通信设备厂商技术区
爱立信技术资料区
» TEMS-Optimization and Log File Analysis in GSM
liyicool
积分 4532
帖子 216
威望 6373 个
礼品券 16 个
专家指数 76
注册 2006-4-20
专业方向 GSM WCDMA 网络优化
发表于 2012-08-14 16:46:54
【资料名称】:TEMS-Optimization and Log File Analysis in GSM
【资料作者】:Somer GOKSEL
【资料日期】:January 26, 2003
【资料语言】:英文
【资料格式】:PDF
Somer GOKSEL
January 26, 2003
Contents
1 INTRODUCTION ........................................................................................................................................04
1.1 PURPOSE and SCOPE of OPTIMIZATION............................................................................. 04
1.2 OPTIMIZATION PROCESS...................................................................................................... 05
1.2.1 PROBLEM ANALYSIS ........................................................................................... 05
1.2.2 CHECKS PRIOR TO ACTION. ............................................................................... 05
1.2.3 DRIVE TEST............................................................................................................. 05
1.2.4 SUBJECTS to INVESTIGATE................................................................................. 06
1.2.5 AFTER the TEST...................................................................................................... 07
1.2.6 RECOMMENDATIONS........................................................................................... 07
1.2.7 TRACKING............................................................................................................... 08
1.2.8 OTHER OPTIMIZATION TOPICS.......................................................................... 08
1.3 BEFORE STARTING................................................................................................................. 09
2 DRIVE TEST ................................................................................................................................................10
2.1 TEMS INFORMATION............................................................................................................. 11
2.2 BASIC COUNTERS of NETWORK PERFORMANCE........................................................... 13
2.2.1 ACCESSIBILITY................................................................................................. 13
2.2.2 RETAINABILITY............................................................................................... 13
2.2.3 ACCESS FAILS................................................................................................... 13
2.3 IDLE MODE BEHAVIOR.......................................................................................................... 14
2.4 LOCATION UPDATE................................................................................................................ 16
2.5 CALL SET–UP............................................................................................................................ 17
2.6 CALL SET–UP PROCESS in LAYER 3 MESSAGES.............................................................. 19
3 ANALYSIS of LOG FILES..........................................................................................................................33
3.1 COVERAGE PROBLEMS......................................................................................................... 33
3.1.1 LOW SIGNAL LEVEL....................................................................................... 34
3.1.2 LACK Of DOMINANT SERVER...................................................................... 35
3.1.3 SUDDEN APPEARANCE/DISAPPEARANCE of NEIGHBORS.................... 36
3.1.4 FAST MOVING MOBILE.................................................................................. 37
3.1.5 SUDDEN DECREASE on SIGNAL LEVEL..................................................... 38
3.1.6 STABLE BEHAVIOR......................................................................................... 39
3.1.7 OSCILLATION on HOPPING CHANNELS..................................................... 40
3.1.8 SAME CELL IN THE NEIGHBOR LIST.......................................................... 41
3.1.9 RX LEVEL TOO CLOSED................................................................................ 42
3.1.10 RX LEVEL ALMOST THE SAME.................................................................... 43
3.1.11 LINE of SIGHT LOST........................................................................................ 44
3.1.12 LOG FILE RECORDING on RESUME............................................................. 45
3.1.13 DROP CALL DUE to BAD COVERAGE.......................................................... 46
3.1.14 ACCESS FAILS AFTER A DROP CALL.......................................................... 47
3.1.15 SOLUTIONS TO LOW LEVEL PROBLEMS................................................... 48
3.2 QUALITY PROBLEMS............................................................................................................. 49
3.2.1 BER and FER....................................................................................................... 49
3.2.2 BAD QUALITY and BAD FER.......................................................................... 50
3.2.3 BAD QUALITY – FER is OK............................................................................. 51
3.2.4 SQI....................................................................................................................... 52
3.2.5 COLLUSION Of MA LIST CAUSING LOW C/I.............................................. 53
3.2.6 C/I ASPECT......................................................................................................... 54
3.2.7 C/A ASPECT....................................................................................................... 54
3.2.8 C/I INTERFERENCE.......................................................................................... 55
3.2.9 TIME DISPERSION............................................................................................ 56
3.2.10 BAD QUALITY due to TIME DISPERSION..................................................... 57
3.2.11 INTER–SYSTEM INTERFERENCE.................................................................. 58
3.2.12 PROPAGATION BEHAVIOR............................................................................ 58
3.3 HANDOVER............................................................................................................................. 59
3.3.1 HANDOVER in LAYER 3 MESSAGES.............................................................61
3.3.2 TYPES of HANDOVER...................................................................................... 67
3.3.2.1 POWER BUDGET HANDOVER......................................................... 67
3.3.2.2 LEVEL HANDOVER............................................................................ 69
3.3.2.3 QUALITY HANDOVER....................................................................... 69
3.3.2.4 INTERFERENCE HANDOVER........................................................... 70
3.3.2.5 UMBRELLA HANDOVER................................................................... 70
3.3.2.6 MS DISTANCE HANDOVER.............................................................. 70
3.3.2.7 INTRACELL HANDOVER.................................................................. 71
3.3.2.8 INTRACELL HANDOVER BASED on QUALITY.............................72
3.3.2.9 RAPID FIELD HANDOVER................................................................ 73
3.3.2.10 DIRECTED RETRY HANDOVER....................................................... 73
3.3.2.11 SHORT NEIGHBOR LIST.................................................................... 74
3.3.3 HANDOVER PROBLEMS................................................................................. 75
3.3.3.1 LATE HANDOVER.............................................................................. 75
3.3.3.2 POWER CONTROL EFFECT.............................................................. 77
3.3.3.3 PING PONG HANDOVER................................................................... 78
3.3.3.4 UNNCESSARY HANDOVER.............................................................. 79
3.3.3.5 MISSING NEIGHBOR RELATION..................................................... 80
3.3.3.6 FAKE NEIGHBOR................................................................................ 81
3.3.3.7 BCCH MISSING FROM SERVING CELLS MBCCH LIST............... 82
3.3.3.8 NCC MISSING FROM SERVING CELLS NCCPERM LIST............. 82
3.3.3.9 SAME BSIC BCCH COMBINATION.................................................. 82
3.3.3.10 UNEXPECTED COVERAGE LAKE................................................... 83
3.3.3.11 ONE–WAY NEIGHBOR RELATION.................................................. 83
3.3.3.12 NEIGHBOR in ANOTHER BSC/MSC................................................. 83
3.3.3.13 HANDOVER FAILURE....................................................................... 85
3.4 DROP CALLS............................................................................................................................ 87
3.4.1 GENERAL REASONS FOR DROP CALLS...................................................... 88
3.4.2 DROP CALL DUE TO LOCKED CALL........................................................... 89
4 REPORTS of ANALYSIS .............................................................................................................................90
4.1 DOWNTOWN SEATTLE NETWORK PERFORMANCE RECOMMENDATION............... 90
4.2 LAKE SAMMAMISH AREA NETWORK PERFORMANCE RECOMMENDATION.......... 92
5 CONCLUSION...............................................................................................................................................94
2012-8-14 16:46:54 下载次数: 22
TEMS-Optimization and Log File Analysis in GSM.pdf
(2.95 MB)
有想去海外做网优的人吗,有洋妞在等你,加群交流,图片未显示的,请耐心等待。
2016-05-20
“如何处理网优出差和家庭的关系”之我见
2014-07-23
凤凰网:1名移动公司技术人员在3•1暴恐袭击遇难,为遇难者默哀!!!
2014-03-03
各位C友快来看啊,刚出炉的网优职业枪手,不需要也来看下
2013-10-22
牛魔王离婚的原因
2013-08-27
为什么尝起来不甜
2013-07-22
zenglian
积分 21442
帖子 1201
威望 175626 个
注册 2006-5-20
发表于 2012-08-14 17:32:44
在线,35天前提问
在线,48天前提问
在线,74天前提问
在线,115天前提问
在线,121天前提问
在线,121天前提问
在线,121天前提问
在线,123天前提问
在线,123天前提问
在线,133天前提问
在线,133天前提问
在线,154天前提问
在线,154天前提问
在线,174天前提问
在线,197天前提问
在线,209天前提问
谢谢分享!!!!!!!!!!!!!!
mengcheng88
积分 7489
帖子 1497
威望 900210 个
礼品券 63 个
注册 2010-5-17
专业方向 网规网优工程师
发表于 2012-08-15 07:58:29
好好学习下,看看啊
suoxiaoqiu
积分 3065
帖子 613
威望 23396 个
注册 2007-1-25
专业方向 无线网络优化
发表于 2012-08-15 21:15:10
下来看看……………………
suo
[下载] TEMS-Optimization and Log File Analysis in GSM" tabindex="1">
当前时区 GMT+8, 现在时间是 2024-05-15 10:53:31
Processed in 0.821394 second(s), 22 queries , Gzip enabled
