CDMA(EVDO)技术资料区
» Sprint CDMA Embedded Device Requirements FINAL APPROVED
liu_wen_gang188
积分 153
帖子 42
威望 7805 个
专家指数 -57
注册 2011-1-8
专业方向 3G 性能
发表于 2013-06-11 14:46:48
【资料名称】:Sprint CDMA Embedded Device Requirements FINAL APPROVED
【资料作者】:Sprint
【资料日期】:June 2, 2009
【资料语言】:英文
【资料格式】:PDF
Document History .......................................................................................... 6
Preface......................................................................................................... 7
Acronyms ..................................................................................................... 8
1 General.................................................................................................10
2 Module Programming ..............................................................................11
2.1 Activation Methods...........................................................................................11
2.2 Device Programming for OMA-DM and Iota 2.4 ............................................ 11
2.3 Connection Manager User Interface using IOTA 2.4. If the device is using
Connection Manager Software the following should be implemented......................... 12
2.3.1 Activating and Programming.................................................................... 12
2.3.2 Preferred Roaming List............................................................................. 12
2.3.3 Profile Updates..........................................................................................13
2.4 Connection Manager User Interface (OMA-DM). If the device is using
Connection Manager software the following should be implemented. ........................ 13
2.4.1 Activation and Programming.................................................................... 13
2.4.2 Preferred Roaming List............................................................................. 13
2.4.3 Firmware Updates.....................................................................................14
2.4.4 Service Updates ........................................................................................14
2.4.5 Hands Free Activation ..............................................................................14
2.4.6 One Touch Activation............................................................................... 15
2.5 Programming for Command Line Interfaces .................................................... 16
2.5.1 The OMASTART Command....................................................................17
2.5.2 PRL Updates for Command Line User Interfaces .................................... 18
2.5.3 The IOTASTART Command ...................................................................19
2.5.4 The Provision Command .......................................................................... 20
Module Information .......................................................................................21
3 Module Information ................................................................................22
3.1 Hardware Identification ....................................................................................22
3.1.1 Module Manufacturer ...............................................................................22
3.1.2 Module Model Number............................................................................. 22
3.1.3 Module Electronic Serial Number / Mobile Equipment Identifier ........... 22
3.2 Version Information..........................................................................................22
3.2.1 Firmware Version .....................................................................................22
3.2.2 Preferred Roaming List Version ............................................................... 22
3.3 Subscriber Information .....................................................................................22
3.3.1 Mobile Directory Number......................................................................... 22
3.3.2 Mobile Subscriber Identification .............................................................. 23
3.3.3 Network Access Identifier ........................................................................ 23
3.4 Device Communications Information............................................................... 23
3.4.1 Communications Port................................................................................23
3.4.2 Diagnostics Port ........................................................................................23
3.4.3 Miscellaneous Ports ..................................................................................23
3.5 Network Information ........................................................................................23
3.5.1 Available Data Networks.......................................................................... 23
3.5.2 Received Signal Strength Indicator .......................................................... 23
3.5.3 Connection Status .....................................................................................23
4 Module Configuration ..............................................................................24
4.1 Connectivity......................................................................................................24
4.2 Roaming............................................................................................................24
4.2.1 Indicators/Notification ..............................................................................24
4.2.2 Preferences................................................................................................24
4.2.3 Data Roam Guard .....................................................................................25
4.3 Security Lock....................................................................................................25
5 International Roaming.............................................................................26
6 Module Diagnostics .................................................................................27
6.1 Connection and RF Information ....................................................................... 27
6.1.1 Service Option Number ............................................................................ 27
6.1.2 Slot Cycle Index........................................................................................27
6.1.3 Band Class ................................................................................................27
6.1.4 Channel Number one ................................................................................ 27
6.1.5 System Identification Number .................................................................. 27
6.1.6 Network Identification Number................................................................ 27
6.1.7 PN Active Set............................................................................................ 28
6.1.8 PN Candidate Set ...................................................................................... 28
6.1.9 PN Neighbor Set ....................................................................................... 28
6.1.10 Dominant PN ............................................................................................ 28
6.1.11 DRC Request ............................................................................................ 28
6.1.12 Received Signal Strength Indicator .......................................................... 28
6.1.13 Ec/Io.......................................................................................................... 28
6.1.14 Receive Frame Error Rate......................................................................... 28
6.1.15 Transmit Adjustment ................................................................................ 28
6.2 Mobile IP Configuration...................................................................................28
6.2.1 Network Access Identifier ........................................................................ 29
6.2.2 Primary Home Agent Address.................................................................. 29
6.2.3 Secondary Home Agent Address.............................................................. 29
6.2.4 Home Address...........................................................................................29
6.2.5 Home Agent Shared Secret....................................................................... 29
6.2.6 AAA Server Shared Secret ....................................................................... 29
6.2.7 Home Agent Security Parameter Index .................................................... 29
6.2.8 AAA Server Security Parameter Index..................................................... 29
6.2.9 Reverse Tunneling Preference .................................................................. 30
6.3 Advanced Parameters........................................................................................30
6.3.1 Electronic Serial Number / Mobile Electronic Identifier.......................... 30
6.3.2 Preferred Vocoder Setting......................................................................... 30
6.3.3 Station Class Mark.................................................................................... 30
6.3.4 Security Lock Code................................................................................... 30
6.3.5 Slot Mode..................................................................................................30
6.3.6 Slot Cycle Index........................................................................................31
6.3.7 Home System Identification Number ....................................................... 31
6.3.8 Home Network Identification Number ..................................................... 31
6.3.9 Mobile Country Code ............................................................................... 31
6.3.10 Mobile Network Code............................................................................... 31
2013-6-11 14:46:48 下载次数: 0
CDMA Embedded Device Requirements FINAL APPROVED ON 20090625.pdf
(402.03 KB)
WCDMA切换事件算法分析
2017-05-03
华为CM300系列CDMA无线模块
2013-09-17
rrc_state_transitions
2013-06-12
认证基础知识简介
2013-06-10
M2M模块培训V1.0
2013-06-05
当前时区 GMT+8, 现在时间是 2024-04-20 19:01:17
Processed in 0.646643 second(s), 18 queries , Gzip enabled
