该工具是集成在TEMS15软件里的,大家可以找我之前发过的TEMS15安装包下载地址:
也就是说现在TEMS又可以进行文件分割了,但是有一定的条件限制,是否满足大家要做假的愿望有待进一步了解,下面原文:
RouteUtility™ will solve our problem cutting logfiles; Cut to the chase with RouteUtility™! RouteUtility is a new processing tool for TEMS product logfiles. One thing it can do is to extract a segment of a TRP logfile into a new logfile. This is ideal if you have recorded a long test drive where the juicy bits that you want to study close-up occurred somewhere in the middle. Just load that logfile into RouteUtility, select the interesting time interval, and snip. See the screenshot for an example. RouteUtility also has other functions: it can split logfiles into one file for each data-collecting device, or for each area visited (defined by GPX-format polygons).
[attach]293847[/attach]
