SAG582135200.pdf (4.71 MB) SAG582135200.pdf (4.71 MB)【资料名称】:Emerson BDF
【资料作者】:Emerson
【资料日期】:2010
【资料语言】:英文
SYSTEM OVERVIEW................................................................................................................................................1
TABLE OF CONTENTS............................................................................................................................................7
ORDERING INFORMATION.....................................................................................................................................9
List Options.........................................................................................................................................................9
Accessory Options...........................................................................................................................................11
LIST DESCRIPTIONS.............................................................................................................................................12
List 1: BDF/CBB Panel (standard depth) ......................................................................................................12
List 2: BDF/CBB Panel (reduced depth) .......................................................................................................13
List 10: Input Power Bus, Top Feed..............................................................................................................14
List 11: Input Power Bus, Bottom Feed ........................................................................................................14
List 20: Optional Internal Return/Ground Bus, Top or Bottom Feed.............................................................15
List 30: Optional Interpanel Parallel Input Power Bus, Top Feed .................................................................15
List 31: Optional Interpanel Parallel Input Power Bus, Bottom Feed............................................................15
List 32: Optional Interpanel Parallel Return/Ground Bus, Top or Bottom Feed............................................16
List 33: Optional Single Load Kit ...................................................................................................................16
List 40: Optional GMT Fuse Module Panels .................................................................................................16
List 50: Meter Panel .....................................................................................................................................17
List 55: 'Stand-Alone' Application Version Meter Panel (includes Distribution Monitoring Circuit
Card) .............................................................................................................................................................17
List LD: BDF/CBB Panel (standard depth) e/w Load Low Voltage Disconnect Contactors..........................18
ACCESSORY DESCRIPTIONS..............................................................................................................................20
Relay Racks ......................................................................................................................................................20
Transition Plates to Mount Relay Rack P/N 525004 on Top of Battery Stands...........................................21
Relay Rack Blank Cover Panels.......................................................................................................................22
Distribution Devices.........................................................................................................................................23
Bullet Nose-Type Circuit Breakers and Bullet Nose-Type Fuseholders e/w TLS/TPS Fuses.......................23
GMT-Type Load Fuses .................................................................................................................................26
Replacement List 40 Input Fuse and Associated Alarm Fuse .......................................................................27
Replacement Alarm and Control Fuses .........................................................................................................27
Optional External Top-Mount Ground (Load Return) Busbar Kits...............................................................28
Base Kit .........................................................................................................................................................28
Expansion Kit ................................................................................................................................................28
Optional Mounting Bracket Kits.......................................................................................................................29
For One (1) Meter Panel and One (1) BDF/CBB Panel.................................................................................29
For Two (2) BDF/CBB Panels ........................................................................................................................29
Optional Cable Management Assembly, P/N 540915.....................................................................................29
Recommended Wire Sizes and Lugs...............................................................................................................30
Load Distribution Wire Sizes and Lugs ..........................................................................................................30
Special Application Crimp Lug / Strap Combination ......................................................................................30
Battery Wire Sizes and Lugs..........................................................................................................................32
Bay Frame Grounding Wire Sizes and Lugs..................................................................................................33
External Alarm, Reference, and Control Wire Sizes......................................................................................34
Lug Tables.....................................................................................................................................................35
Replacement Components.....................................................................................................................
