告警有关查询.rar (7.67 MB)
NSN告警大全.doc (2.06 MB)
资料为中文,目录是英文的。
【资料名称】:诺基亚告警解释(0-8999)
【资料作者】:诺基亚
【资料日期】:2000
【资料格式】:PDF
[attach]278233[/attach]
一.诺基亚设备告警概述10
1.1原始告警格式10
1.2告警列表格式11
二.告警列表12
2.13 ACCESS SERVICE IS OVERLOADED12
2.24 ACCESS SERVICE REJECT RATE LIMIT EXCEEDED13
2.333 FILE UPDATES TO DISK PREVENTED13
2.4557 STATISTICAL REPORTS LOST14
2.5690 WORKING STATE CHANGE15
2.61001 UNIT RESTARTED15
2.71007 RESTARTED PROGRAM BLOCK16
2.81016 MB INTERFACE FAILURE17
2.91021 PROGRAM BLOCK REWARMING STARTED18
2.101022 PROGRAM BLOCK WARMUP FAILURE19
2.111024 HAND PROCESS ERROR IN PROGRAM BLOCK19
2.121044 ERROR IN SWITCH COMPARE TEST20
2.131072 SIGNALLING LINK OUT OF SERVICE21
2.141078 PROCESS EXCEPTION23
2.151088 CONNECTION ERROR BETWEEN MSC AND SMSC24
2.161103 SIGNALLING MEASUREMENT REPORT LOST25
2.171183 HMS LINE CONNECTION LOST27
2.181186 NO RESPONSE TO HMN SUPERVISION27
2.191195 USSD SERVICE INFORMATION NOT FOUND28
2.201425 OVERFLOW IN ALARM BUFFERING28
2.211559 A-INTERFACE CIRCUIT ALLOCATION FAILURE29
2.221569 CRITICAL LIMIT IN SECURITY REPORTING REACHED30
2.231574 DATA ERROR FOUND BY PROTOCOL30
2.241575 COMPONENT NOT ACCEPTED BY REMOTE END31
2.251645 PROTOCOL MESSAGE QUEUE FULL32
2.261647 OPERATION TIMER EXPIRY33
2.271667 UNHANDLED MESSAGES OVERFLOW33
2.281860 DISK DISTURBANCE34
2.292005 CHECKSUM ERROR IN LOAD MODULE34
2.302007 FILE UPDATING ON AUXILIARY STORAGE IS NOT PROCEEDI35
2.312012 ERROR IN FILE OPENING36
2.322015 MB COMMUNICATION ERROR37
2.332017 FILE DISTRIBUTION ERROR37
2.342018 OVERFLOW IN HANDLING ALARM EVENTS38
2.352023 MAIN CLOCK FAILURE39
2.362024 MAIN CLOCK NEEDS ADJUSTMENT39
2.372031 MB CLOCK FAILURE40
2.382032 SSU CLOCK FAILURE40
2.392033 GSW CLOCK FAILURE41
2.402034 SWI CLOCK FAILURE42
2.412035 SUB CLOCK FAILURE43
2.422036 AONU CLOCK FAILURE43
2.432037 CLG-S FAILURE44
2.442038 MFR CLOCK FAILURE44
2.452050 PLUG-IN UNIT MISSING IN SWITCHING NETWORK45
2.462051 POWER FAILURE IN SWITCHING NETWORK46
2.472052 SWITCH CLOCK FAILURE46
2.482064 ROUTE SET UNAVAILABLE47
2.492069 SIGNALLING LINK TEST FAILED48
2.502070 LINK SET UNAVAILABLE48
2.512071 SIGNALLING LINK TERMINAL FAULTY49
2.522072 FAILURE IN SIGNALLING LINK ACTIVATION OR RESTORATION50
2.532075 COMMUNICATION FAILURE BETWEEN SIGNALLING TERMINAL51
2.542079 LOOP TEST FAILED IN SIGNALLING LINK TERMINAL52
2.552087 LOW TRAFFIC CAPACITY ON CIRCUIT GROUP53
2.562092 AVERAGE SEIZURE TIME BELOW THRESHOLD54
2.572098 CALL OVERLOAD IN EXCHANGE54
2.582099 LIMIT FOR UNSUCCESFUL CALLS EXCEEDED55
2.592114 FR VIRTUAL CONNECTION FAILED55
2.602115 FR USER LINK INTEGRITY VERIFICATION FAILED56
2.612133 SEND BUFFER OVERFLOW IN SIGNALLING TERMINAL57
2.622137 PLUG-IN UNIT LOCATION ERROR58
2.632138 PLUG-IN UNIT SOFTWARE PACKAGE CHECK SUM ERROR58
2.642139 PLUG-IN UNIT SOFTWARE PACKAGE LOAD FAILURE59
2.652142 PLUG-IN UNIT SUPERVISION FAILURE60
2.662160 PREPROCESSOR UNIT RESTART FAILURE60
2.672171 NO USER FOR OSI CLNS61
2.682175 OSI CLNS LINKAGE NOT AVAILABLE62
2.692185 ROUTING OF OSI OUTGOING CALL FAILED62
2.702186 CALL CONTROL ANALYSIS MISSING63
2.712194 ANNOUNCEMENT ID ANALYSIS ERROR64
2.722202 ET FAILURE65
2.732205 ET2 FAILURE65
2.742224 ERROR IN MSU HANDLING66
2.752241 SCCP SUBSYSTEM PROHIBITED67
2.762246 SCCP ROUTING FAILURE68
2.772247 SS7 ERRONEOUS SIGNALLING MESSAGE69
2.782250 FAILURE IN D-CHANNEL ACTIVATION OR RESTORATION71
2.792252 LOOP TEST FAILED IN PRIMARY RATE ACCESS TERMINAL72
2.802254 SCCP NOT DEFINED FOR NETWORK73
2.812262 OSI SUBNETWORK INTERFACE OUT OF ORDER74
2.822269 ERRONEOUS DISK CACHE SIZE75
2.832272 BOOT LOADING ERROR75
2.842274 SOMAFI ERROR76
2.852285 SIGNALLING TERMINAL FAULTY77
2.862304 TONE GENERATOR FAILURE78
2.872339 SP-CIC -> PCM-TSL CONVERSION TABLE UPDATE ERROR78
2.882347 POWER SUPPLY FAILURE IN CPU79
2.892386 OVERWRITING UNTRANSFERRED VDS-DEVICE DATA FILE80
2.902393 FALLBACK COPYING TERMINATED IN ERROR80
2.912394 ERROR IN FINISHING FALLBACK COPYING81
2.922397 DATABASE FILE IS IN DANGER TO GET FULL82
2.932399 DATABASE DISK UPDATES ARE PREVENTED82
2.942402 AFS CONNECTION FAILURE83
2.952403 SERIAL CHANNEL FAILURE84
2.962410CONNECTION OF A CIRCUIT HAS FAILED IN THE SWITCHING84
2.972411 RELEASING OF A CIRCUIT HAS FAILED IN THE SWITCHING86
2.982414 MISSING ACC REJECTION PERCENTAGES87
2.992424 DISCREPANCY BETWEEN RECORD DATA AND BITMAP87
2.1002426 CHECKSUM ERROR IN FILE BLOCK88
2.1012439 NO LINK BETWEEN MSC AND SMSC88
2.1022445 UNIT TYPE HAS NO REDUNDANCY89
2.1032477 GLOBAL RESET MESSAGE RECEIVED90
2.1042478 MOBILE ACCESS CLASSES ABNORMAL90
2.1052494 MSRN RESERVATION RATIO91
2.1062503 DETAILED CHARGING LOST91
2.1072504 CHARGING FILE FILLING UP92
2.1082518 NO VALID FALLBACK COPY FOR DEFAULT PACKAGE93
2.1092525 FAILURE IN STORING OF DETAILED CHARGING DATA94
2.1102532 ANALYSIS FOR NETWORK GENERATED NBR OR FOR CHA.94
2.1112536 SUBSCRIBER DATABASE FILE IN VLR IS FULL95
2.1122549 FIRST ALARM LIMIT FOR UNAVAILABLE VDS-DEVICE96
2.1132558 ECHO CANCELLER CONNECTION FAILURE96
2.1142562 NUMBER NOT FOUND FROM HRNFIL OR INVALID DATA97
2.1152568 ERROR IN GSAPRB ANALYSIS FILE98
2.1162590 ERROR IN OPENING OUTPUT FILE99
2.1172621 FAULTY TIME SLOT IN TESTING OF TIME SLOT BASED UNIT99
2.1182623 TOTAL FAILURE OF TIME SLOT BASED UNIT100
2.1192624 FAULTY TIME SLOT IN TESTING OF MFST101
2.1202632 OSCILLATOR FAILURE102
2.1212634 POWER FAILURE IN SYNCHRONIZATION UNIT103
2.1222636 FAILURE IN OUTGOING CLOCK SIGNAL103
2.1232638 FAILURE IN BUS BETWEEN SYNCHRONIZATION UNITS104
2.1242639 FAILURE IN SYNCHRONIZATION UNIT SWITCHOVER105
2.1252641 FAILURE IN SYNCHRONIZATION SIGNAL105
2.1262646 PROTOCOL ROUTING FAILURE106
2.1272650 STORING OF THE DATA FAILED ON ONE DISK107
2.1282651 STORING OF THE DATA FAILED ON BOTH DISKS108
2.1292652 PHYSICAL DISK IS FULL108
2.1302653 FAILURE IN THE HANDLING OF CONTROL FILES109
2.1312654 NO SERVICE PACKAGE FOR CORE INAP TRIGGER KEY109
2.1322656 CIRCUIT POOL INFORMATION CONFLICT BETWEEN MSC110
2.1332658 CHARGED NUMBER FOR THE SECOND LEG OF REROUTING111
2.1342661 NO CONSISTENT COPY OF DATABASE ON DISK111
2.1352662 NO CONSISTENT DATABASE ANYWHERE112
2.1362664 DATABASE COPY STAYS INCONSISTENT ON SAME DISK113
2.1372666 DBSMAN STOPPED IN ACTIVE UNIT114
2.1382668 CALL ESTABLISHMENT FAILURE115
2.1392671 DATA SERVICE UNIT IS NOT AVAILABLE117
2.1402675 SS7 GROUP RESET MESSAGE RECEIVED TO UNUSED CIRCUIT117
2.1412683 ERROR IN MML COMMAND LOG ACCESS118
2.1422687 SYSTEM RESTART IN PROGRESS120
2.1432692 INCORRECT WORKING STATE121
2.1442693 WO-EX UNIT FAULTY121
2.1452703 MAP PROCEDURE FAILURE – HIGH122
2.1462720 TELECOM LINK OVERLOAD123
2.1472725 ADJACENT CELL IDENTIFIER CONFIGURATION ERROR124
2.1482733 OUT OF AVAILABLE VDS-DEVICE DATA FILES125
2.1492734 80% OF THE EVENT BUFFER USED126
2.1502737 ECHO CANCELLER CHANNEL FAILURE126
2.1512740 EXCESSIVE DISTURBANCES IN CALL INDEX RESERVATI127
2.1522741 NO SUCCESSFUL CALLS127
2.1532742 BSC/MGW(REL99) OUT OF SERVICE IN MSC128
2.1542744 BSC/MGW(REL99) OR BTS/SAC IN WRONG STATE IN MSC129
2.1552745 CELLULAR NETWORK CONFIGURATION ERROR130
2.1562748 NO ANALYSIS FOR SMSC ADDRESS131
2.1572751 PLUG-IN UNIT MISSING132
2.1582754 FUSE FAILURE132
2.1592755 CARTRIDGE CLOCK FAILURE133
2.1602756 CARTRIDGE POWER SUPPLY FAILURE134
2.1612757 CARTRIDGE NON-REDUNDANT POWER SUPPLY FAILURE134
2.1622758 POWER SUPPLY ADAPTER FAILURE135
2.1632759 POWER SUPPLY FUSE FAILURE136
2.1642760 HWAT FAILURE136
2.1652761 CLAB FAILURE137
2.1662762 SUPERVISION BUS FAILURE138
2.1672763 FAILURE IN BUS BETWEEN CLAB UNITS138
2.1682764 CLS FAILURE139
2.1692767 FEATURE NOT SUPPORTED139
2.1702770 PREPROCESSOR UNIT FAILURE140
2.1712772 BSC/MGW(REL99) CONTINUOUSLY OUT OF SERVICE IN MSC140
2.1722773 RESET CIRCUIT ACKNOWLEDGEMENT MISSING FROM BSC141
2.1732777 CDSU CHANNEL SUPERVISION FAILED142
2.1742779 CDSU PIU SOFTWARE LOADING FAILED143
2.1752799 FRAUD REPORTING NOT SUCCESSFUL143
2.1762802 CTU DISK BUFFERING INTERRUPTED144
2.1772806 SOMAFI UPDATE ERROR145
2.1782809 MASS MEMORY DEVICE POWER SUPPLY FAILURE145
2.1792812 PRINTER SPOOLER ALMOST FULL146
2.1802818 INCORRECT OPERATING STATE147
2.1812827 EMT PROTOCOL FAILURE147
2.1822843 ALARM DIFFERENCE BETWEEN BSC AND OMC148
2.1832860 DISK FAILURE148
2.1842861 NO ACCESS TO DISK149
2.1852862 DISK CHECKSUM ERROR150
2.1862870 MASS MEMORY POWER SUPPLY FAILURE151
2.1872883 TAPE MEDIA FULL151
2.1882900 INCOMING SIGNAL MISSING151
2.1892902 PCM LINE REMOTE END ALARM152
2.1902908 CODE ERROR RATE OVER LIMIT153
2.1912909 AIS RECEIVED153
2.1922910 FRAMING ERROR154
2.1932911 EXCESSIVE CODE ERROR RATE155
2.1942912 BIT ERROR RATE OVER LIMIT155
2.1952915 FAULT RATE MONITORING156
2.1962923 CRC BIT ERROR RATIO OVER LIMIT157
2.1972925 SLIP FREQUENCY LIMIT EXCEEDED157
2.1982950 TRCO FAILURE158
2.1992952 TRANSCODER PLUG-IN UNIT FAILURE158
2.2002954 NO TRAU FRAME SYNCHRONIZATION159
2.2012955 TRANSCODER CHANNEL FAILURE160
2.2022992 BTS AND TC UNSYNCHRONIZATION CLEAR CALLS ON A161
2.2032993 BTS AND TC UNSYNCHRONIZATION CLEAR CALLS ON AB162
2.2043019 NETWORK SERVICE ENTITY UNAVAILABLE163
2.2053020 NETWORK SERVICE VIRTUAL CONNECTION UNAVAILABL164
2.2063022 NETWORK SERVICE VIRTUAL CONNECTION BLOCK PROCEDURE165
2.2073023 NETWORK SERVICE VIRTUAL CONNECTION RESET PROCEDURE166
2.2083024 NETWORK SERVICE ENTITY CONFIGURATION MISMATCH167
2.2093025 NETWORK SERVICE VIRTUAL CONNECTION TEST PROCEDURE167
2.2103026 NETWORK SERVICE VIRTUAL CONNECTION PROTOCOL ERROR168
2.2113027. UPLINK CONGESTION ON THE NETWORK SERVICE VIRT168
2.2123032 BSSGP VIRTUAL CONNECTION PROTOCOL ERROR169
2.2133050 NO RESPONSE FROM PLUG-IN UNIT169
2.2143053 ETHERNET INTERFACE FAILURE170
2.2153084 ECHO CANCELLER CHANNELS FAILURE171
2.2163118 UNDERVOLTAGE IN POWER SUPPLY BRANCH UB1 OF THE SYS171
2.2173126 DATABASE FILE FOR NORMAL SUBSCRIBERS IS IN DANG172
2.2183146 FAN UNIT FAILURE173
2.2193156 ASSOCIATION ROUTING FAILURE173
2.2203159 SCTP ASSOCIATION LOST174
2.2213216 CONNNECTION BETWEEN MSC AND SMSC FAILED175
2.2223263 CALL ESTABLISHMENT FAILURE IN USER PLANE CONTROL175
2.2233273 (E)GPRS TERRITORY FAILURE178
2.2243293 SCTP PRIMARY PATH NOT AVAILABLE180
2.2253295 LICENCE CAPACITY EXCEEDED181
2.2263296 IWF IP CONNECTION LOST181
2.2273799 MESSAGE BUS FAILURE182
2.2283937 H.248. IP CONNECTION LOST182
2.2293947 VIRTUAL MEDIA GATEWAY IS OUT OF SERVICE183
2.2304000 POWER FAILURE ALARM(外部告警)184
2.2315001 VMS(外部告警)185
2.2325002 VMS(外部告警)185
2.2335003 VMS(外部告警)185
2.2347208 LOCAL BLOCK185
2.2357220 RADIO LOOP OR RX ANTENNA TEST EXECUTION186
2.2367524 TX FREQUENCY TUNER OUT OF ORDER187
2.2377526 RX FREQUENCY TUNER OUT OF ORDER187
2.2387528 TEST LOOP TUNING OUT OF ORDER188
2.2397530 TX OUTPUT POWER LEVEL DECREASED189
2.2407533 TX ANTENNA OR COMBINER CONNECTION FAULTY189
2.2417549 INTERNAL DATA TRANSFER FAILURE190
2.2427600 BCF FAULTY190
2.2437601 BCF OPERATION DEGRADED191
2.2447602 BCF NOTIFICATION192
2.2457604 BTS OPERATION DEGRADED193
2.2467606 RX FAULTY193
2.2477607 TRX OPERATION DEGRADED194
2.2487608 TRX NOTIFICATION195
2.2497609 TRE FAULTY195
2.2507616 OSCILLATOR ADJUSTING TEMPORARILY INTERRUPTED196
2.2517622 CABINET OPEN196
2.2527700 BTS OMU INITIALIZATION197
2.2537701 BCF INITIALIZATION197
2.2547704 PCM FAILURE198
2.2557705 LAPD FAILURE198
2.2567706 BTS O&M LINK FAILURE199
2.2577711 WORKING FULL RATE TCH RATIO BELOW THRESHOLD199
2.2587715 CONTINUOUS RESTARTS OF BCF/TRX200
2.2597716 ACTIVE BCF HW DATABASE DIFFERENCE200
2.2607717 WORKING HALF RATE TCH RATIO BELOW THRESHOLD201
2.2617723 FAILURE IN SENDING SYSTEM INFORMATION TO BTS SIT201
2.2627724 CONFLICT BETWEEN BSS RADIO NETWORK DATABASE A202
2.2637725 TRAFFIC CHANNEL ACTIVATION FAILURE204
2.2647730 CONFIGURATION OF BCF FAILED204
2.2657735 TRX TEST FAILED206
2.2667736 ABIS LOOP TEST FAILED207
2.2677738 BTS WITH NO TRANSACTIONS208
2.2687740 BEATING BTS ALARM208
2.2697741 MEAN HOLDING TIME ABOVE DEFINED THRESHOLD209
2.2707743 MEAN HOLDING TIME BELOW DEFINED THRESHOLD210
2.2717744 EXCESSIVE TCH INTERFERENCE211
2.2727745 CHANNEL FAILURE RATE ABOVE DEFINED THRESHOLD212
2.2737746 CH CONGESTION IN CELL ABOVE DEFINED THRESHOLD213
2.2747753 TRX LOOP TEST FAILED214
2.2757767 BCCH MISSING215
2.2767801 MMI CONNECTED TO BASE STATION216
2.2777805 UNIT TEMPERATURE HIGH216
2.2787808 FAULT IN Q1-INTERFACE OF BCF217
2.2797840 SW DOWNLOAD TO UNIT FAILED217
2.2807861 SERVICE TERMINAL CONNECTED TO ABIS TRANSMISSIO218
2.2817870 CABINET DOOR OPEN219
2.2827890 FAULT IN COOLING FAN219
2.2837900 NO CONNECTION TO TRX220
2.2847939 FORWARD POWER TOO LOW AT TX ANTENNA220
2.2857941 TX ANTENNA PERFORMANCE DEGRADED221
2.2867944 MAIN BRANCH LNA OUT OF ORDER IN ANTENNA FILTER UNI222
2.2877949 DIFFERENCE IN RX LEVELS OF MAIN AND DIVERSITY ANTE222
2.2887990 MAINS BREAKDOWN WITHOUT BATTERY BACK-UP223
2.2897991 POWER SUPPLY FAULT224
2.2908000 POWER SUPPLY FAULT224
2.2918050 LOSS OF INCOMING 2M SIGNAL225
2.2928066 ALARM INDICATION SIGNAL (AIS) RECEIVED226
2.2938081 LOSS OF FRAME ALIGNMENT226
2.2948086 LOSS OF CRC MULTIFRAME ALIGNMENT227
2.2958099 RECEIVED BIT ERROR RATIO (BER) > 1E-3228
2.2968102 RECEIVED BIT ERROR RATIO (BER) > 1E-6229
2.2978112 FREQUENCY ERROR229
2.2988179 FAR-END ALARM230
2.2999011 FAILURE IN DATA COMMUNICATION NETWORK231
2.3009041 PROCESS RECOVERY IS NEEDED REPEATEDLY232
2.3019047 ALARMS FROM NETWORK ELEMENT NOT ARRIVING232
2.3029108 FAILURE IN OMC-NE COMMUNICATION LINK233
2.3039112 THE MINIMUM NUMBER OF PROCESSES REQUIRED IS NO234
2.3049122 MEASUREMENT DATA HAS NOT ARRIVED FROM THE NE234
2.3059205 FILE SYSTEM IS BECOMING FULL235
2.3069207 NE CLOCK TIME DEVIATION EXCEEDS THE ALARM236
2.3079212 NO CONNECTION TO DATABASE CONNECTION SUPERVIS236
2.3089224 SUPERVISION PROGRAM FAILED237
2.3099228 ALARM DATABASE UPLOAD IN PROGRESS238
2.3109450 CONNECTION FAILURE TO AN SNMP HOST238
2.3119451 SNMP AGENT NOT RESPONDING239
2.31219800 CONNECTION LOST240
2.31332333 CAN NOT INITIALISE CHARGING240
本帖最后由 wangweitao 于 2013-1-15 15:44 编辑 ]
