【资料名称】:简单版本CAD
【资料作者】:***
【资料日期】:R2.5-R2012
Acme CAD Converter is a multifunctional computer aided design software, which is widely used at home and abroad. Its speedy bacth-type format conversion function could convert DWG/DXF files into PLT, PDF , EPS, SVG, CGM, WMF, BMP, JPEG, TIFF. Acme CAD Converter supports user-designed page layout size setting, supports 3D objects hidden line removal, and supports the user-designed watermark and linewidth setting, as well as unfound fonts replacement. Meanwhile,this software is also capable in bacth recovering and packing DWG/DXF files.You do not need to take thought for that the characters or external reference blocks (Xref) in the file you send to your colleagues could not be displayed correctly. You would enjoy your work if you could properly use this software.
2012-11-2 11:39:11 下载次数: 1
CAD.rar (6.26 MB)
