【资料名称】:刷EMB时拓扑丢失
【资料作者】:QQ
【资料日期】:2012-07-12
在今晚的对EMB的刷新版本当中查询
ZUSI:EMB,;
ZUSI:SWU,;
显示如下
USI:EMB,;
EXECUTION STARTED
FlexiBSCZZH-NBSC-422012-07-2200:22:36
WORKING STATE OF UNITS
UNIT PHYS STATE LOCATIONINFO
EMB-0SP-EX-
EMB-1WO-EX-
TOTAL OF 2UNITS
COMMAND EXECUTED
USI:SWU,;
EXECUTION STARTED
FlexiBSCZZH-NBSC-422012-07-2200:22:44
SWU-0SE-NH1A004-03-12-
SWU-1SE-NH1A005-03-12-
SWU-2SE-NH1A004-03-13-
SWU-3SE-NH1A005-03-13-
SWU-4SE-NH1A004-03-14-
SWU-5SE-NH1A005-03-14-
SWU-60 WO-EX1A003-04-2EMB-0-
SWU-61 WO-EX1A003-06-7EMB-1-
TOTAL OF 8UNITS
INCORRECT STATES6
COMMAND EXECUTED
在查询查询SWU60,61状态时无法执行显示如下
< ZYFM:ISW:SWU,60;
LOADING PROGRAM VERSION 10.6-0
EXECUTION STARTED
UNIT UNITSOFTWARESWITCH OMU DISK
TYPE INDEXNAME VERSIONVERSION
/*** DX ERROR: 16121 ***/
/*** UNKNOWN LAN DEVICE ***/
LAN HW SUPERVISION HANDLING COMMAND <YF_>
无法控制EMB状态
尝试先切EMB0到TE ZUSC:EMB,0:TE;显示如下
< ZUSC:EMB,0:TE;
LOADING PROGRAM VERSION 27.8-1
EXECUTION STARTED
/*** STATE TRANSITION SP-EX -> TE ***/
/*** NOT CONTROLLED ***/
/*** ERROR INFO FILLED BY OBSERVER ***/
/*** DX ERROR: 16418 ***/
/*** LAN DOES NOT EXIST IN ILDATA DATABASE ***/
/*** OBSERVED BY PROGRAM BLOCK : RYSSIX, 58EH ***/
/*** FAILED UNIT: OMU***/
/*** FAILED PROGRAM BLOCK: ILPMAN, 678H ***/
COMMAND EXECUTION ABORTED
尝试切换EMB1到SP
USC:EMB,1:SP;
EXECUTION STARTED
/*** STATE TRANSITION WO-EX -> SP ***/
此时用ZW6I:SWU 查询到
< ZW6?
LOADING PROGRAM VERSION 5.15-0
FlexiBSCZZH-NBSC-422012-07-2200:25:07
LAN DEVICE TOPOLOGY MANAGEMENT COMMANDS
?..... DISPLAY MENU
E: ..... CHANGE LAN SWITCH STATUS
G: ..... CHOOSE NEW ACTIVE TOPOLOGY
I: ..... INTERROGATE TOPOLOGY
M: ..... MODIFY PASSWORD OF LAN SWITCH
N: ..... MODIFY TOPOLOGY
R: ..... READ CONFIGURATION FILE OF LAN SWITCH
S: ..... COPY CONFIGURATION FILE OF LAN SWITCH
T: ..... OPEN TELNET CONNECTION TO LAN SWITCH
Z; ..... RETURN TO MAIN LEVEL
W6I:SWU
/* IDENTIFY UNIT INDEX:
0 - 65279 (OR INTERVAL WITH CHARACTERS &&)
ACTIVE TOPOLOGYMODIFIABLE TOPOLOGY
UNITSTATUSUNIT
SWU-0 PASSIVE
SWU-1 PASSIVE
SWU-2 PASSIVE
SWU-3 PASSIVE
这时查询参照现网其他bsc的拓扑结构如下
W6I:SWU
UNITSTATUSUNIT
SWU-0 PASSIVE
SWU-1 PASSIVE
SWU-2 PASSIVE
SWU-3 PASSIVE
SWU-4 PASSIVE
SWU-5 PASSIVE
SWU-60ACTIVE
SWU-61ACTIVE
ZW6G:不执行显示
W6G:
/* IDENTIFY TOPOLOGY INDEX:
T1 - T17 (CURRENT IS T5, NETWORK ELEMENT BSC3i)
P ... ACTIVATE PREVIOUS TOPOLOGY
R ... RELOAD CURRENT TOPOLOGY */
显示是T5模式,则用ZW6G更改当前bsc拓扑
W6G:T5:;
CONFIRM COMMAND EXECUTION: Y/N ? Y
NEW TOPOLOGY ACTIVATED
COMMAND EXECUTED
再次查询
W6I:SWU
UNITSTATUSUNIT
SWU-0 PASSIVE
SWU-1 PASSIVE
SWU-2 PASSIVE
SWU-3 PASSIVE
SWU-4 PASSIVE
SWU-5 PASSIVE
SWU-60PASSIVE
SWU-61PASSIVE
用ZW6E:SWU,60:A:;
ZW6E:SWU,61:A:;激活SWU60,61再次查询
W6I:SWU
UNITSTATUSUNIT
SWU-0 PASSIVE
SWU-1 PASSIVE
SWU-2 PASSIVE
SWU-3 PASSIVE
SWU-4 PASSIVE
SWU-5 PASSIVE
SWU-60ACTIVE
SWU-61ACTIVE
恢复正常
