3G综合技术资料区
» ITU-T Q703
ITU-T Q703
taf-xiang
积分 873
帖子 42
威望 933 个
注册 2008-1-3
发表于 2012-04-20 16:40:47
【资料名称】:ITU-T Q703
【资料作者】:ITU-T
【资料日期】:未知
【资料语言】:英文
【资料格式】:PDF
CONTENTS
Recommendation Q.703 (03/93)
Page
1 General.......................................................................................................................................................... 1
1.1 Introduction ..................................................................................................................................... 1
1.2 Signal unit delimitation and alignment ............................................................................................. 1
1.3 Error detection ................................................................................................................................. 1
1.4 Error correction................................................................................................................................ 2
1.5 Initial alignment............................................................................................................................... 3
1.6 Signalling link error monitoring ....................................................................................................... 3
1.7 Link state control functions .............................................................................................................. 3
1.8 Flow control..................................................................................................................................... 3
2 Basic signal unit format................................................................................................................................. 3
2.1 General............................................................................................................................................. 3
2.2 Signal unit format ............................................................................................................................. 5
2.3 Function and codes of the signal unit fields ..................................................................................... 5
2.4 Order of bit transmission .................................................................................................................. 7
3 Signal unit delimitation ................................................................................................................................. 7
3.1 Flags................................................................................................................................................. 7
3.2 Zero insertion and deletion ............................................................................................................... 7
4 Acceptance procedure ................................................................................................................................... 7
4.1 Acceptance of alignment .................................................................................................................. 7
4.2 Error detection ................................................................................................................................. 7
5 Basic error correction method ........................................................................................................................ 8
5.1 General............................................................................................................................................. 8
5.2 Acknowledgements (positive acknowledgement and negative acknowledgement) ......................... 9
5.3 Retransmission................................................................................................................................. 10
6 Error correction by preventive cyclic retransmission..................................................................................... 11
6.1 General............................................................................................................................................. 11
6.2 Acknowledgements.......................................................................................................................... 12
6.3 Preventive cyclic retransmission....................................................................................................... 13
6.4 Forced retransmission ....................................................................................................................... 14
7 Initial alignment procedure ............................................................................................................................ 14
7.1 General............................................................................................................................................. 14
7.2 Initial alignment status indications ................................................................................................... 14
7.3 Initial alignment procedure............................................................................................................... 15
7.4 Proving periods................................................................................................................................ 17
8 Processor outage............................................................................................................................................ 17
9 Level 2 flow control ...................................................................................................................................... 18
9.1 General............................................................................................................................................. 18
9.2 Detection of congestion .................................................................................................................... 18
9.3 Procedure in the congestion situation ............................................................................................... 18
9.4 Congestion abatement procedure...................................................................................................... 18
ii Recommendation Q.703 (03/93)
Page
10 Signalling link error monitoring..................................................................................................................... 18
10.1 General............................................................................................................................................. 18
10.2 Signal unit error rate monitor............................................................................................................ 19
10.3 Alignment error rate monitor............................................................................................................ 20
11 Level 2 codes and priorities ........................................................................................................................... 20
11.1 Link status signal unit....................................................................................................................... 20
11.2 Transmission priorities within level 2............................................................................................... 21
12 State transition diagrams, abbreviations and timers ....................................................................................... 22
12.2 Abbreviations................................................................................................................................... 22
12.3 Timers .............................................................................................................................................. 24
2012-4-20 16:40:47 下载次数: 0
T-REC-Q.703-199303-S!!PDF-E.pdf
(1.11 MB)
OscarDon
论坛副管
积分 61012
帖子 5541
威望 51627 个
礼品券 15891 个
专家指数 25389
注册 2008-6-30
专业方向 通信工程
来自 江苏
发表于 2012-04-21 21:24:14
在线,36天前提问
在线,49天前提问
在线,75天前提问
在线,116天前提问
在线,122天前提问
在线,122天前提问
在线,122天前提问
在线,124天前提问
在线,124天前提问
在线,134天前提问
在线,134天前提问
在线,155天前提问
在线,155天前提问
在线,175天前提问
在线,198天前提问
在线,210天前提问
这个是什么?没看明白
当我轻轻转身,细数身上的伤痕,每一道都是福分。
当前时区 GMT+8, 现在时间是 2024-05-16 07:03:44
Processed in 0.688438 second(s), 17 queries , Gzip enabled
