delay CDD scheme ........................................................................................................................... 23
7.1.4 Closed-loop spatial multiplexing scheme ................................................................................................... 23
7.1.5 Multi-user MIMO scheme .......................................................................................................................... 23
7.1.5A Dual layer scheme ....................................................................................................................................... 23
7.1.6 Resource allocation ..................................................................................................................................... 23
7.1.6.1 Resource allocation type 0 .................................................................................................................... 24
7.1.6.2 Resource allocation type 1 .................................................................................................................... 24
7.1.6.3 Resource allocation type 2 .................................................................................................................... 25
7.1.7 Modulation order and transport block size determination .......................................................................... 26
7.1.7.1 Modulation order determination ............................................................................................................ 27
7.1.7.2 Transport block size determination ....................................................................................................... 27
7.1.7.2.1 Transport blocks not mapped to two-layer spatial multiplexing ........................................................... 28
7.1.7.2.2 Transport blocks mapped to two-layer spatial multiplexing ................................................................. 34
7.1.7.2.3 Transport blocks mapped for DCI Format 1C ....................................................................................... 34
7.1.7.3 Redundancy Version determination for Format 1C .............................................................................. 35
7.2 UE procedure for reporting channel quality indication (CQI), precoding matrix indicator (PMI) and rank
indication (RI) .................................................................................................................................................. 35
7.2.1 Aperiodic CQI/PMI/RI Reporting using PUSCH ....................................................................................... 38
ETSI
3GPP TS 36.213 version 9.3.0 Release 9 4 ETSI TS 136 213 V9.3.0 (2010-10)
7.2.2 Periodic CQI/PMI/RI Reporting using PUCCH ......................................................................................... 42
7.2.3 Channel quality indicator (CQI) definition ................................................................................................. 48
7.2.4 Precoding Matrix Indicator (PMI) definition .............................................................................................. 50
7.3 UE procedure for reporting ACK/NACK ......................................................................................................... 51
8 Physical uplink shared channel related procedures ................................................................................ 54
8.1 Resource Allocation for PDCCH DCI Format 0 .............................................................................................. 57
8.2 UE sounding procedure .................................................................................................................................... 57
8.3 UE ACK/NACK procedure .............................................................................................................................. 60
8.4 UE PUSCH Hopping procedure ....................................................................................................................... 61
8.4.1 Type 1 PUSCH Hopping ............................................................................................................................ 62
8.4.2 Type 2 PUSCH Hopping ............................................................................................................................ 62
8.5 UE Reference Symbol procedure ..................................................................................................................... 62
8.6 Modulation order, redundancy version and transport block size determination ............................................... 62
8.6.1 Modulation order and redundancy version determination .......................................................................... 63
8.6.2 Transport block size determination ............................................................................................................. 64
8.6.3 Control information MCS offset determination .......................................................................................... 64
8.7 UE Transmit Antenna Selection ....................................................................................................................... 66
9 Physical downlink control channel procedures ...................................................................................... 66
9.1 UE procedure for determining physical downlink control channel assignment ............................................... 66
9.1.1 PDCCH Assignment Procedure .................................................................................................................. 66
9.1.2 PHICH Assignment Procedure ................................................................................................................... 67
9.2 PDCCH validation for semi-persistent scheduling ........................................................................................... 68
10 Physical uplink control channel procedures ........................................................................................... 70
10.1 UE procedure for determining physical uplink control channel assignment .................................................... 70
10.2 Uplink ACK/NACK timing .............................................................................................................................. 75
11 Physical multicast channel related procedures ....................................................................................... 76
11.1 UE procedure for receiving the physical multicast channel ............................................................................. 76
11.2 UE procedure for receiving MCCH change notification .................................................................................. 76
Annex A (informative): Change history ............................................................................................... 77
History .............................................................................................................................................................. 81
2013-12-17 14:47:56 下载次数: 13
ts_136213v090300p.pdf
(684.06 KB)
爱在春天 旧上海 发现基站
2013-06-15
集团GSM-MR邻区及相关资源数据文件提取方法
2012-11-07
直放站问题及优化方法
2012-09-05
云南移动基站安装施工规范
2012-07-05
全省最差小区整治经验及案例2012年3月
2012-04-23
载波池系统及工程实现
2012-02-03
cfb22524689
积分 189
帖子 37
威望 1063 个
注册 2012-6-10
专业方向 通信行业
发表于 2013-12-17 16:48:48
在线,36天前提问
在线,50天前提问
在线,76天前提问
在线,117天前提问
在线,122天前提问
在线,122天前提问
在线,122天前提问
在线,124天前提问
在线,124天前提问
在线,134天前提问
在线,135天前提问
在线,156天前提问
在线,156天前提问
在线,176天前提问
在线,199天前提问
在线,211天前提问
全英文文档,伤不起啊~
通信悠悠
积分 3447
帖子 696
威望 138163 个
专家指数 -33
注册 2013-8-19
专业方向 通信工程,网络优化
发表于 2013-12-17 21:11:12
不错的帖子,好好学习了,呵呵,要是有中文的就更好了
[下载] 3gpp R9 V9.0.3" tabindex="1">
当前时区 GMT+8, 现在时间是 2024-05-16 19:29:14
Processed in 0.330048 second(s), 17 queries , Gzip enabled
