MSS 路由选择中的
LBCU ID
1.要
使MSS支持LBCU ID 规则在CLASS 2 的992为TRUE(0FF)
Parameter 002:0992 LBCU_IN_ROUTE_SELECTION
Descriptive name
Use of LBCU ID in route selection procedure
Modifiable
YES
Description
The parameter determines the use of LBCU ID in the route selection procedure of the MSC Server.
ValueMeaning
TRUELBCU ID is used in the route selection procedure.
FALSELBCU ID is not used in the route selection procedure.
Default value(s)
00H (FALSE)
Allowed values
0FFH (TRUE) / 00H (FALSE)
Feature
1370 - MSS Control Plane Routing
< ZWOI:2,992;
LOADING PROGRAM VERSION 8.2-0
EXECUTION STARTED
PARAMETER CLASS: 2SYSTEM_FUNCT_CONFIGUR
IDENTIFIERNAME OF PARAMETERVALUECHANGE POSSIBILITY
00992LBCU_IN_ROUTE_SELECTION00FFYES
COMMAND EXECUTED
2.在MSS中不同的VMGW如果属于相同的MGW ,将有相同的LBCU-ID
PARAMETER HANDLING COMMAND <WO_>
< ZJGI:MODE=1:MGWID=0;
LOADING PROGRAM VERSION 6.31-0
MSCiKMG122006-08-1809:40:41
MGW DATA:
MGW ID........................0
MGW NAME......................KMVMGWC10
MGW ADDRESS...................10.0.3.4
PORT NUMBER...................8009
DOMAIN NAME...................
ROUTE.........................0
MGW TYPE......................GENERAL
UNIT TYPE.....................SIGU
UNIT INDEX....................10
CTRL ADDRESS..................10.0.0.4
E.164 AESA....................86137428760
LOCAL BCU-ID..................100
REGISTRATION ALLOWANCE........ALLOWED
REGISTRATION STATUS...........REGISTERED
AUDIT STATUS..................ALLOWED
LOCAL PORT....................2945
TRANSPORT TYPE................SCTP
SCTP PARAMETER SET NUMBER.....3
IPATM.........................ALLOWED
REDUCTION.....................0%
HNDLTONE......................INDIRECT
CONFERENCE CALL CAPABILITY....Y
H.248 PROTOCOL RELATED DATA:
H.248 VERSION.................1
H.248 CODING..................ASN
THROUGH-CONN. CAPABILITY......TOPOLOGY
TIMERS:
NORMAL MG EXECUTION TIME.............15 *10 MSEC
NETWORK DELAY TIME...................0 *10 MSEC
PROVISIONAL RESPONSE TIME............15 *10 MSEC
HEARTBEAT FOR H248 CONNECTION TIME...0 *10 MSEC
REGISTRATION COMMAND WAITING TIME....0 *10 MSEC
T MAX TIME...........................1000 *10 MSEC
SUPERVISION TIME.....................60000 *10 MSEC
MGW PROFILE...................NOKIA MGW PROFILE VER 2
PACKAGE(S)....................UNKNOWN VER 1 ( )
0x0001 VER 1 (G)
0x0002 VER 1 (ROOT)
0x0003 VER 1 (TONEGEN)
0x0004 VER 1 (TONEDET)
0x0005 VER 1 (DG)
0x0006 VER 1 (DD)
0x0007 VER 1 (CG)
0x000A VER 1 (CT)
0x000B VER 1 (NT)
0x000D VER 1 (TDMC)
0x001E VER 1 (BCP)
0x0021 VER 1 (GB)
0x0022 VER 1 (BT)
0x0023 VER 1 (BCG)
0x0024 VER 1 (XCG)
0x0025 VER 1 (SRVTN)
0x0026 VER 1 (XSRVTN)
0x0027 VER 1 (INT)
0x002F VER 1 (THREEGUP)
0x0030 VER 1 (THREEGCSD)
0x0031 VER 1 (THREEGTFOC)
0x0032 VER 1 (THREEGXCG)
0x0033 VER 1 (AASB)
0x0082 VER 1 (THREEGCSDEN)
0x8005 VER 1 (NOKIAIWF)
0x8006 VER 1 (NOKIAROOTC)
0x8007 VER 1 (THREEGTRACE)
SUPPORTED CODECS..............G711 64 A LAW
G711 64 Y LAW
AMR UMTS
AMR UMTS 2
AMR FR
AMR HR
GSM EFR
GSM FR
COMMAND EXECUTED
MEDIA GATEWAY DATA HANDLING COMMAND <JG_>
< ZJGI:MODE=1:MGWID=8;
MSCiKMG122006-08-1809:40:56
MGW DATA:
MGW ID........................8
MGW NAME......................KMVMGWC20
MGW ADDRESS...................10.0.3.12
UNIT INDEX....................5
CTRL ADDRESS..................10.0.0.12
E.164 AESA....................86137428761
LOCAL BCU-ID..................200
TIMERS:
0x0001 VER 1 (G)
0x0002 VER 1 (ROOT)
0x0005 VER 1 (DG)
0x0006 VER 1 (DD)
0x0007 VER 1 (CG)
0x000A VER 1 (CT)
0x000B VER 1 (NT)
0x000D VER 1 (TDMC)
0x001E VER 1 (BCP)
0x0021 VER 1 (GB)
0x0022 VER 1 (BT)
0x0023 VER 1 (BCG)
0x0024 VER 1 (XCG)
0x0027 VER 1 (INT)
0x0033 VER 1 (AASB)
G711 64 Y LAW
AMR UMTS
AMR UMTS 2
AMR FR
AMR HR
GSM EFR
GSM FR
COMMAND EXECUTED
3.不同的LAC对应不同的MGW,相同的MGW下的LAC有相同的MSRN GROUP
< ZELO;
LOADING PROGRAM VERSION 11.2-0
MSCiKMG122006-08-1809:41:18
LOCATION AREA
LA NAME
AC35001LAC :35001
MOBILE COUNTRY CODE ....................(MCC).. :460
MOBILE NETWORK CODE ....................(MNC).. :00
REPAGING ATTEMPTS ......................(AT)... :002
REPAGING INTERVALS .....................(INT).. :00350 ( x 10 msec )
MSRN GROUP .............................(RNGP). :000
ALLOWED MNC IN NATIONAL ROAMING ........(MNC).. : -
DAYLIGHT SAVING ........................(DSAV). : -
TIME ZONE ..............................(TZ)... : -
LOCATION AREA
LA NAME
AC35002LAC :35002
LOCATION AREA
LA NAME
AC35033LAC :35033
MSRN GROUP .............................(RNGP). :001
LOCATION AREA
LA NAME :LAC35003LAC :35003
LOCATION AREA
LA NAME :LAC35032LAC :35032
LOCATION AREA
LA NAME :LAC35016LAC :35016
LOCATION AREA
LA NAME :LAC35020LAC :35020
COMMAND EXECUTED
LOCATION AREA HANDLING COMMAND <EL_>
4.不同的MSRN GROUP将对应不同的ROAMING NUMBERS
< ZWVJ;
LOADING PROGRAM VERSION 8.22-0
MSCiKMG122006-08-1809:41:37
HANDOVER NUMBERS
FIRST NUMBERLAST NUMBERTONTOTAL
1374287690013742876999NATIONAL100
1374387690013743876999NATIONAL100
TOTAL200
ROAMING NUMBERS
FIRST NUMBERLAST NUMBERRNGPTOTAL
8613742876000 8613742876899 0900
8613743876000 8613743876899 1900
TOTAL1800
EMERGENCY SERVICES ROUTING KEYS
FIRST NUMBERLAST NUMBERINDEXTOTAL
TOTAL0
< ZWVI;
MSCiKMG122006-08-1809:41:45
MOBILE COUNTRY CODE
460
MOBILE NETWORK CODE
00
EIR NUMBER
NUMBERNPTON
E.164INTERNATIONAL
DEFAULT CALLING LINE IDENTITY
NUMBERNPTON
13742876E.164NATIONAL
8613742876 E.164INTERNATIONAL
MSC NUMBER
NUMBERNPTON
VLR NUMBER
NUMBERNPTON
EXTRA CALL FORWARDING NUMBER
NUMBERNPTON
GMLC ADDRESS FOR EMERGENCY SERVICES
NUMBERNPTON INDEX
CORE NETWORK NODE IDENTIFIER
COMMAND EXECUTED
5.在对端交换机中,将根据不同的漫游号码 ROAMING NUMBERS 指向不同的MGW
ZRIH:TREE=50,DIG=13742876;
LOADING PROGRAM VERSION 14.2-0
MSCiKMG142006-08-1810:14:13
TREE=50ATYPE=NTON=NAT
DIGITSAL NDESTCHI CNT NSDEST CORGNCHA
137428760 KMWC11NKMWC1A 0NORMAL
1 KMWC11NKMA1A0NORMAL
COMMAND EXECUTED
MAIN LEVEL COMMAND <___>
< RIH:TREE=50,DIG=13743876;
MSCiKMG142006-08-1810:14:21
137438760 KMWC21NKMWC2A 0NORMAL
1 KMWC21NKMA2A0NORMAL
COMMAND EXECUTED
6.相同局向的CGR由于MGW的不同将有不同的CGR, 相同MGW下的CGR由于其对应的是同一MGW下的VMGW, 将有相同的LBCU ID
< ZRCI;
LOADING PROGRAM VERSION 12.31-1
CIRCUIT GROUP(S)
CGR NCGRTYPEDIR TREENBCRCT STATE
139 OSIAS7 SPE BI-5WO-EX
146 ETT00SPE BI-35WO-EX
147 DAS7USPE BI-352 WO-EX
149 X25CGR SPE BI-2WO-EX
152 TONESSPE BI-28WO-EX
234 CLS SPE BI-2WO-EX
246 AS7 SPE BI-864 WO-EX
247 CCS7SPE BI-266 WO-EX
400 KBSC110ECCSOUT -583 WO-EX
401 KBSC111ECCSOUT -577 WO-EX
402 KBSC112ECCSOUT -592 WO-EX
403 KBSC113ECCSOUT -578 WO-EX
404 KBS1AMR1ECCSOUT -230 WO-EX
405 KBS1AMR2ECCSOUT -240 WO-EX
410 KBSC214ECCSOUT -460 WO-EX
411 KBSC215ECCSOUT -460 WO-EX
412 KBSC216ECCSOUT -460 WO-EX
413 KBSC217ECCSOUT -460 WO-EX
414 KBS2AMR1ECCSOUT -240 WO-EX
415 KBS2AMR2ECCSOUT -240 WO-EX
420 KBSC310ECCSOUT -460 WO-EX
421 KBSC311ECCSOUT -460 WO-EX
422 KBSC312ECCSOUT -460 WO-EX
423 KBSC313ECCSOUT -460 WO-EX
424 KBS3AMR1ECCSOUT -240 WO-EX
425 KBS3AMR2ECCSOUT -240 WO-EX
430 KBSC414ECCSOUT -580 BA-US
431 KBSC415ECCSOUT -580 BA-US
432 KBSC416ECCSOUT -580 BA-US
433 KBSC417ECCSOUT -580 BA-US
434 KBS4AMR1ECCSOUT -240 BA-US
435 KBS4AMR2ECCSOUT -240 BA-US
440 KBSC520ECCSOUT -460 WO-EX
441 KBSC521ECCSOUT -460 WO-EX
442 KBSC522ECCSOUT -440 WO-EX
443 KBSC523ECCSOUT -480 WO-EX
444 KBSC5AMRECCSOUT -120 WO-EX
450 KBSC624ECCSOUT -437 WO-EX
451 KBSC625ECCSOUT -429 WO-EX
452 KBSC626ECCSOUT -424 WO-EX
453 KBSC627ECCSOUT -430 WO-EX
454 KBSC6AMRECCSOUT -240 WO-EX
460 KBSC720ECCSOUT -490 WO-EX
461 KBSC721ECCSOUT -491 WO-EX
462 KBSC722ECCSOUT -491 WO-EX
463 KBSC723ECCSOUT -488 WO-EX
470 KBSC824ECCSOUT -375 WO-EX
471 KBSC825ECCSOUT -376 WO-EX
472 KBSC826ECCSOUT -372 WO-EX
473 KBSC827ECCSOUT -349 WO-EX
500 KMD110 ECCSBI220 277 WO-EX
501 KMD111 ECCSBI220 279 WO-EX
510 KMD120 ECCSBI220 277 WO-EX
511 KMD121 ECCSBI220 279 WO-EX
550 KMD212 ECCSBI220 278 WO-EX
551 KMD213 ECCSBI220 278 WO-EX
560 KMD222 ECCSBI220 278 WO-EX
561 KMD223 ECCSBI220 278 WO-EX
600 KMD310 ECCSBI220 463 WO-EX
601 KMD311 ECCSBI220 465 WO-EX
602 KMD312 ECCSBI220 465 WO-EX
603 KMD313 ECCSBI220 465 WO-EX
610 KMD320 ECCSBI220 463 WO-EX
611 KMD321 ECCSBI220 463 WO-EX
612 KMD322 ECCSBI220 465 WO-EX
613 KMD323 ECCSBI220 465 WO-EX
650 KMD414 ECCSBI220 463 WO-EX
651 KMD415 ECCSBI220 465 WO-EX
652 KMD416 ECCSBI220 465 WO-EX
653 KMD417 ECCSBI220 465 WO-EX
660 KMD424 ECCSBI220 463 WO-EX
661 KMD425 ECCSBI220 463 WO-EX
662 KMD426 ECCSBI220 465 WO-EX
663 KMD427 ECCSBI220 465 WO-EX
1000KMA110 ECCSBI200 339 WO-EX
1001KMA111 ECCSBI200 341 WO-EX
1010KMA120 ECCSBI200 339 WO-EX
1011KMA121 ECCSBI200 341 WO-EX
1050KMA212 ECCSBI200 339 WO-EX
1051KMA213 ECCSBI200 341 WO-EX
1060KMA222 ECCSBI200 339 WO-EX
1061KMA223 ECCSBI200 341 WO-EX
1100KMMGA14ECCSBI200 494 WO-EX
1101KMMGA15ECCSBI200 496 WO-EX
1110KMMGA24ECCSBI200 494 WO-EX
1111KMMGA25ECCSBI200 496 WO-EX
1150KMMGB16ECCSBI200 494 WO-EX
1151KMMGB17ECCSBI200 496 WO-EX
1160KMMGB26ECCSBI200 494 WO-EX
1161KMMGB27ECCSBI200 496 WO-EX
1300KMG0710ECCSBI220 272 WO-EX
1301KMG0711ECCSBI220 244 WO-EX
1310KMG0720ECCSBI220 242 WO-EX
1311KMG0721ECCSBI220 279 WO-EX
1320KMG0812ECCSBI220 275 WO-EX
1321KMG0813ECCSBI220 242 WO-EX
1330KMG0822ECCSBI220 246 WO-EX
1331KMG0823ECCSBI220 277 WO-EX
1340KMG0914ECCSBI220 272 WO-EX
1341KMG0915ECCSBI220 237 WO-EX
1350KMG0924ECCSBI220 239 WO-EX
1351KMG0925ECCSBI220 273 WO-EX
1360KMG1016ECCSBI220 263 WO-EX
1361KMG1017ECCSBI220 248 WO-EX
1370KMG1026ECCSBI220 232 WO-EX
1371KMG1027ECCSBI220 279 WO-EX
1380KMG1116ECCSBI220 277 WO-EX
1381KMG1117ECCSBI220 248 WO-EX
1390KMG1126ECCSBI220 246 WO-EX
1391KMG1127ECCSBI220 279 WO-EX
1400KMWC120TDMCOUT -465 WO-EX
1401KMWC121TDMCOUT -465 WO-EX
1410KMWC210TDMCOUT -465 WO-EX
1411KMWC211TDMCOUT -465 WO-EX
1420KMWD112ECCSBI220 62BA-US
1421KMWD113ECCSBI220 0BA-US
1430KMWD122ECCSBI220 62BA-US
1431KMWD123ECCSBI220 0BA-US
1440KMWD214ECCSBI220 62BA-US
1441KMWD215ECCSBI220 0BA-US
1450KMWD224ECCSBI220 62BA-US
1451KMWD225ECCSBI220 0BA-US
1460KMWE116ECCSBI220 155 WO-EX
1461KMWE117ECCSBI220 155 WO-EX
1470KMWE126ECCSBI220 155 WO-EX
1471KMWE127ECCSBI220 155 WO-EX
1700AIP0110ECCSBI230 93WO-EX
1701AIP0111ECCSBI230 62WO-EX
1710AIP0120ECCSBI230 93WO-EX
1711AIP0121ECCSBI230 62WO-EX
1720AIP0212ECCSBI230 62WO-EX
1721AIP0213ECCSBI230 31WO-EX
1730AIP0222ECCSBI230 62WO-EX
1731AIP0223ECCSBI230 31WO-EX
1740AIP0314ECCSBI230 93WO-EX
1741AIP0315ECCSBI230 62WO-EX
1750AIP0324ECCSBI230 93WO-EX
1751AIP0325ECCSBI230 62WO-EX
1760AIP0416ECCSBI230 93WO-EX
1761AIP0417ECCSBI230 93WO-EX
1770AIP0426ECCSBI230 93WO-EX
1771AIP0427ECCSBI230 93WO-EX
COMMAND EXECUTED
