CDMA(EVDO)技术资料区
» CDMA 1x CALL FAILRUE
z198663abab
积分 627
帖子 49
威望 2672 个
礼品券 7 个
专家指数 -30
注册 2009-3-20
专业方向 通信
发表于 2012-05-20 22:40:05
Failure reason
Number
Rate%
Reason
SDM_Activate_Fail_AcquirePreambleFail_Normal[1231024226]
20809
49.26
1.Common reason is weak coverage;--distribute on many cells
2. Channel Elements problem;---distribute on certain cells.
ERR_SPS_RLSA_DSPM_CLH_TimerExpired_Twaitorder[1075777538]
7236
17.13
SDM_Find_Fail_WaitConfigRLPTimeout[1231024165]
6982
16.53
Only available for packet service, The common reason is weak coverage;--distribute on many cells
HO_STAT_CARRIER_NO_CE[18949]
2481
5.87
During the site restarting, the Channel board is restart slowly than other boards, there is no CE can be use, so the call failed
ERR_SPS_RLSA_BSSAP_TE_Tfchsetup[1193213966]
1427
3.38
T
he main reason is that the time offset is different between BSC and BTS. There are two possible failure reasons:
1) GPS has problem;2) High error code on transmission link.
2012-5-20 22:40:05 下载次数: 10
1X Call Failure.xls
(27 KB)
eCNS600产品概述
2016-04-15
原创思维导图 LTE知识树V1.0(Xmind软件打开)
2014-04-21
LTE十章学习 资料精选
2013-09-06
TD-LTE初级中级240题库+答案
2013-07-19
运维文档_DBS2MML工具使用指导书
2013-01-29
跳频技术详解
2012-09-27
1X Call Failure.xls
当前时区 GMT+8, 现在时间是 2024-04-30 05:48:14
Processed in 0.280932 second(s), 15 queries , Gzip enabled
