通信设备厂商技术区
华为技术资料区
» BSC_DataBase
BSC_DataBase
乘着风棒
积分 96
帖子 19
威望 1459 个
注册 2009-8-7
专业方向 无线网优
发表于 2012-09-11 14:42:24
【资料名称】:BSC_DataBase
【资料作者】:siemens
【资料日期】:2000
【资料语言】:英文
【资料格式】:PDF
TABASE BR9.0 ....................................................................................................................................... 9
1.1 BR9.0 OBJECT TREE OF FUNCTIONAL BSC DATABASE OBJECTS ................................................................. 9
1.2 BSC DATABASE COMMANDS AND PARAMETERS................................................................................. 11
Setting the object entry point and time and date for the BSS:................................................................ 11
Setting the BSC control values for periodic measurement data file upload: .......................................... 11
Setting the timing values for BSSMAP control and BSC overload handling: ......................................... 14
Setting the global parameters of the BSC: ............................................................................................. 25
Creating new database parameters without info model change: ........................................................... 64
Setting the alarm priorities of the BSS functional objects:...................................................................... 65
Setting the remote Inventory data of the BSC Equipment:..................................................................... 68
Setting the alarm priorities of the BSCE objects:.................................................................................... 68
Setting the alarm priorities of the EBSCE objects: ................................................................................. 70
Defining the eBSC configuration:............................................................................................................ 72
Creating the spare PCM interface boards: ............................................................................................. 73
Creating the PCM interface boards: ....................................................................................................... 73
Creating the common attributes for all PCUs belonging to the entire BSC:........................................... 74
Creating the PCU objects: ...................................................................................................................... 81
Creating the Network Service Entity (NSE): ........................................................................................... 82
Creating an SGSN Pool:......................................................................................................................... 90
Creating the local NSE Virtual Link IP of an NS connection: ................................................................. 91
Creating the remote NSE Virtual Link IP: ............................................................................................... 91
Creating the PCM links for the Abis interface:........................................................................................ 92
Creating the PCMS link:.......................................................................................................................... 96
Creating the TRAU:................................................................................................................................. 98
Basic TRAU-mapping 1: NOT_COMPATIBLE_WITH_CROSSCONNECT (no pools created)...................... 99
Basic TRAU-mapping 2: COMPATIBLE_WITH_CROSSCONNECT (no pools created) ............................... 99
Creating the LPDLS links:..................................................................................................................... 103
Creating the PCMA link:........................................................................................................................ 104
Setting the uplink and downlink volumes for specific PCMA timeslots:................................................ 110
Creating the PCMG link: ....................................................................................................................... 111
Creating the physical link connection on the GPRS Gb interface (Frame Relay Link): ...................... 113
Creating the end-to-end communication between BSS and SGSN: Network Service Virtual Connection
(NSVC):................................................................................................................................................. 114
Creating the BTS Site Manager:........................................................................................................... 115
Creating the Common BTS data of a BTSM for Dynamic MAIO Allocation (DMA):............................. 132
Creating the hopping laws used for Dynamic MAIO Allocation: ........................................................... 137
Creating the LPDLM links: .................................................................................................................... 138
Creating the terrestrial Abis timeslots for flexible Abis allocation: ........................................................ 140
Creating a cell with definition of global parameters: ............................................................................. 145
Setting the cell specific parameters for DMA Admission Control ......................................................... 211
Setting the cell attributes for the Interference Measurement of idle TCHs:.......................................... 223
Setting the cell specific timer values:.................................................................................................... 225
Setting the cell specific optional features:............................................................................................. 235
Defining the cell specific service layer lists for the feature 'Service dependent Channel Allocation'
(SDCA) via 'Multi Service Layer Support' (MSLS):............................................................................... 250
Setting the cell specific attributes for Power Control: ........................................................................... 261
Power Control Parameter Relations.................................................................................................................. 274
Creating the GPRS point to point packet transfer service in a cell:...................................................... 275
Creating the cell-specific Frequency Hopping systems for static MAIO Allocation (SMA):.................. 310
Creating the TRXs: ............................................................................................................................... 312
Enabling GPRS and EDGE in a cell: .................................................................................................... 317
Creating the BCCH for the cell: ............................................................................................................ 319
Creating the SDCCHs for the cell: ........................................................................................................ 320
Creating the TCHs for the cell: ............................................................................................................. 322
Creating hybrid TCHs/SDCCHs (TCH/SD) for the cell:........................................................................ 325
Setting the cell specific parameters and threshold values for CS Handover: ...................................... 330
Handover Parameter Relations......................................................................................................................... 380
Setting the cell specific parameters and threshold values for 14,4kbit/s data call up- and downgrading
and quality inter-cell handover:............................................................................................................. 382
GERAN-S Database Parameter Planning & Engineering Manual BR9.0 Version 27.04.07
__________________________________________________________________________________________________________
6 / 575 Network Engineering GERAN
Enabling features related to ASCI, SMS-CB, Frequency Hopping, HSCSD, Call Release due to
Excessive Distance and Dynamic MAIO Allocation (DMA): ................................................................. 384
Creating the Target Cell Objects: ......................................................................................................... 389
Creating the Target Point-to-point Packet Flow Objects: ..................................................................... 392
Creating the Adjacent Cell Objects:...................................................................................................... 394
Creating the Target Cell Objects for handover from GSM to UMTS (FDD): ........................................ 410
Creating the Adjacent Cell Objects for external UMTS FDD or UMTS TDD cells:............................... 412
Creating the CCS7 level 3 address and basic SCCP parameters of the BSC..................................... 418
Creating the remote CCS7 transport point : ......................................................................................... 421
Creating the remote CCS7 Destination Points (DPCs of MSCs, SMLC etc.): ..................................... 421
Creating the CCS7 link set: .................................................................................................................. 427
Creating the CCS7 link: ........................................................................................................................ 433
Creating the PCMH link: ....................................................................................................................... 434
Creating a Nailed-Up Connection through the BSC/TRAU: ................................................................. 436
Creating an X25 connection via dedicated link:.................................................................................... 437
Creating an X25 connection via A-interface: ........................................................................................ 439
Creating an IP Link connection:............................................................................................................ 441
Creating the O&M link for the RC connection:...................................................................................... 442
Creating the link for the external connection to the SMS-CB system:.................................................. 442
Creating the SDH link for connectivity purposes: ................................................................................. 443
Defining the optical interface (INTF) configuration parameters:........................................................... 444
Creating the ATM Virtual Path (ATMVP): ............................................................................................. 445
Configuration of Bidirectional Continuity Monitors for ATM Virtual Path (BCMATMVP): ..................... 447
Creating the ATM Virtual Channel (ATMVC):....................................................................................... 448
Configuration of Bidirectional Continuity Monitors for ATM Virtual Channels (BCMATMVC): ............. 449
Defining the BSC reference synchronization clock origin:.................................................................... 450
Defining an external synchronization signal: ........................................................................................ 450
Creating the Quality of Service Alarm Objects: .................................................................................... 451
Creating the Quality of Service Alarm threshold sets: .......................................................................... 452
Creating the Quality of Service Alarm Objects for the BSC object:...................................................... 454
Creating the Quality of Service Alarm Objects for BTS objects: .......................................................... 455
Creating the Quality of Service Alarm Objects for PTPPKF objects: ................................................... 459
Activating IMSI tracing in the BSC:....................................................................................................... 461
Creating a Cell Traffic Recording (CTR) job:........................................................................................ 462
Enabling the data recording for the feature 'History on Dropped Calls': .............................................. 464
Defining the BSC environmental alarms:.............................................................................................. 469
Configuring the feature Online RF Loopback: ......................................................................................
2012-9-11 14:42:24 下载次数: 13
BSC_DataBase_Parameter_Description_BR9.0.pdf
(3.68 MB)
Uplink TBF Establish
2013-10-18
BR-BSS Parameter Mapping
2013-08-19
GSM Paging Capacity Design Technical Guide
2013-06-04
Huawei 2G HO Introduction and HO Parameter Setting Rules V4
2013-04-02
Scanning Balmon Review
2013-01-31
GSM疑难问题
2011-12-14
当前时区 GMT+8, 现在时间是 2024-04-29 20:17:17
Processed in 0.326818 second(s), 13 queries , Gzip enabled
