【资料名称】:GSM认证考试试题集(二)
【资料作者】:网络
【资料日期】:2010-12-2
中国通信人才网 发布时间: 2010-12-2 17:39:07 文章来源:网络
选择题
100. 【必考题】 The MS is paged on an incoming call in all cells within a C (1分)
A.PLMN B.MSC/VLR Service Area C.Location Area
101. 【必考题】 Where is paging initiated? C (1分)
A.BSC B.BTS C.MSC
102. 【必考题】 What part was added to the MTP in the SS7 signaling system to enable it to support connection-orientated and connection-less signaling? A (1分)
A.ISUP B.TCAP C.SCCP
103. 【必考题】 The interface between MSC and the BSC in know as B (1分)
A.A-interface B.A-bis-interface C.B-interface
104. 【必考题】 Which of the following effects the size of a cell? A (1分)
A.The type of BSC that the BTS is connected to B.Timing Advance C.Number of cells in a cluster
105. 【必考题】 Which of the following groups of cells would be most likely to be used in a city area? B (1分)
A.Umbrella, Micro and Pico B.Omnidirectional, Sector and Overlaid C.Underlaid, Overlaid and Omnidirectional
106. 【必考题】 Which logical channel transmits the BSIC of a cell? B (1分)
A.BCCH B.SCH C.RACH
107. 【必考题】 Where are measurement report, which determine handover of a call, carried out? A (1分)
A.BSC and MS B.MS and BTS C.MS and MSC
108. 【必考题】 The MS is close to the cell border defined by the Timing Advance. The BSC compares the current average value of TA to the defined value Timing Advance LIMit(TALIM). If TA exceeds the limit, what happens? A (1分)
A.An attempt is made to handover the call to a neighbouring cell B.An intracell handover takes place C.The TALIM is increased until a handover can be effected
109. 【必考题】 The maximum Timing Advance(TA) allowed in GSM is? B (1分)
A.63 bit periods B.128 bit periods C.2048 bit periods
110. 【必考题】 Which unit performs LAPD concentration and multiplexing? (1分)
A.GS B.TRAU C.SRS
111. 【必考题】 Intracell Handover involves? A (1分)
A.Change of timeslot only B.Change of frequency only C.Change of timeslot and/or change of frequency
112. 【必考题】 The normal cell maximum radius for GSM is? A (1分)
A.35km B.70km C.50km
113. 【必考题】 Which of the following types of signals would carry the information: “Location Updating Request”? B (1分)
A.Initial MS Message B.BSSMAP C.DTAP
114. 【必考题】 Which unit is used for the transcoding of speech information? A (1分)
A.TRAU B.TRH C.TRX
115. 【必考题】 The two different types of multiframes are? B (1分)
A.13-and 26-frame B.26-and 51-frame C.51-and 102-frame
116. 【必考题】 When a MS is powered on what happens? B (1分)
A.The MS scans the radio frequencies of the network B.The mobile scans the frequencies carrying the BCCH channels only C.The mobile scans the frequencies, carrying the BCCH channels, of the neighbouring cells only
117. 【必考题】 CALL CONFIRMED is a signal sent from the MS to the MSC for the purpose of? A (1分)
A.Responding to SETUP signal from the MSC B.Responding to the AUTHENTICATION REQUEST signal from MSC C.Responding to the PAGING COMMAND from the MSC
118. 【必考题】 Which of the following is used by the BTS and MS in providing security for the speech and data over the air interface? B (1分)
A.K1 B.Kc C.SRES
119. 【必考题】 The subsystem that id concerned with the PCM links is? B (1分)
A.RCS B.RTS C.TAS
120. 【必考题】 he following: Normal, IMSI Detach, IMSI Attach, Periodic Registration are all forms of A (1分)
A.Location Updating B.Authentication C.Paging
121. 【必考题】 Which of the following is false regarding Location Areas? C (1分)
A.One Location Area can belong to several BSCs B.One Location Area can belong to several MSCs C.One Location Area is always handle by only one MSC
122. 【必考题】 Why is TMSI used? B (1分)
A.As a temporary personal code to access the network B.For security reasons C.For use with a rented mobile telephone
123. 【必考题】 Which of the following channels operation in bit-stealing mode? C (1分)
A.SDCCH B.SACCH C.FACCH
124. 【必考题】 Timers are used for Periodic Location Updating. Where are these timers located? B (1分)
A.A) MS and MSC B.B) MS and BSC C.C) BSC and MSC
125. 【必考题】 The Cell Identity is unique to? C (1分)
A.The location Area B.The MSC/VLR Service Area C.The PLMN
126. 【必考题】 How many traffic channels can maximum be handled by a TRX? C (1分)
A.1 B.4 C.8
127. 【必考题】 How many TS are required on the Abis interface per TRX if LAPD C (1分)
A.2 B.2.25 C.3
128. 【必考题】 How many TSs and E1s are required to connect the following access network to a BSC when a DXC is used to get maximum utilization of the E1s? Access network with 30 sites of type 3/3/3 and 20 sites of type 2/2/2. LAPD-multiplexing and LAPD-concentration is used. C (1分)
A.870 TSs, 29 E1s B.848 TSs, 28 E1s C.780 TSs, 26 E1s
129. 【必考题】 How many physical connections are required in a network with 10 MSCs in a flat fully meshed network and in a hierarchical transit network with two transits? (1分)
A.100 (meshed), 10 (transit) B.45 (meshed), 20 (transit) C.100 (meshed), 20 (transit)
130. 【必考题】 A link set has three signaling links, on which load sharing is used and the maximum load per signaling link is 30%. What will be the maximum signaling volume that can be carried on this link set? (1分)
A.192 kbit/s B.57,6 kbit/s C.51,2 kbit/s
131. 【必考题】 What is the difference between message transfer on a) MTP and b) SCCP level in STP? (1分)
A.a) GTT is in STP, b) no GTT in STP B.a) no GTT in STP, b) GTT in STP C.no difference
132. 【必考题】 Which of the following is not a valid SDCCH configuration? A (1分)
A.SDCCH/4 combined with CCCH on timeslot one B.SDCCH/4 including CBCH combined with CCCH on timeslot zero C.SDCCH/8 non-combined on timeslot zero D.SDCCH/8 including CBCH non-combined on timeslot one E.SDCCH/8 non-combined on timeslot one
133. 【必考题】 What does this user formula calculate? E (1分)
A.TCH assignment success rate B.TCH availability C.TCH channel utilization D.TCH traffic level E.TCH mean holding time
134. 【必考题】 What is a probable cause of random access failure? A (1分)
A.MAXTA exceeded B.TALIM exceeded C.Congestion on the SDCCH D.All of these E.E) None of these
135. 【必考题】 AUC是用于 B (1分)
A.对用户的合法身份做鉴权。 B.产生鉴权和加密所必需的三参数组。 C.用于保存所有用户的数据。 D.用于保存所有移动设备的系列号。
136. 【必考题】 SCH用于向移动台发送 C (1分)信息。
A.频率校正信息 B.功率控制及时间提前量 C.TDMA帧号和BSIC D.系统信息
137. 【必考题】 移动台要发起呼叫时第一个使用到的逻辑信道是 D (1分)
A.FCCH B.BCCH C.SDCCH D.RACH
138. 【必考题】 下面哪种信道既有上行也有下行。 B (1分)
A.PCH B.SDCCH C.BCCH D.AGCH
139. 【必考题】 移动台在同一MSC下的切换由 C (1分)决定。
A.MS B.MSC C.BSC D.BTS
140. 【必考题】 位置区是指用于 C (1分)呼寻MS的区域,也是MS发生位置登记的区域。
A.VLR B.HLR C.MSC D.BSC
141. 【必考题】 在逻辑信道的分类中, D (1分)不属于广播信道(BCH)。
A.同步信道(SCH) B.频率校正信道(FCCH) C.广播控制信道(BCCH) D.寻呼信道(PCH)
142. 【必考题】 What is used to prevent ‘ping-ponging’ , that is, rapid, successive handovers? B (1分)
A.Discontinuous Transmission B.Hysteresis C.Dynamic Power Control D.Frequency Hopping E.Cell Load Sharing
143. 【必考题】 Where are measurement reports, which determine handover of a call,carried out? B (1分)
A.BSC and MS B.MS and BTS C.MS and MSC D.TEMS and MS E.OSS and MS
144. 【必考题】 How often is a complete measurement report transmitted from the MS to the BSC? C (1分)
A.Every 60 s B.Every 128 ms C.Every 480 ms D.Every 960 ms E.Every 480 ms or 960 ms
145. 【必考题】 Blocking supervision measurements take place every A (1分)
A.100 sec B.90 sec C.60 sec D.30 sec E.25 sec
146. 【必考题】 How many TRXs can the Ericsson BSC support? D (1分)
A.128 B.256 C.512 D.1020 E.1024
147. 【必考题】 Which of the following Bursts has the longest Guard Period? B (1分)
A.Synchronization Burst B.Access Burst C.Normal Burst D.Dummy Burst E.Frequency Correction Burst
148. 【必考题】 Which channel transmits the Location Area Identity? B (1分)
A.PCH B.BCCH C.RACH D.SCH E.FCCH
149. 【必考题】 Which of the following is false regarding Location Areas? B (1分)
A.One Location Area can belong to several BSCs B.One Location Area can belong to several MSCs C.One Location Area is always handled by only one MSC D.Several Location Area can be handled by one BSC E.Several Location Area can be handled by one MSC
150. 【必考题】 is it possible to change the BCCH frequency without halting the Cell n Ericsson R8? C (1分)
A.No, only possible for the TCH B.Yes, but a BTS technician must be on site to assist with the OMT. C.Yes D.Yes, but the condition is that there are no traffic in the cell. E.Yes, but the condition is that there are no half-rate traffic in the cell
151. 【必考题】 如果一个网络运营商分别有15 MHz的上、下行频宽,那么他可以获得多少个GSM频点 (减去一个保护频点)? D (1分)
A.600 B.599 C.75 D.74
152. 【必考题】 由于阻挡物而产生的类似阴影效果的无线信号衰落称为: C (1分)
A.多径衰落 B.快衰落 C.慢衰落 D.路径衰落
153. 【必考题】 1毫瓦与1瓦约相差多少? B (1分)
A.20 dB B.30 dB C.1000 dB D.100 dB
154. 【必考题】 以下哪个现象不存在模拟网,而只存在于数字无线网中? D (1分)
A.瑞利衰落 B.拥塞 C.快衰落 D.码间干扰
155. 【必考题】 什么是system balance? D (1分)
A.每个小区可以承载相同数目的用户 B.网络可以支持不同class的移动台 C.所有的BTS的发射功率都是同样大小的 D.MS与BTS都在满足其接收灵敏度的条件下工作
156. 【必考题】 无线信号在自由空间的衰落情况是:传播距离每增大一倍,信号强度减小 C (1分)
A.2dB B.3dB C.6dB D.9dB
157. 【必考题】 1W= C (1分)dBm
A.10 B.20 C.30 D.33
158. 【必考题】 GSM系统中时间提前量(TA)的一个单位对应空间传播的距离接近 C (1分)米
A.450 B.500 C.550 D.600
159. 【必考题】 对于GSM系统,手机在通话状态中每 B (1分)s向网络提供一次测量报告,其中包含了 B (1分)个TCH复帧
A.480、21 B.480、4 C.3.69、21 D.3.69、4
160. 【必考题】 下面对跳频的描述, B (1分)是正确的
A.跳频方式与硬件无关 B.基带跳频中除BCCH载波外,其它载波的TS0都参与跳频. C.随机跳频方式中的频点变化无规律性. D.CDU-D可以支持混合跳频方式
161. 【必考题】 下列哪种系统信息不用于IDLE MODE C (1分)
A.类型1 B.类型3 C.类型5 D.类型2
162. 【必考题】 小区内切发生中 A (1分)情况下;
A.强信号质差 B.弱信号质差 C.AW=ON时 D.小区拥塞时
163. 【必考题】 基带跳频与混合跳频的区别是 B (1分)
A.配置频点与载波设备的数量关系不同 B.CDU型号要求不同 C.克服多径衰落的方式不同 D.空中寻址方式不同
164. 【必考题】 下列哪个数据不必向MS广播 (1分)
A.RLINKT B.RLINKUP C.T3212 D.BTDM
165. 【必考题】 当频点数大于载波数时, A (1分)
A.基带跳频可以执行, 混合跳频可以执行. B.基带跳频不可以执行, 混合跳频可以执行. C.基带跳频可以执行, 混合跳频不可以执行 D.基带跳频不可以执行, 混合跳频不可以执行.
166. 【必考题】 修改基站载波功率时,相关的数据有哪些 A (1分)
A.BSPWRB BSPWRT BSPWR BSTXPWR B.BSPWRB BSPWRT C.BSPWR BSTXPWR D.BSPWRB BSPWRT BSPWR BSTXPWR MPWR
167. 【必考题】 在空闲模式下,MS通过什么算法进行小区选择. C (1分)
A.K算法 B.L算法 C.C1算法 D.LOCATION算法
168. 【必考题】 在通话过程中,当MS发生越区切换时, B (1分)
A.切换后立即发生位置更新 B.通话结束后才进行位置更新 C.MSC/VLR先进行更新,通话结束后MS才更新SIM中的位置区信息 D.不必进行位置更新
169. 【必考题】 已知a,b两点的绝对电平为Pa=–5dB, Pb=5dB.则两点的相对电平Pba为 A (1分)
A.10 dB B.–10db C.0Db D.5dB
170. 【必考题】 采用分集接收主要是为了解决:. C (1分)
A.一副天线接收信号太弱的问题 B.提高天线接收灵敏度 C.克服多径衰落 D.以上三项都错
171. 【必考题】 采用分集接收技术,对 A (1分)有较大的改善。
A.上行链路信号 B.下行链路信号 C.上行与下行链路信号 D.以上都不正确
172. 【必考题】 What is the name of the type of fading which is due to shadowing? D (1分)
A.Multipath B.Atmospheric fading C.Rayleigh fading D.Log-normal fading E.Path loss
173. 【必考题】 Which logical channel must be dimensioned for each cell when considering the frequency of call setups? C (1分)
A.SACCH B.FCCH C.SDCCH D.SCH E.BCCH
174. 【必考题】 What is the difference between 1 milliwatt and 1 watt? B (1分)
A.20 dB B.30 dB C.100 dB D.10 dB E.40 dB
175. 【必考题】 A subscriber makes a two minute call and a four minute call during the busy hour. How much traffic does he generate for that hour? C (1分)
A.10 millierlangs B.50 millierlangs C.100 millierlangs D.200 millierlangs E.0.4 erlangs
176. 【必考题】 What is the advantage of using DTX for an MS? A (1分)
A.Increases battery life B.Better Bit Error Rate (BER) C.Higher received signal strength D.Increased bit rate E.Better voice quality
177. 【必考题】 What does locating mean? B (1分)
A.Paging of a mobile in more than one cell B.Best cell selection C.Changing of cell parameters D.Roaming E.Tuning
178. 【必考题】 以下关于位置区(LA)和BSC/MSC的说法哪个正确? A (1分)
A.一个LA可由属于不同BSC的小区(CELL)构成 B.一个LA可由属于不同MSC的小区(CELL)构成 C.一个LA只能由属于同一BSC的小区(CELL)构成
179. 【必考题】 GSM系统使用的多址方式为? C (1分)
A.FDMA B.TDMA C.FDMA+TDMA
180. 【必考题】 GSM系统中时间提前量(TA)的一个单位对应空间传播的距离大约为 C (1分)米? A.450 B.500 C.550
181. 【必考题】 以下哪种与时间相关的信息用于无线空间的信号加密? B (1分)
A.呼叫时长 B.TDMAframenumber C.呼叫起始时刻
182. 【必考题】 BSC的哪个单元负责处理定位测量数据 A (1分) A.TRH B.TRAU C.CP
183. 【必考题】 GSM小区(CELL)的发射半径控制在35公里内的主要由哪种因素决定 A (1分)
A.时隙定位的问题 B.频率复用方式 C.输出功率不允许超过40W
184. 【必考题】 每个基站中都装配两个接收天线的原因是 C (1分)
A.增强发射信号强度 B.互为备份 C.增强接收信号强度
185. 【必考题】 以下哪个逻辑信道移动用户用于联接系统? C (1分)
A.寻呼信道(PCH) B.广播信道(BCCH) C.随机接入信道(RACH) D.TS2
186. 【必考题】 测量结果通过哪种逻辑信道传回基站? B (1分)
A.SDCCH B.SACCH C.TCH
187. 【必考题】 RAND,Kc和SRES的组合的英文名称为 B (1分)
A.Mobile number group B.Triplet C.Triplegroup
188. 【必考题】 以下哪种功能在BSC中完成? B (1分)
A.测量无线连接的信号强度 B.分配无线信道 C.本地交换
189. 【必考题】 临时移动用户识别号(TMSI)的作用是: B (1分)
A.识别出租的手机 B.减少移动用户的身份在无线空间的暴露次数 C.作为用户使用新设备的临时身份号
190. 【必考题】 当移动用户移动到同一LA中另一CELL时,是否总要将此变化通知GSM网络系统? B (1分)
A.总要 B.只有当移动用户正在呼叫时才要 C.不需要
191. 【必考题】 在CME20系统中,克服时间色散的措施是 B (1分)。
A.采用跳频技术 B.采用接收机均衡器 C.采用交织技术 D.采用GMSK调制技术
192. 【必考题】 以下关于位置区的描述, C (1分)项是错误的?
A.位置区是寻呼MS的区域。 B.把业务繁忙的区域尽量划在一个位置区。 C.一个位置区可以属于两个以上的MSC/VLR服务区。 D.MS从一个位置区到另一个位置区立即要做位置更新。
193. 【必考题】 在逻辑信道的分类中, D (1分)不属于广播信道(BCH)。
194. 【必考题】 移动台落地的短信息是通过什么信道来传送的? A (1分)
A.MS空闲时通过SDCCH来传送,而MS忙时通过SACCH来传送。 B.MS空闲时通过SACCH来传送,而MS忙时通过SDCCH来传送。 C.都通过SDCCH来传送。 D.都通过SACCH来传送。
195. 【必考题】 通过BCCH载波的TS0来传送的下行逻辑信道有 B (1分)。
A.FCCH、SCH、BCCH、RACH、PCH。 B.FCCH、SCH、BCCH、AGCH、PCH。 C.BCCH、SDCCH、SACCH、AGCH、PCH。 D.BCCH、SDCCH、FACCH、AGCH、PCH。
196. 【必考题】 为了实现周期位置更新功能,定时器设在哪些网络实体里? C (1分)
A.MSC、BSC和MS。 B.MSC和BSC。 C.MSC和MS。BSC和MS。
197. 【必考题】 RACH的突发脉冲串中加上一个68.25比特的保护空间,其意义是 B (1分):
A.做为一个串的识别 B.因第一次接入,MS不知道TA值,所以加大保护空间。 C.填充比特,使每串的数码为156.25比特 D.没有特别意义
198. 【必考题】 在MSC与BSC之间的接口为: C (1分)
A.A-bits接口 B.Gb接口 C.A接口 D.Um接口
199. 【必考题】 移动台在通话状态时HLR和MSC分别知道移动台在哪个区域? D (1分)
A.HLR知道MS在哪个MSC服务区,而MSC知道MS在哪个位置区域(LAI)。 B.HLR知道MS在哪个MSC服务区,而MSC知道MS在哪个BSC服务区。 C.HLR知道MS在哪个BSC服务区,而MSC知道MS在哪个位置区域(LA)。 D.HLR知道MS在哪个MSC服务区,而MSC知道MS在哪个小区(CGI)。
200. 【必考题】 无线参数T3212的作用是: B (1分)
A.通知移动台多长时间作一次切换。 B.通知移动台多长时间作一次周期性登记。 C.限定移动台在建立呼叫后多长时间内不能进行切换。 D.限定移动台在发生切换后多长时间内不能再次进行切换。
