【资料名称】:爱立信最新APG AUDIT 工具--ALAN R9A
【资料作者】:ericsson
【资料日期】:20120311
【资料语言】:英文
【资料格式】:TXT
@@__________________________________________________________________________
@@___ _______ ___ __ ______ __
@@ /|/ __ \/| ________/ (_) /_/ ___/__________(_)___/ /_
@@/ /| | / /_/ // /| |/ / / / __/ / __/\__ \/ ___/ ___/ / __ \/ __/
@@/ ___ |/ ____// ___ / /_/ / /_/ / / /____/ / /__/ // / /_/ / /_
@@ /_/|_/_//_/|_\__,_/\__,_/_/\__//____/\___/_//_/ .___/\__/
@@ /_/
@@ NAME
@@AP Audit Script
@@ PRODUCT
@@AUSBIN, CXC 137 1120/4
@@ Copyright Ericsson AB 2009.
@@ All rights reserved.
@@The Copyright to the computer program(s) herein
@@is the property of Ericsson AB, Sweden.
@@The program(s) may be used and/or copied only with
@@the written permission from Ericsson AB or in
@@accordance with the terms and conditions stipulated in the
@@agreement/contract under which the program(s) have been
@@supplied.
@@ DESCRIPTION
@@This winfiol script will generate log files to be analyzed
@@offline by ALAN, CXC 137 1124/4
@@This winfiol script is to be used with WinFIOL 6.4 or later.
@@It is recommended for the user to use WinFIOL 7.1 SP2
@@Note : WinFIOL 7.1 SP2 echo commands correctly while using SSH (HI80445)
@@ AUTHOR
@@2005-12-19 by EAB/UZ/ZS UABHAKM
@@ REVDATENAMEDESCRIPTION
@@ R1A20051219UABHAKMFirst revision, complies to CXC 137 1120/4 R1A
@@ R2A20060215UABHAKMSecond revision, complies to CXC 137 1120/4 R2A
@@Tr's solved:
@@HG56987
@@HG57835
@@HG57839
@@ R3A20060407UABHAKMThird revision, complies to CXC 137 1120/4 R3A
@@HG70665
@@HG70690
@@HG66302
@@HG72032
@@HG69453
@@HG58613
@@ R3B20060411UABHAKMFourth revision, complies to CXC 137 1120/4 R3B
@@ R4A20060622UABHAKMFifth revision, complies to CXC 137 1120/4 R4A
@@ R4B20060704ESEFRSVSixth revision, complies to CXC 137 1120/4 R4B
@@ R4C20060821UABHAKMSeventh revision, complies to CXC 137 1120/4 R4C
@@ R5A20060926UABHAKMEight revision, complies to CXC 137 1120/4 R5A
@@HH29261
@@HH24770
@@HH28381
@@ R5B20061221UABHAKMNinthrevision, complies to CXC 137 1120/4 R5B
@@ R5C20070308UABHAKMTenthrevision, complies to CXC 137 1120/4 R5C
@@ R6A20070906UABHAKMEleventhrevision, complies to CXC 137 1120/4 R6A
@@ R6B20071207UABHAKMTwelthrevision, complies to CXC 137 1120/4 R6B
@@ R6C20081008EFRAZOLThirteenth revision, complies to CXC 137 1120/4 R6C
@@ R6D20081128XMADTHAFourteenth revision, complies to CXC 137 1120/4 R6D
@@ R6E20090123XMADTHAFifteenth revision, complies to CXC 137 1120/4 R6E
@@ R6F20090227XMADTHASixteenth revision, complies to CXC 137 1120/4 R6F
@@ R7A20090403XCSSUJVSeventeenth revision, complies to CXC 137 1120/4 R7A
@@ R7B20090709XMADTHAEighteenth revision, complies to CXC 137 1120/4 R7B
@@ R7C20091001XSIVAARNineteenth revision, complies to CXC 137 1120/4 R7C
@@ R7D20100406XLAVAMRTwentieth revision, complies to CXC 137 1120/4 R7D
@@ R7E20100930XCHAKRITwenty First revision,complies to CXC 137 1120/4 R7E
@@ R7F20110160XCHAKRITwenty Second revision,complies to CXC 137 1120/4 R7F
@@ R8A20110615XCHAKRITwenty Third revision,complies to CXC 137 1120/4 R8A
@@ R8B20110825XCHAKRITwenty Fourth revision,complies to CXC 137 1120/4 R8B
@@ R8C20111014XCHAKRITwenty Fifth revision,complies to CXC 137 1120/4 R8C
@@ R8D20111104XCHAKRITwenty Sixth revision,complies to CXC 137 1120/4 R8D
@@ R9A20120311XCHAKRITwenty Seventh revision,complies to CXC 137 1120/4 R9A
@@ SEE ALSO
@@ALANBIN, CXC 137 1124/4 @@
@@File: AP_Audit_R9A.txt
@@Supported
@@ sw levels: APZ 11.1, 11.2, 11.3, 12.0, 13.0, 15.0,16.0 and APG40 One Track up to AGM020
@@ hw levels: APG40 C/1, APG40 C/2, APG40 C/4 and APG43
@@Script used with WinFIOL 6.4 or later.
@@Script plug-in must be loaded.
@@To check:
@@Help->Status Information->
lug-ins
@@'Script plug-in' must be present in the list.
@@This winfiol script creates Audit logs to be reviewed offline with ALAN-tool and/or manual.
@@Log in to A-node and transmit/send this file
@@Log in to B-node and transmit/send this file
@@ Note: The Logfile name is automatically set to
@@ C:\Temp\AP_Audit_R9A_"hostname"_"nodestate_"osversion"_"date"_"time".log
@@20040430Rev.A First version
@@20041119Rev.B Second version
@@20050430Rev.C Third version
@@Extended ACL checks
@@LBB hotfixes checked
@@Antivirus exclusion lists collected
@@DPHIP (CP hardware versions)
@@Ipna osdumps collected
@@Commondll and dll logs collected
@@Extended collection of mcs fms aes configuration data
@@20050909Rev.D Fourth version
@@MML commands only executed in Active node and only on AP-1
@@Improvements for dual ap configuration
@@Improvements for APZ 212 40
@@Commands only possible in Active node not executed in Passive node
@@Adaption for APZ 12.0
@@ACL checks according to Baseline
@@More efficient "comment out" syntax used (@@)
@@IPN-2 and -3 also checked
@@DIRCP; CP Event Record collected
@@Examples for net start and net share changed
@@APMSP;CHOIP;CHOPP; To check charging configuration on the APZ-side
@@Cluster /ver and /list
@@Alarm panel configuration
@@Rdt/ohs configuration
@@Tree information
@@Application-,System-logs only 100 last events printed
@@Printing of sfc-, fch- and dr.watson logs are disabled
@@Please use mktr (or enable by remove @@) if they are requested
@@Commondll.log, dll.log and IPN osdumps are commented out
@@Date /t&time /t&mml CACLP:ALL; are sent together (to check CP/AP time deviation)
@@Timezone information
@@ISP statistics
@@Automatic naming of the logfile
@@20051021Rev.E Fifth version
@@Userdump (needed for OSU)
@@fcc_amversion added for WinS03
@@Version check of Pragma telnet server
@@Check for incorrectly installed files
@@WinS03: Print all services
@@Check automatically started applications
@@New partitions in cacls for WinS03
@@Osversion added to logfile name
@@20051110Rev.F Sixth version
@@OSU: To check that no empty user variable PATH exist.
@@OSU: To check that no occurrences of <Account Domain not found> exist.
@@OSU: No "big" ddi files should exist (Normal size ~50KByte).
@@OSU: Make sure that Administrator doesn't have membership in
@@groups 'Guests' and 'Domain Guests'.
@@OSU: Check required free disk space.
@@aehevls removed. Can cause APZ21240 cp fault caused by high cpu load.
@@20051219AUSBIN CXC1371120/4 R1A only some text differs to Rev.F
@@20060215AUSBIN CXC1371120/4 R2A
@@ipnaadm -list also printed for AP-2.
@@dbols -l included.
@@cpfdf cpfls -l afpls -l cdhdsls -l cdhls -l dbols -l also printed on AP-2.
@@mdutil removed for WinS03.
@@<Account Domain not found> check improved. (quicker)
@@dhcp config printing changed for WinS03.
@@OSU: Check if Display of Legal Notice is active.
@@OSU: Check that both node names are in uppercase.
@@OSU: Check that ossuser account never expires.
@@lmhosts example corrected.
@@Example for Excluded from AVIR updated.
@@Example for set changed.
@@OSU: "Default FTP Site" has to be "C:\Inetsrv\ftproot".
@@OSU: To check that no other user than Default is defined in the Pragma Telnet Server.
@@20060407AUSBIN CXC1371120/4 R3A
@@New for APG40/C4: ScsiDisk and megarc.
@@Check the alog status.
@@Added example for e:\boot.ini WinS03.
@@OSU: Check for file c:\winnt\backup.fts (HG66302).
@@OSU: Attributes and files on e: partition printed.
@@OSU: Check permissions on E: partition (HG70665).
@@OSU: Check for missing files (HG72032).
@@OSU: Check correct labels (HG69453 and HG58613).
@@20060411AUSBINCXC1371120/4 R3B
@@Minor corrections for ipn print on passive node, Backup.ftsand boot.ini example.
@@20060622AUSBINCXC1371120/4 R4A
@@FOR command removed on request from BSC-OSS.
@@Check content of hosts and compare them between A and B node.
@@Print MAXSIZE of the eventlogs.
@@Installation date/time printed for the security patches (TR HG72875).
@@Check if the repair fix 109 22-APZ 212 30/4-494 was correct installed.
@@Check for directories that should be files on C:\ (TR HG72032).
@@DHCP: To check that no directory called "old" exist.
@@DHCP: To check that no corrupted dir's exist. (e.g. <DIR>j500000D.log).
@@DHCP: checkdb.
@@winmsdreport printed for WinS03.
@@Check that SSH installation is correct (SCS534984).
@@DNS Server configuration.
@@OSU: Check required free disk space on E: 19 MByte (TR HG87416).
@@20060704AUSBINFTP virtual directories printed on passive node.
@@20060821AUSBINCXC1371120/4 R4C minor corrections.
@@20060926AUSBINCXC1371120/4 R5A
@@Ping the other node over the public interface.
@@Check of replication and USN.
@@Setupservice.def is printed.
@@Check lct configuration of the service account.
@@Listing of ddi files for WinS03.
@@Check anonymous logon setting for the FTP Sites (TR HH29261).
@@Preferred owners are checked for the cluster groups (TR HH24770).
@@OSU: Check input language setting (TR HH28381).
@@20061220AUSBINCXC1371120/4 R5B
@@EXCHANGE IDENTITY DATA, IOEXP.
@@Adaption to run on APG43 (note: APG43 is not officially supported).
@@Status of insecure protocols (csadm).
@@date and time added to the logfile name.
@@Check FTP Sites settings.
@@netstat -s to get network statistics
@@Total script execution time printed.
@@bupls/bupidls/sybrp/lamip
@@tree C:\ /A
@@20070308AUSBINCXC1371120/4 R5C
@@bugfix for totaltime calculation and cacls on data disks.
@@Changes for ap2 at bupls and repadmin.
@@Extended Active Directory Check.
@@Volume check in WinS03 changed, wmic.
@@Check the registered IE version.
@@audit error for second APG -- wrongly included CP commands (HH71860)
@@20070906AUSBINCXC1371120/4 R6A
@@APG43 supported
@@cluster net /prop | sort | find "Role"
@@The Baseline config file, IntegrityAP.dir is printed.
@@dir /od c:\bur dir /od C:\acs\data\BUR
@@attrib E:\* /S /D
@@NIC speed and duplex.
@@Check for directories that should be files (TR HG72032) updated.
@@DNS should not be configured to listen on the Public interface.
@@ISP log maximum size
@@@EXIT used instead of @END to end this script.
@@folders/files in C:\acs\data\FCH\current\ are listed.
@@print acl's for responding ftp dir's.
@@Check for isperror.log dir C:\acs\logs\prc.
@@Extended FRS and gp Check
@@SCSIDISK and megarc additions for C/4
@@20071210AUSBINCXC1371120/4 R6B
@@afpls -a for all defined transferqueues.
@@Check that clustername and cluster ip-address works from both nodes.
@@Check setting of RAID remirroring speed.
@@Updated text: "IgnoreBroadcastFlag0x1" all other APZ's (classic and also APZ 212 50/55)
@@Check that $oem$ doesn't exist on the root catalog on C:\ drive.
@@OSU: SearchList must be empty before starting OSU.
@@stmdbrt -p Database Retainment Time Print
@@exalls -f the path and filename for EXAL listed.
@@alogexls List all items that are excluded from alog.
@@cpdlist EOL & EOP is listed.
@@cluster res "{clusterResource}" /listowners
@@20081008AUSBINCXC1371120/4 R6C
@@ netsh dhcp server show serverstatus added.
@@ Check if burbackup archive exists on datadisk for WinS03.
@@ Jump over certain code if Winfiol 7.0 or older is used
@@(7.0 SP1 and newer is OK).
@@ Check for number of network interfaces in registry.
@@ Change the path of logfile.
@@20081128AUSBINCXC1371120/4 R6D
@@ Corrected typoerror in "which dnscmd.exe".
@@20090123AUSBINCXC1371120/4 R6E
@@ net time \\192.168.202.1 && net time \\192.168.202.2 added (HJ92696)
@@ gpupdate /force added (HJ99663)
@@ eventquery /L application /V /FO list /R 1 /FI "Source eq SceCli" added (HJ99663)
@@ diskeeper /p /jt=z added (HJ99663)
@@ SCSIDISK /CS ,megarc commands,gamevelog for C/4 added (HJ99663)
@@ Corrected typoerror in "cacls S:\STS\Data\*"
@@20090227AUSBINCXC1371120/4 R6F
@@ Revised check for CA ANTIVIRUS VER 8.1 (AVIRBIN CXC 137 1268/4 R1A)
@@20090403AUSBINCXC1371120/4 R7A
@@Adaption to run on APG43 Blade Cluster (HK34818)
@@Inclusion of WinS2003 Quorum Disk (HK57350)
@@20090709AUSBINCXC1371120/4 R7B
@@regedit /e Keyb.txt "HKEY_Users\" changed to reg query "HKU" /s /f "
reload" >Keyb.txt (HK23886)
@@dir \\{int_a}\c$\winnt\sysvol\domain\Policies\gptTmpl.inf /s/b and
@@dir \\{int_b}\c$\winnt\sysvol\domain\Policies\gptTmpl.inf /s/b added. (HK24490)
@@dsquery computer -stalepwd 29 added. (HK29936)
@@WinFIOL version printed. (HK29943)
@@ phaprint commands combined with single command. (HK35345)
@@TFTP server commands added for checking TFTP performance. (HK35616)
@@reg query "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters" /v ReservedPorts. (HK38154)
@@Corrected the Extended FRS check routine and so Extended Active Directory check is done always. (HK46884)
@@gpresult /z added. (HK51693)
@@20091001AUSBINCXC1371120/4 R7C
@@Extended DHCP Server check for AP2 machines (HK70097)
@@Updated WinFIOL version print statement. (HK87590)
@@Extended GPO policy checks for AP2 configuration (HK89797)
@@nels added for checking the Blade Cluster Configuration. (HK91440)
@@20100406AUSBINCXC1371120/4 R7D
@@Introduced COMPUTERNAME instead of IPNs (HL66537)
@@dir "C:\WINNT\Installer" | findstr "2015A3F9-5EED-4C67-BD3A-FF024A40C22D" added(HL41602)
@@type \\{NODEA}\C$\acs\data\FCR\verbosity and type \\{NODEB}\C$\acs\data\FCR\verbosity added. (HL41506)
@@reg query \\{NODEA}\HKLM\System\CurrentControlSet\Control\TimeZoneInformation
@@reg query \\{NODEB}\HKLM\System\CurrentControlSet\Control\TimeZoneInformation added. (HL60686)
@@Additional raidutil commands are added. (HL41654)
@@20100929AUSBINCXC1371120/4 R7E
@@Introduced the command for AP number (HL97608)
@@Introduced command to find the veritas version(HM54509)
@@Revised the query for obtaining APG43 hardware version (HM71509)
@@Introduced the command to check the frchangedisk version (HM71623)
@@Introduced command to check the BIOS revision (HM71628)
@@Added the command to check the DVD model and the write cache status(HM76392)
@@Added the command to quota of disks for APG43(HM76423)
@@Added the command to list the hardware configuration table(HM77062)
@@Added the command to check if the autoadminlogon feature is enabled or not(HM91777)
@@20110106AUSBINCXC1371120/4 R7F
@@Added command to check the cluster configuration (HL74967)
@@20110615AUSBINCXC1371120/4 R8A
@@ Changed the code to find the HKU Administrator registry key(HO21753)
@@ Added a command to check the wsrm service startup type and state(HO57613)
@@ Added a command to check if the folder V:\APZ\DATA\BOOT is present or not(HO57613)
@@ Added new folders for cacls check for system disks(HO40579)
@@20110825AUSBINCXC1371120/4 R8B
@@ Included new folders under cacls command (HO66275)
@@20110311AUSBINCXC1371120/4 R9A
@@ Included the check for the cluster quorum (HP33515 )
@@ Included the commands for APDISKDIAG (HP46113 )
@@Included commands related toEVO (HP41525 )
@@Included commands related to HCS service (HP41532)
@@Start logging to file.
@@The logfile name is set to C:\Temp\AP_Audit_R9A_"hostname"_"nodestate"_"osversion"_"date"_"time".log
@Z-
@R-
hostname
@COPY {_line1}{hostname}1 30
prcstate
@COPY {_line1}{nodestate}1 9
ver
@COPY {_line2}{osver} 1 22
@IF {osver} = "Windows NT Version 4.0" THEN SET {osver}="NT4"
@IF {osver} = "Microsoft Windows [Ver" THEN SET {osver}="WinS03"
@GETDATE {date} YYMMDD
@GETTIME {time} HHMM
@SET {_VERSION}=wf
@SET {cdt}=NO
dir C:\Temp\audit.lite
@COPY {_line6}{light}40 10
@IF {light} = audit.lite THEN SET {cdt}=YES
del C:\Temp\audit.lite >nul 2<&1
@LOG ON C:\Temp\AP_Audit_R9A_{hostname}_{nodestate}_{osver}_{date}_{time}.log
@GETTIME {start_hh} HH
@GETTIME {start_mm} MM
echo "AUSBIN CXC 137 1120/4 R9A"
cd /d C:\
@COMMENT DATE={date}, TIME={time}
@SET {WinFIOLver}="WinFIOL version unknown"
@IF {_VERSION} = "wf" THEN GOTO WINFIOLver6
@LENGTH {_VERSION} {length1}
@IF {length1} = 2 THEN GOTO WINFIOLverCheck
@IF {length1} = 3 THEN GOTO WINFIOLverSPCheck
@IF {length1} > 3 THEN GOTO WinFIOLverUnknown
@LABEL WINFIOLverCheck
@COPY {_VERSION} {WinFIOLver1} 1 1
@COPY {_VERSION} {WinFIOLver2} 2 1
@SET {WinFIOLver}="WinFIOL " + {WinFIOLver1} + "." + {WinFIOLver2}
@GOTO WINFIOLend
@LABEL WINFIOLverSPCheck
@COPY {_VERSION} {WinFIOLver3} 3 1
@SET {WinFIOLver}="WinFIOL " + {WinFIOLver1} + "." + {WinFIOLver2} + " SP" + {WinFIOLver3}
@GOTO WINFIOLend
@LABEL WINFIOLver6
@SET {WinFIOLver}="WinFIOL 6.4"
@LABEL WinFIOLverUnknown
@LABEL WINFIOLend
@COMMENT WinFIOL Version: {WinFIOLver}
dsdls | find "MML"
@SCAN {_line1} "MML" {pos}
@LENGTH {_line1}{length1}
@IF {length1} = 0 THEN GOTO NO_MML
@SET {mkah}=MML
@GOTO END_MML
@LABEL NO_MML
@SET {mkah}=NOMML
@LABEL END_MML
dsdls | find /i "ap2"
@IF {length1} = 0 THEN SET {ap_no}="ap1"
@COPY {_line1}{ap_no}1 3
@LOWCASE {ap_no}
@IF {ap_no}<> "ap2" THEN SET {ap_no}="ap1"
@@ Reason: To Identify and time stamp this audit.
hostname
date /t
time /t
@@ Reason: To get the operating system version.
cd /d C:\
ver
@COMMENT OS={osver}
@@ Expected result: NT4 or WinS03.
@@ Reason: To check if this node is Active or Passive.
prcstate
@@ Expected result: active | passive
@@ Reason: Find out which hardware version, APG40/C2, APG40/C4 or APG43.
hwver
@COPY {_line3}{hwver}1 8
@LENGTH {_line3}{length1}
@SET {bchwver} = ""
@IF {length1} = 0 THEN GOTO NO_HWVER
@IF {hwver}="APG40C/4" THEN GOTO HW_SET
@IF {hwver}="APG43" THEN GOTO HW_SET
@LABEL NO_HWVER
@SET {hwver}="APG40C/2"
@LABEL HW_SET
@COMMENT hwver={hwver}
@IF {hwver}="APG40C/4" THEN GOTO NOT_GEP
@IF {hwver}="APG40C/2" THEN GOTO NOT_GEP
reg query "HKLM\Software\Ericsson\Adjunct Processor\APOS" /v HwVersion
@LABEL NOT_GEP
@SET {bc}=""
@@swrsid
@@COPY {_line1}{apzbcver}32 2
nels
@PASTE {systype} {_lines}
@COMPACT {systype}
@SIZE {systype} {numtype}
@SET {indextype} = 1
@WHILE {indextype} < {numtype}
@IF {systype[{indextype}]} MATCHES ".*not recognized.*" THEN GOTO NOT_BC
@BEFORE {APtype} {systype[{indextype}]} ":"
@IF {APtype} MATCHES ".*System Type.*" THEN @AFTER {CPtype} {systype[{indextype}]} ":"
@IF {APtype} MATCHES ".*System Type.*" THEN @BEFORE {CPtype} {CPType} "-"
@IF {APtype} MATCHES ".*System Type.*" THEN @TRIM {CPtype}
@IF {APtype} MATCHES ".*Node Architecture.*" THEN GOSUB APG43_EVO
@INC {indextype}
@ENDWHILE
@COMMENT CPtype={CPtype}
@@IF {NodeArc} MATCHES ".*Component Based Architecture.*" THEN GOTO APG43_EVO
@IF {CPtype} = "Multi" THEN SET {bchwver}="BC"
@LABEL NOT_BC
@@COMMENT hwver={hwver}
@@COMMENT bchwver={bchwver}
@@ Expected result: APG40/C2, APG40/C4 or APG43 stored in var {hwver}.
@@ Reason: To get the computer name
@SET {NODEA} = %COMPUTERNAME:~0,-1%A
@SET {NODEB} = %COMPUTERNAME:~0,-1%B
@@ Reason: To get the system software history.
swrsid -h
@@ Expected result: A history list.
@@ Reason: To check that correct software is installed.
swrprint -a
@@ Expected result: compare with proper CM-level.
@@ Reason: To check that software folders match swrprint above.
dir /s C:\acs\data\FCH\current\ | findstr /I "CXC SETUP.EXE"
@@ Expected result: compare with swrprint and the other node.
@@ Reason: To check which hot fixes and security patches are installed.
@IF {hwver} = "APG43" THEN GOTO END_SECPATCHES
type "C:\Program Files\FORCE\hflist.txt"
cd /d C:\temp && regedit /e C:\temp\hfix.log "HKEY_LOCAL_MACHINE\SOFTWARE\FORCE Computers\LBB\Hotfix\"
@T 5
if exist C:\temp\hfix.log type C:\temp\hfix.log && del C:\temp\hfix.log
@@ Expected result: R1.1 has to be installed before S3.2 is installed
@@,if not S2.4 might be corrupt.
@@Note: This is not valid after R1.9
@LABEL END_SECPATCHES
@@ Reason: Check if the repair fix 109 22-APZ 212 30/4-494 was correct installed.
cd /d c:\temp && regedit /eRunOnce.txt "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce"
cd /d c:\temp && regedit /eRunOnceEx.txt "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnceEx"
type RunOnce.txt && del RunOnce.txt
type RunOnceEx.txt && del RunOnceEx.txt
@@ Expected Result: Empty keys, otherwise S2.4 installation is not completed.
@@ Reason: Check the registered IE version.
cd /d C:\temp && regedit /e iever.log "HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\"
@COMMENT IE_Ver
type iever.log | FindStr /R "^\"Ve"
del iever.log
@@ Expected Result: The first Version key printed is the IE version.
@@ Reason: To check the diskeeper installer file/folder
@IF {hwver} = "APG43" THEN GOTO NO_DISKEEPER_INST
@LABEL NO_DISKEEPER_INST
@@ Reason: To Check for incorrectly installed files.
dir "C:\Program Files\AP\" /s | findstr /ie "\.1"
@@ Expected result: No filenames ending with .1 should be printed.
@@ Reason: Check that SSH installation is correct. (SCS534984)
dir "C:\Program Files\F-Secure\ssh server"
@@ Expected result:No filenames ending with .1 should be printed.
@@ Reason: OSU: Check that no leftovers exist from any earlier OSU attempt. (TR HG95576)
@IF {osver} = "WinS03" THEN GOTO NO_NTDSNT4
cd /d c:\temp && regedit /eNtdsnt4.txt "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\NTDS"
type Ntdsnt4.txt && del Ntdsnt4.txt
@@ Expected result:No keys should exist.
@LABEL NO_NTDSNT4
@@ A bug in Pragma Telnet Server Build 7 may result in no user profile being created when user logs in using telnet.
@@ Upgrade to Pragma Telnet Server Build 10 is done with LBB Hotfix 5.3.1 (AC-A16 for R9.1),
@@ however due to a problem at installation of LBB 5.3.1 the Pragma Telnet Server remains on Build 7 although
@@ LBB Hotfix 5.3.1 shows that installation is successful and swrprint shows that Pragma Telnet Server Build 10 is installed.
@@ Primus solution SCS494532 has been created, and the next check can be done:
@IF {hwver} = "APG43" THEN GOTO NOP_PRAGMA
@IF {osver} = "WinS03" THEN GOTO NO_PRAGMA
type "C:\Program Files\Pragma\TelnetD\readme.txt" | findstr /C:"2000 Build"
dir "C:\Program Files\Pragma\TelnetD\TELNETD.exe"
@@ Expected result:
@@ Pragma TelnetServer 2000 Build 7
@@ Directory of C:\Program Files\Pragma\TelnetD
@@ 10/03/0208:33a163,840 TELNETD.exe
@@ 1 File(s)163,840 bytes
@@ Note: The size of file TELNETD.exe is 163840 bytes for Build 7, and 172032 bytes for Build 10.
@@ If wrong version of Telnet served is installed, the solution can be applied.
@LABEL NO_PRAGMA
@@ Reason: OSU: To check that no other user than Default is defined in the Pragma Telnet Server.
cd /d C:\temp && regedit /e Pragma_HKLM.txt "HKEY_LOCAL_MACHINE\SOFTWARE\PragmaSystems\TelnetD\Users\"
type C:\temp\Pragma_HKLM.txt | find "[HKEY_LOCAL_MACHINE\SOFTWARE\PragmaSystems\TelnetD\Users\\"
@@ Expected result: Nothing else than Default entries are printed
@@ [HKEY_LOCAL_MACHINE\SOFTWARE\PragmaSystems\TelnetD\Users\\Default]
@@ [HKEY_LOCAL_MACHINE\SOFTWARE\PragmaSystems\TelnetD\Users\\Default\Environment]
@@ [HKEY_LOCAL_MACHINE\SOFTWARE\PragmaSystems\TelnetD\Users\\Default\TerminateStrings]
@@ Logging more pragma configuration data:
type C:\temp\Pragma_HKLM.txt && del C:\temp\Pragma_HKLM.txt
cd /d C:\temp && regedit /e Pragma_Tel.txt "HKEY_LOCAL_MACHINE\SOFTWARE\PragmaSystems\TelnetD\"
type C:\temp\Pragma_Tel.txt && del C:\temp\Pragma_Tel.txt
cd /d C:\temp && regedit /e Pragma_Env.txt "HKEY_LOCAL_MACHINE\SOFTWARE\PragmaSystems\TelnetD\Users\Default\Environment\"
type C:\temp\Pragma_Env.txt && del C:\temp\Pragma_Env.txt
cd /d C:\temp && regedit /e Pragma_Term.txt "HKEY_LOCAL_MACHINE\SOFTWARE\PragmaSystems\TelnetD\Users\Default\TerminateStrings\"
type C:\temp\Pragma_Term.txt && del C:\temp\Pragma_Term.txt
@LABEL NOP_PRAGMA
@@ Reason: AP: Multiple Time Zone Link List.
@@ No time difference between both the APG Nodes.
@@ CP:Time zones, GMT, summer time periods (if defined).
@@ No time deviation should exist between AP and CP clocks.
net time \\{NODEA} && net time \\{NODEB}
tzls -a
cd /d C:\temp && regedit /e tz.log "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\TimeZoneInformation\"
@T 10
type C:\temp\tz.log
@T 5
del C:\temp\tz.log
@IF {nodestate} <> "active" THEN GOTO NO_PASSIVE_1
mtzln -p
date /t&time /t&mml CACLP:ALL;
@@ Expected result:TMZ : TZ
@@ 0 = (GMT+01:00) Brussels, Berlin, Bern, Rome,
@@Stockholm, Vienna
@LABEL NO_PASSIVE_1
@@ Reason: Display environment variables, verify the path settings.
set
@@ Expected result: The environment variable, output depending of installed
@@applications. Verify the path settings
@@ Example from 11.3 AC-M314
@@ AP_HOME=C:\Program Files\AP
@@ AVENGINE=C:\PROGRA~1\CA\SHARED~1\SCANEN~1
@@ ClusterLog=C:\acs\logs\Cluster.log
@@ ClusterLogLevel=3
@@ COMPUTERNAME=AP150B
@@ ComSpec=C:\WINNT\system32\cmd.exe
@@ CRTERM=ansi
@@ HOMEDRIVE=C:
@@ HOMEPATH=\
@@ INCLUDE=C:\Program Files\Mts\Include
@@ INOCULAN=C:\PROGRA~1\CA\ETRUST~1
@@ LIB=C:\Program Files\Mts\Lib
@@ NUMBER_OF_PROCESSORS=1
@@ OS=Windows_NT
@@ Os2LibPath=C:\WINNT\System32\os2\dll;
@@ Path=C:\WINNT\system32;C:\WINNT;C:\Program Files\Pragma\Shared Files;C:\Program Files\Pragma\Toolkit;C:\PROGRA~1\Distinct;
@@ C:\PROGRA~1\COMMON~1\DISTIN~1;c:\Program Files\FORCE\AM_Services;c:\Program Files\Pkzip;C:\Program Files\Mts;
@@ C:\Program Files\Dptmgr;C:\Program Files\AP\ACS\bin;C:\Program Files\AP\ACS\lib;C:\Program Files\AP\OCS\bin;
@@ C:\Program Files\AP\OCS\lib;C:\Program Files\AP\AES\bin;C:\Program Files\AP\AES\lib;C:\PROGRA~1\F-Secure\ssh;
@@ C:\PROGRA~1\CA\SHARED~1\SCANEN~1;C:\PROGRA~1\CA\ETRUST~1;C:\Program Files\AP\CPS\bin;C:\Program Files\AP\CPS\lib;
@@ C:\Program Files\AP\FMS\bin;C:\Program Files\AP\FMS\lib;C:\Program Files\AP\MAS\bin;C:\Program Files\AP\MAS\lib;
@@ C:\Program Files\AP\MCS\bin;C:\Program Files\AP\MCS\lib;C:\Program Files\AP\PES\bin;C:\Program Files\AP\PES\lib;
@@ C:\Program Files\AP\STS\bin;C:\Program Files\AP\STS\lib;
@@ PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.JS
@@ PRAGMASYS_INETD_PID=137
@@ PRAGMASYS_INETD_SOCK=216
@@ PRAGMASYS_MODE=Stream
@@ PRAGMASYS_REMOTE_ADDR=134.138.111.22
@@ PRAGMASYS_TELNETD_PID=779
@@ PROCESSOR_ARCHITECTURE=x86
@@ PROCESSOR_IDENTIFIER=x86 Family 6 Model 8 Stepping 6, GenuineIntel
@@ PROCESSOR_LEVEL=6
@@ PROCESSOR_REVISION=0806
@@ Prompt=$P$G
@@ SystemDrive=C:
@@ SystemRoot=C:\WINNT
@@ TEMP=C:\TEMP
@@ TERM=ansi
@@ TMP=C:\TEMP
@@ USERDOMAIN=AP150DOM
@@ USERNAME=Administrator
@@ USERPROFILE=C:\WINNT\Profiles\Administrator
@@ windir=C:\WINNT
@@ Reason: OSU: Check default input language.
@@ Some keyboards settings may cause Pragma to malfunction in Windows Server 2003.
@@ (TR HH28381, Italian Keyboard setting).
@COMMENT Current user
@@locale ID (LCID):
cd /d C:\temp && regedit /e KEYB.txt "HKEY_Current_User\Keyboard Layout\Preload\"
type C:\temp\Keyb.txt && del C:\temp\Keyb.txt
@@ LCID defined substitute:
cd /d C:\temp && regedit /e Keyb.txt "HKEY_Current_User\Keyboard Layout\Substitutes\"
@COMMENT Default user
@@ locale ID (LCID):
cd /d C:\temp && regedit /e KEYB.txt "HKEY_Users\.DEFAULT\Keyboard Layout\Preload\"
cd /d C:\temp && regedit /e Keyb.txt "HKEY_Users\.DEFAULT\Keyboard Layout\Substitutes\"
@COMMENT Administrator
reg query "HKU" | findstr -e 500
@LENGTH {_line1} {length}
@IF {length} = 0 THEN GOTO END_KEYB
@set {hku_admin} = {_line1}
@IF {osver} = "NT4" THEN GOTO NO_QUERY
REG QUERY "{hku_admin}\Keyboard Layout\Preload"
REG QUERY "{hku_admin}\Keyboard Layout\Substitutes"
@GOTO END_KEYB
@LABEL NO_QUERY
cd /d C:\temp && regedit /e Keyb.txt "HKEY_USERS{key}Preload\"
cd /d C:\temp && regedit /e Keyb.txt "HKEY_USERS{key}Substitutes\"
@LABEL END_KEYB
@@ Expected result: OSU: If 'Italian (Italy) - Italian' keyboard is the default setting (00000410="it"),
@@change it to
@@English (United States) - US,00000409="us".
@@ Reason: OSU: To check that no empty user variable PATH exist.
@IF {osver} = "WinS03" THEN GOTO OSU_ONLY_NT4
cd /d C:\temp && regedit /e hk_users.txt "HKEY_USERS"
type hk_users.txt | find /I "
ATH"
del hk_users.txt
@@ Expected result: No occurrences of "PATH"=""
@@ It's a requirement before starting OSU that no empty user variable PATH exist.
@@ Reason: OSU: Check for file c:\winnt\backup.fts (TR HG66302).
dir c:\winnt\System32\backup.fts
@@ Expected result: file backup.fts present.
@@ It's a requirement before starting OSU that the file exist.
@@ If it's missing a "dummy" file named backup.fts can be created or copied
@@ from the other node.
@LABEL OSU_ONLY_NT4
@@ Reason: OSU: Check for directories that should be files (TR HG72032).
dir C:\ /s /b /a /ad|findstr \.|findstr /v /r \..*\\|findstr /v \\\.|findstr /v ".IE5 assembly WinSxS profiles"
@@ Expected result: No directories found that should be files.
@@(OS2.EXE OS2SRV.EXE)
@@ Reason: OSU: Check if Display of Legal Notice is active for PC-Anyware and
@@Console login.
cd /d c:\temp && regedit /e Legal_Notice.txt "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon"
type Legal_Notice.txt| find "LegalNoticeCaption"
type Legal_Notice.txt| find "LegalNoticeText"
del Legal_Notice.txt
@@ Expected result:
@@ "LegalNoticeCaption"=""
@@ "LegalNoticeText"=""
@@ For OSU it's a requirement that no Legal Notice message is displayed at autologon.
@@ Reason : Checking the verbosity files in C:\acs\data\FCR
@@ Expected result: This file should not present. Output for the above command:
@@The system cannot find the file specified.
@@ Reason: To verify that no memory/handle leaks exist.
@@To check memory configuration, allocation and usage.
@@To check the pagefile.
pstat
@@ Expected result: This is an example of reasonable values of an msc
@@Pstat version 0.3:memory: 785844 kbuptime:10:26:56.631
@@PageFile: \??\C:\pagefile.sys
@@Current Size: 819200 kbTotal Used:1264 kbPeak Used1272 kb
@@ Memory: 785844K Avail: 549748KTotalWs: 329784K InRam Kernel: 2416K P:19140K
@@ Commit: 217596K/ 179384K Limit:1566560K Peak: 234464KPool N: 9416K P:19208K
@@ Reason: To make sure no serious alarms exist.
alist
@IF {nodestate} <> "active" THEN SET {cpno}="CP not"
@IF {mkah} <> "MML" THEN SET {cpno}="CP not"
@IF {mkah} <> "MML" THEN GOTO NO_PASSIVE_2
@IF {nodestate} <> "active" THEN GOTO NO_PASSIVE_2
@IF {bchwver} = "BC" THEN GOTO BC_ALACP_CHECK
mml ALACP;
@GOTO BC_ALACP_END
@LABEL BC_ALACP_CHECK
mml -cp ALL ALACP;
@LABEL BC_ALACP_END
@COPY {_line1}{cpno} 1 5
@IF {cpno} <> "ALARM" THEN SET {cpno}="CP not"
@IF {cpno} = "CP not" THEN GOTO NO_PASSIVE_2
@COPY {_line5}{alacp} 109
@IF {bchwver} = "BC" THEN GOTO BC_ALLIP_CHECK
mml ALLIP:ALCAT={alacp};
mml ALLIP:ACL=A1;ALLIP
RCA=39;
@GOTO BC_ALLIP_END
@LABEL BC_ALLIP_CHECK
mml -cp ALL ALLIP:ALCAT={alacp};
mml -cp ALL ALLIP:ACL=A1;ALLIP
RCA=39;
@LABEL BC_ALLIP_END
@@ Expected result: No APZ alarms should exist.
@@ Reason: To check status of the LAN's towards the AP directory service.
@IF {bchwver} = "BC" THEN GOTO BC_APAMP_CHECK
mml APAMP;
@GOTO APAMP_CHECK_END
@LABEL BC_APAMP_CHECK
mml -cp ALL APAMP;
@LABEL APAMP_CHECK_END
@@ Expected result: The STATUS shall be: one ACTIVE and one PASSIVE
@@ link towards each node.
@LABEL NO_PASSIVE_2
@@ Reason: To check status of the directory service (internal in the AP
@@ and towards the cp.
dsdls -a
@@ Expected result: Both the internal AP node and the cp0 should be
@@ listed with their applications registered within dsd.
@@ Reason : To check the AP node number
phaprint ACS_ALHEXECBIN_apNodeNumber
@@Expected result: The AP node number should be listed
@@ Reason: To check that the communication devices are working properly.
@IF {mkah} <> "MML" THEN GOTO NO_MML_OR_AP2
@IF {nodestate} <> "active" THEN GOTO NO_CP
@IF {cpno} = "CP not" THEN GOTO NO_CP
@IF {bchwver} = "BC" THEN GOTO BC_OCTDP_CHECK
mml OCTDP;
@GOTO OCTDP_CHECK_END
@LABEL BC_OCTDP_CHECK
mml -cp ALL OCTDP;
@LABEL OCTDP_CHECK_END
@@ Expected result: Connections should exists over both devices
@@ (around 30), they should be in state NORMAL.
@@ Reason: EXCHANGE IDENTITY DATA
@IF {bchwver} = "BC" THEN GOTO BC_IOEXP_CHECK
mml IOEXP;
@GOTO IOEXP_CHECK_END
@LABEL BC_IOEXP_CHECK
mml -cp ALL IOEXP;
@LABEL IOEXP_CHECK_END
@@ Expected result:EXCHANGE IDENTITY DATA
@@ IDENTITY
@@ 4101R1KREF240CM013 626
@@ Reason: To check the CP hardware versions.
@SET {apzversion} = 0
@IF {bchwver} = "BC" THEN GOTO BC_DPHIP_CHECK
mml DPHIP;
mml SAOSP;
@GOTO BC_DPHIP_END
@LABEL BC_DPHIP_CHECK
mml -cp ALL DPHIP;
mml -cp ALL SAOSP;
@LABEL BC_DPHIP_END
@@ Extracting the APZ Version and Type
mml saosp | find "APZ VERSION"
@SCAN {_line1} "APZ VERSION" {pos}
@SET {pos} = {pos}-5
@COPY {_line1}{apzver} {pos}3
@TRIM {apzver}
mml saosp | find "APZ TYPE"
@SCAN {_line1} "APZ TYPE" {pos}
@COPY {_line1}{apzver1} {pos}3
@TRIM {apzver1}
@CONCAT {apzversion} {apzver1} {apzver}
@@ Expected result: A printout of the hardware identities of all
@@ the boards in the CP. Check IPNX, IPNA or IPNAX versions.
@@ Recommended lowest versions:
@@ IPNX and IPNA:
@@ IPNXROJ 207 503/1 R2A
@@ RPIRS-1ROJ 207 124/2 R2A (IPNA)
@@ IPNAX:
@@ IPNAXROJ 208 435/1R2A
@@ IPNAXROJ 208 435/2R1A
@@ Reason: To check the CP EVENT RECORD.
@IF {bchwver} = "BC" THEN GOTO BC_DIRCP_CHECK
mml DIRCP;
@GOTO BC_DIRCP_END
@LABEL BC_DIRCP_CHECK
mml -cp ALL DIRCP;
@LABEL BC_DIRCP_END
@@ Expected result: A printout of the CP EVENT RECORD
@@ Reason: To check the IPN status.
@@ Note: Only for Classic, APZ 212 3X
@IF {apzver} > "33" THEN GOTO NO_IPN
mml "OCINP:IPN=ALL;OCSIP:IPN=ALL;OCESP:IPN=ALL;"
@LABEL NO_CP
ipnaadm -list
dir K:\OCS\logs
@LABEL NO_MML_OR_AP2
@IF {ap_no} = "ap2" THEN GOTO NO_IPN_AP2
@@ To avoid printing ipn for other than classic apz's
@@ will only work if win.ini is correct.
type C:\winnt\win.ini | find "y="
@COPY {_line1}{wininiver} 11 1
@SET {classic}=0
@IF {wininiver} = "c" THEN SET {classic} = 1
@IF {wininiver} = "C" THEN SET {classic} = 1
@IF {classic} <> 1 THEN GOTO NO_IPN
@@ IPN to find out if last ipn fc was correct.
type C:\tftpboot\boot.ipn0
type C:\tftpboot\boot.ipn1
type C:\tftpboot\boot.ipn2
type C:\tftpboot\boot.ipn3
fc c:\tftpboot\boot.ipn0 c:\tftpboot\boot.ipn1
fc c:\tftpboot\boot.ipn2 c:\tftpboot\boot.ipn3
type c:\"Program Files"\AP\OCS\conf\boot.ipnX.cp_loading
type c:\"Program Files"\AP\OCS\conf\boot.ipnX.not_loading
fc c:\tftpboot\boot.ipn0 c:\"Program Files"\AP\OCS\conf\boot.ipnX.cp_loading
fc c:\tftpboot\boot.ipn1 c:\"Program Files"\AP\OCS\conf\boot.ipnX.cp_loading
fc c:\tftpboot\boot.ipn2 c:\"Program Files"\AP\OCS\conf\boot.ipnX.not_loading
fc c:\tftpboot\boot.ipn3 c:\"Program Files"\AP\OCS\conf\boot.ipnX.not_loading
@@ Expected result: Correct versions on board and in configuration files.
@@For an AP-2 ipnaadm -list should normally be empty
@@ Reason: To get the IPN osdumps.
@IF {nodestate} <> "active" THEN GOTO NO_PASSIVE_4
@@IPNA00:
@@for %i in (k:\ocs\logs\*ipna00*) do echo "Typing %~ni " && ipnaadm -osdump -get %~nxi
@@IPNA01:
@@for %i in (k:\ocs\logs\*ipna01*) do echo "Typing %~ni " && ipnaadm -osdump -get %~nxi
@@ Expected result: The IPN osdumps are printed for later analysis.
@GOTO NO_PASSIVE_4
@LABEL NO_IPN_AP2
ipnaadm -list
@LABEL NO_IPN
@LABEL NO_PASSIVE_4
@@ Reason: Check network status.
netstat -an
@@ Expected result: Total Connections: 400-500
@@ESTABLISHED: 75-100
@@LISTENING: 200-300
@@TIME_WAIT and CLOSE_WAIT: Varies a lot.
@@ Reason: Network statistics.
netstat -s
@@ Expected result: Statistics
@@ Reason: Verify that no important corrections are missing.
@IF {mkah} <> "MML" THEN GOTO NO_PASSIVE_5
@IF {nodestate} <> "active" THEN GOTO NO_PASSIVE_5
@IF {bchwver} = "BC" THEN GOTO BC_PCORP_CHECK
mml "PCORP:BLOCK=APAP&MTAP&JTP&OCAD&OCADM&OCITS&AD2";
@GOTO PCORP_CHECK_END
@LABEL BC_PCORP_CHECK
mml -cp ALL "PCORP:BLOCK=APAP&MTAP&JTP&OCAD&OCADM&OCITS&AD2";
@LABEL PCORP_CHECK_END
@@ Expected result: Corrections according to current CM/ACA level.
@@ Reason: To check that no buffer congestions are present.
@IF {bchwver} = "BC" THEN GOTO BC_LABUP_CHECK
mml LABUP;
@GOTO LABUP_CHECK_END
@LABEL BC_LABUP_CHECK
mml -cp ALL LABUP;
@LABEL LABUP_CHECK_END
@@ Expected result: NCONG = 0
@LABEL NO_PASSIVE_5
@@Hardware dependent checks
@IF {bchwver}="BC" THEN GOSUB BC_HW
@IF {hwver}="APG43" THEN GOSUB APG43_HW
@IF {hwver}="APG40C/4" THEN GOSUB HW_C4
@IF {hwver} = "APG40C/2" THEN GOSUB HW_C2
@@ Reason: To verify the LINK SPEED in the SCB-RP boards
@@IF {hwver} <> "APG43" THEN GOTO SCB_END
@@hwcls | findstr "SCB-RP"
@@PASTE {SCBInfo} {_lines}
@@COMPACT {SCBInfo}
@@SIZE {SCBInfo} {nlines}
@@IF {nlines} <=1 THEN GOTO SCB_END
@@SET {indexval} = 1
@@SET {SCBRP_AP2} = 0
@@WHILE {indexval} < {nlines}
@@COPY {SCBInfo[{indexval}]} {chkipval} 1 8
@@TRIM {chkipval}
@@IF {chkipval} MATCHES "1.2.0.4" THEN GOTO STORE_IP_AP1
@@IF {chkipval} MATCHES "15.2.0.4" THEN GOTO STORE_IP_AP2
@@GOTO IP_STORED
@@LABEL STORE_IP_AP2
@@SET {SCBRP_AP2} = 1
@@LENGTH {SCBInfo[{indexval}]} {Lenval_AP2}
@@COPY {SCBInfo[{indexval}]} {FullLine_AP2} 1 {Lenval_AP2}
@@CUT {slotval_AP2} {FullLine_AP2} COL 2 Sep " "
@@IF {slotval_AP2} MATCHES "25" THEN GOTO Slot_IP25_AP2
@@ Storing IP Address of SCB-RP with Slot 0
@@CUT {IPvalue0A_AP2} {FullLine_AP2} COL 6 Sep " "
@@CUT {IPvalue0B_AP2} {FullLine_AP2} COL 7 Sep " "
@@GOTO IP_STORED
@@ Storing IP Address of SCB-RP with Slot 25
@@LABEL Slot_IP25_AP2
@@CUT {IPvalue25A_AP2} {FullLine_AP2} COL 6 Sep " "
@@CUT {IPvalue25B_AP2} {FullLine_AP2} COL 7 Sep " "
@@GOTO IP_STORED
@@LABEL STORE_IP_AP1
@@LENGTH {SCBInfo[{indexval}]} {Lenval}
@@COPY {SCBInfo[{indexval}]} {FullLine} 1 {Lenval}
@@CUT {slotval} {FullLine} COL 2 Sep " "
@@IF {slotval} MATCHES "25" THEN GOTO Slot_IP25
@@CUT {IPvalue0A} {FullLine} COL 6 Sep " "
@@CUT {IPvalue0B} {FullLine} COL 7 Sep " "
@@GOTO IP_STORED
@@LABEL Slot_IP25
@@CUT {IPvalue25A} {FullLine} COL 6 Sep " "
@@CUT {IPvalue25B} {FullLine} COL 7 Sep " "
@@LABEL IP_STORED
@@INC {indexval}
@@ENDWHILE
@@ Connecting to SCB-RP Slot 0 using Telnet with IPA
@@COMMENT Connecting to SCB-RP Slot 0 with IPA : {IPvalue0A}
@@telnet /R {IPvalue0A}
@@GOSUB SCB_Information
@@ Connecting to SCB-RP Slot 0 using Telnet with IPB
@@COMMENT Connecting to SCB-RP Slot 0 with IPB : {IPvalue0B}
@@telnet /R {IPvalue0B}
@@ Connecting to SCB-RP Slot 25 using Telnet with IPA
@@COMMENT Connecting to SCB-RP Slot 25 with IPA : {IPvalue25A}
@@telnet /R {IPvalue25A}
@@ Connecting to SCB-RP Slot 25 using Telnet with IPB
@@COMMENT Connecting to SCB-RP Slot 25 with IPB : {IPvalue25B}
@@telnet /R {IPvalue25B}
@@ Checking the SCB-RP for AP2 Configurations
@@IF {SCBRP_AP2} <> 1 THEN GOTO SCB_END
@@ Connecting to SCB-RP Slot 0 using Telnet with IPA on AP2 Machine
@@COMMENT Connecting to SCB-RP Slot 0 for AP2 with IPA : {IPvalue0A_AP2}
@@telnet /R {IPvalue0A_AP2}
@@ Connecting to SCB-RP Slot 0 using Telnet with IPB on AP2 Machine
@@COMMENT Connecting to SCB-RP Slot 0 for AP2 with IPB : {IPvalue0B_AP2}
@@telnet /R {IPvalue0B_AP2}
@@ Connecting to SCB-RP Slot 25 using Telnet with IPA on AP2 Machine
@@COMMENT Connecting to SCB-RP Slot 25 for AP2 with IPA : {IPvalue25A_AP2}
@@telnet /R {IPvalue25A_AP2}
@@ Connecting to SCB-RP Slot 25 using Telnet with IPB on AP2 Machine
@@COMMENT Connecting to SCB-RP Slot 25 for AP2 with IPB : {IPvalue25B_AP2}
@@telnet /R {IPvalue25B_AP2}
@@LABEL SCB_END
@@ Reason: Check that the IIS Meta database is consistent.
@IF {osver} = "WinS03" THEN GOTO NOMD
mdutil enum_all
@@ Expected result: Readable ACSII output.
@@ Reason: Check FTP Sites settings.
mdutil get MSFTPSVC/
mdutil get MSFTPSVC/1
mdutil get MSFTPSVC/2
mdutil get MSFTPSVC/3
@@ Expected result:
@@AllowAnonymous "Default FTP Site" = 0 ,APIO_1 & APIO_2 = 1
@@LogType "Default FTP Site" = 1 ,APIO_1 & APIO_2 = 0
@LABEL NOMD
@@ Reason: Dump the Users in the System.
userdump
@@ Expected result: 1) Simple test of PDC/BDC communication
@@2) Both service users exist and are not Locked or
@@Disabled.
@@ OSU: Make sure that Administrator doesn't have membership in
@@ OSU: Performing an upgrade using an account that will expire during the upgrade
@@can cause unpredictable behaviour in the AP.
@@Please verify the expiry data and modify or remove if required.
@@ Reason: Check that the virtual directories are correct.
ftpls
vdls -n "Default FTP Site"
vdls -n "APIO_1"
vdls -n "APIO_2"
@@ Expected result: Only absolute paths are used, no "shares" used.
@@ OSU: "Default FTP Site" has to be "C:\Inetsrv\ftproot"
@@ Example:
@@C:\>ftpls
@@Microsoft (R) Windows Script Host Version 5.6
@@Copyright (C) Microsoft Corporation 1996-2001. All rights reserved.
@@Site Name"Default FTP Site"
@@IP Address
@@Physical Path"c:\inetsrv\ftproot"
@@Site Status "STARTED"
@@Site Name"APIO_1"
@@IP Address:Port:"192.168.169.1:21:"
@@Physical Path"c:\inetsrv\cpftproot"
@@Site Name"APIO_2"
@@IP Address:Port:"192.168.170.1:21:"
@@C:\>vdls -n "Default FTP Site"
@@Virtual Directory ACS
@@Physical Path"C:\ACS\data\FTP"
@@Virtual Directory ftpvol
@@Physical Path"G:\ftpvol"
@@Virtual Directory images
@@Physical Path"M:\images"
@@Virtual Directory tcm_load
@@Physical Path"v:\apz"
@@C:\>vdls -n "APIO_1"
@@Virtual Directory APZ
@@Physical Path"V:\APZ"
@@Virtual Directory cpa
@@Physical Path"V:\APZ\data\CPA\CPHW\crash"
@@Virtual Directory cpb
@@Physical Path"V:\APZ\data\CPB\CPHW\crash"
@@Virtual Directory CPSDUMP
@@Physical Path"L:\CPS\data\FTP"
@@Virtual Directory CPSLOAD
@@Physical Path"L:\FMS\data\CPF\RELVOLUMSW"
@@C:\>vdls -n "APIO_2"
@@ Reason: Check anonymous logon setting for the FTP Sites. (TR HH29261)
@IF {osver} = "NT4" THEN GOTO NO_WMIC
wmic /namespace:\\root\MicrosoftIISv2 path IIsFtpServerSetting WHERE "ServerComment='Default FTP Site'" GET AllowAnonymous
wmic /namespace:\\root\MicrosoftIISv2 path IIsFtpServerSetting WHERE "ServerComment='Default FTP Site'" GET LogType
wmic /namespace:\\root\MicrosoftIISv2 path IIsFtpServerSetting WHERE "ServerComment='APIO_1'" GET AllowAnonymous
wmic /namespace:\\root\MicrosoftIISv2 path IIsFtpServerSetting WHERE "ServerComment='APIO_1'" GET LogType
wmic /namespace:\\root\MicrosoftIISv2 path IIsFtpServerSetting WHERE "ServerComment='APIO_2'" GET AllowAnonymous
wmic /namespace:\\root\MicrosoftIISv2 path IIsFtpServerSetting WHERE "ServerComment='APIO_2'" GET LogType
@@ Expected result:
@@ 'Default FTP Site': AllowAnonymous = FALSE, LogType = 1
@@ 'APIO_1': AllowAnonymous = TRUE, LogType = 0
@@ 'APIO_2': AllowAnonymous = TRUE, LogType = 0
@LABEL NO_WMIC
@@ Reason: To check that file attributes are correctly set.
attrib C:\*
@@ Expected result: Check that these files have following attributes except
@@for the A attribute that can be either set or not.
@@ NT4:
@@A RC:\AUTOEXEC.BAT
@@AS C:\boot.ini
@@ASHC:\BOOTSECT.DOS
@@AHC:\burinfo.txt
@@A RC:\COMMAND.COM
@@ASHRC:\IO.SYS
@@ASHRC:\MSDOS.SYS
@@ASHRC:\NTDETECT.COM
@@ASHRC:\ntldr
@@ WinS03:
@@ASHRC:\boot.ini
@@SHC:\BOOTSECT.DOS
@@ASHRC:\MSDOS.SYS
@@ASHRC:\ntldr
@@ASHC:\pagefile.sys
@@ Reason: To check that files and that their attributes are correct on E: partition.
@@(TR HG70690)
@SET {attflag}= "/S"
@IF {osver} = "WinS03" THEN SET {attflag}= "/S /D"
attrib E:\* {attflag}
@@ASHRE:\BOOT.INI
@@ASHRE:\ntdetect.com
@@ASHRE:\ntldr
@@A E:\cmdcons\*
@@ASHRE:\boot.ini
@@SHRE:\cmdcons
@@ASHRE:\cmldr
@@ASHRE:\NTDETECT.COM
@@ASHRE:\ntldr
@@SHE:\System Volume Information
dir /a:h e:\
@@ Expected result:
@@ NT4:
@@ Volume in drive E is ntboot
@@ Volume Serial Number is 5C4F-3ADC
@@ Directory of e:\
@@ 10/24/0008:23a 540 BOOT.INI
@@ 01/26/0005:35p 26,832 ntdetect.com
@@ 01/09/0401:33p156,496 ntldr
@@ WinS03:
@@ c:\winnt\profiles\Administrator>dir /a:h e:\
@@Volume Serial Number is A469-E377
@@Directory of e:\
@@ 08/24/200506:54 PM641 BOOT.BAK
@@ 10/28/200509:14 AM641 boot.ini
@@ 10/28/200509:14 AM <DIR> cmdcons
@@ 03/25/200503:00 PM298,096 cmldr
@@ 03/25/200503:00 PM47,772 NTDETECT.COM
@@ 03/25/200503:00 PM295,536 ntldr
@@ 03/09/200601:00 PM <DIR> RECYCLER
@@ 10/28/200508:58 AM <DIR> System Volume Information
@@ 5 File(s)642,686 bytes
@@ 3 Dir(s)20,492,288 bytes free
@@ Note! Check that the hidden directory cmdcons is present on WinS03.
@@ Reason: To check that the AP boots from correct partition.
type e:\boot.ini
@@ Expected result:
@@ NT4:
@@ [boot loader]
@@ timeout=3
@@ default=multi(0)disk(0)rdisk(0)partition(2)\WINNT
@@ [operating systems]
@@ multi(0)disk(0)rdisk(0)partition(2)\WINNT="2 Windows NT Enterprise Server Version 4.00 org"
@@ multi(0)disk(0)rdisk(0)partition(2)\WINNT="2 Windows NT Enterprise Server Version 4.00 org [VGA mode]" /basevideo /sos
@@ multi(0)disk(0)rdisk(0)partition(3)\WINNT="3 Windows NT Enterprise Server Version 4.00 org Backup"
@@ multi(0)disk(0)rdisk(0)partition(3)\WINNT="3 Windows NT Enterprise Server Version 4.00 org Backup [VGA mode]" /basevideo /sos
@@ WinS03:
@@ [boot loader]
@@ timeout=3
@@ multi(0)disk(0)rdisk(0)partition(2)\WINNT="Windows Server 2003 Enterprise" /fastdetect
@@ multi(0)disk(0)rdisk(0)partition(2)\WINNT="Windows Server 2003 Enterprise [VGA mode]" /basevideo /sos /noguiboot /bootlog /safeboot:minimal
@@ multi(0)disk(0)rdisk(0)partition(3)\WINNT="Windows Server 2003 Enterprise Backup" /fastdetect
@@ multi(0)disk(0)rdisk(0)partition(3)\WINNT="Windows Server 2003 Enterprise Backup [VGA mode]" /basevideo /sos /noguiboot /bootlog /safeboot:minimal
@@ C:\CMDCONS\BOOTSECT.DAT="Microsoft Windows Recovery Console" /cmdcons
@@Hardware dependent ACL checks
@IF {cdt} = YES THEN GOTO SKIP_ACL
@IF {hwver}="APG43" THEN GOSUB APG43_ACL
@IF {hwver}="APG40C/4" THEN GOSUB APG40_ACL
@IF {hwver} = "APG40C/2" THEN GOSUB APG40_ACL
@LABEL SKIP_ACL
@@ Reason: To print the IntegrityAP Baseline.
@IF {hwver}="APG43" THEN GOTO APG43_IntegrityAP
type C:\acs\data\fch\current\CXC1371063\IntegrityAP.dir
@GOTO IntegrityAP_END
@LABEL APG43_IntegrityAP
type C:\acs\data\fch\current\CXC1371132\IntegrityAP.dir
@LABEL IntegrityAP_END
type C:\WINNT\system32\IntegrityAP.dir
@@ Expected result: Baseline
@@ Reason: To check if baseline files exist on this system
dir C:\acs\logs\lct
@@ Expected result:
@@11/16/0503:59p583,090 IntegrityAP.da2
@@11/16/0503:59p312,671 IntegrityAP.dat
@@ Reason: To check that LCTBIN CNI 4-203 is implemented correct.
cacls %Systemroot%\repair
@@ Expected result:
@@NT AUTHORITY\SYSTEM
OI)(CI)F
@@BUILTIN\Administrators
OI)(CI)F
@@ Reason: To check the contents of win.ini.
type c:\winnt\win.ini
@@ Expected result: APZ 212 40:
@@Mode=1002
@@Server=1
@@Directory=V:\APZ\data\BOOT
@@Maximum Block Size=1450
@@APZ 212 30/33:
@@Directory=c:\tftpboot
@@Server=1
@@Maximum Block Size=512
@@Mode=1002
@@ Reason: MS Diagnostic report.
@IF {osver} = "WinS03" THEN GOTO NO_WINMSD
cd /d C:\TEMP && winmsd /a
@T 6
find "Free:" %computername%.txt
find "Handles" %computername%.txt
find "Service Account" %computername%.txt | find "\"
type %computername%.txt
@@ Expected result: MS Diagnostic report
@@Check Free/Total disk space,labels, number of Handles etc.
@@Check that same service user runs the services.
@@Passive node should only see disk C:\ D:\ E:\ F:\
@@OSU: correct labels and in lower case only.
@@OSU: If the any of the two points below isn't true this is an indication
@@of that the labels might be incorrect. It must be investigated in detail and
@@if needed corrected before any attempt to start the repartitioning.
@@(TR HG69453 and HG58613)
@@1. Sectors per cluster: 1is ntserv
@@Sectors per cluster: 4is ntbackup
@@2. The line with "Total: 2,086,559 KB" is ntserv
@@The line with "Total: 2,086,558 KB" is ntbackup
@@ examples:
@@Drives Report
@@C:\(Local - NTFS) ntbackup Total: 2,086,558 KB, Free: 305,108 KB
@@Serial Number: DCD6 - D112
@@Bytes per cluster: 512
@@Filename length: 255
@@D:\(Local - NTFS) ntserv Total: 2,086,559 KB, Free: 1,156,650 KB
@@Serial Number: 440C - 3067
@@Sectors per cluster: 1
@@E:\(Local - NTFS) ntboot Total: 30,208 KB, Free: 27,741 KB
@@Serial Number: 5C4F - 3ADC
@@F:\(Local - NTFS) ntdump Total: 4,097,516 KB, Free: 4,049,360 KB
@@Serial Number: C881 - 6A04
@@Sectors per cluster: 8
@@ Reason: Print the Service User profile (NT4).
regedit /e C:\TEMP\ServiceUser.txt "HKEY_LOCAL_MACHINE\Software\Ericsson\Adjunct Processor\ACS\lct"
type C:\TEMP\ServiceUser.txt
@SCAN {_line4} "=" {pos}
@SET {pos} = {pos}+2
@COPY {_line4}{serviceuser} {pos} 20
@COMMENT Service user={serviceuser}
dir /a C:\winnt\profiles\{serviceuser}
dir /a /s C:\winnt\profiles\{serviceuser}
@@ Expected Result: Folders according to example below.
@@ C:\temp>dir /a C:\winnt\profiles\GZYcVOiSHqSf1S7GY1AF
@@Volume in drive C is ntserv
@@Volume Serial Number is 5C0B-41E7
@@Directory of C:\winnt\profiles\GZYcVOiSHqSf1S7GY1AF
@@ 03/30/0601:55p<DIR> .
@@ 03/30/0601:55p<DIR> ..
@@ 03/30/0601:55p<DIR> Application Data
@@ 03/30/0601:55p<DIR> Cookies
@@ 03/30/0601:55p<DIR> Desktop
@@ 03/30/0601:55p<DIR> Favorites
@@ 03/30/0601:55p<DIR> History
@@ 03/30/0601:55p<DIR> Local Settings
@@ 03/30/0601:55p<DIR> NetHood
@@ 03/31/0608:58a147,456 NTUSER.DAT
@@ 03/31/0608:58a1,024 ntuser.dat.LOG
@@ 03/30/0601:55p<DIR> Personal
@@ 03/30/0601:55p<DIR> PrintHood
@@ 03/30/0601:55p<DIR> Recent
@@ 03/30/0601:55p<DIR> SendTo
@@ 03/30/0601:55p<DIR> Start Menu
@@ 03/30/0601:55p<DIR> Templates
@@17 File(s)148,480 bytes
@@407,070,208 bytes free
del C:\TEMP\%computername%.txt
cd /d C:\
@LABEL NO_WINMSD
@@ Reason: Check setupservices.def
type C:\Winnt\system32\setupservice.def
@@ Expected result:
@@ClusSvc
@@LBBAM_Service
@@# Start of lines belonging to CXC1371062 R5E BURBIN
@@burserver
@@# End of lines belonging to CXC1371062
@@# Start of lines belonging to CXC1371059 R2B PRCBIN
@@ACS_PRC_IspService
@@# End of lines belonging to CXC1371059
@@# Start of lines belonging to CXC137499 R4D SFCBIN
@@ACS_SFC_Recovery
@@# End of lines belonging to CXC137499
@@# Start of lines belonging to CXC1371092 R1C ALOGBIN
@@ACS_ALOG_BufMan
@@ACS_ALOG_SysMon
@@ACS_ALOG_SecLog
@@# End of lines belonging to CXC1371092
@@# Start of lines belonging to CXC1371060 R1E FCHBIN
@@acs_fch_server
@@# End of lines belonging to CXC1371060
@@ Only present from AGM015:
@@# Start of lines belonging to CXC1371117 R1A FCRBIN
@@ACS_FCR_Server
@@# End of lines belonging to CXC1371117
@@# Start of lines belonging to CXC1371091 R2B NSFBIN
@@acs_nsf_server
@@# End of lines belonging to CXC1371091
type C:\Winnt\system32\setupservice.def | findstr /v #
@@ Expected result:
@@ ClusSvc
@@ LBBAM_Service
@@ burserver
@@ ACS_PRC_IspService
@@ ACS_SFC_Recovery
@@ ACS_ALOG_BufMan
@@ ACS_ALOG_SysMon
@@ ACS_ALOG_SecLog
@@ acs_fch_server
@@ acs_nsf_server (from AGM015)
@@ ACS_FCR_Server (from AGM015)
@@ Reason: Check lct configuration of the service account
cd /d c:\temp && regedit /e lct.txt "HKEY_LOCAL_MACHINE\SOFTWARE\Ericsson\Adjunct Processor\ACS\LCT"
type lct.txt && del lct.txt
@@ Expected result: The currently existing service account.
@@Check that it correspond to the account used by the services printed above.
@@ Reason: Check automatically started applications.
cd /d c:\temp && regedit /e auto_HKLM.txt "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run"
cd /d c:\temp && regedit /e auto_HKCU.txt "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run"
cd /d c:\temp && regedit /e auto_HKU.txt "HKEY_USERS\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Run"
type auto_HKLM.txt
type auto_HKCU.txt
type auto_HKU.txt
del auto_HK*.txt
@@ Expected result: To identify incorrect configured applications.
@@ Reason: Check workstation and server configuration.
net config workstation
net config server
@@ Expected result:
@@Computer name\\[NODE NAME]
@@User name Administrator
@@Workstation active on NetBT_E100B1 ([mac]) NetBT_E100B2 ([mac]) NetBT_E100B4 ([mac]) NetBT_E100E5([mac])
@@Software versionWindows NT 4.0
@@Workstation domain [DOMAIN NAME]
@@Logon domain [DOMAIN NAME]
@@COM Open Timeout (sec)3600
@@COM Send Count (byte) 16
@@COM Send Timeout (msec)250
@@Server Name\\[NODE NAME]
@@Server Comment
@@Software version Windows NT 4.0
@@Server is active on NetBT_E100B1 ([mac]) NetBT_E100B1 ([mac]) NetBT_E100B4 ([mac]) NetBT_E100B4 ([mac]) NetBT_E100B2 ([mac])
@@NetBT_E100B2 ([mac]) NetBT_E100E5 ([mac]) NetBT_E100E5 ([mac]) NetBt_If4 ([mac]) NetBt_If2 ([mac])
@@Server hidden No
@@Maximum Logged On UsersUnlimited
@@Maximum open files per session2048
@@Idle session time (min)15
@@ Reason: To check the IP Configuration.
ipconfig /all | findstr /I "Primary"
ipconfig /all
@@ Expected result: Verify the settings on the adapters as shown below.
@@ C:\>ipconfig /all
@@ Windows NT IP Configuration
@@Host Name . . . . . . . . . : ap150a.uab.ericsson.se
@@DNS Servers . . . . . . . . : 134.138.226.13
@@134.138.201.17
@@Node Type . . . . . . . . . : Hybrid
@@NetBIOS Scope ID. . . . . . :
@@IP Routing Enabled. . . . . : No
@@WINS Proxy Enabled. . . . . : No
@@NetBIOS Resolution Uses DNS : No
@@ Ethernet adapter E100B1:
@@Description . . . . . . . . : Intel(R) PRO Adapter
@@Physical Address. . . . . . : 00-80-42-13-BD-7D
@@DHCP Enabled. . . . . . . . : No
@@IP Address. . . . . . . . . : 192.168.200.1
@@Subnet Mask . . . . . . . . : 255.255.255.0
@@Default Gateway . . . . . . :
@@ Ethernet adapter E100B4:
@@Physical Address. . . . . . : 00-80-42-13-BD-80
@@IP Address. . . . . . . . . : 192.168.202.1
@@ Ethernet adapter E100B3:
@@Physical Address. . . . . . : 00-80-42-13-BD-7F
@@IP Address. . . . . . . . . : 192.168.201.1
@@ Ethernet adapter E100B2:
@@Physical Address. . . . . . : 00-80-42-13-BD-7E
@@IP Address. . . . . . . . . : 134.138.168.171 (Cluster ip address, only on active node)
@@Subnet Mask . . . . . . . . : 255.255.252.0
@@IP Address. . . . . . . . . : 134.138.168.169
@@Default Gateway . . . . . . : 134.138.168.1
@@Primary WINS Server . . . . : 153.88.194.201
@@Secondary WINS Server . . . : 147.214.112.67
@@ Ethernet adapter E100E5:
@@Description . . . . . . . . : Intel D101ER-based Integrated Fast Ethernet
@@Physical Address. . . . . . : 00-80-37-F2-59-90
@@IP Address. . . . . . . . . : 192.168.169.33 (SPOE only on active node AP-1, .34 for AP-2)
@@IP Address. . . . . . . . . : 192.168.169.1
@@ Ethernet adapter E100E6:
@@Physical Address. . . . . . : 00-80-37-F2-59-91
@@IP Address. . . . . . . . . : 192.168.170.1
@@ Reason: To check that no extra network interfaces exist in registry.
@IF {osver} = "NT4" THEN GOTO SKIPNIC
reg query HKLM\System\CurrentControlset\services\tcpip\parameters\interfaces
@@ Expected result:
@@ Only 8 entries should be found: 6 NIC's and 2 WAN entries.
@@ More entries than that can cause unexpected behaviour.
@@ See Primus SCS736846 and TR HI94847 for more information
@LABEL SKIPNIC
@@ Reason: To check that speed and duplex are correct set on the NIC's.
@IF {osver} = "NT4" THEN GOTO FORCEDPX
@@2K3
regedit /e C:\temp\dupl.txt "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\\{4D36E972-E325-11CE-BFC1-08002bE10318}"
type C:\temp\dupl.txt | findstr /I "DriverDesc SpeedDuplex RequestedMediatype" && del C:\temp\dupl.txt
@@ Expected result:
@@"SpeedDuplex"="0"
@@Ref. Primus SCS645594
@GOTO ENDSPEED
@LABEL FORCEDPX
@@NT4
regedit /e C:\temp\dupl.txt "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\E100B1"
@COMMENT E100B1
type C:\temp\dupl.txt | findstr /I "SpeedDuplex" | findstr /V PROSetNdi && del C:\temp\dupl.txt
regedit /e C:\temp\dupl.txt "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\E100B2"
@COMMENT E100B2
regedit /e C:\temp\dupl.txt "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\E100B3"
@COMMENT E100B3
regedit /e C:\temp\dupl.txt "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\E100B4"
@COMMENT E100B4
regedit /e C:\temp\dupl.txt "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\E100E5"
@COMMENT E100E5
type C:\temp\dupl.txt | findstr /I "Speed ForceDpx" | findstr /V PROSetNdi && del C:\temp\dupl.txt
regedit /e C:\temp\dupl.txt "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\E100E6"
@COMMENT E100E6
@@ Expected result:
@@"SpeedDuplex"=dword:00000000
@@"ForceDpx"=dword:00000000
@@"Speed"=dword:00000000
@@SCS645594
@LABEL ENDSPEED
@@ Reason: To list the entries in the local IP routing table.
route print
@@ Expected result: Example below.
@@ Interface List
@@ 0x1 ........................... MS TCP Loopback interface
@@ 0x2 ...00 80 42 13 bd 7d ...... Intel(R) PRO Adapter
@@ 0x3 ...00 80 42 13 bd 80 ...... Intel(R) PRO Adapter
@@ 0x4 ...00 80 42 13 bd 7f ...... Intel(R) PRO Adapter
@@ 0x5 ...00 80 42 13 bd 7e ...... Intel(R) PRO Adapter
@@ 0x6 ...00 80 37 f2 59 90 ...... Intel D101ER-based Integrated Fast Ethernet
@@ 0x7 ...00 80 37 f2 59 91 ...... Intel D101ER-based Integrated Fast Ethernet
@@ Active Routes:
@@ Network DestinationNetmask Gateway InterfaceMetric
@@0.0.0.0 0.0.0.0 134.138.168.1134.138.168.1691
@@127.0.0.0255.0.0.0127.0.0.1 127.0.0.1 1
@@134.138.168.0 255.255.252.0134.138.168.169134.138.168.1691
@@134.138.168.169255.255.255.255127.0.0.1 127.0.0.1 1
@@134.138.255.255255.255.255.255134.138.168.169134.138.168.1691
@@192.168.169.0 255.255.255.0 192.168.169.1192.168.169.1 1
@@192.168.169.1255.255.255.255127.0.0.1 127.0.0.1 1
@@192.168.170.0 255.255.255.0 192.168.170.1192.168.170.1 1
@@192.168.170.1255.255.255.255127.0.0.1 127.0.0.1 1
@@192.168.200.0 255.255.255.0 192.168.200.1192.168.200.1 1
@@192.168.200.1255.255.255.255127.0.0.1 127.0.0.1 1
@@192.168.200.255255.255.255.255 192.168.200.1192.168.200.1 1
@@192.168.201.0 255.255.255.0 192.168.201.1192.168.201.1 1
@@192.168.201.1255.255.255.255127.0.0.1 127.0.0.1 1
@@192.168.201.255255.255.255.255 192.168.201.1192.168.201.1 1
@@192.168.202.0 255.255.255.0 192.168.202.1192.168.202.1 1
@@192.168.202.1255.255.255.255127.0.0.1 127.0.0.1 1
@@192.168.202.255255.255.255.255 192.168.202.1192.168.202.1 1
@@224.0.0.0224.0.0.0134.138.168.169134.138.168.1691
@@224.0.0.0224.0.0.0 192.168.169.1192.168.169.1 1
@@224.0.0.0224.0.0.0 192.168.170.1192.168.170.1 1
@@224.0.0.0224.0.0.0 192.168.200.1192.168.200.1 1
@@224.0.0.0224.0.0.0 192.168.201.1192.168.201.1 1
@@224.0.0.0224.0.0.0 192.168.202.1192.168.202.1 1
@@255.255.255.255255.255.255.255 192.168.200.1192.168.200.1 1
@@ Reason: OSU: To check that an up-to-date backup is available.
@@and up-to-date backup archives exists on datadisk
@@ alternative: type d:\burinfo.txt
burverify -d
@IF {nodestate} <> "active" THEN GOTO NO_PASSIVE_8
@IF {osver} = "NT4" THEN GOTO K_Images
@IF {hwver} = "APG43" THEN GOTO K_Images
dir /s M:\images
@GOTO NO_PASSIVE_8
@LABEL K_Images
dir /s K:\images
@LABEL NO_PASSIVE_8
dir /od c:\bur
@@ Expected result:
@@ Imagename: cm312_apnnb
@@ Date:10/19/04 4:32:46 PM
@@ Node:APnnB
@@ Status: OK (8948 files and 778 directories copied, 0 locked files)
@@ OSU: No "big" ddi files should exist (Normal size ~50KByte)
@@ Reason: Make sure things in C:\ are ok.
dir /A c:\
@@ Expected result: No large temporary files.
@@Check that directory $oem$ and no other suspicious
@@files or folders exist.
@@ Reason: To list the C drive directory structure.
tree C:\ /A
@@ Expected result: Directory PATH listing for volume ntserv.
@@ Reason: To check the virus signature version.
inocmd32 -sig
@@ Expected result: The versions should be up-to-date.
@@ InoculateIT Signature version:virsig.da023.67.352004/11/18
@@ Vet Signature version:vet.da111.07.87452004/11/19
@@ Reason: To check the antivirus exclusion settings.
@@Valid AVIRBIN CXC1371268/4 R1A APZ 212 30/4-1240
cd /d C:\temp && regedit /e antivir.txt "HKEY_LOCAL_MACHINE\Software\ComputerAssociates\eTrustITM\CurrentVersion\Realtime"
if exist antivir.txt type antivir.txt | find "szExcludeProcessNames"
if exist antivir.txt type antivir.txt | find "szExcludeDirs" && del antivir.txt
@@Valid AVIRBIN CXC1371065/4 R2D APZ21230/4-131
cd /d C:\temp && regedit /e antivir.txt "HKEY_LOCAL_MACHINE\Software\ComputerAssociates\eTrustAntivirus\CurrentVersion\Realtime"
cd /d C:\temp && regedit /e antivir.txt "HKEY_LOCAL_MACHINE\Software\ComputerAssociates\InoculateIT\6.0\Realtime"
@@Valid for AVIRBIN CXC1371035/4 R1E APZ21220/5-1086 (China)
cd /d C:\temp && regedit /e antivir.txt "HKEY_LOCAL_MACHINE\Software\ComputerAssociates\eTrustAntivirusInoculateIT\6.0\Realtime"
@@ Expected result: Processes and partitions currently excluded.
@@ The example is valid for AVIRBIN CXC1371065/4 R2H APZ21230/4-371
@@ Excluded Processes:
@@ "szExcludeProcessNames"="acs_msd_service|acs_rtr_service|acs_usa_sysloga|aes_afp_server.|aes_cdh_server.|
@@ aes_dbo_server.|burServer.exe|cidaemon.exe|cps_busrv.exe|fms_cpf_server.|fosffc.exe|mcs_adh_adm.exe|
@@ mcs_mts_adm.exe|ntagent.exe|pes_clh_server.|rdt.exe|stsmain.exe|stsprov.exe"
@@ Excluded Dirs
@@ "szExcludeDirs"="C:\\acs\\data\\Ftp\\mktrbuild|K:\\Images\\nodeA|K:\\Images\\nodeB|L:\\FMS\\Data|Y:\\RDT"
@@ Reason: Check that A-node is PDC and that B-node is BDC in the domain
@@and that domain related communication works between the nodes.
@IF {osver} = "WinS03" THEN GOTO ERNST
netdom query
netdom bdc
@LABEL ERNST
@@ Netdom query command on A-node:
@@ NetDom 1.8 @1997-98. Written by Christophe Robert - Microsoft.
@@ Querying domain information on computer \\WELOVEAPG40A ...
@@ Computer \\WELOVEAPG40A is a domain controller of WELOVEAPG40DOM.
@@ Searching PDC for domain WELOVEAPG40DOM ...
@@ Found PDC \\WELOVEAPG40A
@@ Connecting to \\WELOVEAPG40A ...
@@ Computer \\WELOVEAPG40A is the PDC of WELOVEAPG40DOM.
@@ Netdom query command on B-node:
@@ Querying domain information on computer \\WELOVEAPG40B ...
@@ Computer \\WELOVEAPG40B is a domain controller of WELOVEAPG40DOM.
@@ Verifying secure channel on \\WELOVEAPG40B ...
@@ Secure channel established successfully with \\WELOVEAPG40A for domain WELOVEAPG40DOM.
@@ Netdom bdc command on A-node and B-node:
@@ Listing BDCs of WELOVEAPG40DOM ...
@@ BDC1 = \\WELOVEAPG40B
@@ Reason: Display connections to shared network resources.
net use
@@ Expected result: No entries in the list.
@@ New connections will be remembered.
@@ There are no entries in the list.
@@ OSU: Mapped connections will only be listed for current user.
@@If this AP Audit script is run with an account other than Administrator (e.g. ossuser),
@@'net use' should also be executed manually with the Administrator account.
@@ Reason: Check information about all of the resources
@@that are shared on the local computer.
net share
@@ Expected result: Example printout from AC-M4225 system.
@@ Share nameResourceRemark
@@ E$E:\Default share
@@ ADMIN$ C:\WINNTRemote Admin
@@ Q$Q:\Default share
@@ IPC$Remote IPC
@@ R$R:\Default share
@@ C$C:\Default share
@@ S$S:\Default share
@@ D$D:\Default share
@@ Y$Y:\Default share
@@ L$L:\Default share
@@ F$F:\Default share
@@ V$V:\Default share
@@ G$G:\Default share
@@ K$K:\Default share
@@ J$J:\Default share
@@ M$M:\Default share
@@ Images K:\Images
@@ NETLOGONC:\WINNT\system32\Repl\Import\S Logon server share
@@ Share CPS L:\
@@ Share FMS L:\
@@ Share JJ:\
@@ Share KK:\
@@ Share LOGSK:\
@@ Share MCS M:\
@@ Share RR:\
@@ Share SS:\
@@ The command completed successfully.
@@ Reason: To check that all services expected to run really runs.
net start
@@ Expected result: A list of all running services.
@@Do an extra check on that:
@@ACS_FCH_server, Messenger, FTP server and AntiVirus
@@services are running.
@@ Example from an active node on AC-M4225 level.
@@ These Windows NT services are started:
@@ ACS_ACSC_Logmaint
@@ ACS_ALH_EXEC
@@ ACS_ALOG_BufMan
@@ ACS_ALOG_Main
@@ ACS_ALOG_SecLog
@@ ACS_ALOG_SysMon
@@ ACS_CHB_ClockSyncService
@@ ACS_CHB_HeartBeatService
@@ ACS_DSD_service
@@ ACS_FCH_Server
@@ ACS_MSD_service
@@ ACS_MSD_service_1
@@ ACS_MSD_service_2
@@ ACS_MSD_service_3
@@ ACS_MSD_service_4
@@ ACS_MSD_service_5
@@ ACS_MSD_service_6
@@ ACS_MSD_service_7
@@ ACS_NSF_Server
@@ ACS_PRC_ClusterControl
@@ ACS_PRC_CountReboot
@@ ACS_PRC_eva
@@ ACS_PRC_IspLogger
@@ ACS_PRC_LBB
@@ ACS_RTR_service
@@ ACS_RTR_service_1
@@ ACS_RTR_service_2
@@ ACS_RTR_service_3
@@ ACS_RTR_service_4
@@ ACS_RTR_service_5
@@ ACS_RTR_service_6
@@ ACS_RTR_service_7
@@ ACS_SFC_Recovery
@@ ACS_SSU_Monitor
@@ ACS_USA_SyslogAnalyser
@@ AES_AFP_server
@@ AES_CDH_server
@@ AES_DBO_server
@@ Alerter
@@ AM-Service
@@ burServer
@@ Cluster Server
@@ Computer Browser
@@ CPS_BUSRV
@@ DisableInactiveUserAccountsService
@@ Diskeeper
@@ Distinct TFTP
@@ DPTSRV
@@ Ethernet NDIS
@@ eTrust Antivirus Job Server
@@ eTrust Antivirus Realtime Server
@@ eTrust Antivirus RPC Server
@@ EventLog
@@ F-Secure SSH Server
@@ FMS_CPF_server
@@ FTP Publishing Service
@@ gatherer
@@ IIS Admin Service
@@ InetD
@@ Last Login Service
@@ LBBAM Service
@@ MAS_CPTASP_cptcentral
@@ MAS_CPTASP_cptcentral_A
@@ MAS_CPTASP_cptcentral_B
@@ MAS_CPTASP_cptheartbeat
@@ MCS_ADH_Adm
@@ MCS_AIAP_Adm
@@ MCS_ALDA_ADM
@@ MCS_ALEC_ADM
@@ MCS_ALIS_ADM
@@ MCS_MTS_ADM
@@ Messenger
@@ Microsoft DHCP Server
@@ Net Logon
@@ NT LM Security Support Provider
@@ OCS_IPNAADM
@@ OCS_OCP_echo
@@ pcAnywhere Host Service
@@ PES_CLH_server
@@ Plug and Play
@@ Protected Storage
@@ Remote Procedure Call (RPC) Locator
@@ Remote Procedure Call (RPC) Service
@@ Server
@@ SoftWareListService
@@ Spooler
@@ stsmain
@@ stsopcf
@@ stsprov
@@ Task Scheduler
@@ TCP/IP NetBIOS Helper
@@ Workstation
@@ Reason: Verify cached netbios names and lmhost entries matches.
nbtstat -c
@@ Expected result: (NT4)
@@NetBIOS Remote Cache Name Table
@@ NameType Host Address Life [sec]
@@WELOVEAPG40DOM<1C>GROUP 192.168.202.1 -1
@@WELOVEAPG40DOM<1B>UNIQUE192.168.202.1 -1
@@WELOVEAPG40B<03>UNIQUE192.168.202.2 -1
@@WELOVEAPG40B<00>UNIQUE192.168.202.2 -1
@@WELOVEAPG40B<20>UNIQUE192.168.202.2 -1
@@WELOVEAPG40A<03>UNIQUE192.168.202.1 -1
@@WELOVEAPG40A<00>UNIQUE192.168.202.1 -1
@@WELOVEAPG40A<20>UNIQUE192.168.202.1 -1
type C:\winnt\system32\drivers\etc\lmhosts
@@ Expected result:
@@192.168.202.1AP143A#PRE #DOM:AP143DOM
@@192.168.202.2AP143B#PRE #DOM:AP143DOM
@@192.168.202.1"AP143DOM \0x1b"#PRE
@@ Note: The lmhosts file should not exist in WinS03
type c:\winnt\system32\drivers\etc\hosts
@@ Expected result: Classic
@@ 127.0.0.1 localhost
@@ # Start of lines belonging to CXC137442 R3D TOCAPBIN
@@ 192.168.169.1ap1a-l1ap1a
@@ 192.168.170.1ap1a-l2ap1a
@@ 192.168.169.2ap1b-l1ap1b
@@ 192.168.170.2ap1b-l2ap1b
@@ 192.168.169.128cp0ex-stoc0-l1cp0excp0
@@ 192.168.170.128cp0ex-stoc1-l2cp0excp0
@@ 192.168.169.129cp0sb-stoc0-l1cp0sb
@@ 192.168.170.129cp0sb-stoc1-l2cp0sb
@@ # End of lines belonging to CXC137442
@@ 192.168.169.33ap_1
@@ 192.168.169.33app_apio
@@ 192.168.169.33app_sts
@@ 192.168.169.33app_gatherer_global
@@ 192.168.169.33app_global_gatherer
@@ Expected result: APZ 212 50
@@ # Start of lines belonging to CXC137442 R3L TOCAPBIN
@@ 192.168.169.128cp0ex-stoc0-l1cp0-Aside cp0excp0
@@ 192.168.170.128cp0ex-stoc1-l2cp0-Aside cp0excp0
@@ 192.168.169.129cp0sb-stoc0-l1cp0-Bside cp0sb
@@ 192.168.170.129cp0sb-stoc1-l2cp0-Bside cp0sb
@@ Reason: Check that the quorum logging is ok.
@IF {nodestate} <> "active" THEN GOTO NO_PASSIVE_9
@IF {osver} = "WinS03" THEN GOTO WinS_QUORUM
dir J:\MSCS
@GOTO NO_PASSIVE_9
@LABEL WinS_QUORUM
dir I:\MSCS
@@ Expected result: Only one quolog.log and one chk****.tmp should exist.
@LABEL NO_PASSIVE_9
@@ Reason: Check that everything in cluster is up and running.
@IF {nodestate} = "undefined" THEN GOTO NO_PING
cluster res | findstr /vie online
@@ Expected result: Empty printout if all resources are online.
cluster /ver
cluster /quorum
cluster /list
cluster node
cluster group
cluster res
@@ Recursive cluster res printing is not supported in WinFIOL versions older than 7.0.1.
@IF {_version} = "wf" THEN GOTO contclus
@IF {_version} <= "700" THEN GOTO contclus
cluster res
@PASTE {clusterRes} {_lines}
@COMPACT {clusterRes}
@SIZE {clusterRes} {numRes}
@SET {indexRes} = 4
@WHILE {indexRes} < {numRes}
@BEFORE {clusterResource} {clusterRes[{indexRes}]} ""
@TRIM {clusterResource}
@AFTER {tmp} {clusterRes[{indexRes}]} {clusterResource}
@TRIM {tmp}
@BEFORE {clustergroup} {tmp} ""
@IF {clusterResource} MATCHES ".+RGAPM_0" THEN @SET {clustergroup}="RGAPM_0"
@IF {clusterResource} MATCHES ".+RGAPM_1" THEN @SET {clustergroup}="RGAPM_1"
@IF {clusterResource} MATCHES ".+RGAPM_[01]" THEN @BEFORE {clusterResource} {clusterResource} " RGAPM"
@IF {clusterResource} MATCHES ".+Cluster Group" THEN @SET {clustergroup}="Cluster Group"
@IF {clusterResource} MATCHES ".+Cluster Group" THEN @BEFORE {clusterResource} {clusterResource} " Cluster Group"
@IF {clusterResource} MATCHES ".+Disk Group" THEN @SET {clustergroup}="Disk Group"
@IF {clusterResource} MATCHES ".+Disk Group" THEN @BEFORE {clusterResource} {clusterResource} " Disk Group"
@IF {clusterResource} MATCHES ".+PMC860 Group" THEN @SET {clustergroup}="PMC860 Group"
@IF {clusterResource} MATCHES ".+PMC860 Group" THEN @BEFORE {clusterResource} {clusterResource} " PMC860 Group"
@COMMENT res="{clusterResource}", grp="{clustergroup}"
@INC {indexRes}
@ENDWHILE
@LABEL contclus
cluster res /prop
cluster res /priv
cluster netint
cluster netint /prop
@@ Expected result:
@@Cluster node:Status shall be UP
@@ Cluster group: Status shall be Online
@@ Cluster res: Status shall be Online
@@ OSU: Check that both node names ends with 'A' or' B'in UPPERCASE.
@@ Node name must not contain _ (underscore).
@@ Otherwise the script will stop in the SelfTest execution, with "Error resolving
@@ node names by naming conventions" (Both nodes will be seen as BDC's.)
@@ OSU:
@@ In WinNT4 it should look like this:
@@ C:\>cluster net /prop | sort | find "Role"
@@Heartbeat 1 Role1 (0x1)
@@Heartbeat 2 Role1 (0x1)
@@IPN100-1 Role2 (0x2)
@@IPN100-2 Role2 (0x2)
@@Local Maintenance Role2 (0x2)
@@PublicRole2 (0x2)
@@ In W2K3 it should look like this (this is more useful for ALAN than anything else):
@@ c:\winnt\profiles\Administrator>cluster net /prop | sort | find "Role"
@@ DHeartbeat 1 Role1 (0x1)
@@ DHeartbeat 2 Role1 (0x1)
@@ DIPN100-1 Role2 (0x2)
@@ DIPN100-2 Role2 (0x2)
@@ DLocal Maintenance Role2 (0x2)
@@ DPublicRole2 (0x2)
@@ 1 = Internal cluster communications only (private network)
@@ 2 = Client access only (public network)
@@ 3 = All Communications (mixed network)
@@ Reason: Check that preferred owners are correct.
cluster group RGAPM_0 /listowners
cluster group RGAPM_1 /listowners
cluster group "Disk Group" /listowners
cluster group "Cluster Group" /listowners
@IF {hwver} = "APG43" THEN GOTO NO_PMC860
cluster group "PMC860 Group" /listowners
@LABEL NO_PMC860
@@ Expected result:
@@ Preferred Owner Nodes: RGAPM_0 -> A-node, RGAPM_1 -> B-node
@@ the other groups shall be empty.
@@ Reason: OSU: Check the other nodes public network interface.
cluster netint /prop| find "Public" | find "Address"
@COPY {_line1}{ping1} 57 20
@IF {length1} = 0 THEN GOTO NO_PING
@IF {ping1} = "mapper." THEN GOTO NO_PING
@COPY {_line2}{ping2} 57 20
@COPY {_line3}{ping3} 57 20
@LENGTH {_line2}{length2}
@IF {length2} = 0 THEN SET {ping2}={ping3}
ping {ping1}
ping {ping2}
ping {ping1}
ping {ping2}
@@ Expected result: Lost = 0 (0% loss)
@LABEL NO_PING
@@ Reason: Check that clustername and cluster ip-address works from both nodes.
cluster res "Cluster IP Address" /priv | find "AddressA"
@IF {length1} = 0 THEN @GOTO NO_CLUS
@COPY {_line1}{pingu} 56 20
@IF {pingu} = " mapper." THEN GOTO NO_CLUIP
ping {pingu}
@GOTO NO_CLUIP
@LABEL NO_CLUS
cluster res "Cluster IP Address" /priv | find "Address"
@COPY {_line3}{pingu} 34 20
@LENGTH {_line3}{length3}
@IF {length3} = 0 THEN @GOTO NO_CLUIP
ping {pingu}
@LABEL NO_CLUIP
cluster /ver
@IF {length1} = 0 THEN GOTO NO_PONG
@COPY {_line1}{clustername} 18 32
ping {clustername}
@@ Expected result: Reply from both cluster name and cluster ip address
@@Lost = 0 (0% loss)
@LABEL NO_PONG
@@ Reason: OSU: SearchList must be empty before starting OSU.
cd /d C:\temp && regedit /e tcpip_parameters.log "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters"
type C:\temp\tcpip_parameters.log | findstr SearchList && del C:\temp\tcpip_parameters.log
@@ Expected result: "SearchList"=""
@@ Reason: To check the shutdown event tracker
Reg query "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows NT\Reliability"
@@ Expected result:
@@HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows NT\Reliability
@@ShutdownReasonOn REG_DWORD 0x0
@@SnapShot REG_DWORD 0x1
@@ Reason: To check for the reserved ports.
@T 2
@@ Expected result: Reserved port numbers 2345-2346
@@ IF port number 2345 - 2346 is not reserved then Primus SCS819024 have to be applied.
@@ Reason: To check the paths for FTP logs.
dir c:\winnt\system32\LogFiles
@@ Expected result: MSFTPSVC1 .....
@@ To be compared with the settings in LOGMBIN CXC1371079/4 R1A
@@ Compare with phaprint to see that MAINTENANCE OF FTP LOGS is correct.
@@ Reason: Check the alog status and list excluded items.
@IF {nodestate} <> "active" THEN GOTO NO_PASSIVE_15
aloglist
alogexls
@@ Expected result:
@@STATUS
@@ACTIVE
@@MAXIMUM LOGFILE SIZE
@@100 MB
@@LOGGING PERIOD
@@2006-03-09 00242006-03-10 0026
@@TRANSFER QUEUE
@@ALOG
@LABEL NO_PASSIVE_15
@@ Reason: To get the system parameters
phaprint
@@ Expected result: Parameter values.
@@ Reason: To verify that messagestore and rtr are configured correctly.
@IF {mkah} <> "MML" THEN GOTO NO_MML_1
@IF {bchwver} = "BC" THEN GOTO BC_APMSP_CHECK
mml APMSP;
mml CHOIP;CHOPP;
@GOTO BC_APMSP_END
@LABEL BC_APMSP_CHECK
mml -cp ALL APMSP;
@LABEL BC_APMSP_END
@@ Expected result: AP MESSAGE PROTOCOL TO AP STATISTICS DATA
@@COMMON CHARGING OUTPUT INTERFACE DATA
@@Interface should be AP
@@and to print acl's for responding ftp directories.
@LABEL NO_MML_1
@IF {nodestate} <> "active" THEN GOTO NO_PASSIVE_10
@IF {bchwver} <> "BC" THEN GOTO APG40_MSD
msdls -m CHS
rtrls
dir /sK:\ACS\data\ACA\
dir /s K:\ACS\Data\RTR
@GOTONO_PASSIVE_10
@LABEL APG40_MSD
msdls -m CHS -s cp0ex
rtrls -s CHS cp0ex
@IF {hwver} <> "APG43" THEN GOTO APG40_MSDDRIVE
dir /sK:\ACS\data\ACA\CHS\cp0ex\
@GOTO NO_PASSIVE_10
@LABEL APG40_MSDDRIVE
dir /sQ:\ACS\data\ACA\CHS\cp0ex\
dir /s Y:\ACS\Data\RTR
vdls -n "Default FTP Site" | findstr -i Y:\Acs\Data\
@COPY {_line1}{resp1}25 50
@IF {length1} = 0 THEN GOTO NO_PASSIVE_10
@COPY {_line2}{resp2}25 70
@IF {length2} = 0 THEN GOTO NO_RESP1
@COPY {_line3}{resp3}25 70
@IF {length3} = 0 THEN GOTO NO_RESP2
@LENGTH {_line4}{length4}
@COPY {_line4}{resp4}25 70
@IF {length4} = 0 THEN GOTO NO_RESP3
@LENGTH {_line5}{length5}
@COPY {_line5}{resp5}25 70
@IF {length5} = 0 THEN GOTO NO_RESP4
@LABEL NO_RESP5
cacls {resp5}
cacls {resp5}\*
@LABEL NO_RESP4
cacls {resp4}
cacls {resp4}\*
@LABEL NO_RESP3
cacls {resp3}
cacls {resp3}\*
@LABEL NO_RESP2
cacls {resp2}
cacls {resp2}\*
@LABEL NO_RESP1
cacls {resp1}
cacls {resp1}\*
@LABEL NO_PASSIVE_10
phaprint ACS_ACABIN_MSD_Home
phaprint -t ACS_ACABIN_MessageStores
phaprint ACS_RTRBIN_Home
@@ Expected result: See examples below
@@Common part:
@@firstMessNo: {0000000000, 0051293764}
@@lastMessNo:{0000000000, 0051298729}
@@lastAckMess: {0000000000, 0051298582}
@@in file:Q:\ACS\data\ACA\CHS\cp0ex\dataFiles\19307492_3
@@firstFile:00046, lastFile: 00046, noOfFiles: 00001
@@maxNoOfMess: 06000, maxMessSize: 04096, maxNoOfFiles: 00040
@@File part:
@@00000: fileName: Q:\ACS\data\ACA\CHS\cp0ex\dataFiles\19307492_3
@@ firstMessInFile: {0000000000, 0051293764}, noOfMess: 04966
@@ Unlinked:No, MTAPFileNo: 046
@@RTR TABLE
@@MESSAGE STOREFILE TRANSFER QUEUE
@@CHScp0exRTRFILES
@@File size 4096
@@File holding time300
@@Fixed file records NO
@@File record length 2048
@@File padding char0
@@Generation time 00:00
@@Reset flagNO
@@Statistics since :03/17/2004 13:38:47
@@Process start :04/26/2004 10:49:25
@@Volume read(Kb):625878210
@@Volume reported (Kb):625878210
@@MS buffers read:167622607
@@MS buffers lost:0
@@MS buffers skipped:0
@@Number of proc restarts:20
@@Conn attempts to MS :57
@@Attach attempts to GOH :19
@@ Reason: CPF FILE TABLE, AFP TABLE, CDH DESTINATION TABLE and
@@CDH DESTINATION SET TABLE.
@IF {nodestate} <> "active" THEN GOTO NO_PASSIVE_11
@SET {cpfparam}=""
@IF {bchwver}="BC" THEN SET {cpfparam}="-cp cp0"
cpfdf {cpfparam}
cpfls {cpfparam} -l
afpls -l
cdhdsls -l
cdhls -l
dbols -l
@@ Expected result: Files, Transfer queues, Destinations and
@@Destination Sets(APZ 11.2) according to customers conf.
@@ Reason: afpls -a for all defined transferqueues, to get complete afp table definitions.
@@ Only executed if WinFiol 7.0 is used.
afpls
@IF {_version} = "wf" THEN GOTO endAFPLS
@IF {_version} <= "700" THEN GOTO endAFPLS
@@ Recursive AFPLS printing is not supported in WinFIOL versions older than 7.0.1.
@PASTE {transferQueues} {_lines}
@COMPACT {transferQueues}
@SIZE {transferQueues} {numTransferQueues}
@SET {indexTQ} = 3
@WHILE {indexTQ} < {numTransferQueues}
@COPY {transferQueues[{indexTQ}]} {transferQueue} 1 32
@TRIM {transferQueue}
@COMMENT ##############################################################################
@COMMENT TRANSFER QUEUE: {transferQueue}
afpls -l {transferQueue}
@PASTE {destinationSets} {_lines}
@SIZE {destinationSets} {numDestinationSets}
@SET {indexDS} = 10
@WHILE {indexDS} < {numDestinationSets}-1
@ITEM {destinationSet} {destinationSets[{indexDS}]} " " 3
@TRIM {destinationSet}
@COMMENT TRANSFER QUEUE: {transferQueue}, DESTINATION SET: {destinationSet}
afpls -a {transferQueue} {destinationSet}
@INC {indexDS}
@ENDWHILE
@INC {indexTQ}
@ENDWHILE
@LABEL endAFPLS
@@ Reason: To print rdt/ohs information. Note ! Only valid in APZ 11.1 (R9).
swrprint RDTBIN | find /I "RDTBIN"
@COPY {_line1}{rdt}1 3
@IF {rdt} <> RDT THEN GOTO NO_RDT
rdtview -s
rdtview -f
rdtview -p
rdtview -b
type "c:\program files\ap\rdt\conf\cxc137567.par"
type "c:\program files\ap\ohs\conf\cxc137368.par"
type "c:\program files\ap\ohs\conf\cxc137571.rin"
type "c:\program files\ap\ohs\conf\cxc137572.rin"
@@ Expected result: rdt/ohs configuration data
@LABEL NO_RDT
@@Reson: Check if HCS is present on the node and take the printout in AP1 active node
@IF {nodestate} <> "active" THEN GOTO NO_HCS_PASSIVE
@IF {ap_no}<> "ap1" THEN GOTO NO_HCS_PASSIVE
swrprint HCSBIN | find /I "HCSBIN"
@COPY {_line1} {hcs} 1 3
@IF {hcs} <> HCS THEN GOTO NO_HCS_PASSIVE
hcrsls
hcrfls
hcjls
@LABELNO_HCS_PASSIVE
@@ Reason: Check the IO CONFIGURATION DATA.
@IF {ap_no} = "ap2" THEN GOTO END_BUP
@IF {bchwver} = "BC" THEN GOTO BC_IOMSP_CHECK
mml IOMSP;
mml IOMSP:AP=1,ALL;
mml IOCDP;
@GOTO IOMSP_CHECK_END
@LABEL BC_IOMSP_CHECK
mml -cp ALL IOMSP;
mml -cp ALL IOMSP:AP=1,ALL;
mml -cp ALL IOCDP;
@LABEL IOMSP_CHECK_END
@@ Expected result: All destinations are working and there is no
@@queue on any AD.
@@ Reason: AP - CP group/user associations.
cuals
@IF {bchwver} = "BC" THEN GOTO BC_IOTGP_CHECK
mml IOUAP:USER=ALL;IOUGP;IOTGP;
@GOTO BC_IOTGP_END
@LABEL BC_IOTGP_CHECK
mml -cp ALL IOTGP;
@LABEL BC_IOTGP_END
@@ Expected result: Verify that AP group/user <-> CP user associations
@@are OK.
@@ Reason: IO DEVICE DATA LISTING.
@@SYSTEM STANDBY DEVICE.
@IF {bchwver} = "BC" THEN GOTO BC_IOROP_CHECK
mml IOROP;IOSYP;IOIOP:IO1=ALL;
@GOTO IOROP_CHECK_END
@LABEL BC_IOROP_CHECK
mml -cp ALL IOROP;IOSYP;IOIOP:IO1=ALL;
@LABEL IOROP_CHECK_END
@@ Expected result: Only AD-devices should be used.
@@ Reason: Check what printout destinations are defined.
cpdlist -l
cpdlist
@@queue on any AD.
@@ Reason: IO Device in CP, Test.
cpdtest -c
cpdtest -p
cpdtest -s
dir /s K:\MCS\logs\
type K:\MCS\logs\trace.log
@@ Expected result: Test results, statistics and log.
@@ Reason: To check that valid SYSTEM BACKUP FILES exists in CPF.
@IF {bchwver} = "BC" THEN GOTO BC_SYBRP_FILE_CHECK
mml SYBFP:FILE;
@GOTO BC_SYBRP_FILE_END
@LABEL BC_SYBRP_FILE_CHECK
mml -cp ALL SYBFP:FILE;
@LABEL BC_SYBRP_FILE_END
cpfls {cpfparam}| FindStr /R "RELFSW[0-9]"
cpfls {cpfparam} -ls RELFSW0
cpfls {cpfparam} -ls RELFSW1
cpfls {cpfparam} -ls RELFSW2
cpfls {cpfparam} -ls RELCMDHDF
@@ Expected result: RELFSW0, RELFSW1 AND RELFSW2 should exist and the
@@latest backup should be in RELFSW0.
@@ Reason: To get CP backup softvare info/status.
@IF {cpno} = "CP not" THEN GOTO END_BUP
@IF {bchwver} = "BC" THEN GOTO BC_SYBRP_CHECK
mml SYBRP;
@GOTO BC_SYBRP_END
@LABEL BC_SYBRP_CHECK
mml -cp ALL SYBRP;
@LABEL BC_SYBRP_END
@IF {apzver} > "33" THEN GOTO _BUPLS
bupprint
@GOTO END_BUP
@LABEL _BUPLS
@IF {bchwver} = "BC" THEN GOTO BC_LAMIP_CHECK
mml LAMIP;
@GOTO BC_LAMIP_END
@LABEL BC_LAMIP_CHECK
mml -cp ALL LAMIP;
@LABEL BC_LAMIP_END
bupls
bupidls
@@ Expected result:
@@ For APZ212 40 ->
@@ The printout from LAMIP should normally match RELFSW0 in bupidls.
@@RPHMI MICRO PROGRAM IN PROM
@@RPHMI FLASH LOAD MODULES
@@SYSTEM BOOT IMAGE
@@PLEX ENGINE DUMP
@LABEL END_BUP
@@ Reason: To verify if any external alarms are configured.
exalls
exalls -l
exalls -f
@@ Expected result: The defined receivers.
@@ Reason: To verify if any alarm panels alarms are configured.
aldls
aldpls
@@ Expected result: The defined panels.
@@ Reason: To verify that the DHCP database is consistent.
@LABEL NO_PASSIVE_11
@IF {ap_no} = "ap2" THEN GOTO NO_DHCP
@@ Reason: To check that no directory called "old" exist.
dir C:\WINNT\system32\dhcp\backup\Jet | findstr/I old
@@ Expected result: No directory called old should exist,if it does it must be removed before an OSU is started.
@@ Reason: To check that no corrupted dir's exist. (e.g. <DIR>j500000D.log)
dir C:\winnt\system32\dhcp /s /b /a /ad|findstr \.|findstr /v /r \..*\\|findstr -v \\\.
@@ Expected result: Nothing printed. (files that turned into dir's)
@IF {osver} = "WinS03" THEN GOTO NO_DHCP
@IF {nodestate} <> "active" THEN GOTO NO_DHCP_PASSIVE
dhcpcmd 127.0.0.1 enumclients 192.168.169.0 -v
dhcpcmd 127.0.0.1 enumclients 192.168.170.0 -v
@@ Note: Only the active node is checked.
dhcpcmd.exe 127.0.0.1 checkdb 192.168.169.0
dhcpcmd.exe 127.0.0.1 checkdb 192.168.170.0
@@ Expected result:
@@ DHCP Server version 4.1
@@ Command successfully completed.
@LABEL NO_DHCP_PASSIVE
cd /d C:\temp && regedit /e dhcptmp.log "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\DHCPServer\Configuration\"
type C:\temp\dhcptmp.log | find "IpAddress"
type C:\temp\dhcptmp.log | find "ClientUID"
type C:\temp\dhcptmp.log | find "AllowedClientTypes"
del c:\temp\dhcptmp.log
cd /d C:\temp && regedit /e dhcptmp.log "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\DHCPServer\Parameters\"
@@ Expected result: "AllowedClientTypes"=hex:03
@@"IgnoreBroadcastFlag"=0 only for APZ 21240
@@"IgnoreBroadcastflag"=1 all other APZ's (classic and also APZ 212 50/55)
@@ Before APZ 11.3 the flag doesn't exist.
@@ Example below from AC-M315 APZ 212 40
@@ dhcpcmd 127.0.0.1 enumclients 192.168.169.0 -v
@@ Num Client info read = 2.
@@ Total Client count = 2.
@@ ClientInfo :
@@IP Address = 192.168.169.128.
@@SubnetMask = 255.255.255.0.
@@Client Hardware Address = 00-01-ec-c6-ee-e1.
@@Name = eib_a.
@@Comment = eib_a.
@@Type = BOOTP
@@Expires = Never (lease duration is infinite.)
@@Owner Host IP Address = 192.168.169.2.
@@Owner Host NetBios Name = AP143B.
@@Owner Host Name = (null).
@@ ClientInfo :
@@IP Address = 192.168.169.129.
@@Client Hardware Address = 00-01-ec-c5-a2-91.
@@Name = eib_b.
@@Comment = eib_b.
@@Type = None
@@Expires = 01/01/1601 00:00:00.
@@Owner Host IP Address = 0.0.0.0.
@@ C:\>dhcpcmd 127.0.0.1 enumclients 192.168.170.0 -v
@@ ClientInfo :
@@IP Address = 192.168.170.128.
@@Client Hardware Address = 00-01-ec-c6-ee-e2.
@@Name = eic_b.
@@Comment = eic_b.
@@Type = None
@@ ClientInfo :
@@IP Address = 192.168.170.129.
@@Client Hardware Address = 00-01-ec-c5-a2-90.
@@Name = eib_b.
@@Comment = eib_b.
@@Type = BOOTP
@@Owner Host IP Address = 192.168.170.2.
@@ "ServerIpAddress"=dword:7f000001
@@ "IpAddress"=dword:c0a8a980
@@ "IpAddress"=dword:c0a8a981
@@ "IpAddress"=dword:c0a8aa80
@@ "IpAddress"=dword:c0a8aa81
@@ "ClientUID"=hex:00,a9,a8,c0,01,00,01,ec,c6,ee,e1
@@ "ClientUID"=hex:00,a9,a8,c0,01,00,01,ec,c5,a2,91
@@ "ClientUID"=hex:00,aa,a8,c0,01,00,01,ec,c6,ee,e2
@@ "ClientUID"=hex:00,aa,a8,c0,01,00,01,ec,c5,a2,90
@@ "AllowedClientTypes"=hex:03
@@ Note:
@@"AllowedClientTypes"=hex:03 means the DHCP Server accept requests from both DHCP and BOOTP clients.
@@Faulty setting can result in that CP reload or VM reload can fail.
@@See Primus SCS570690 ("Howto: Change the value of AllowedClientTypes in the DHCP Server settings in NT4")
@LABEL NO_DHCP
@@ Reason: Check the function change status and last history.
@IF {nodestate} = "undefined" THEN GOTO FCHEND
@T 2
fchstate
@COPY {_line1}{fchrev}1 4
@IF {fchrev} = "The" THEN GOTO OLDFCH
@@fchstate -d
@IF {fchrev} = "This" THEN GOTO FCHEND
@LABEL OLDFCH
fchstart -V
@@type c:\acs\logs\fch\acs_fch_activity.log
@LABEL FCHEND
fchstart -j verify
@@ Reason: Check the soft function change status and last history.
sfcstate
@@typec:\acs\logs\sfc\ACS_SFC_InstallationLog | more
@@ Expected result: sfc status and Log listed
@@ Reason: In Service Performance statistics print.
@IF {nodestate} <> "active" THEN GOTO NO_PASSIVE_12
ispprint -t {date}
ispprint -a -t {date}
@@ Expected result: no unexpected process restarts or failovers
@LABEL NO_PASSIVE_12
@@ Reason: To get (dr.watson log) and list saved/unsaved process dumps.
@@type C:\acs\logs\core\drwtsn32.log
dir /s C:\user.dmp
dir F:\
dir /s /od F:\ACS\logs
@@ Expected result: Logs and dumps listed
@@ Reason: List the STS configuration.
@IF {ap_no} = "ap2" THEN GOTO NO_PASSIVE_13
@IF {nodestate} <> "active" THEN GOTO NO_PASSIVE_13
@@ Measuring Program Print
stmmp -L -l
stmmp -L
@@ Measurement Report Print
stmrp -L
stmrp -L -l
@@ Object Types Print
stmotls
@@ Lists all output requests
stmfols
@@ Database Retainment Time Print
stmdbrt -p
@@ Expected result: STS configuration data
@@ Note: Large number of included but not reported object types should be
@@ investigated in detail together with the customer.
@LABEL NO_PASSIVE_13
@@ Reason: The Commondll- and dll log are only printed out for trouble shooting
@@reasons.
@@type C:\ACS\Logs\LCT\Commondll.log
@@@comment COMMOMDLL LOG FINISHED
@@type C:\ACS\Logs\LCT\dll.log
@@ Expected result: The Commondll and dll logs are printed.
@@ Reason: Print MAXSIZE of the NT4 eventlogs.
@IF {osver} = "WinS03" THEN GOTO WINS03_YES
cd /d c:\temp && regedit /eAppl.txt "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\Application"
cd /d c:\temp && regedit /eSyst.txt "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\System"
cd /d c:\temp && regedit /eSecu.txt "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\Security"
cd /d c:\temp && regedit /e Isp.txt "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\Isp"
type Appl.txt | find "MaxSize" && del Appl.txt
type Syst.txt | find "MaxSize" && del Syst.txt
type Secu.txt | find "MaxSize" && del Secu.txt
type Isp.txt | find "MaxSize" && del Isp.txt
dir /s "C:\winnt\system32\config\*.evt"
ispconf
dir C:\acs\logs\prc
@@ Expected result:
@@ C:\temp>typeAppl.txt | find "MaxSize" && del Appl.txt
@@ "MaxSize"=dword:009d0000(10048 KByte)
@@ C:\temp>typeSyst.txt | find "MaxSize" && del Syst.txt
@@ C:\temp>typeSecu.txt | find "MaxSize" && del Secu.txt
@@ "MaxSize"=dword:01d60000(30080 KByte)
@@ C:\temp>type Isp.txt | find "MaxSize" && del Isp.txt
@@ "MaxSize"=dword:00200000(2048 Kbyte)
@@ Directory of C:\winnt\system32\config
@@ 05/21/0706:21p10,289,152 AppEvent.Evt
@@ 05/21/0707:59p 1,114,112 IspEvent.Evt
@@ 05/21/0706:21p30,801,920 SecEvent.Evt
@@ 05/21/0706:21p 2,228,224 SysEvent.Evt
@@ ISP log maximum size is 2048 kbytes.
@@ Tr ref:
http://mhweb.ericsson.se/mhweb/servlet/trview?trid=HH98939
@IF {osver} = "NT4" THEN GOTO END_AUDIT
@LABEL WINS03_YES
@COMMENT Windows Server 2003 part
@@ Reason: To check the ipsec configuration.
netsh ipsec static show all
netsh ipsec dynamic show config
@@ Expected result: Ipsec configuration
@@ Reason: Insecure protocols status.
@IF {nodestate} = "undefined" THEN GOTO NO_CSADM
csadm -s
@@ Expected result: Inbound connections using insecure protocols are blocked
@@or
@@Insecure protocols are allowed
@@or
@@Security configuration invalid.Reinitialise with command csadm accordingly
@LABEL NO_CSADM
@@To get memory configuration, allocation and usage info.
@@To get pagefile info.
wmic CPU GET Name,LoadPercentage,Status,StatusInfo,Level
wmic MEMLOGICAL GET AvailableVirtualMemory,TotalPageFileSpace,TotalPhysicalMemory,TotalVirtualMemory
wmic MEMPHYSICAL GET MaxCapacity,MemoryErrorCorrection
wmic PAGEFILE GET
tasklist
tasklist /SVC
wmic PROCESS GET Processid,Name,ThreadCount,HandleCount,Priority,PageFaults,WorkingSetSize,QuotaNonPagedPoolUsage,QuotaPagedPoolUsage
wmic PROCESS GET Processid,Name,KernelModeTime,UserModeTime
wmic SERVICE GET displayname,name,startname,startmode,state
@@ Expected result: Processor,process, services, memory and pagefile information.
@@ Reason: Check the Volumes.
wmic VOLUME GET BlockSize, Capacity, Compressed, DirtyBitSet, DriveLetter, FileSystem, FreeSpace, Label
@@ Expected result: (Active Node)
@@BlockSizeCapacityCompressedDirtyBitSetDriveLetterFileSystemFreeSpace Label
@@51230932992FALSE FALSEE:NTFS18959872ntboot
@@4096 4195856384FALSE FALSEC:NTFS687570944 ntbackup
@@4096 4195856384FALSE FALSED:NTFS1585561600ntserv
@@1024 1052834816FALSE FALSEF:NTFS1040470016ntdump
@@4096 2623827968FALSE FALSEK:NTFS2582175744Disk K
@@4096 10487230464FALSE FALSEL:NTFS9931243520Disk L
@@4096 5140799488FALSE FALSEM:NTFS3437150208Disk M
@@4096 4194856960FALSE FALSER:NTFS4168855552Disk R
@@2048 2097444864FALSE FALSES:NTFS2083944448Disk S
@@4096 8389783552FALSE FALSEV:NTFS7936909312Disk V
@@4096 2516934656FALSE FALSEG:NTFS2056646656Disk G
@@2048 2097412096FALSE FALSEQ:NTFS2064562176Disk Q
@@4096 14682124288FALSE FALSEY:NTFS14130991104Disk Y
@@512106928128 FALSE FALSEI:NTFS103987200 Disk I
@@ Reason : To display the reservations
@IF {ap_no} = "ap2" THEN GOTO NO_PASSIVE_17
@IF {nodestate} <> "active" THEN GOTO NO_PASSIVE_17
netsh dhcp server scope 192.168.169.0 show clients 1
netsh dhcp server scope 192.168.170.0 show clients 1
@LABEL NO_PASSIVE_17
@@ Reason: To check the DHCP configuration.
@IF {nodestate} <> "active" THEN GOTO NO_PASSIVE_14
netsh dhcp show server
@@ Expected result:
@@ Example: APZ 212 33 with IPN.
@@ 2 Servers were found in the directory service:
@@Server [AP26A.AP26DOM.int] Address [192.168.169.1] Ds location: cn=192.168.169.1
@@Server [AP26B.AP26DOM.int] Address [192.168.169.2] Ds location: cn=192.168.169.2
netsh dhcp server show serverstatus
@@ Expected result:
@@ Server Status:
@@ Server Attrib - Rogue Authorization Succeeded:FALSE
@@ Server Attrib - Dynamic BootP Support Enabled:TRUE
@@ Server Attrib - DHCP Server Part Of DS: TRUE
@@ Server Attrib - DHCP Server Bindings Aware:TRUE
@@ Server Attrib - Administrative Rights:TRUE
@@ The Server Attribute "Rogue Authorization Succeeded" should be TRUE.
@@ To rectify this, the duplicated Server Attribute needs to be deleted.
@@ See Primus SCS685644 for reference.
@IF {ap_no} = "ap2" THEN GOTO NO_DHCP_AP2_2
netsh dhcp server scope 192.168.169.0 dump
@@ Expected result:
@@ Dhcp Server 192.168.202.1 Scope 192.168.169.0 Add reservedip 192.168.169.128 49504e413030 "ipn0" "" ""
@@ Dhcp Server 192.168.202.1 Scope 192.168.169.0 set reservedoptionvalue 192.168.169.128 66 STRING "192.168.169.1"
@@ Dhcp Server 192.168.202.1 Scope 192.168.169.0 set reservedoptionvalue 192.168.169.128 67 STRING "boot.ipn0"
@@ Dhcp Server 192.168.202.1 Scope 192.168.169.0 Add reservedip 192.168.169.130 49504e413032 "ipn2" "" ""
@@ Dhcp Server 192.168.202.1 Scope 192.168.169.0 set reservedoptionvalue 192.168.169.130 66 STRING "192.168.169.1"
@@ Dhcp Server 192.168.202.1 Scope 192.168.169.0 set reservedoptionvalue 192.168.169.130 67 STRING "boot.ipn2"
netsh dhcp server scope 192.168.170.0 dump
@@ Expected result:
@@ Dhcp Server 192.168.202.1 Scope 192.168.170.0 Add reservedip 192.168.170.128 49504e413031 "ipn1" "" ""
@@ Dhcp Server 192.168.202.1 Scope 192.168.170.0 set reservedoptionvalue 192.168.170.128 66 STRING "192.168.170.1"
@@ Dhcp Server 192.168.202.1 Scope 192.168.170.0 set reservedoptionvalue 192.168.170.128 67 STRING "boot.ipn1"
@@ Dhcp Server 192.168.202.1 Scope 192.168.170.0 Add reservedip 192.168.170.130 49504e413033 "ipn3" "" ""
@@ Dhcp Server 192.168.202.1 Scope 192.168.170.0 set reservedoptionvalue 192.168.170.130 66 STRING "192.168.170.1"
@@ Dhcp Server 192.168.202.1 Scope 192.168.170.0 set reservedoptionvalue 192.168.170.130 67 STRING "boot.ipn3"
@@ Example: APZ 212 40 with GESP (CM013)
@@ C:\temp>netsh dhcp show server
@@Server [AP155A.AP155DOM.int] Address [192.168.169.1] Ds location: cn=192.168.169.1
@@Server [AP155B.AP155DOM.int] Address [192.168.169.2] Ds location: cn=192.168.169.2
@@ Command completed successfully.
@@ C:\temp>netsh dhcp server scope 192.168.169.0 dump
@@ Changed the current scope context to 192.168.169.0 scope.
@@ Dhcp Server 192.168.202.2 add scope 192.168.169.0 255.255.255.0 "ipna"
@@ Dhcp Server 192.168.202.2 Scope 192.168.169.0 set state 1
@@ #Start Add Ipranges to the Scope 192.168.169.0, Server 192.168.202.2
@@ Dhcp Server 192.168.202.2 Scope 192.168.169.0 Add iprange 192.168.169.3 192.168.169.254 BOTH
@@ #EndAdd Ipranges to the Scope 192.168.169.0, Server 192.168.202.2
@@ #Start Add Excluderanges to the Scope : 192.168.169.0, Server : 192.168.202.2
@@ #EndAdd Excluderanges to the Scope : 192.168.169.0, Server : 192.168.202.2
@@ #Start Add OptionValues to the Scope : 192.168.169.0, Server : 192.168.202.2
@@ Dhcp Server 192.168.202.2 Scope 192.168.169.0 set optionvalue 66 STRING "192.168.169.2"
@@ Dhcp Server 192.168.202.2 Scope 192.168.169.0 set optionvalue 51 DWORD "-1"
@@ Dhcp Server 192.168.202.2 Scope 192.168.169.0 set optionvalue 51 DWORD user="Default BOOTP Class" "-1"
@@ #EndAdd OptionValues to the Scope : 192.168.169.0, Server : 192.168.202.2
@@ #Start Add ReservedIp to the Scope : 192.168.169.0, Server : 192.168.202.2
@@ Dhcp Server 192.168.202.2 Scope 192.168.169.0 Add reservedip 192.168.169.128 0001ecb1dd37 "eib_a" "CP-AP Lan1" "BOTH"
@@ Dhcp Server 192.168.202.2 Scope 192.168.169.0 set reservedoptionvalue 192.168.169.128 67 STRING "image\boot_image_cpa"
@@ Dhcp Server 192.168.202.2 Scope 192.168.169.0 Add reservedip 192.168.169.129 008037ae87c7 "eic_b" "CP-AP Lan3" "BOTH"
@@ Dhcp Server 192.168.202.2 Scope 192.168.169.0 set reservedoptionvalue 192.168.169.129 67 STRING "image\boot_image_cpb"
@@ Dhcp Server 192.168.202.2 Scope 192.168.169.0 Add reservedip 192.168.169.132 3235352e3235352e31352e313a65746830 "GESB-I-A" "Internal network plane A (eth0)" "DHCP"
@@ Dhcp Server 192.168.202.2 Scope 192.168.169.0 Add reservedip 192.168.169.133 3235352e3235352e31352e32333a65746830 "GESB-I-B" "Internal network plane B (eth0)" "DHCP"
@@ Dhcp Server 192.168.202.2 Scope 192.168.169.0 Add reservedip 192.168.169.134 3235352e3235352e31352e333a65746830 "GESB-E-A" "External network plane A (eth0)" "DHCP"
@@ Dhcp Server 192.168.202.2 Scope 192.168.169.0 Add reservedip 192.168.169.135 3235352e3235352e31352e32313a65746830 "GESB-E-B" "External network plane B (eth0)" "DHCP"
@@ #EndAdd ReservedIp to the Scope : 192.168.169.0, Server : 192.168.202.2
@@ C:\temp>netsh dhcp server scope 192.168.170.0 dump
@@ Changed the current scope context to 192.168.170.0 scope.
@@ Dhcp Server 192.168.202.2 add scope 192.168.170.0 255.255.255.0 "ipnb"
@@ Dhcp Server 192.168.202.2 Scope 192.168.170.0 set state 1
@@ #Start Add Ipranges to the Scope 192.168.170.0, Server 192.168.202.2
@@ Dhcp Server 192.168.202.2 Scope 192.168.170.0 Add iprange 192.168.170.3 192.168.170.254 BOTH
@@ #EndAdd Ipranges to the Scope 192.168.170.0, Server 192.168.202.2
@@ #Start Add Excluderanges to the Scope : 192.168.170.0, Server : 192.168.202.2
@@ #EndAdd Excluderanges to the Scope : 192.168.170.0, Server : 192.168.202.2
@@ #Start Add OptionValues to the Scope : 192.168.170.0, Server : 192.168.202.2
@@ Dhcp Server 192.168.202.2 Scope 192.168.170.0 set optionvalue 66 STRING "192.168.170.2"
@@ Dhcp Server 192.168.202.2 Scope 192.168.170.0 set optionvalue 51 DWORD "-1"
@@ Dhcp Server 192.168.202.2 Scope 192.168.170.0 set optionvalue 51 DWORD user="Default BOOTP Class" "-1"
@@ #EndAdd OptionValues to the Scope : 192.168.170.0, Server : 192.168.202.2
@@ #Start Add ReservedIp to the Scope : 192.168.170.0, Server : 192.168.202.2
@@ Dhcp Server 192.168.202.2 Scope 192.168.170.0 Add reservedip 192.168.170.128 0001ecb1dd38 "eic_a" "CP-AP Lan2" "BOTH"
@@ Dhcp Server 192.168.202.2 Scope 192.168.170.0 set reservedoptionvalue 192.168.170.128 67 STRING "image\boot_image_cpa"
@@ Dhcp Server 192.168.202.2 Scope 192.168.170.0 Add reservedip 192.168.170.129 008037ae87c6 "eib_b" "CP-AP Lan4" "BOTH"
@@ Dhcp Server 192.168.202.2 Scope 192.168.170.0 set reservedoptionvalue 192.168.170.129 67 STRING "image\boot_image_cpb"
@@ Dhcp Server 192.168.202.2 Scope 192.168.170.0 Add reservedip 192.168.170.132 3235352e3235352e31352e313a65746831 "GESB-I-A" "Internal network plane A (eth1)" "DHCP"
@@ Dhcp Server 192.168.202.2 Scope 192.168.170.0 Add reservedip 192.168.170.133 3235352e3235352e31352e32333a65746831 "GESB-I-B" "Internal network plane B (eth1)" "DHCP"
@@ Dhcp Server 192.168.202.2 Scope 192.168.170.0 Add reservedip 192.168.170.134 3235352e3235352e31352e333a65746831 "GESB-E-A" "External network plane A (eth1)" "DHCP"
@@ Dhcp Server 192.168.202.2 Scope 192.168.170.0 Add reservedip 192.168.170.135 3235352e3235352e31352e32313a65746831 "GESB-E-B" "External network plane B (eth1)" "DHCP"
@@ #EndAdd ReservedIp to the Scope : 192.168.170.0, Server : 192.168.202.2
@@ C:\temp>REG QUERY HKLM\SYSTEM\CurrentControlSet\Services\DHCPServer\Parameters
@@ HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\DHCPServer\Parameters
@@APIProtocolSupport REG_DWORD 0x5
@@BackupDatabasePath REG_SZ C:\WINNT\System32\dhcp\backup
@@BackupInterval REG_DWORD 0x3c
@@DatabaseCleanupInterval REG_DWORD 0x3c
@@DatabaseLoggingFlag REG_DWORD 0x1
@@DatabaseName REG_SZ dhcp.mdb
@@DatabasePath REG_SZ C:\WINNT\System32\dhcp
@@DebugFlag REG_DWORD 0x0
@@RestoreFlag REG_DWORD 0x0
@@DhcpLogFilesMaxSize REG_DWORD 0x46
@@DhcpLogFilePath REG_SZ C:\WINNT\System32\dhcp
@@Version REG_DWORD 0xece0205
@@IgnoreBroadcastFlag REG_DWORD 0x0
@@DhcpLogDiskSpaceCheckInterval REG_DWORD 0x32
@@DhcpLogMinSpaceOnDisk REG_DWORD 0x14
@@DetectConflictRetries REG_DWORD 0x0
@@ HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\DHCPServer\Parameters\Configuration
@@ HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\DHCPServer\Parameters\MultiHomeInfo
@@ Note:
@@ ClientType BOTH means the DHCP Server accept requests from both DHCP and BOOTP clients.
@@ Faulty setting can reusult in that CP reload or VM reload can fail.
@@ Scope and reservedip shall be type BOTH. Execpt reservedip's for GESB, they shall be type DHCP.
@@ Reason: Checking files can be fetched using TFTP
@@ Checking the TFTP performance
@IF {mkah} <> "MML" THEN GOTO TFTP_CHECK_BC
@IF {cpno} = "CP not" THEN GOTO TFTP_CHECK_BC
@IF {apzversion} = "2141" THEN GOTO TFTP_BC
@IF {apzversion} = "21255" THEN GOTO TFTP_APG43
@IF {apzver} = "40" THEN GOTO TFTP_CHECK_APZ40
@IF {apzver} = "50" THEN GOTO TFTP_CHECK_APZ50
@IF {apzversion} = "21260" THEN GOTO TFTP_CHECK_APZ60
@GOTO TFTP_CLASSIC
@@ Checking for APZ version 60
@LABEL TFTP_CHECK_APZ60
cd C:\temp
ptft -i 127.0.0.1 GET /image/a/pxelinux.0
attrib -r pxelinux.0
del pxelinux.0
ptft -i 127.0.0.1 GET /image/b/pxelinux.0
del pxelinux.0
@GOTO NO_PASSIVE_14
@@ Checking Blade Cluster or not
@LABEL TFTP_CHECK_BC
@IF {bchwver} = "BC" THEN GOTO TFTP_CLASSIC_BC
@GOTO TFTP_CLASSIC
@@ Checking for BC CLASSIC Version
@LABEL TFTP_CLASSIC_BC
cd C:\temp
del pxelinux.0
del pxelinux.0
@GOTO NO_PASSIVE_14
@@ Classic Machine
@LABEL TFTP_CLASSIC
@@ Checking for Classic APZ Version
cd C:\temp
ptft -i 127.0.0.1 GET /boot.ipn0
ptft -i 127.0.0.1 GET /boot.ipn1
attrib -r boot.ipn0
attrib -r boot.ipn1
del boot.ipn0 boot.ipn1
@GOTO NO_PASSIVE_14
@@ Checking for APZ version 40
@LABEL TFTP_CHECK_APZ40
cd C:\temp
ptft -i 127.0.0.1 GET /image\boot_image_cpa
attrib -r boot_image_cpa
del boot_image_cpa
ptft -i 127.0.0.1 GET /image\boot_image_cpb
attrib -r boot_image_cpb
del boot_image_cpb
@GOTO NO_PASSIVE_14
@@ Checking for APZ Version 50
@LABEL TFTP_CHECK_APZ50
cd C:\temp
ptft -i 127.0.0.1 GET /image/a/elilo.efi
attrib -r elilo.efi
del elilo.efi pxelinux.0
ptft -i 127.0.0.1 GET /image/b/elilo.efi
attrib -r elilo.efi
@GOTO NO_PASSIVE_14
@@ Checking for APZ Version 55
@LABEL TFTP_APG43
cd C:\temp
del pxelinux.0
del pxelinux.0
@GOTO NO_PASSIVE_14
@@ Checking for APZ Version 21401 (Blade Cluster)
@LABEL TFTP_BC
cd C:\Temp
@@Checking Dual CPs related TFTP services
@SET {count} = 1
@WHILE {count} <= {DCP1}
@CONCAT {BCDCP} "CP" {count}
ptft -i 127.0.0.1 GET /{BCDCP}/CPA/pxelinux.0
del pxelinux.0
ptft -i 127.0.0.1 GET /{BCDCP}/CPB/pxelinux.0
del pxelinux.0
@INC {count}
@ENDWHILE
@@ Checking Single CPs related TFTP Services
@SET {count} = 0
@WHILE {count} < {SCP1}
@CONCAT {BCSCP} "BC" {count}
ptft -i 127.0.0.1 GET /{BCSCP}/CPA/pxelinux.0
del pxelinux.0
@INC {count}
@ENDWHILE
@@ Expected Result : The files will be transfered through TFTP.
@LABEL NO_PASSIVE_14
@@ Expected result: DHCP configuration
@@"IgnoreBroadcastFlag0x0" only for APZ 21240
@@"IgnoreBroadcastFlag0x1" all other APZ's (classic and also APZ 212 50/55)
@LABEL NO_DHCP_AP2_2
@@ Reason: Print MAXSIZE of the WINS03 eventlogs.
wmic NTEVENTLOG LIST /FORMAT
IST
@@ Expected result:
@@ LogfileName=Application, MaxFileSize=16777216
@@ LogfileName=Directory Service, MaxFileSize=15728640
@@ LogfileName=DNS Server, MaxFileSize=15728640
@@ LogfileName=File Replication Service, MaxFileSize=15728640
@@ LogfileName=ISP, MaxFileSize=2097152
@@ LogfileName=Security, MaxFileSize=31457280
@@ LogfileName=System, MaxFileSize=16777216
@@ Reason: System Information report
cd /d C:\TEMP
diagproc
type winmsdreport.txt
del C:\TEMP\winmsdreport.txt
type diagproc.txt
del C:\TEMP\diagproc.txt
cd /d C:\
@@ Reason: Operating system configuration information report.
systeminfo
@@ Reason: Print the Service User profile (WinS03).
@T 2
@@ C:\temp>dir /a C:\winnt\profiles\MZxDXMoNPWBNKyEYDVKS
@@Volume Serial Number is F005-D27B
@@Directory of C:\winnt\profiles\MZxDXMoNPWBNKyEYDVKS
@@ 03/22/200609:21 AM <DIR> .
@@ 03/22/200609:21 AM <DIR> ..
@@ 06/13/200603:42 PM <DIR> Application Data
@@ 03/23/200512:20 PM <DIR> Cookies
@@ 03/23/200512:59 PM <DIR> Desktop
@@ 01/11/200603:05 PM <DIR> Favorites
@@ 03/23/200512:59 PM <DIR> Local Settings
@@ 01/11/200603:05 PM <DIR> My Documents
@@ 03/23/200512:59 PM <DIR> NetHood
@@ 06/15/200601:37 PM524,288 NTUSER.DAT
@@ 06/15/200601:43 PM 8,192 ntuser.dat.LOG
@@ 06/15/200601:37 PM180 ntuser.ini
@@ 03/23/200512:59 PM <DIR> PrintHood
@@ 01/11/200603:05 PM <DIR> Recent
@@ 04/01/200507:24 PM <DIR> SendTo
@@ 03/23/200512:59 PM <DIR> Start Menu
@@ 03/23/200501:04 PM0 Sti_Trace.log
@@ 03/23/200512:59 PM <DIR> Templates
@@ 4 File(s)532,660 bytes
@@14 Dir(s)919,965,696 bytes free
cd /d C:\
@@ Reason: DNS should not be configured to listen on the Public interface.
netstat -an | find ":53 "
@@ Expected result: Public ip must not be listed.
@@ Expected "good" printout:
@@TCP 127.0.0.1:530.0.0.0:0LISTENING
@@TCP 192.168.169.1:53 0.0.0.0:0LISTENING
@@TCP 192.168.202.1:53 0.0.0.0:0LISTENING
@@UDP 127.0.0.1:53*:*
@@UDP 192.168.169.1:53 *:*
@@UDP 192.168.202.1:53 *:*
@@ No occurrences of node A or B public ip addresses should appear in the list.
netdom query DC
netdom query PDC
netdom query FSMO
@@ Expected result: WinS03
@@ C:\>netdom query DC
@@ List of domain controllers with accounts in the domain:
@@ AP165BAP165AThe command completed successfully.
@@ C:\>netdom query PDC
@@ Primary domain controller for the domain:
@@ AP165AThe command completed successfully.
@@ C:\>netdom query FSMO
@@ Schema owner AP165A.AP165DOM.INT
@@ Domain role ownerAP165A.AP165DOM.INT
@@ PDC roleAP165A.AP165DOM.INT
@@ RID pool managerAP165A.AP165DOM.INT
@@ Infrastructure ownerAP165A.AP165DOM.INT
@@ Reason: DNS Server configuration.
which dnscmd.exe
@SCAN {_line1} "not found" {DNSCMD}
@IF {DNSCMD} <> 0 THEN GOTO NO_DNSCMD
dnscmd /Info
@@ Expected result: DNS Server configuration.
@@ Example:
@@ Query result:
@@ Server info
@@server name= AP206B.AP206DOM.INT
@@version= 0ECE0205 (5.2 build 3790)
@@DS container = cn=MicrosoftDNS,cn=System,DC=ap206dom,DC=int
@@forest name= ap206dom.int
@@domain name= ap206dom.int
@@builtin domain partition = ForestDnsZones.ap206dom.int
@@builtin forest partition = DomainDnsZones.ap206dom.int
@@last scavenge cycle= not since restart (0)
@@Configuration:
@@dwLogLevel= 00000000
@@dwDebugLevel = 00000000
@@dwRpcProtocol= FFFFFFFF
@@dwNameCheckFlag = 00000002
@@cAddressAnswerLimit= 0
@@dwRecursionRetry= 3
@@dwRecursionTimeout = 15
@@dwDsPollingInterval= 180
@@Configuration Flags:
@@fBootMethod= 3
@@fAdminConfigured = 1
@@fAllowUpdate= 1
@@fDsAvailable= 1
@@fAutoReverseZones= 1
@@fAutoCacheUpdate = 0
@@fSlave= 0
@@fNoRecursion= 0
@@fRoundRobin= 0
@@fStrictFileParsing= 0
@@fLooseWildcarding= 0
@@fBindSecondaries = 1
@@fWriteAuthorityNs= 0
@@fLocalNetPriority= 1
@@Aging Configuration:
@@ScavengingInterval= 0
@@DefaultAgingState= 0
@@DefaultRefreshInterval = 168
@@DefaultNoRefreshInterval= 168
@@ServerAddresses:
@@Addr Count = 8
@@Addr[0] => 192.168.202.2
@@Addr[1] => 192.168.169.2
@@Addr[2] => 134.138.169.210
@@Addr[3] => 192.168.201.2
@@Addr[4] => 192.168.170.2
@@Addr[5] => 192.168.200.1
@@Addr[6] => 192.168.169.33
@@Addr[7] => 134.138.169.211
@@ListenAddresses:
@@Addr Count = 2
@@Forwarders:
@@Addr Count = 2
@@Addr[0] => 134.138.201.17
@@Addr[1] => 134.138.226.13
@@forward timeout= 10
@@slave= 0
@LABEL NO_DNSCMD
@@ Reason: Active Directory Replication
@@(see also Primus SCS578050 and SCS578518)
@@ Check NTDS, Configuration data for Active Directory.
reg query \\{NODEA}\HKLM\SYSTEM\CurrentControlSet\Services\NTDS\Parameters
@COPY {_line1}{crap} 1 80
@LENGTH {_line1}{length}
@IF {length} <> 0 THEN GOTO NO_REG
@COPY {_line4}{rootA} 29 100
@COPY {_line5}{CNCA} 30 150
@COPY {_line6}{MDNA} 30 150
reg query \\{NODEB}\HKLM\SYSTEM\CurrentControlSet\Services\NTDS\Parameters
@SCAN {_line5} "Root Domain" {pos}
@IF {pos}=0 THEN GOTO LR1
@COPY {_line5}{rootB} 29 100
@COPY {_line6}{CNCB} 30 150
@COPY {_line7}{MDNB} 30 150
@GOTO LR2
@LABEL LR1
@COPY {_line6}{rootB} 29 100
@COPY {_line7}{CNCB} 30 150
@COPY {_line8}{MDNB} 30 150
@LABEL LR2
@COMMENT ----------------------------------------------------------
@COMMENT A-ROOTDOMAIN: {rootA}
@COMMENT B-ROOTDOMAIN: {rootB}
@COMMENT A-Configuration NC: {CNCA}
@COMMENT B-Configuration NC: {CNCB}
@COMMENT A-Machine DN Name: {MDNA}
@COMMENT B-Machine DN Name: {MDNB}
@@ Expected result: correct domain/node in both nodes, see example below.
@@ HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\NTDS\Parameters
@@System Schema Version REG_DWORD 0x1e
@@Root Domain REG_SZ DC=AP206DOM,DC=INT
@@Configuration NC REG_SZ CN=Configuration,DC=AP206DOM,DC=INT
@@Machine DN Name REG_SZ CN=NTDS Settings,CN=AP206A,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=AP206DOM,DC=INT
@@DSA Working Directory REG_SZ C:\WINNT\NTDS
@@DSA Database file REG_SZ C:\WINNT\NTDS\ntds.dit
@@Database backup path REG_SZ C:\WINNT\NTDS\dsadata.bak
@@Database log files path REG_SZ C:\WINNT\NTDS
@@Hierarchy Table Recalculation interval (minutes) REG_DWORD 0x2d0
@@Database logging/recovery REG_SZ ON
@@DS Drive Mappings REG_MULTI_SZ c:\=\\?\Volume{971ae065-3288-11db-bb9c-806e6f6e6963}\
@@Performance Counter Version REG_DWORD 0x11
@@Strict Replication Consistency REG_DWORD 0x1
@@Schema Version REG_DWORD 0x1e
@@ldapserverintegrity REG_DWORD 0x1
@@Global Catalog Promotion Complete REG_DWORD 0x1
@@Src Srv objectGuid REG_BINARY B26B5600D483CD49B18AFFA0C83A9FE5
@@Root Domain REG_SZ DC=ap206dom,DC=INT
@@Configuration NC REG_SZ CN=Configuration,DC=ap206dom,DC=INT
@@Machine DN Name REG_SZ CN=NTDS Settings,CN=AP206B,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=ap206dom,DC=INT
@@Src Root Domain Srv REG_SZ AP206A.ap206dom.int
@@DS Drive Mappings REG_MULTI_SZ c:\=\\?\Volume{5cafbc35-3288-11db-bd5b-806e6f6e6963}\
@GOTO REG_FOUND
@LABEL NO_REG
@COMMENT ROUTINE NTDS SKIPPED: {crap}
@LABEL REG_FOUND
@@ ## A-ROOTDOMAIN: AP206DOM,DC=INT
@@ ## B-ROOTDOMAIN: ap206dom,DC=INT
@@ ## A-Configuration NC:CN=Configuration,DC=AP206DOM,DC=INT
@@ ## B-Configuration NC:CN=Configuration,DC=ap206dom,DC=INT
@@ ## A-Machine DN Name: CN=NTDS Settings,CN=AP206A,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=AP206DOM,DC=INT
@@ ## B-Machine DN Name: CN=NTDS Settings,CN=AP206B,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=ap206dom,DC=INT
@@ Check frconfig build and success
@IF {hwver}="APG43" THEN GOTO NO_FRCONFIG
@COMMENT A-Node
type "\\192.168.202.1\C$\Program Files\Force\frconfig"\FrConfig.log | Findstr /I /C:"failed on node" /C:succesful /C:build
@@ Expected result:
@@ 08/23/200613:39:21 >INFO - FrConfig v1.4.0 (build 3) started
@@ 08/23/200615:42:47 >INFO - Parameter change completed succesfully on node AP206A
@COMMENT B-Node
type "\\192.168.202.2\C$\Program Files\Force\frconfig"\FrConfig.log | Findstr /I /C:"failed on node" /C:succesful /C:build
@@ Expected result:
@@ 08/23/200613:54:27 >INFO - FrConfig v1.4.0 (build 3) started
@@ 08/23/200615:43:51 >INFO - Parameter change completed succesfully on node AP206B
@LABEL NO_FRCONFIG
@@ Check that the replication is working
where /R C:\ repadmin.exe
@COPY {_line1}{repadmin_path}1 70
@COPY {repadmin_path} {repinfo} 1 5
@IF {repinfo}=INFO: THEN @COMMENT repadmin.exe not found on this system.
@IF {repinfo}=INFO: THEN @GOTO NO_USN
dsquery computer
dsquery computer|findstr /i /c:"Domain Controllers"
@SCAN {_line1} ",OU" {OU}
@IF {OU} = 0 THEN GOTO NO_USN
@SET {OU} = {OU}-5
@COPY {_line1}{AAA}5 {OU}
@SCAN {_line2} ",OU" {OU}
@SET {OU} = {OU}-5
@COPY {_line2}{BBB}5 {OU}
@SCAN {_line1} ",DC=" {pos}
@SET {pos} = {pos}+1
@SET {length} = {length}-{pos}
@COPY {_line1}{DCA}{pos} {length}
@SCAN {_line2} ",DC=" {pos}
@LENGTH {_line2}{length}
@COPY {_line2}{DCB}{pos} {length}
@@ Verify replication A-node
"{repadmin_path}" /options {AAA}
@@verify replication B-node
"{repadmin_path}" /options {BBB}
"{repadmin_path}" /showrepl {AAA}
"{repadmin_path}" /showrepl {BBB}
"{repadmin_path}" /replsummary
@@ IS_GC = domain controller is a Global Catalog server (Only A-node)
@@ Verify that USNs are OK, All time should be close (see Time in example)
"{repadmin_path}" /showutdvec {AAA} {DCA}
"{repadmin_path}" /showutdvec {BBB} {DCB}
@@ "C:\Program Files\FORCE\frconfig\DomainRename\"repadmin /showutdvec apg40a dc=apg40dom,dc=test,dc=com
@@ Caching GUIDs.
@@ Default-First-Site-Name\APG40B@ USN 193753 @ Time 2006-07-18 15:27:31
@@ Default-First-Site-Name\APG40A@ USN 225305 @ Time 2006-07-18 15:29:17
@@ "C:\Program Files\FORCE\frconfig\DomainRename\"repadmin /showutdvec apg40b dc=apg40dom,dc=test,dc=com
@@ Caching GUIDs.
@@ Default-First-Site-Name\APG40B@ USN 193766 @ Time 2006-07-18 15:29:15
@@ Default-First-Site-Name\APG40A@ USN 225339 @ Time 2006-07-18 15:29:17
@@ If the time are not close to each other between A- and B-Node (less than one hour),
@@ then Primus SCS578518 will need to be applied.
@@ Reason: Extended Active Directory check.
dsquery * -s {AAA} -limit 0 | sort >c:\temp\ad_nodea.txt
dsquery * -s {BBB} -limit 0 | sort >c:\temp\ad_nodeb.txt
fc c:\temp\ad_nodea.txt c:\temp\ad_nodeb.txt
del c:\temp\ad_nodea.txt c:\temp\ad_nodeb.txt
@@ Expected result:
@@ Comparing files C:\TEMP\ad_nodea.txt and C:\TEMP\AD_NODEB.TXT
@@ FC: no differences encountered
@@ Reason:check the age of the password
dsquery computer -stalepwd 29
@@ Expected result: The result should be null
@@ If the age of the password is above 29 days then Primus SCS791088 have to be applied for APG40.
@@ This is very important since if the USN are not working correctly the Replication is not working correctly
@@ even if the replication status says that everything is working OK.
@GOTO AD_OK
@LABEL NO_USN
@COMMENT ROUTINE USN SKIPPED: ERROR
@LABEL AD_OK
@@ Reason: Extended FRS and gp check (ref. EMIKSUO PA4)
"C:\WINNT\system32\gpupdate" /force
time /t
"C:\WINNT\system32\eventquery" /L application /V /FO list /R 1 /FI "Source eq SceCli"
cd c:\winnt\sysvol\sysvol
dir
for /d %i in ("c:\winnt\sysvol\sysvol\*") do fsutil reparsepoint query "%i"
for /d %i in ("c:\winnt\sysvol\staging areas\*") do fsutil reparsepoint query "%i"
dir "c:\winnt\sysvol\staging areas"
@LABEL NTFRS_check_for_files
dir \\{NODEA}\c$\winnt\sysvol\domain\scripts\testa.txt /b
@COPY {_line1}{isfilethere_testa}1 30
dir \\{NODEB}\c$\winnt\sysvol\domain\scripts\testb.txt /b
@COPY {_line1}{isfilethere_testb}1 30
@SET {testa_there} = 0
@IF {isfilethere_testa} = "testa.txt" THEN SET {testa_there} = 1
@IF {testa_there} = 1 THEN GOTO waitfor15sec_A
@SET {testb_there} = 0
@IF {isfilethere_testb} = "testb.txt" THEN SET {testb_there} = 1
@IF {testb_there} = 0 THEN GOTO NTFRS_check_continue
@T 15
del \\{NODEB}\c$\winnt\sysvol\domain\scripts\testb.txt
@GOTO NTFRS_check_continue
@LABEL waitfor15sec_A
@T 15
del \\{NODEA}\c$\winnt\sysvol\domain\scripts\testa.txt
@GOTO NTFRS_check_for_files
@LABEL NTFRS_check_continue
copy /Y nul \\{NODEA}\c$\winnt\sysvol\domain\scripts\testa.txt
copy /Y nul \\{NODEB}\c$\winnt\sysvol\domain\scripts\testb.txt
@T 15
@T 15
dir \\{NODEA}\c$\winnt\sysvol\domain\Policies
dir \\{NODEB}\c$\winnt\sysvol\domain\Policies
dir \\{NODEA}\c$\winnt\sysvol\domain\Policies\gpt.ini /s/b
dir \\{NODEB}\c$\winnt\sysvol\domain\Policies\gpt.ini /s/b
dir \\{NODEA}\c$\winnt\sysvol\domain\Policies\gptTmpl.inf /s/b
dir \\{NODEB}\c$\winnt\sysvol\domain\Policies\gptTmpl.inf /s/b
dsquery * -limit 0 | findstr -i "CN=Machine,CN={" | findstr -v "CN=Microsoft,"
dir C:\winnt\sysvol /s /b
"C:\Program files\GPMC\Scripts\ListAllGPOs.wsf" /v
cd /d c:\temp & dumplog -frs
type log.txt && del log.txt
net share
@T 1
ntfrsutl ds {NODEA}
@T 1
ntfrsutl ds {NODEB}
reg query "HKLM\System\CurrentControlSet\Services\Ntfrs\Parameters" /v "Ntfs Journal size in MB"
fsutil usn queryjournal C:
reg query "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon" /v "WaitForNetwork"
@@ Expected result:
@@For further info to analyse the printouts, have a look at primus SCS622571 & SCS570607
@@ Alternative for oss.
@@dir "c:\winnt\sysvol\sysvol\*" | findstr JUNCTION
@@@SCAN {_line1} "JUNCTION" {pos}
@@@COMMENT {pos}
@@@SET {pos}={pos}+14
@@@COPY {_line1}{junc}{pos} 30
@@fsutil reparsepoint query c:\winnt\sysvol\sysvol\{junc}
@@dir "c:\winnt\sysvol\staging areas\*" | findstr JUNCTION
@@@COMMENT {pos}
@@fsutil reparsepoint query "c:\winnt\sysvol\staging areas\{junc}"
@@ Reason: To check the group policy
cd /d C:\TEMP && gpresult /z > C:\TEMP\gpresult.txt
type gpresult.txt && del C:\TEMP\gpresult.txt
@@ Expected result
egalnoticetext and legalnoticecaption policies should be unconfigured
@@Print Automatic Defragmentation status by Diskeeper
"C:\Program Files\Diskeeper Corporation\Diskeeper\Diskeeper" /p /jt=z
@LABEL END_AUDIT
@@Close the logfile
cd /d C:\
echo "End of AP Audit script rev R9A"
@GETTIME {time_end} HHMM
@GETTIME {end_hh} HH
@GETTIME {end_mm} MM
@IF {start_hh}=00 THEN @SET {start_min} = {start_mm}
@IF {start_hh}<>00 THEN @SET {start_min} = {start_hh}*60
@IF {start_hh}<>00 THEN @SET {start_min}={start_min}+{start_mm}
@SET {start_min} = 1440-{start_min}
@IF {start_hh}>{end_hh} THEN @SET {start_min} = {start_min}
@SET {end_min}=0
@SET {end_min} = {end_hh}*60
@SET {end_min}={end_min}+{end_mm}
@IF {start_hh}<{end_hh} THEN @SET {end_min}={end_min}
@IF {end_hh}>{start_hh} THEN @SET {end_min}=1440-{end_min}
@IF {end_hh}={start_hh} THEN @SET {end_min}=1440-{end_min}
@IF {start_hh}>{end_hh} THEN @SET {totaltime}={start_min}+{end_min}
@IF {start_hh}={end_hh} THEN @SET {totaltime}={start_min}-{end_min}
@IF {start_hh}<{end_hh} THEN @SET {totaltime}={start_min}-{end_min}
@COMMENT Date: {date}
@COMMENT Started:{time}
@COMMENT Finished: {time_end}
@COMMENT Total execution time: {totaltime} minutes.
@C
@EXIT
@@---------------Main Script AP_Audit_R9A.txt last line--------------------
@@Subroutines
@@-----------------------------Subroutine SCB-RP Information -APG43---------
@@LABEL SCB_Information
@@SET {loginsuccess} = 0
@@ONRECEIVE "Login incorrect" GOTO send_usrid
@@ONRECEIVE "login:" GOSUB send_pwd
@@ONRECEIVE "Password:" GOSUB send_cmd
@@ Login Username for SCB-RP Slot
@@LABEL send_usrid
@@razor
@@PASTE {loginfo} {_lines}
@@COMPACT {loginfo}
@@SIZE {loginfo} {numlog}
@@SET {indexv} = 1
@@WHILE {indexv} < {numlog}
@@IF {loginfo[{indexv}]} MATCHES ".*not recognized.*" THEN GOTO SlotInfo_END
@@INC {indexv}
@@ENDWHILE
@@RETURN
@@ Password
@@LABEL send_pwd
@@assar
@@RETURN
@@ Checking the login success on SCB-RP Slot
@@LABEL send_cmd
@@PASTE {logdetail} {_lines}
@@COMPACT {logdetail}
@@SIZE {logdetail} {numlines}
@@SET {indexcount} = 1
@@WHILE {indexcount} < {numlines}
@@IF {logdetail[{indexcount}]} MATCHES ".*elcome to.*" THEN SET {loginsuccess} = 1
@@INC {indexcount}
@@ENDWHILE
@@IF {loginsuccess} <> 1 THEN GOTO SlotInfo_END
@@ Command to check the link speed of eGEM
@@scbsw status
@@exit
@@LABEL SlotInfo_END
@@RETURN
@@-----------------------------Subroutine HW_C2-----------------------------
@LABEL HW_C2
@COMMENT APG40_C2_HW
@@ Reason: To display the serial number and Manufacturing Date.
fcc_getbib
@@ Expected result: MADATE= 'date'
@@ SERIALNO = 'number'
@@ Reason: Check status of RAID Cluster Support.
"C:\Program Files\Dptmgr\Raidutil" -K
@@ Expected result: Cluster Support must be Enabled on both nodes and
@@FW version FT06 or newer.
@@ Address Manufacturer/ModelFWCluster Support
@@ d0DPTPM3757U2FT06 Enabled
@@ Reason: Check the RAID disk and firmware status.
"C:\Program Files\Dptmgr\Raidutil" -L all
@@ Expected result: On an active node all disks should be Optimal and
@@FW version FT06 or newer. Ignore status 'Drive Failed'
@@on RAID volumes on the passive node.
@@ Reason: Check setting of RAID remirroring speed.
raidutil -r d0
@@ Expected result:
@@ Address TypeRate
@@ d0b0t7d0HBA 9.0s (fast)
@@ d0b0t1d0RAID 1 (Mirrored)9.0s (fast)
@@ d0b0t0d0RAID 1 (Mirrored)9.0s (fast)
@@ d0b0t2d0RAID 1 (Mirrored)9.0s (fast)
@@ To correct a faulty setting:
@@ Command:
@@ raidutil -r fast d0
@@ Reason: To view the raid controllers eventlog using the raidutil commands
"C:\Program Files\Dptmgr\Raidutil" -e soft d0
"C:\Program Files\Dptmgr\Raidutil" -e recov d0
"C:\Program Files\Dptmgr\Raidutil" -e nonrecov d0
"C:\Program Files\Dptmgr\Raidutil" -e status d0
@@ Reason: To check Am-boards and their internal communication.
@@To check the temperature on AM- and PSU-board.
@IF {osver} = "NT4" THEN GOTO FCC_AM
fcc_amversion own
fcc_amversion other
@LABEL FCC_AM
@IF {cdt} = YES THEN return
cd /d "C:\Program Files\force\AM_Services\" && fcc_amtest own -f
del "C:\Program Files\force\AM_Services\AMProtocol.log"
cd /d "C:\Program Files\force\AM_Services\" && fcc_amtest other -f
cd /d C:\
@@ Expected result: AM board typically 26.0 C must be below 50.
@@PSU board typically 37.0 C must be below 58.
@@AM board firmware version.
@IF {nodestate} <> "active" THEN GOTO NO_PASSIVE_16
cd /d "C:\Program files\force\tools"
FrChangeDisk /?
cd /d C:\
@@Expected Result:
@@FrChageDisk Version: 1.1
@LABEL NO_PASSIVE_16
@@Reason:To check if autoadmin logon is enabled
reg query "HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon" /v AutoAdminLogon
@@Expected Result:
@@HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
@@ AutoAdminLogon REG_SZ 0
@@Reason:To check the contents of the V:\APZ\DATA\BOOT Folder
@IF {nodestate} <> "active" THEN GOTO NO_PASSIVE_19
cfeted -v cur
@@Expected Result:
@@ Directory of V:\APZ\data\boot
@@18/06/201115:21 <DIR> .
@@18/06/201115:21 <DIR> ..
@@08/03/201116:39 <DIR> APZ_VM
@@07/03/201116:28 <DIR> cpa
@@07/03/201116:28 <DIR> cpb
@@18/06/201115:21 <DIR> fw
@@08/03/201116:41 <DIR> image
@@18/06/201115:21 <DIR> temp
@@0 File(s)0 bytes
@@8 Dir(s)7.966.674.944 bytes free
@LABEL NO_PASSIVE_19
@@Reason:To check the WSRM service
wsrmls
@@Expected Result:
@@WSRM POLICIES
@@POLICY NAMESTATE
@@MCS_RapNot Active
@@AES_RapActive
@@FMS_RapNot Active
@@WSRMDefaultNot Active
@RETURN
@@-----------------------------Subroutine HW_C4-----------------------------
@LABEL HW_C4
@COMMENT APG40_C4_HW
fcc_getbib
@@ Reason: To show (APG40/C4)
@@physical SCSI Disks Information
@@Logical Drives configuration
@@MegaRAID Configuration
@@Gathering RAID information via SCSIDISK tool:
@@Physical SCSI disk info:
"C:\Program Files\Force\Raid\ScsiDisk" /DI
@@Logical drive configuration:
"C:\Program Files\Force\Raid\ScsiDisk" /LD
@@Dump Debug Data of MegaRC controller (only available before a reboot):
"C:\Program Files\Force\Raid\ScsiDisk" /DD
@@Channel Swap Setting:
"C:\Program Files\Force\Raid\ScsiDisk" /CS
@@Gathering RAID information via MEGARC:
@@Adapter and Logical drive info:
"C:\Program Files\Force\Raid\megarc" -ctlrInfo-a0
@@logical drives info
"C:\Program Files\Force\Raid\megarc" -ldInfo -a0 -Lall
@@Configuration info:
"C:\Program Files\Force\Raid\megarc" -dispCfg -a0
@@Physical drive info:
"C:\Program Files\Force\Raid\megarc" -logPhysInfo -a0
@@Adapter,Channel,Target ID information
"C:\Program Files\Force\Raid\megarc" -phys -chAll -idAll -a0
@@Adapter,Firmware Type,Card Type Info:
"C:\Program Files\Force\Raid\megarc" -AllAdpInfo
@@BIOS Setting Info:
"C:\Program Files\Force\Raid\megarc" -ShowBios -a0
@@NVRAM Log:
"C:\Program Files\Force\Raid\megarc" -getNVRAMLog -a0
@@Extended Sense Log:
"C:\Program Files\Force\Raid\megarc" -ViewExtSenseData -chAll -idAll -a0
@@Error Information:
"C:\Program Files\Force\Raid\megarc" -pdFailInfo -chAll -idAll -a0
@@Gamevlog:
type c:\winnt\system32\gamserv\gamevlog.log
@@ Expected result: MegaRAID Configuration
fcc_amversion own
fcc_amversion other
cd /d C:\
FrChangeDisk /?
cd /d C:\
@@Expected Result:
@@Expected Result:
cfeted -v cur
@@Expected Result:
@@0 File(s)0 bytes
wsrmls
@@Expected Result:
@@WSRM POLICIES
@@POLICY NAMESTATE
@@MCS_RapNot Active
@@AES_RapActive
@@FMS_RapNot Active
@RETURN
@@---------------------------Subroutine APG43_EVO----------------------------
@LABEL APG43_EVO
@@ Reason: To show EVO node info
@COMMENT APG43_EVO
@IF {nodestate} <> "active" THEN GOTO NO_PASSIVE_20
hwiprint
@LABEL NO_PASSIVE_20
hwmxls
upgpkg -i
timerefls
timerefscxconf -l
xcountls
@RETURN
@@---------------------------Subroutine APG43_HW----------------------------
@LABEL APG43_HW
@@ Reason: To show APG43 hw info
@COMMENT APG43_HW
hwmls
hwmls -l
hwcls
hwcls -x long
WMIC Csproduct List Brief
@@ Reason : To find the DVD model
@IF {nodestate} <> "active" THEN GOTO NO_PASSIVE_18
wmic cdrom get deviceid
@@Expected Result:Prints the DVD model and the FW ver
@LABEL NO_PASSIVE_18
vxassist version
vxdg list
vxdisk list
vxdisk diskinfo Harddisk0
vxdisk diskinfo Harddisk1
vxdisk diskinfo Harddisk2
vxdisk diskinfo Harddisk3
vxvol volinfo E:
vxvol volinfo C:
vxvol volinfo D:
vxvol volinfo F:
@IF {nodestate} <> "active" THEN GOTO 43_PASSIVE_4
vxvol volinfo I:
vxvol volinfo K:
vxdg -gdatadisk dginfo
cd /d "C:\Program Files\AP\APOS\clone"
dskcache PhysicalDrive1
dskcache PhysicalDrive2
cd /d c:\temp
ssuls -l
@LABEL 43_PASSIVE_4
echo Y | apdiskdiag -v
@@ Expected result:
@@ Reason: To check which hot fixes and security patches are installed.
reg query "HKLM\SOFTWARE\Ericsson\Adjunct Processor\APOS\CXC1371176" /v PATCHES /se :
reg query "HKLM\SOFTWARE\Ericsson\Adjunct Processor\APOS\CXC1371177" /v PATCHES /se :
@@ Expected result KB list
@@ Reason: To check tftp configuration
reg query "HKLM\SOFTWARE\WinAgents\TFTPService"
@@ Expected result:
@@HKEY_LOCAL_MACHINE\SOFTWARE\WinAgents\TFTPService
@@ DefaultRights REG_SZ RW
@@ HostList REG_SZ
@@ LogDirectory REG_SZ C:\Program Files\WinAgents\TFTP Service\LogFiles
@@ TFTPRoot REG_SZ K:\APZ\data\BOOT
@@ AllowOverWrite REG_DWORD 0x1
@@ TFTPRetr REG_DWORD 0xa
@@ TFTPTimeout REG_DWORD 0xa
@@ FWEnabled REG_DWORD 0x0
@@ FWMaxPort REG_DWORD 0xffff
@@ FWMinPort REG_DWORD 0x401
@@ LogLevel REG_DWORD 0x6
@@ WriteLog REG_DWORD 0x1
@@ HighPriority REG_DWORD 0x1
@@ LogFileCount REG_DWORD 0x1
@@ TFTPPort REG_DWORD 0x45
@@ OpBlocksize REG_DWORD 0x1
@@ OpTSize REG_DWORD 0x1
@@ OpTimeout REG_DWORD 0x1
@@ LocalTime REG_DWORD 0x0
@@ Reason: Internal, to detect if APG43 for blade cluster
reg query "HKLM\SOFTWARE\Ericsson\Adjunct Processor\ACS\CS"
@@COPY {_line1}{bc}1 5
@@IF {bc}="" THEN SET {bc}="YES"
@@Expected Result:
@RETURN
@@---------------------------Subroutine APG40_ACL---------------------------
@LABEL APG40_ACL
@COMMENT APG40_ACL
@@ Reason: To check that the acl:s are set correct.
@@These ACL's are according to the "standard baseline"
cd /d C:\
@@ Print all acl's on all "system" disks
cacls C:\
cacls D:\
cacls E:\
cacls F:\
cacls C:\winnt /C
cacls C:\winnt\*.dll /C
cacls C:\winnt\*.exe /C
cacls C:\winnt\*.sys /C
cacls C:\winnt\system32
cacls C:\winnt\system32\*.dll /C
cacls C:\winnt\system32\*.exe /C
cacls C:\winnt\system32\*.sys /C
cacls "C:\Program Files\AP"
cacls "C:\Program Files\AP\*" /C /T
cacls C:\acs
cacls C:\acs\*.* /C /T
cacls C:\inetsrv\ftproot /C /T
cacls C:\tftpboot
cacls C:\tftpboot\* /C /T
cacls C:\temp
cacls F:\
cacls F:\acs
cacls F:\ACS\data
cacls F:\ACS\logs
cacls F:\acs\data\emf
@COMMENT END_OF_DATA_DISKS
@@ Expected result: No deviation from reference system. In case deviations
@@are found, use APAclSet to correct the problem.
@@Note: The functionality to create and restore an ACL
@@definition file was released in CNI
@@109 22-APZ21220/5-1224.
@@Reference ACL files are delivered from
@@CM130/CM220/CM4220/CM311
@@ To find the ACL baseline reference for your system, search in Prim/GASK for the 1095
@@ for the reference package for your AP GAS e.g.
@@ "REFERENCE PACKAGE FOR GAS 3.0 AP1/40 - AC-M4225 LZY 216 1180/3" has a 1095-LZY 216 1180/3.
@@ In the 1095 the ACL baseline reference is called "ACL reference".
@@ If there is more than 1 ACL reference document the superseded documents will have a
@@ "No or ceased relationship" which is indicated by a slash ( ??) in the "PRA" column.
@@ The valid document will have a revision in this PRA column e.g. "A".
@@ 1095 documents are easily browsed in GASK2WEB
http://gask.ericsson.se/gask2web/1095/index.html
@@ A link to a document in GASK can be used e.g. by using the
@@ GASK2Web Document Browser
http://gask.ericsson.se/gask2web/index.html
@@ e.g. ACL baseline reference document 225/1551-LZY 216 1180/3 Uen Rev A is
http://gask2web.ericsson.se/pub/get?DocNo=225/1551-LZY2161180/3&lang=EN&rev=A
@@ Full description also available at:
http://apzsupp.rnd.as.sw.ericsson.se/axe/ap/APG40_Audit_Script_work_files/Howto_find_ACL-baseline-ref.doc
@@ Reason: To check all acl:s for three dir levels on all data disks.
@IF {nodestate} <> "active" THEN GOTO NO_PASSIVE_6
@@ I:\ J:\ K:\ L:\ M:\ R:\ S:\ V:\ G:\ Q:\ Y:\
@IF {osver}="NT4" THEN GOTO J_Cacls
cacls I:\
@GOTO J_Cacls_End
@LABEL J_Cacls
cacls J:\
@LABEL J_Cacls_End
cacls K:\
cacls L:\
cacls M:\
cacls R:\
cacls S:\
cacls V:\
cacls G:\
cacls Q:\
cacls Y:\
@COMMENT A_U_D_I_T
@IF {osver} = "NT4" THEN GOTO J_Drive
@@ I
cacls I:\
cacls I:\*
cacls I:\MSCS\*
@GOTO J_Drive_End
@LABEL J_Drive
@@ J
cacls J:\
cacls J:\*
cacls J:\MSCS\*
@LABEL J_Drive_End
@@ L
cacls L:\
cacls L:\*
cacls L:\CPS\*
cacls L:\CPS\Data\*
cacls L:\FMS\*
cacls L:\FMS\Data\*
@@ M
cacls M:\
cacls M:\*
cacls M:\MCS\*
cacls M:\MCS\Data\*
cacls M:\Images\*
@@ R
cacls R:\
cacls R:\*
cacls R:\STS\*
cacls R:\STS\Data\*
cacls R:\STS\Logs\*
@@ S
cacls S:\
cacls S:\*
cacls S:\STS\*
cacls S:\STS\Data\*
@@ V
cacls V:\
cacls V:\*
cacls V:\APZ\*
cacls V:\APZ\Data\*
@@ G
cacls G:\
cacls G:\*
cacls G:\Ftpvol\*
@@ Q
cacls Q:\
cacls Q:\*
cacls Q:\ACS\*
cacls Q:\ACS\Data\*
@@ Y
cacls Y:\
cacls Y:\*
cacls Y:\ACS\*
cacls Y:\ACS\Data\*
@@ K
cacls K:\
cacls K:\*
cacls K:\ACS\*
cacls K:\AES\*
cacls K:\FMS\*
@IF {osver} <> "NT4" THEN GOTO K_Drive_End
cacls K:\IMAGES\*
@LABEL K_Drive_End
cacls K:\MCS
cacls K:\OCS
cacls K:\SGS
@@Only valid for APZ 11.1
@@ X
cacls X:\
cacls X:\*
cacls X:\MessageStore\*
cacls X:\MessageStore\ACA\*
@@ Expected result:ACL's for "root" on all drives
@@Everyone
OI)(CI)R
@@NT AUTHORITY\SYSTEM:(OI)(CI)F
@@BUILTIN\Administrators:(OI)(CI)F
@@General example:
@@ACL's on L:\ directories
@@ AP61DOM\FMSADMG:(OI)(CI)F (user "FMSADMG" varies according to subsys)
@@ AP61DOM\FMSUSRG:(OI)(CI)R (user "FMSUSRG" varies according to subsys)
@@ Exception for G:\ftpvol
@@ G:\ftpvol AP150DOM\FMSUSRG:(OI)(CI)R
@@AP150DOM\FMSADMG:(OI)(CI)F
@@AP150DOM\ACSUSRG:(OI)(CI)R
@@AP150DOM\ACSADMG:(OI)(CI)F
@LABEL NO_PASSIVE_6
@@ Reason: Not part of the "standard baseline".
cacls C:\*.* /c
cacls "C:\inetsrv\*.*" /c
@IF {nodestate} <> "active" THEN GOTO NO_PASSIVE_7
@IF {osver} <> "NT4" THEN GOTO M_Drive_Cacls
cacls K:\Images\* /T
cacls J:\* /C /T
@GOTO NO_PASSIVE_7
@LABEL M_Drive_Cacls
cacls M:\Images\* /T
cacls I:\* /C /T
@@ Expected result: ACL
@LABEL NO_PASSIVE_7
@@ Reason: To check permissions on E: partition (TR HG70665)
cacls E:\
cacls E:\* /C
@@ Expected result: ACL's according to examples.
@@ Example NT4:
@@ C:\>cacls E:
@@ E:\ Everyone:(OI)(CI)R
@@ C:\>cacls E:\* /C
@@ E:\BOOT.INI NT AUTHORITY\SYSTEM:F
@@ BUILTIN\Administrators:(OI)(CI)F
@@ E:\ntdetect.com NT AUTHORITY\SYSTEM:F
@@ E:\ntldr NT AUTHORITY\SYSTEM:F
@@ E:\RECYCLER Everyone:R
@@ Everyone:(OI)(CI)(IO)R
@@ NT AUTHORITY\SYSTEM:F
@@ NT AUTHORITY\SYSTEM:(OI)(CI)(IO)F
@@ BUILTIN\Administrators:F
@@ BUILTIN\Administrators:(OI)(CI)(IO)F
@@ Example Windows 2003 Server:
@@ c:\winnt\profiles\Administrator>cacls E:
@@ E:\ BUILTIN\Administrators:(OI)(CI)F
@@Everyone:(OI)(CI)R
@@ c:\winnt\profiles\Administrator>cacls E:\* /C
@@ E:\BOOT.BAK BUILTIN\Administrators:F
@@ BUILTIN\Users:R
@@ E:\boot.ini BUILTIN\Server Operators:C
@@ E:\cmdcons BUILTIN\Administrators:(OI)(CI)F
@@BUILTIN\Administrators:F
@@CREATOR OWNER:(OI)(CI)(IO)F
@@BUILTIN\Users:(OI)(CI)R
@@BUILTIN\Users:(CI)(special access
@@FILE_APPEND_DATA
@@FILE_WRITE_DATA
@@ E:\cmldr BUILTIN\Administrators:F
@@ BUILTIN\Users:R
@@ E:\NTDETECT.COM BUILTIN\Server Operators:C
@@NT AUTHORITY\SYSTEM:F
@@ E:\ntldr BUILTIN\Server Operators:C
@@ E:\RECYCLER BUILTIN\Administrators:(OI)(CI)F
@@ NT AUTHORITY\SYSTEM:(OI)(CI)F
@@ CREATOR OWNER:(OI)(CI)(IO)F
@@ BUILTIN\Users:(OI)(CI)R
@@ BUILTIN\Users:(CI)(special access
@@ FILE_APPEND_DATA
@@ BUILTIN\Users:(CI)(special access:)
@@ FILE_WRITE_DATA
@@ E:\System Volume Information NT AUTHORITY\SYSTEM:(OI)(CI)F
@@ Reason: To check that no occurrences of <Account Domain not found> exist.
@@ OSU: extremely important on Q and Y partition.
@COMMENT SYSTEM DISKS
cacls C:\* /T /C > c:\temp\acllist_c.txt 2<&1
type C:\temp\acllist_c.txt|find "Account Domain not found"
del c:\temp\acllist_c.txt
cacls E:\* /T /C > c:\temp\acllist_e.txt 2<&1
type C:\temp\acllist_e.txt|find "Account Domain not found"
del c:\temp\acllist_e.txt
cacls F:\* /T /C > c:\temp\acllist_f.txt 2<&1
type C:\temp\acllist_f.txt|find "Account Domain not found"
del C:\temp\acllist_f.txt
@IF {nodestate} <> "active" THEN GOTO NO_ACTIVE_1
@COMMENT DATA DISKS
cacls G:\* /T /C > c:\temp\acllist_g.txt 2<&1
type C:\temp\acllist_g.txt|find "Account Domain not found"
del c:\temp\acllist_g.txt
cacls I:\* /T /C > c:\temp\acllist_i.txt 2<&1
type C:\temp\acllist_i.txt|find "Account Domain not found"
del c:\temp\acllist_i.txt
cacls J:\* /T /C > c:\temp\acllist_j.txt 2<&1
type C:\temp\acllist_j.txt|find "Account Domain not found"
del c:\temp\acllist_j.txt
cacls K:\* /T /C > c:\temp\acllist_k.txt 2<&1
type C:\temp\acllist_k.txt|find "Account Domain not found"
del c:\temp\acllist_k.txt
cacls L:\* /T /C > c:\temp\acllist_l.txt 2<&1
type C:\temp\acllist_l.txt|find "Account Domain not found"
del c:\temp\acllist_l.txt
cacls M:\* /T /C > c:\temp\acllist_m.txt 2<&1
type C:\temp\acllist_m.txt|find "Account Domain not found"
del c:\temp\acllist_m.txt
cacls Q:\* /T /C > c:\temp\acllist_q.txt 2<&1
type C:\temp\acllist_q.txt|find "Account Domain not found"
del c:\temp\acllist_q.txt
cacls R:\* /T /C > c:\temp\acllist_r.txt 2<&1
type C:\temp\acllist_r.txt|find "Account Domain not found"
del c:\temp\acllist_r.txt
cacls S:\* /T /C > c:\temp\acllist_s.txt 2<&1
type C:\temp\acllist_s.txt|find "Account Domain not found"
del c:\temp\acllist_s.txt
cacls V:\* /T /C > c:\temp\acllist_v.txt 2<&1
type C:\temp\acllist_v.txt|find "Account Domain not found"
del c:\temp\acllist_v.txt
cacls Y:\* /T /C > c:\temp\acllist_y.txt 2<&1
type C:\temp\acllist_y.txt|find "Account Domain not found"
del C:\temp\acllist_y.txt
@@ Expected result: No Account Domain not found found.
@LABEL NO_ACTIVE_1
@RETURN
@@---------------------------Subroutine APG43_ACL---------------------------
@LABEL APG43_ACL
@COMMENT APG43_ACL
cd /d C:\
cacls C:\
cacls D:\
cacls E:\
cacls F:\
cacls C:\winnt /C
cacls "C:\program files\ap\xmlfile"
cacls "C:\program files\appext"
cacls "C:\program files\appext\*" /C /T
cacls C:\acs
cacls C:\tftpboot
cacls C:\temp
cacls F:\
cacls F:\acs
cacls F:\ACS\data
cacls F:\ACS\logs
@IF {nodestate} <> "active" THEN GOTO 43_PASSIVE_1
@@ I:\ K:\
cacls I:\
cacls K:\
@COMMENT A_L_A_N
@@ I
cacls I:\
cacls I:\*
cacls I:\MSCS\
cacls I:\Diskeeper\*
@@ K
cacls K:\
cacls K:\*
cacls K:\ACS\*
cacls K:\AES\*
cacls K:\APZ\*
cacls K:\CPS\*
cacls K:\CQS\*
cacls K:\Diskeeper\*
cacls K:\FMS\*
cacls K:\ftpvol\*
cacls K:\Images\*
cacls K:\MCS\*
cacls K:\OCS\*
cacls K:\SGS\*
cacls K:\STS\*
@@General example:
@LABEL 43_PASSIVE_1
cacls C:\*.* /c
@IF {nodestate} <> "active" THEN GOTO 43_PASSIVE_2
cacls I:\* /C /T
@LABEL 43_PASSIVE_2
cacls E:\
cacls E:\* /C
@@ BUILTIN\Users:R
@@BUILTIN\Users:(CI)(special access:)
@@FILE_APPEND_DATA
@@FILE_WRITE_DATA
@@ BUILTIN\Users:R
@@ FILE_APPEND_DATA
@@ FILE_WRITE_DATA
@IF {nodestate} <> "active" THEN GOTO 43_PASSIVE_3
@COMMENT DATA DISKS
@LABEL 43_PASSIVE_3
@RETURN
@@-------------------------Subroutine BC_HW------------------------
@LABEL BC_HW
@COMMENT BC_HW
cpgls
apzvlanls
nels
@PASTE {DCP0} {_lines}
@COMPACT {DCP0}
@SIZE {DCP0} {numtype}
@SET {indextype} = 1
@WHILE {indextype} < {numtype}
@BEFORE {DCP0} {DCP0[{indextype}]} ":"
@IF {DCP0} MATCHES ".*Number of Dual-Sided CPs.*" THEN @AFTER {DCP1} {DCP0[{indextype}]} ":"
@IF {DCP0} MATCHES ".*Number of Single-Sided CPs.*" THEN @AFTER {SCP1} {DCP0[{indextype}]} ":"
@INC {indextype}
@ENDWHILE
@COMMENT Dual CPs: {DCP1}
@COMMENT Single CPs: {SCP1}
@SET {CP_Count} = {DCP1} + {SCP1}
@COMMENT Total CP_Count {CP_Count}
cpls -l
@PASTE {CPNAMES} {_lines}
@SIZE {CPNAMES} {numCPs}
@IF {nodestate} <> "active" THEN GOTO BC_PASSIVE_1
cpdtest -c
cpdtest -p
cpdlist -s
ssuls -l
capls
@SET {indexCP} = 5
@WHILE {indexCP} < {numCPs}
@ITEM {GET_CPNAME} {CPNAMES[{indexCP}]} " " 1
@IF {GET_CPNAME} MATCHES "BC.*" THEN GOTO L1
@IF {GET_CPNAME} MATCHES "CP.*" THEN GOTO L1
@GOTO L2
@LABEL L1
@TRIM {GET_CPNAME}
@COMMENT GET_CPNAME {GET_CPNAME}
cpfdf -cp {GET_CPNAME}
cpfls -cp {GET_CPNAME} -l
cpdtest -s -cp{GET_CPNAME}
cpfls -cp {GET_CPNAME}| FindStr /R "RELFSW[0-9]"
cpfls -cp {GET_CPNAME} -ls RELFSW0
cpfls -cp {GET_CPNAME} -ls RELFSW1
cpfls -cp {GET_CPNAME} -ls RELFSW2
cpfls -cp {GET_CPNAME} -ls RELCMDHDF
bupls -cp {GET_CPNAME}
bupidls -cp {GET_CPNAME}
@COMMENT END OF CP : {GET_CPNAME}
@LABEL L2
@INC {indexCP}
@ENDWHILE
afpls -l
cdhdsls -l
cdhls -l
dbols -l
dir /s K:\MCS\logs\
@LABEL BC_PASSIVE_1
@RETURN
@@-------------------File AP_Audit_R9A.txt last line-----------------------
