通信设备厂商技术区
诺基亚技术资料区
» NSN切换参数问题
[求助]
NSN切换参数问题
lwq6867082
积分 283
帖子 57
威望 2788 个
注册 2010-10-26
专业方向 GSM/TD
发表于 2012-02-11 14:34:25
请问以下NSN切换参数,这样设置表示说明意思。有没有相关的参数说明资料。
ENABLE INTRA HO INTERF UL ...... N ENABLE INTRA HO INTERF DL ...... N
ENABLE PWRBUDGET HANDOVER ...... Y ENABLE MS DISTANCE PROCESS ..... N
ENABLE SDCCH HANDOVER .......... N ENABLE UMBRELLA HANDOVER ....... Y
ENABLE FAST AVE CALL SETUP ..... N ENABLE FAST AVE PC ............. Y
ENABLE FAST AVE HO ............. Y
MIN INT BETWEEN HO REQ ............. 05 sHO PERIOD UMBRELLA ....... 06
MIN INT BETWEEN UNSUCC HO ATTEMPT .. 04 sHO PERIOD PBGT ........... 06
GSM PLMN PRIORISATION .............. 0
AMH TRAFFIC CONTROL MCN ........ N AMH TRAFFIC CONTROL IUO ........ N
AMH TRHO PBGT MARGIN ...........2
AVERAGING WINDOW SIZE ADJ CELL ..... 06NUMBER OF ZERO RESULTS ... 2
ALL ADJACENT CELLS AVERAGED ........ N
THRESHOLD FOR MULTI-RAT MS ..................... never
MIN TRAFFIC LOAD FOR SPEECH CALL ............... 80 %
NUMBER OF MEASURED FDD CELLS ................... 02
MIN INTERVAL BETWEEN UNSUCC ISHO ATTEMP ........ 03 s
ADJACENT WCDMA RAN CELL AVERAGING WINDOW SIZE .. 06
NUMBER OF WCDMA RAN ZERO RESULTS ............... 05
ALL ADJACENT WCDMA RAN CELLS AVERAGED .......... N
INTER-SYSTEM DIRECT ACCESS ENABLED ............. N
TRIGGERING RATIO FOR WCDMA RAN CELL PENALTY .... 50 %
WCDMA RAN CELL PENALTY TIME .................... 127 s
HO AVERAGING LEVDLWINDOW SIZE ............ 04 WEIGHTING .... 1
HO AVERAGING LEVULWINDOW SIZE ............ 04 WEIGHTING .... 1
HO AVERAGING QUAL DLWINDOW SIZE ............ 01 WEIGHTING .... 1
HO AVERAGING QUAL ULWINDOW SIZE ............ 01 WEIGHTING .... 1
MS SPEED AVERAGING ............. 04
HO THRESHOLDS QUAL DLRX QUAL ...... 1.6% -3.2%PX .. 03NX .. 04
HO THRESHOLDS QUAL ULRX QUAL ...... 1.6% -3.2%PX .. 03NX .. 04
HO THRESHOLDS LEVDLRX LEVEL ............-110 dBm PX .. 05NX .. 06
HO THRESHOLDS LEVULRX LEVEL ............-110 dBm PX .. 05NX .. 06
HO THRESHOLDS LEVUL FOR RAPID FIELD DROP .-110 dBm PX .. 00 (DISABLED)
ENABLE ENHANCED RAPID FIELD DROP ...........DIS(DISABLED)
THRESHOLD DEEP DROPPING EDGE ............... 10 dBPX .. 02NX .. 03
DEEP DROPPING EDGE MONITORING WINDOW .......2
MODIFIED AVERAGING WINDOW ..................2
MODIFIED NUMBER OF ZERO RESULTS ............1
ENHANCED RAPID FIELD DROP DURATION ......... 10s
NON BCCH LAYER ACCESS THRESHOLD ............-090 dBm
NON BCCH LAYER EXIT THRESHOLD ..............-095 dBm PX .. 01NX .. 01
HO THRESHOLDS INTERFERENCE DL RX LEVEL .....-075 dBm PX .. 02NX .. 03
HO THRESHOLDS INTERFERENCE UL RX LEVEL .....-085 dBm PX .. 02NX .. 03
MS DISTANCE AVERAGING PARAMWINDOW SIZE ..... 10
MS DISTANCE HO THRESHOLD PARAMMS RANGE MAX .... 63PX .. 01NX .. 01
USED C/I ESTIMATION METHOD ...... NONE (ESTIMATION METHODS NOT IN USE)
LOWER C/I LIMIT 1 ...30 dBPRIORITY ADJ. STEP FOR BAND 1 ... 3
LOWER C/I LIMIT 2 ...25 dBPRIORITY ADJ. STEP FOR BAND 2 ... 1
LOWER C/I LIMIT 3 ...20 dBPRIORITY ADJ. STEP FOR BAND 3 ... 0
LOWER C/I LIMIT 4 ...17 dBPRIORITY ADJ. STEP FOR BAND 4 ... -1
LOWER C/I LIMIT 5 ...13 dBPRIORITY ADJ. STEP FOR BAND 5 ... -2
LOWER C/I LIMIT 6 ... 9 dBPRIORITY ADJ. STEP FOR BAND 6 ... -5
PRIORITY ADJ. STEP FOR BAND 7 ... -8
SUPER REUSE ESTIMATION METHOD .............MAX(MAXIMUM TAKING METHOD)
ENABLE INTER FRT HANDOVER .................DIS(DISABLED)
INTERFERING CELL AVERAGING WINDOW SIZE ....8
INTERFERING CELL NUMBER OF ZERO RESULTS ...7
ALL INTERFERING CELLS AVERAGED ............Y
SUPER REUSE GOOD C/I THRESHOLD ............ 27 dB PX .. 08NX .. 10
SUPER REUSE BADC/I THRESHOLD ............ 20 dB PX .. 08NX .. 10
MINIMUM BSIC DECODE TIME .................. 10
ENABLE TCH ASS SUPER IUO ..................0
MINIMUM INTERVAL BETWEEN UNSUCC IUO HO .... 20s
MINIMUM INTERVAL BETWEEN IUO HO REQ BQ .... 10s
SUPER REUSE GOOD THRESHOLD RX LEVEL .......-065 dBm PX .. 08NX .. 10
SUPER REUSE BAD THRESHOLD RX LEVEL ........-070 dBm PX .. 02NX .. 06
LOWER SPEED LIMIT .........................0( 0 km/h )
UPPER SPEED LIMIT .........................0( 0 km/h )
MS SPEED THRESHOLD PX .........3MS SPEED THRESHOLD NX .........6
MS SPEED DETECTION STATE ..................0
COMMAND EXECUTED
顺丰1分钱寄快递,还免费送钱了
2015-04-23
LTE路测跨LAC时CSFB出现未接通的问题
2014-08-22
GSM无线网络结构优化
2012-06-01
手机注册网络流程
2011-10-13
层3信令在路测中的应用
2011-10-13
SEG、BCF、BTS、CELL ID分别指什么
2011-02-24
yangjianxuan
积分 28596
帖子 3110
威望 28214 个
礼品券 40 个
注册 2006-7-1
专业方向 无线网优
发表于 2012-02-11 15:37:09
在线,14天前提问
在线,28天前提问
在线,53天前提问
在线,94天前提问
在线,100天前提问
在线,100天前提问
在线,100天前提问
在线,102天前提问
在线,102天前提问
在线,112天前提问
在线,113天前提问
在线,134天前提问
在线,134天前提问
在线,153天前提问
在线,177天前提问
在线,188天前提问
开了伞状切换,PBGT切换就基本上失效了!
wygzql
积分 61
威望 964 个
注册 2011-11-28
专业方向 通信
发表于 2012-02-13 13:39:17
一个一个来说吧:
ENABLE INTRA HO INTERF UL ...... Y…………………………………………………………EIC
启用由于上行干扰引起的小区内切换。手机在连接模式下,基站需不断测量手机的上行电平和上行通话质量。一般情况下,上行接收质量与上行接收电平成正比,但当上行信道有外部干扰时会出现上行接收电平很高而接收质量却很差的情况,这种情况同样会导致系统启动切换过程。因上行干扰引起切换时,系统可以有二种选择,一种是启动小区内部切换;另一种则启动小区间切换。EIC可用YES:启用和NO:不启用。YES表示由于上行干扰引起切换时可以采用小区内切换过程;NO则表示由于上行干扰引起切换时不允许采用小区内切换过程。由于上行干扰引起切换时,移动站接收的上行信号电平还较高,它说明移动站实际的物理位置接近当前的服务小区,因此适宜于小区内部切换。一般建议由于上行干扰引起切换时,采用小区内切换过程,即设置EIC为YES。这样设置的缺点在于:若小区内的某个上行频点存在外部干扰时,小区内切换后可能依然存在上行干扰,从而导致连续切换,甚至可能出现连接失败。因此若某个小区中经常性存在某个频率点上的上行干扰时,建议设置EIC为NO。我们系统设为Y。)
共获得 1 次点评
道家书生
威望 +10 个
· 加分,很专业的讨论
发表与:2012-2-16 00:22:58
wygzql
积分 61
威望 964 个
注册 2011-11-28
专业方向 通信
发表于 2012-02-13 13:45:47
ENABLE INTRA HO INTERF DL ...... Y……………………………………………………………EIH
启用由于下行干扰引起的小区内切换
ENABLE PWRBUDGET HANDOVER ...... Y……………………………………………………….EPB
启用功率预算切换
ENABLE MS DISTANCE PROCESS ..... N……………………………………………………………EMS
是否允许距离原因切换
ENABLE SDCCH HANDOVER .......... N ……………………………………………………ESD
是否允许SDCCH切换,但是现网SDCCH切换失败率较高,所以不建议开启
ENABLE UMBRELLA HANDOVER ....... N……………………………………………………………EUM
伞切开关,NSN最常用的一种均衡话务的手段
ENABLE FAST AVE CALL SETUP ..... N………………………………………………………EFA
在呼叫建立阶段(SDCCH)是否允许进行快速切换测量平均计算,一般用于微蜂窝,因为切换半径小,宏站覆盖半径较大,可选择机会多,所以一般不启用这个切换算法
有事了,明天继续
共获得 1 次点评
道家书生
专家指数 +1 , 威望 +30 个
· 加分,很专业的讨论
发表与:2012-2-16 00:23:21
lwq6867082
积分 283
帖子 57
威望 2788 个
注册 2010-10-26
专业方向 GSM/TD
发表于 2012-02-15 14:21:47
谢谢,继续指教啊。
[求助] NSN切换参数问题" tabindex="1">
当前时区 GMT+8, 现在时间是 2024-04-24 12:59:30
Processed in 0.364600 second(s), 24 queries , Gzip enabled
