通信设备厂商技术区
诺基亚技术资料区
» RG20下TCSM 光口相关设置和创建
RG20下TCSM 光口相关设置和创建
xukai
威望 235 个
注册 2012-5-25
专业方向 BSC
发表于 2012-07-18 12:00:19
【资料名称】:RG20下COMMBIN TCSM创建
【资料作者】:NSN
【资料日期】:2011/5/19
【资料格式】:PDF
cabinet......................................................................................20
4.2 Combined TCSM3i equipment after upgrade.........................................21
4.2.1 TCSA-0 cabinet......................................................................................21
4.2.2 TCSA-1 cabinet......................................................................................21
4.2.3 TCSA-2 cabinet......................................................................................22
5 Pre-requirements..................................................................................24
5.1 Pre-requirements & Actions needed prior upgrade................................24
5.2 Restrictions ............................................................................................25
5.3 Needed documentation ..........................................................................25
5.4 Needed equipment.................................................................................26
5.5 HIT and upgrade macros........................................................................27
5.5.1 System requirements for HIT .................................................................27
5.5.2 Installing HIT ..........................................................................................27
5.5.3 Installing HIT upgrading macros.............................................................27
5.5.4 HIT settings ............................................................................................28
5.5.5 Connection settings................................................................................29
5.5.6 Starting the HIT application / macro execution.......................................40
6 Fallback copying of the current package...........................................48
7 BSC configuration printout (pre-check).............................................49
8 SDH/Sonet equipment protection upgrade for combined
TCSM3i (OFFLINE) ...............................................................................50
8.1 Choose TCSA cabinet to be upgraded...................................................52
8.2 Move traffic from STMU which will be upgraded ....................................52
8.3 Delete old configurations & equipment...................................................52
8.4 Install redundant ETS2 plug-in unit(s)....................................................53
Contents
4 (129)Nokia Siemens Networks DN0978606
Issue 1.5-0
8.5 Make cabling changes and install new cables....................................... 54
8.6 New configuration & equipment with HW protection ............................. 54
8.6.1 BSC3i 1000/2000 or upgraded Flexi BSC ............................................. 54
8.6.2 New Delivery Flexi BSC ........................................................................ 62
9 SDH/Sonet equipment protection upgrade for combined
TCSM3i (LIVE)...................................................................................... 71
9.1 TCSA-0.................................................................................................. 73
9.1.1 Remove protection groups .................................................................... 73
9.1.2 Remove interfaces from SET-144 and disconnect effected
TCSM(s) ................................................................................................ 73
9.1.3 Change SET-144 to SE-NH state.......................................................... 73
9.1.4 Delete SET-144 ..................................................................................... 74
9.1.5 Create SET-138..................................................................................... 74
9.1.6 Make cabling changes........................................................................... 75
9.1.7 Change SET-138 to WO-EX state......................................................... 76
9.1.8 Create interface(s) from SET-138 and connect related TCSM(s) ......... 76
9.1.9 Remove interfaces from SET-146 and disconnect effected
TCSM(s) ................................................................................................ 76
9.1.10 Change STMU-36 SE-NH state............................................................. 77
9.1.11 Delete SET-146 and STMU-36.............................................................. 77
9.1.12 Insert a new ETS2 plug-in unit to GTIC-2 and GTIC-3 track 7 .............. 78
9.1.13 Create STMU-36 to GTIC-2................................................................... 78
9.1.14 Create SET-144..................................................................................... 78
9.1.15 Make cabling changes........................................................................... 79
9.1.16 Create interface(s) from SET-144 and connect related TCSM(s) ......... 79
9.1.17 Change STMU-36 to WO-EX state........................................................ 80
9.1.18 Remove interfaces from SET-152 and disconnect effected
TCSM(s) ................................................................................................ 80
9.1.19 Change STMU-38 SE-NH state............................................................. 80
9.1.20 Delete SET-152 ..................................................................................... 80
9.1.21 Create SET-146..................................................................................... 81
9.1.22 Make cabling changes........................................................................... 82
9.1.23 Create interface(s) from SET-146 and connect related TCSM(s) ......... 83
9.1.24 Change SET-146 to WO-EX state......................................................... 83
9.1.25 Delete STMU-38.................................................................................... 83
9.1.26 Create STMU-33/35/37 ......................................................................... 83
9.1.27 Install new cables and modules............................................................. 84
9.1.28 Create protection groups ....................................................................... 86
9.1.29 Change STMU-33/35/37 to WO-EX ...................................................... 86
9.2 TCSA-1.................................................................................................. 87
9.2.1 Remove protection groups .................................................................... 87
9.2.2 Remove interfaces from SET-160, SET-162 and disconnect
effected TCSM(s) .................................................................................. 88
9.2.3 Change STMU-40 SE-NH state............................................................. 88
9.2.4 Delete SET-160 and SET- 162.............................................................. 88
9.2.5 Delete STMU-40.................................................................................... 89
9.2.6 Create STMU-38 to GTIC-5................................................................... 89
Contents
DN0978606
Issue 1.5-0
Nokia Siemens Networks 5 (129)
9.2.7 Create SET-152 and SET-154 ...............................................................89
9.2.8 Create interface(s) from SET-152, SET-154 and connect
related TCSM(s).....................................................................................90
9.2.9 Change STMU-38 to WO-EX .................................................................90
9.2.10 Remove interfaces from SET-168 and disconnect effected
TCSM(s).................................................................................................91
9.2.11 Change STMU-42 SE-NH state .............................................................91
9.2.12 Delete SET-168......................................................................................91
9.2.13 Delete STMU-42.....................................................................................92
9.2.14 Create STMU-40 ....................................................................................92
9.2.15 Create SET-160 .....................................................................................92
9.2.16 Create interface(s) from SET-160 and connect related TCSM(s) ..........93
9.2.17 Change STMU-40 to WO-EX .................................................................93
9.2.18 Change SET-176 to SE-NH state...........................................................94
9.2.19 Delete SET-176......................................................................................94
9.2.20 Create SET-162 .....................................................................................94
9.2.21 Make cabling changes............................................................................95
9.2.22 Change SET-162 to WO-EX state..........................................................96
9.2.23 Create interface(s) from SET-162 and connect related TCSM(s) ..........96
9.2.24 Remove interfaces from SET-178 and disconnect effected
TCSM(s).................................................................................................96
9.2.25 Change STMU-44 to SE-NH ..................................................................97
9.2.26 Delete SET-178......................................................................................97
9.2.27 Delete STMU-44.....................................................................................97
9.2.28 Insert a new ETS2 plug-in unit to GTIC-5 and GTIC-6 track 7...............98
9.2.29 Create STMU-42 to GTIC-5 ...................................................................98
9.2.30 Create SET-168 .....................................................................................98
9.2.31 Make cabling changes............................................................................99
9.2.32 Create interface(s) from SET-168 and connect related TCSM(s) ..........99
9.2.33 Change STMU-42 WO-EX state ..........................................................100
9.2.34 Remove interfaces from SET-184 and disconnect effected
TCSM(s)...............................................................................................100
9.2.35 Change STMU-46 to SE-NH state .......................................................100
9.2.36 Delete SET-184....................................................................................100
9.2.37 Create SET-170 ...................................................................................101
9.2.38 Make cabling changes..........................................................................102
9.2.39 Create interface(s) from SET-170 and connect related TCSM(s) ........102
9.2.40 Change SET-170 to WO-EX state........................................................102
9.2.41 Delete STMU-46...................................................................................103
9.2.42 Create STMU-39/41/43 ........................................................................103
9.2.43 Install new cables and modules ...........................................................104
9.2.44 Create protection groups......................................................................105
9.2.45 Change STMU-39/41/43 to WO-EX .....................................................106
9.3 TCSA-2 ................................................................................................106
9.3.1 Remove protection groups ...................................................................106
9.3.2 Remove interfaces from SET-192, SET-194 and disconnect
effected TCSM(s) .................................................................................107
9.3.3 Change STMU-48 SE-NH state ...........................................................107
Contents
6 (129)Nokia Siemens Networks DN0978606
Issue 1.5-0
9.3.4 Delete SET-192 and SET- 194............................................................ 107
9.3.5 Delete STMU-48.................................................................................. 108
9.3.6 Create STMU-44 ................................................................................. 108
9.3.7 Create SET-176 and SET-178 ............................................................ 109
9.3.8 Create interface(s) from SET-176, SET-178 and connect
related TCSM(s) .................................................................................. 110
9.3.9 Change STMU-44 to WO-EX .............................................................. 110
9.3.10 Remove interfaces from SET-200 and disconnect effected
TCSM(s) .............................................................................................. 110
9.3.11 Change STMU-50 SE-NH state........................................................... 110
9.3.12 Delete SET-200 ................................................................................... 111
9.3.13 Delete STMU-50.................................................................................. 111
9.3.14 Create STMU-46 ................................................................................. 111
9.3.15 Create SET-184................................................................................... 112
9.3.16 Create interface(s) from SET-184 and connect related TCSM(s) ....... 112
9.3.17 Change STMU-46 to WO-EX .............................................................. 113
9.3.18 Change SET-208 to SE-NH state........................................................ 113
9.3.19 Delete SET-208 ................................................................................... 113
9.3.20 Create SET-186................................................................................... 114
9.3.21 Make cabling changes......................................................................... 114
9.3.22 Change SET-186 to WO-EX state....................................................... 115
9.3.23 Create interface(s) from SET-186 and connect related TCSM(s) ....... 115
9.3.24 Remove interfaces from SET-210 and disconnect effected
TCSM(s) .............................................................................................. 115
9.3.25 Change STMU-52 SE-NH ................................................................... 116
9.3.26 Delete SET-210 ................................................................................... 116
9.3.27 Delete STMU-52.................................................................................. 117
9.3.28 Insert a new ETS2 plug-in unit to GTIC-8 and GTIC-9 track 7 ............ 117
9.3.29 Create STMU-48 to GTIC-8................................................................. 117
9.3.30 Create SET-192................................................................................... 117
9.3.31 Make cabling changes......................................................................... 118
9.3.32 Create interface(s) from SET-192 and connect related TCSM(s) ....... 119
9.3.33 Change STMU-48 WO-EX state.......................................................... 119
9.3.34 Remove interfaces from SET-216 and disconnect effected
TCSM(s) .............................................................................................. 119
9.3.35 Change STMU-54 SE-NH state........................................................... 119
9.3.36 Delete SET-216 ................................................................................... 120
9.3.37 Create SET-194................................................................................... 120
9.3.38 Make cabling changes......................................................................... 121
9.3.39 Create interface(s) from SET-194 and connect related TCSM(s) ....... 122
9.3.40 Change SET-194 to WO-EX state....................................................... 122
9.3.41 Delete STMU-54.................................................................................. 122
9.3.42 Create STMU-45/47/49 ....................................................................... 122
9.3.43 Install new cables and modules........................................................... 123
9.3.44 Create protection groups ..................................................................... 125
9.3.45 Change STMU-45/47/49 to WO-EX .................................................... 125
10 Actions after upgrade & Post conditions........................................ 126
2012-7-18 12:00:19 下载次数: 7
S15 BSC3i_TCSM3i upgrade for SDH_Sonet equipment protection (S12 - S14 TCSM HW).pdf
(2.52 MB)
SPN2
中国移动SPN2.0技术白皮书
当前时区 GMT+8, 现在时间是 2024-04-19 12:51:49
Processed in 0.256348 second(s), 13 queries , Gzip enabled
