1.3.1周期CQI上报
1.3.1.1周期CQI上报的类型
Table 7.2.2-1: CQI and PMI Feedback Types for PUCCH reporting Modes
PMI Feedback Type
No PMISingle PMI
PUCCH CQIFeedback Type
WidebandMode 1-0Mode 1-1
(wideband CQI)
UE SelectedMode 2-0Mode 2-1
(subband CQI)
For each of the transmission modes defined in Section 7.1, the following reporting modes are supported on PUCCH:
Transmission mode 1: Modes 1-0, 2-0
Transmission mode 2: Modes 1-0, 2-0
Transmission mode 3: Modes 1-0, 2-0
Transmission mode 4: Modes 1-1, 2-1
Transmission mode 5: Modes 1-1, 2-1
Transmission mode 6: Modes 1-1, 2-1
Transmission mode 7: Modes 1-0, 2-0
1.3.1.2Subband和bandwidth part定义
以系统带宽为100prb为例,Subband包含RB数为8(见下表),所以整个带宽划分为100/8=13个Subband,最后一个subband包含的RB数目少一些。系统带宽为100prb时划分出的bandwidth part为4(见下表)个,具体包含的Subband分别为,
bandwidth part0:Subband0,1,2,3
bandwidth part1:Subband4,5,6
bandwidth part2:Subband7,8,9
bandwidth part3:Subband10,11,12
Table 7.2.2-2: Subband Size (k) and Bandwidth Parts (J) vs. Downlink System Bandwidth
System Bandwidth
Subband Size k (RBs)Bandwidth Parts (J)
6 – 7NANA
8 – 1041
11 – 2642
27 – 6363
64 – 11084
注意:周期和非周期CQI 上报都有subband的定义,但是它们的取值并不一样。
1.3.1.3周期CQI上报的内容
1)Mode1-0:
RI
One wideband CQI
Other Transmission modes:
One wideband CQI
2)Mode1-1:
RI
One wideband CQI
PMI
Wideband spatial differential CQI(if RI>1)
One wideband CQI
PMI
3)Mode2-0:
RI
One wideband CQI
Subband CQI with subband label
One wideband CQI
3)Mode2-1:
RI
One wideband CQI
PMI
Subband CQI
Subband spatial differential CQI(if RI>1)
subband label
One wideband CQI
PMI
Subband CQI
subband label
1.3.1.4周期CQI上报的时间点
1、配置Wideband cqi上报
a)Wideband cqi上报时间点:满足下面条件的子帧
NP and offset NOFFSET,CQI 由参数 cqi-pmi-ConfigIndex 决定,该参数由RRC配置。
b)RI(如果需要的话)上报时间点:满足下面条件的子帧
MRI和NOFFSET,RI 由ri-ConfigIndex决定,该参数由RRC配置。
c)RI和 Wideband cqi上报冲突的情况下只上报RI。
2、配置Wideband cqi+subband cqi上报
a)Wideband cqi或subband cqi上报时间点:满足下面条件的子帧
其中Wideband cqi上报时间点满足下面条件的子帧
,H=J*K+1
两个Wideband cqi上报之间的J*K个上报机会用于上报subband cqi,每个bp轮着报它prefer的子带的cqi值,一共可以报K轮。
NP and offset NOFFSET,CQI 由参数 cqi-pmi-ConfigIndex 决定,该参数由RRC配置。K也由RRC配置。
c)RI和 Wideband cqi或subband cqi上报冲突的情况下只上报RI。
1.3.2非周期CQI上报
目前enb实现情况:
1)由DCI0中的cqi request字段指示终端是否要进行非周期CQI上报
2)在下面两种情况下调度:
通过测试消息设置周期调度非周期CQI上报
发生mimo模式内自适应切换时调度一次非周期CQI上报
What is a man's first duty? The answer is brief: To be himself.
