【C友贴图区】
C友贴图和看图,请到此版
勿发违规图片
【C友开心吧】
C友交流开心笑话的区域
乐一乐,就在开心吧
【心情咖啡屋】
分享你的心情和通信生活
C友交流心情的地方
【求职招聘区】
招聘,求职,职业交流
讨论通信人的职场前景
  • 阅读:2124
MAX14920\1 High-Accuracy 12-/16-Cell Measurement AFEs
fatpanda
积分 166
帖子 13
威望 978 个
注册 2009-4-13
专业方向  集成电路
发表于 2013-07-29 13:31:57  只看楼主
【资料名称】:MAX14920\1 High-Accuracy 12-/16-Cell Measurement AFEs
【资料作者】:MAXIM
【资料日期】:2013\7\29
【资料格式】:PDF
The MAX14920/MAX14921 battery measurement analog
front-end devices accurately sample cell voltages and
provide level shifting for primary/secondary battery packs
up to 16 cells/+65V (max). The MAX14920 monitors up
to 12 cells, while the MAX14921 monitors up to 16 cells.
Both devices simultaneously sample all cell voltages,
allowing accurate state-of-charge and source-resistance
determination. All cell voltages are level shifted to ground
reference with unity gain, simplifying external ADC data
conversion.
The devices have a low-noise, low-offset amplifier that
buffers differential voltages of up to +5V, allowing monitoring
of all common lithium-ion (Li+) cell technologies.
The resulting cell voltage error is Q0.5mV.
The devices’ high accuracy make them ideal for monitoring
cell chemistries with very flat discharge curves, such as
lithium-metal phosphate.
Passive-cell balancing is supported by external FET
drivers. Integrated diagnostics in the devices allow
open-wire detection and undervoltage/overvoltage
alarms. The devices are controlled by a daisy-chainable
SPI interface.
The MAX14920 is available in a 64-pin (10mm x 10mm)
TQFP package with an exposed pad. The MAX14921 is
available in an 80-pin (12mm x 12mm) TQFP package.
Both devices are specified over the -40°C to +85°C
extended temperature range.
2013-7-29 13:31:57  下载次数: 0
MAX14920-MAX14921.pdf (1.34 MB)
    当前时区 GMT+8, 现在时间是 2024-04-27 06:49:26
    Processed in 0.252142 second(s), 12 queries , Gzip enabled
