网站又没法搜帖子了,怎么回事?404,出现好几天了 在线,20天前提问
怎么下载文件一直失败? 在线,33天前提问
为什么登不进去 在线,59天前提问
服务器又出问题了 在线,100天前提问
签到出现问题几天了 在线,106天前提问
为什么不能签到? 在线,108天前提问
签到又有问题了吗 在线,108天前提问
从哪里下载这个监控软件? 在线,118天前提问
能同时发本5g的书么? 在线,118天前提问
Keysight World: Innovate全球创新云峰会直播链接是. 在线,139天前提问
请问直播链接是? 在线,139天前提问
请问24号的keysight的会议地址在哪里呀 在线,159天前提问
ims失败原因值 在线,182天前提问
UE RRC Inactive处于以下哪些管理状态 在线,194天前提问
Assignment attempts (TASSATT):
The assignment attempt counter (TASSATT) is stepped in the target cell for the first assignment attempt (both successful and unsuccessful attempts) to change a connection from a signalling only connection to a TCH for speech or data. An assignment is initiated by reception of ASSIGNMENT REQUEST or HANDOVER REQUEST with cause = Directed Retry.
For assignments in the serving cell, TASSATT is stepped in the serving cell when the message ASSIGNMENT COMMAND is sent to the MS.
For intra BSC inter cell assignments, TASSATT is stepped in the target cell when the message HANDOVER COMMAND is sent to the MS.
For inter BSC assignments, TASSATT is stepped in the target cell in the target BSC when the message HANDOVER COMMAND (included in a HANDOVER REQUEST ACKNOWLEDGE) is sent by the target BSC to the MSC.
For change of channel mode, TASSATT is stepped in serving cell when assignment implies a change from signalling only to speech or data on a TCH. The counter is stepped when the message CHANNEL MODE MODIFY is sent to the MS.
Message :ASSIGNMENT COMMAND (to MS)
HANDOVER COMMAND (from target BSC to MS)
CHANNEL MODE MODIFY (to MS)
Counter :(TASSATT)
Assignment attempts (TASSALL):
The 'Assignment attempt' counter (TASSALL) is incremented for the first attempt to change a connection from a signalling only connection to a TCH for speech or data, initiated by reception of ASSIGNMENT REQUEST or HANDOVER REQUEST (cause = directed retry).
At successful assignment attempt the counter is incremented for the target cell.
If the assignment attempt is unsuccessful, independent of reason, the counter is incremented for the cell where the mobile station was tuned to an SDCCH or TCH used for signalling.
Message :ASSIGNMENT REQUEST
Counter :(TASSALL)
