Modified parameters
For an overview of parameter changes, see Overview of parameter changes.
Modified BSS radio network parameters in Nokia Siemens Networks GSM/EDGE BSS, rel. RG20(BSS), operating documentation, issue 05
Modified BSS radio network parameters in S15
•There are no modified parameters in RG20(BSS).
Modified BSS radio network parameters in Nokia Siemens Networks GSM/EDGE BSS, rel. RG20(BSS), operating documentation, issue 04
Modified BSS radio network parameters in S15.1
Adjacent GSM Cell (ADJC/ADCE) radio network object parameters
•HO target area (HOTA)
FieldBSC S15BSC S15.1
DescriptionWith this parameter you define whether the adjacent cell is a normal or an extended cell. The meanings of the HOTA values are:
0 ... Normal cell or 2nd generation extended cell
1 ... UltraSite, Talk-family, Flexi EDGE, Flexi Multiradio or BTSplus extended cell, BSC tries to allocate a new channel from a normal transceiver (N-TRX)
2 ... UltraSite, Talk-family, Flexi EDGE, Flexi Multiradio or BTSplus extended cell, BSC tries to allocate a new channel from an extended transceiver (E-TRX)
3 ... UltraSite, Talk-family, Flexi EDGE, Flexi Multiradio or BTSplus extended cell, BSC tries to allocate a new channel from a transceiver that is of the same type as the transceiver where the call exists
4 ... Flexi EDGE, Flexi Multiradio or BTSplus super extended cell, BSC tries to allocate a new channel from a super extended transceiver (S-TRX)
MML NOTE:
The allowed values depend on the generations of the source and target BTS in the following way:
BTS GENERATION SOURCE............BTS GEN. ADJACENT CELL..........HOTA
2ND GENERATION,............................2ND GENERATION,.........................0
TALK-FAMILY,.......................................PRIMESITE,
PRIMESITE,..........................................METROSITE,
METROSITE,..........................................INSITE,With this parameter you define whether the adjacent cell is a normal or an extended cell. The meanings of the HOTA values are:
MML NOTE:
北方狼
